Wrong byte 18 options
Dutchie
C?ID=125479
I'ver retrofitted a set of 6C full led headlights on my 6R Polo.
They work great, yet the leds (mainbeam) go off after 10 secs. When i check Byte 18 of the BCM i have 5 options;
00 When a new BCM is installed this is the default
41
43
60
66
The code 66 is on a 6R wrong. Causing the MIL to go on, and the lights to go off. The propper byte 18 for the 6R with bi-xenon or 6C full led (on this BCM) is 67. Is it perhaps possible to ad 67 to the menu.
default autoscan:
#hndoc:?docid=0000196A&xt=hnh:1BCE26FBAF063C09DA99C75010387DA3E454A4D03DB2DF4DE45A328BE87DF2E2
VCDS Mobile 0.4309.0.4
VIN: WVWZZZ6RZDY149893
Scan: 01 02 03 08 09 10 15 17 19 25 2E 37 44 56 61
Address 01: Engine  (CPTA2 J623)	Labels: None
	Part No SW: 04E 906 016 R	HW: 04E 907 309 D
	Component: 1,4l R4 TSI   H08 5764
	Revision: WCH08---
	Coding: 00250032242411000000
	Shop #: WSC 21756 000 1048576
	ASAM Dataset: EV_ECM14TFS01104E906016R 002008
	ROD: N/A
	VCID: 312586C7FCAAD2C64CED0F425-8064
	No ASAM data for: "EV_ECM14TFS01104E906016R"
No fault codes found.
Address 02: Auto Trans	Labels: None
	Part No SW: 0AM 300 060 C	HW: 0AM927769D
	Component: GSG DSG AG7     431  5271
	Revision: 00043014	Serial Number: CU501211096629
	Shop #: WSC 63623 001 1048576
	VCID: 2A1791ABD17C381E8DA7C0F60-5160
Address 03: ABS Brakes  (J104)	Labels: None
	Part No SW: 6R0 907 379 AS	HW: 6R0 907 379 AS
	Component: ESP9.0i front H01 0002
	Coding: 21DD4885432700C9841C1272C25400550905
	Shop #: WSC 01383 785 00200
	ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
	ROD: N/A
	VCID: 8F61A03FCADE6436FA9939BA3-80DA
	No ASAM data for: "EV_Brake1ESP90iBOSCH"
Address 08: Auto HVAC  (J255)	Labels: None
	Part No SW: 6R0 907 044 H	HW: 6R0 907 044 H
	Component: Climatronic   H11 0711
	Revision: V0000000
	Shop #: WSC 00000 000
	VCID: 3833BBE31FD01B8E0B337AAEE-806D
Address 09: Cent. Elect.  (J519)	Labels: None
	Part No SW: 7H0 937 090	HW: 7H0 937 090
	Component: BCM PQ25 Max4 H72 0708
	Revision: B9072001
	Coding: 3BB0293F48E12400B3280FB07EEB9ED95FC0412F7E840040200000020000
	Shop #: WSC 00788 648 00255
	VCID: EB99D4AF9E06E016B6310D0A7-80BE
	Subsystem 1 - 	Part No SW: 1K0-955-559-AH
	Component: RLS 241012 0554  0403
	Coding: 02302D
	Subsystem 2 - 	Part No SW: 6R0-959-801-ABÿÿÿÿ
	Component: J386__TSG_FT 008 1621
	Coding: 58BC30
	Subsystem 3 - 	Part No SW: 6R0-959-802-AD-AB
	Component: J387__TSG_BT 008 1621
	Coding: 58BC30
	Subsystem 4 - 	Part No SW: 1K8-951-171-A
	Component: DWA-Sensor 00001 0103
	Subsystem 5 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 6 - 	Part No SW: 1K8-951-171-A
	Subsystem 7 - 	Part No SW: 5K0-959-542-B
	Component: E221__MFL-TASH30 0032
	Coding: 830000
Address 10: Park/Steer Assist  (J446)	Labels: None
	Part No SW: 6R0 919 475 C	HW: 7E0 919 475
	Component: PARKHILFE 4K  H11 0013
	Revision: --------
	Coding: 108104
	ASAM Dataset: EV_VW250ParkiAssis2 S01008
	ROD: N/A
	VCID: 3E3FADFB3DF43DBEC16FBCE6C-806B
	No ASAM data for: "EV_VW250ParkiAssis2"
Address 15: Airbags  (J234)	Labels: None
	Part No SW: 6R0 959 655 K	HW: 6R0 959 655 K
	Component: VW10Airbag01S H10 0020
	Revision: --------
	Coding: 003153
	ROD: N/A
	VCID: 4AD7F12B713C811E6DE720760-801F
	No ASAM data for: "EV_AirbaVW10BPAVW250"
	Subsystem 1 - 	Serial Number: 3575HRB40064UNBCA1PT
	Subsystem 2 - 	Serial Number: 3585HRB401I4UOJA90UA
	Subsystem 3 - 	Serial Number: 3515RRB400E4UOFEI9RN
Address 17: Instruments  (J285)	Labels: None
	Part No SW: 6R0 920 870 C	HW: 6R0 920 870 C
	Component: KOMBI         H05 0607
	Coding: 140A01
	ROD: N/A
	VCID: 352DB2D708C2FEE610155B721-8060
	No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 6N0 909 901	HW: 7H0 937 090
	Component: GW-K-CAN TP20 H72 0708
	Revision: B9072001
	Coding: 002000
	VCID: F0A3C3C3B72003CE8363424E6-80A5
Address 25: Immobilizer  (J334)	Labels: None
	Part No SW: 5K0 953 234	HW: 5K0 953 234
	Component: IMMO          H05 0607
	ROD: N/A
	VCID: EA97D1AB91FCE11ECD2700F60-80BF
	No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 2E: Media Player 3  (J650)	Labels: None
	Part No SW: 5N0 035 342 F	HW: 5N0 035 342 F
	Component: SG EXT.PLAYER H19 0550
	Revision: A1001003
