trying to get this to work High beam assist on by default I need sec access code 09 cent electric
enabling high beam assist to stay on permanently (doesn't turn off when you turn the ignition off). Moving the light switch to any position other than AUTO will turn high beam assist off though.
security code for my tt 09 cent electrics please
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptations
• (5)-Assistenzlichtfunktionen-Fernlichtassistent Assistant lighting functions - Beam Assistant Reset
• Wert anpassen: "nicht aktiv" [Standard = "aktiv", d.h. Fernlichtassistent bei "Zündung aus" deaktiviert]
Adjust Value " not active " [ Default = " active " , that is, off -beam assistant at " ignition "
Rain Closing
1.Go into [09] Central Electronics
2.Go into Security Access and enter 31347 does not work need correct code
10 - Adaptations
Rain Closing
Monday,20,June,2016,17:59:34:06095
VCDS Version: 16.6.0.2 (x64)
Data version: 20160602 DS251
Dealer/Shop Name: ls26
VIN: TRUZZZ8J0B1007029 License Plate: A123 XXX
Mileage: 29610km-18398mi Repair Order: 1A
Chassis Type: 8J (8P0)
Scan: 01 03 08 09 10 15 16 17 19 20 22 25 26 2E 37 42 44 46 47 4C
52 55 56 61 77
VIN: TRUZZZ8J0B1007029 Mileage: 29610km-18398miles
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 DT HW: 03L 906 018 DT
Component: R4 2,0L EDC H22 7766
Revision: 42H22--- Serial number: AUX7Z0J6FNQ00E
Coding: 00190012042700080000
Shop #: WSC 01236 785 00200
ASAM Dataset: EV_ECM20TDI01103L906018DT 003004
ROD: EV_ECM20TDI01103L906018DT.rod
VCID: 7F088455E6EAB3BBA0-802A
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [109] - Electrical Fault
Mileage: 29318 km
Date: 2016.05.28
Time: 11:21:08
Coolant temperature: 14 °C
Intake air temperature: 16 °C
Voltage terminal 30: 11.780 V
Electric auxiliary heater; shut-off conditions-Bit 0: 00000000
Electric auxiliary heater; shut-off conditions-Bit 8: 00000010
Electric auxiliary heater; relay activation-Bit 0: 00000000
Preheat time: 1300 ms
Glow status-Bit 0: 00000000
Glow status-Bit 8: 00000000
Time since ignition off: 69278 s
Outside air temperature: 15.5 °C
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 B HW: 8J0 614 517 B
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0083827
VCID: 2C5283198F1CF82355-8078
Part No SW: 8J0 820 043 BA HW: 8J0 820 043 BA
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001160703
Coding: 1049876
VCID: 66C631315170027343-8032
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 H HW: 8P0 907 063 H
Component: BCM PQ35 H 106 0615
Revision: 00106 AD
Coding: 46000B2FE005F1202070E8E80180894C567E59FA3020D128DC004E440045
Shop #: WSC 01236 758 00200
VCID: 397CAA4DB04E5D8BDE-806C
Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00FD10
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02492C
Subsystem 3 - Part No: 8J0 951 177
Component: DWA-Sensor H0 H03 0030
01800 - Light Switch (E1)
Fault Frequency: 6
Reset counter: 171
Mileage: 29318 km
Date: 2016.05.28
Time: 14:37:45
Term 15 On
Voltage: 11.75 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93641019102174
Coding: 00000B
VCID: 428ECDA1DD981E538F-8016
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K004MCJ0
Coding: 0011636
VCID: 79FC6A4D30CE9D8B9E-802C
Subsystem 1 - Serial number: 6332DRB40C404B9E.
Subsystem 2 - Serial number: 6342DRB40C404A1FU
Subsystem 3 - Serial number: 63747RB405BE48CB5
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0003041
VCID: 4686D1B131B02273A3-8012
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 R HW: 8J0 920 980 R
Component: KOMBIINSTR. VDO H01 0590
Revision: D0H01003 Serial number: 2246J003000719
Coding: 0277428
Shop #: WSC 60809 001 1048576
VCID: 408AC7A913940C4399-8014
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H33 5304
Revision: H33 Serial number: 260810F2001488
Coding: E9B31F2650065204005101
VCID: 316C926DA83E95CB66-8064
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8J0 857 511 G HW: 8J0 857 511 G
Component: FLA H03 0004
Revision: AA002001
Coding: 02028A64747464545425363E
VCID: 34629B79972CA0E30D-8060
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 4482CBB9078C1063BD-8010
Revision: D0H01003 Serial number: AUX7Z0J6FNQ00E
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 D
Component: 256 VSG TT H17 0150
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74E25B79D7ACE0E3CD-8020
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
Component: RNS-E PU EU H05 0220
Revision: 0000011S Serial number: AUZBZ7KD402034
Coding: 0619725
Shop #: WSC 00720 210 91789
VCID: 2B5080058A12FF1B5C-807E
02261 - Data Medium
Fault Status: 00101110
Reset counter: 199
Mileage: 29535 km
Date: 2016.06.13
Time: 15:53:05
Mileage: 29530 km
Count: 1406
Clock: 06:36
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8J7 959 801 M HW: 8J7 959 801 M
Component: Tuer-SG H04 0101
Coding: 0004661
Part No: 8J0 909 144 J
Component: EPS_ZFLS Kl. 236 3001
Revision: 00H17000
VCID: 3778AC75465A4BFB28-8062
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000019514
Coding: 0146333
VCID: 2544763DECF6C96B8A-8070
16349 - Control Module - Error in Output Stage
Reset counter: 218
Mileage: 19582 km
Date: 2014.01.16
Time: 05:52:32
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 C HW: 4F0 907 274
Component: J793 RKA+ H03 0190
Revision: 00000275 Serial number: 00002750002188
Coding: 0604100
VCID: 326E9D61AD38AED31F-8066
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8J7 959 802 M HW: 8J7 959 802 M
Coding: 0004660
VCID: 4798DCB536BA3B7B58-8012
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Coding: 0000010
VCID: 3C72B3597F7C68A3C5-8068
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619725
02261 - Data Medium
Reset counter: 199
Mileage: 29535 km
Date: 2016.06.13
Time: 15:53:05
Mileage: 29530 km
Count: 1406
Clock: 06:36
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H33 5304
Coding: 030201FE
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005222899
Coding: 0011402
VCID: 74E25B7917ACE0E3CD-8020
End-------------------------(Elapsed Time: 02:29)--------------------------
