Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: 2004 Audi A8 02 Sensors
    Mar 2015
    Rhode Island
    Hey everyone! my car has been driving a little different and not as much power so I decided to run VCDS and noticed I had 2 faults 16804 & 16814. The first thing I did was cleared the DTC's and as soon as I did the car drove nice again. After awhile it started doing it again so I ran a scan again and got the same DTC's. I decided the first thing I was going to do was check the wiring from the 02 Sensors but GOD they are difficult to get to. I put my car on ramps and tried to get to them from the bottom without any luck.. So with all this said I have a few questions that I'm hoping people could help me with.....
    1. Why isn't my Check engine light going on? (maybe didn't run it long enough to trigger it?)
    2. Is it weird that both banks are showing a DTC at the same time?
    3. Could this be a cat problem or just an 02 Sensor
    4. is there away to run a test on the 02 Sensors & Cats in VCDS?
    5. WHATS THE EASIEST WAY TO GET TO BOTH BANKS?? MY TO ADD SOME DIELECTRIC GREASE AND CLEANING... OR TO REPLACE IF NEEDED.
    I will say I looked in the measuring blocks and notice both cats read about 455 at idle not by RPM's up to 2,000.. is this an issue?
    if you have anymore questions that need answered to help please feel free and ask, thanks for anyone help. I have provided a full AutoScan for your reading pleasures below.
    Friday,03,June,2016,12:07:40:14758
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WAUML44E74N017518   License Plate:
    Mileage: 100450km-62416mi   Repair Order:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0F 15 16 17 19 25 28 34 36 38 42 46
              47 4F 52 53 55 56 61 62 72 76
    VIN: WAUML44E74N017518   Mileage: 100450km-62416miles
    Address 01: Engine        Labels: 077-910-560-BFM.lbl
       Part No SW: 4E0 910 560 A    HW: 4E0 907 560
       Component: 4.2L V8/5V      G   0070
       Revision: 00000000    Serial number: AUX3Z0CD531019
       Coding: 0007773
       Shop #: WSC 02313 785 00200
       VCID: 1F4DDD45CE847AC667-804A
    16804 - Catalyst System; Bank 1
                P0420 - 002 - Efficiency Below Threshold - Intermittent
    16814 - Catalyst System; Bank 2
                P0430 - 002 - Efficiency Below Threshold - MIL ON
       Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
       Component: AG6 09E 4,2L5V USA  0110
       Revision: 00000001    Serial number:        0027237
       VCID: 2447D2A9E7E2591E3A-8070
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
       Component: ESP 5.7 allrad  H46 0510
       Coding: 0007597
       Shop #: WSC 23435 000 00000
       VCID: 224BD4B1FDF6572E48-8076
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 A
       Component:     FBS AUDID3  H03 0140
       Revision: 01403903    Serial number: AUX3Z0CD531019
       Coding: 0263168
       Shop #: WSC 02311 785 00200
       VCID: 58BFB659EB2ACDFE66-800C
       Subsystem 1 - Part No: 4E0 905 852 C
       Component: ELV                 1734
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H07  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3940960
       Shop #: WSC 23435 444 82899
       VCID: 2345D1B5E2EC5E2643-8076
    Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
       Part No SW: 4E0 910 732 S    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 346IP047514325
       Coding: 0000103
       VCID: 326B24F1AD16C7AEB8-8066
       Subsystem 1 - Part No: 4E0 910 611
       Component: E0380 BedienteilH01 0050
       Subsystem 2 - Serial number: 00000000097794
       Subsystem 3 - Serial number: 0113.11.130000000100010015˙
       Subsystem 4 - Serial number: 010015˙
       Part No SW: 4E0 910 043     HW: 4E0 820 043 B
       Component: KLIMAAUTOMAT    016 0240
       Revision: 00000022    Serial number: 00000000033347
       Coding: 1151313
       VCID: 5ABBAC519526DFEE50-800E
       Subsystem 1 - Part No: 4E0 910 772 A
       Component: Sitzluefter  FS H02  010
       Subsystem 2 - Part No: 4E0 910 772 A