	Coding: 020100
	VCID: 2A1791ABD17CB91E8DA7C0F60-807F
Address 37: Navigation  (J794)	Labels: None
	Part No SW: 3C8 035 279 A	HW: 3C8 035 279 A
	Component: RNS315-EU
	Coding: 040004110200010000001308
	ROD: N/A
	VCID: 29156EA7D47AAA06849DD7E2D-807C
	No ASAM data for: "EV_RNS315EUV2UDS"
Address 44: Steering Assist	Labels: None
	Part No SW: 6R0 423 156 C
	Component: LenkhilfeTRW        V278
	Coding: 11241
	Shop #: WSC 00788 000
	VCID: 302383C3F7A057CE43E3024E6-8065
After recoding byte 18 to 67
Saturday,18,June,2016,15:57:12:41861
VCDS Version: 16.6.0.2 (x64)  HEX-NET CB: 0.4321.4
Data version: 20160602 DS251
VIN: WVWZZZ6RZDY149893   License Plate: 52ZPN6
Mileage: 20880km-12974mi   Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 2E 37 44 56 61 0B
VIN: WVWZZZ6RZDY1******  Mileage: 20880km-12974miles
Address 01: Engine (J623-CPTA)       Labels: 04E-907-309-V1.clb
   Revision: WCH08---    Serial number:
   ROD: EV_ECM14TFS01104E906016R.rod
   VCID: 312AD004608ADFCB66-8064
   Part No SW: 0AM 300 060 C    HW: 0AM 927 769 D
   Revision: 00043014    Serial number: CU501211096629
   VCID: 2A18C768845CAC13A7-5160
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Serial number: --------------
   ROD: EV_Brake1ESP90iBOSCH_VW25.rod
   VCID: 0F6E76FCD6FEE93B50-805A
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Revision: V0000000
   VCID: 383CED208BF00E8321-806C
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Revision: B9072001    Serial number: 0531 324121754
   Coding: 3AB0293F48E12400B3280F307EEB9ED94FC0662F7E840040200000020000
   VCID: 6B96026C8A26751B1C-803E
   Component: RLS 241012 05  54  0403
   Coding: 17302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Coding: 58BC30
   Subsystem 4 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 1K8 951 171 A
   Subsystem 7 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
   Component: E221__MFL-TAS  H30 0032
   Coding: 830000
            010 - Open or Short to Plus
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Revision: --------    Serial number: 47361230500225
   Coding: 108104
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E30FB38A1D430B3EB-806A
   Revision: --------    Serial number: 003GX01GR2P.
   Coding: 003153
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 4AD8A7E8ED1C8C1347-801E
   Serial number: 3575HRB40064UNBCA1PT
   Serial number: 3585HRB401I4UOJA90UA
   Serial number: 3515RRB400E4UOFEI9RN
   Serial number: 3525RRB400E4UOFE911O
   Coding: 140A01
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 3522E41494E2F3EB3A-8060
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Revision: B9072001
   Coding: 002000
   VCID: 70AC1500A30096C329-8024
   VCID: 6A9807688DDC6C1367-803E
   Revision: A1001003    Serial number: 7663867709
   Coding: 020100
   VCID: 2A18C768455CAC13A7-807E
   Component: RNS315-EU   H59 0319
   Serial number: VWZAZ2M5552143
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 291A3864485AA70BAE-807C
   Component: EUR_W_V4  0050
   Part No: 6R0 423 156 C
   Coding: 11241
   Shop #: WSC 00788
   VCID: 302CD500F780D6C369-8064
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H72 0708
   Coding: 032B7A64
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
End----------(Elapsed Time: 02:13, VBatt start/end: 14.2V/14.2V)-----------
Saturday,18,June,2016,16:11:18:41861
VIN: WVWZZZ6RZDY149893   Mileage: 20880km-12974miles
   Revision: V0000000
   Coding: 3AB0293F48E12400B3280FB07EEB9ED9DFC0672F7E840040200000020000
   Coding: 17302D
   Coding: 58BC30
   Coding: 58BC30
   Coding: 830000
                    Fault Status: 01101010
                    Reset counter: 66
                    Mileage: 20883 km
                    Date: 2016.06.18
                    Time: 16:01:06
                    Reset counter: 66
                    Mileage: 20883 km
                    Date: 2016.06.18
                    Time: 16:01:06
   Coding: 108104
   Coding: 003153
   Coding: 140A01
   Revision: B9072001
   Coding: 002000
   Coding: 020100
   Coding: 11241
   Shop #: WSC 00788
   Coding: 032B7A64
End-------------------------(Elapsed Time: 01:57)--------------------------