       Component: Sitzluefter BFS H02  010
       Subsystem 3 - Serial number: 898053000
       Subsystem 4 - Serial number: HO15122003065A000000000168˙†89
       Subsystem 5 - Serial number: 000168˙†898053000      000-SHO
       Subsystem 6 - Serial number:     000-SHO18122003065A00000000
       Subsystem 7 - Serial number: 65A000000000072˙
    00066 - Rear Right Footwell Heater (Z43)
                        Reset counter: 150
                        Mileage: 100452 km
                        Date: 2016.06.03
                        Time: 11:45:04
                        Voltage: 12.70 V
    Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
       Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
       Component: ILM Fahrer      H11 0100
       Coding: 0111113
       VCID: 2A5B3C9185C68F6E00-807E
       Subsystem 1 - Part No: 4E1 910 113
       Component: Wischer WWS D3  H30 0320
       Coding: 00000030
       Shop #: WSC 02313
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 D    HW: 4E0 035 593
       Component: SDAR SIRIUS     H04 0670
       Revision: 00000000    Serial number: AUZ4Z7E2009013
       VCID: 285FC6999BCABD7E16-807C
    Address 15: Airbags        Labels: 4E0-910-655-84.lbl
       Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
       Component: Airbag 8.4E+    H10 0920
       Coding: 0530707
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549 A
       Coding: 0012241
       VCID: 65C18FADAC586016ED-8030
       Component: Lenkradmodul    H04 0080
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 900     HW: 4E0 920 950 B
       Component: KOMBIINSTR. VDO H44 0090
       Revision: D15         Serial number: AUDID3CD006664
       Coding: 0000202
       Shop #: WSC 65537 000 00032
       VCID: 5CB7AA499F1221DE42-8008
    Address 19: CAN Gateway        Labels: 4E0-910-468.clb
       Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
       Component: Gateway         H07 0030
       Revision: 07          Serial number: 0200503C0111AE
       Coding: FCFE7FDC0B0904
       Shop #: WSC 07228 444 53694
       VCID: 2643C8A191DEAB0E24-8072
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0263168
       Component: ELV                 1734
       4E0905852C  ELV                 1734
       Part No SW: 4E0 910 158     HW: 4E0 919 158 A
       Component: KLIMA-STG. FOND 015 0220
       Revision: 00000018    Serial number: 00000000027901
       Coding: 0000000
       VCID: 61C99BBDB8700C3611-8034
    Address 34: Level Control        Labels: 4E0-910-553.lbl
       Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
       Component: LUFTFDR.-CDC    H05 4290
       Coding: 0015510
       Shop #: WSC 22145 444 54027
       VCID: 2541CFADECD8A0162D-8070
       Component: Sitzmemory FS  H07  0060
       Coding: 4071522
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135
       Component: Dachknoten D3   H01 0090
       Serial number: 00000331600277
       Coding: 0003989
       VCID: 1D31E74DC48868D675-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 801
       Component: Türsteuer.FS BRM007 0110
       Coding: 0028196
       VCID: 5EB3A041890E33CE2C-800A
    Address 46: Central Conv.        Labels: 4E0-910-289.lbl
       Part No SW: 4E0 910 289 A    HW: 4E0 907 289
       Component: Komfortgeraet   H03 0030
       Revision: 00300003    Serial number:  W040312110112
       Coding: 0065214
       VCID: 275DC5A596D4B2061F-8072
       Component: Heckdeckel   P14H06 0070
       Component: Neigungssensor  H02 0020
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 150
                        Mileage: 193858 km
                        Date: 2011.08.15
                        Time: 01:50:33
    Address 47: Sound System        Labels: None
       Part No SW: 4E0 910 224 C    HW: 4E0 035 223 B
       Component: DSP-High D3/AUX H13 0470
       Revision: Dev_D01     Serial number: 00000000655399
       Coding: 0000016
       Shop #: WSC 54321 444 12345
       VCID: 1E33E041C98E73CE6C-804A
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H08 0020
       Revision:             Serial number: 00000000030051
       Coding: 0010111
       Subsystem 1 - Part No: 4E0 910 511 A
       Component: UGDO HL US      H02 0030
       Subsystem 2 - Serial number: VK4978T078WE
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 802
       Component: Türsteuer.BF BRM005 0110
       Coding: 0028196
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 A    HW: 4E0 907 801
       Component: EPB  AV1C1010   H01 1010
       Revision: AV1C1010
       Coding: 0000532
       Shop #: WSC 23435 444 58960
    Address 55: Headlight Range        Labels: 4E0-910-357.lbl
       Part No SW: 4E0 910 357     HW: 4E0 907 357
       Component: Pre-AFS         H01 0030
       VCID: 62CB94B1BD76172E08-8036
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541
       Component: TUNER EU/US/RDW H41 0630
       Revision: 00000000    Serial number: 304CE047583230
       Shop #: WSC 06802 176 59446
       VCID: 31692BFDA810FCB6C1-8064
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 A    HW: 4E0 915 181
       Component: ENERGIEMANAGER  H02 0230
       Revision: 00000000    Serial number: 00000004980755
       Shop #: WSC 07212 444 82777
       Subsystem 1 - Part No: 000 915 105 DL
       Component: von VA0  310314E03G
       Coding: 303030393135313035444C56413033313033313445303347
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 801 A
       Component: Türsteuer.HL BRM007 0110
       Coding: 0032300
       VCID: 5DB1A74D840828D635-8008
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 802 A
       Component: Türsteuer.HR BRM007 0110
       Coding: 0032300
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Component: Parkhilfe 8-Kan H11 0010
       Revision: --.--.--    Serial number: 00000335600021
       Coding: 0001208
       VCID: 2149DBBDF8F04C3651-8074
    End-------------------------(Elapsed Time: 02:49)--------------------------
  2. Likes Uwe liked this post
  3. #2
    What are fuel psi and volume tests, filter + regulation?
    What about readiness tests?
    What is the actual thresholds of cats and oxs?
    Are there any air leaks?
    What are trims?
    0x01-04-046/047?
    0x01-04-034/036/043/044?
    Mar 2015
    Rhode Island
    @Jack, Thanks for the reply brother, I have checked for Exhaust leaks and cannot seem to find any.
    I assume the following
    0x01-04-046/047?
    0x01-04-034/036/043/044? are the channels for testing the Engine in measuring blocks?
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    Nope "BASIC" Settings
    Mar 2015
    Rhode Island
    Ok I assume I need to do what was stated in the previous link? Car on regular operation temp and rev the engine to 2,000 rpms?
    Also just write down my findings? Or would it be easier to do a video of the live data for you? Thanks again
    LOG ........
    Post data.
    Video is fun too.
    Additionally you need a firmware update and I can help with that....... as it may help the CAT codes.
    Component: 4.2L V8/5V G 0070 <<<<<<<<<<<<<<<<<< over here!
  8. Likes BostonSlaya liked this post
    Mar 2015
    Rhode Island
    Ok I will do it now! Sorry to ask again but do Ido this after th car is a normal temp? And do I bring my rpms to a certain number for a certain amount of time? BTW your awesome!
  10. #8
    Readiness can be done from cold ramp on up.
    Might as well start with LDP and EVAP stuff to verify not part of problem.
    0x01-15 see if script is available or go back to link here below and manually run the tests.
    Always do readiness twice and after a key cycle in-between to simulate a DCY.
  11. #9
    Mar 2015
    Rhode Island
    Ok also how do I get the firmware update that your talking about?
  12. #10
    You may use the contact form
    http://europeanpartsemporium.com/?page_id=31
    or
    http://www.ebay.com/itm/Audi-VW-ECU-...item4d0adf98f2
    Typically this requires mailing in your controller for update and is sent back after completed.
    It is highly unlikely that both CATS fail at the same time or both OXS sensors......
