Results 1 to 10 of 15
Thread: VW Golf 7 Gateway High Recode
    Jun 2016
    Post VW Golf 7 Gateway High Recode
    Hello All,
    I have a guestion about the right coding VW Golf 7 Gateway High.
    Especially the adaptations.
    I have a gateway High coced through online vw but I have one error on the infotainment 5F.
    The problem with the error are the comfort user setting on the infotainment.
    If you look at the picture you see with the High Gateway there is no description of the use consumption like the Climate control.
    If you look to the Mid range Gateway you see the description of use consumption on the infotainment Climate control.
    The adaptation of the High range Gateway have more options then the Mid Gateway.
    The reason why I want to change the gateway from Mid to High there is olso an error, because the old one is flashed to a newer software.
    and the error will go when you drive tro a VW Agent and let the software put in the system again..
    But i have a second Gateway without error so i want to try to recode this.
    It must be the setting maybe somone can give a hint to look.
    The text are in German because at the moment i didnt install the Englisch version only German and the old gateway are now in the car.
    Error old gateway
    1 Fehler gefunden:
    1537 - Datensatz unplausibel
    B2012 00 [009] - -
    bestätigt - geprüft seit letzter Löschung
    Umgebungsbedingungen:
    Fehlerstatus: 00000001
    Fehlerpriorität: 2
    Fehlerhäufigkeit: 2
    Verlernzähler: 6
    Kilometerstand: 46443 km
    Datum: 2016.06.05
    Zeit: 20:19:43
    High Gateway
    Adresse 19: Diagnoseinterface (J533)       Labeldatei: DRV\5Q0-907-530-V1.clb
       Teilenummer SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
       Bauteil: GW MQB High   128 1203
       Revision: --------    Seriennummer: 0001839445
       Codierung: 030100042B086400EF000648080F00010001000000000000000000000000
       Betriebsnr.: WSC 01357 011 00200
       ASAM Datensatz: EV_GatewLear 011020
       ROD: EV_GatewLear.rod
       VCID: 72C480A0A509DFAE78-8026
    Mid Gateway
       Teilenummer SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
       Bauteil: GW MQB Mid    121 1144
       Revision: --------    Seriennummer: 0000104516
       Betriebsnr.: WSC 51454 001 1048576
       ASAM Datensatz: EV_GatewLear 009013
       VCID: 3A546880BDF967EE70-806E
    Adresse 5F: Informationselek. I (J794)       Labeldatei: 5G0-035-MIB-STD1.clb
       Teilenummer SW: 5G0 035 846 A    HW: 5G0 035 846
       Bauteil: MU-S-N-ER     038 0421
       Seriennummer: V1F01510120522
       Codierung: 02730001FF00000011110001000800001F0100940100010045
       Betriebsnr.: WSC 12345 666 54321
       ASAM Datensatz: EV_MUStd4CPASE 002039
       ROD: EV_MUStd4CPASE_SK37.rod
       VCID: 2772A1F45E4BEA061F-8072
       Media Player 1:
       Subsystem 1 - Teilenummer SW: 5G0 919 605 D    HW: 5G0 919 605 D
       Bauteil: ABT_Std_Nav  H51 0022
       Seriennummer: VWZ8Z9NJ902C5F
       Motorelektronik 2:
       Subsystem 2 - Teilenummer SW: 5G0 919 866 AC    HW: -----------
       Bauteil:  ECE 2016  --- 0054
       Seriennummer: --------------------
    1 Fehler gefunden:
    7203 - Funktionseinschränkung wegen fehlender Botschaft
              U1111 00 [009] - -
                        Fehlerpriorität: 6
                        Fehlerhäufigkeit: 5
                        Verlernzähler: 213
                        Kilometerstand: 46356 km
                        Datum: 2016.06.01
                        Zeit: 13:30:55
    http://i489.photobucket.com/albums/r...603_153533.jpg
    http://i489.photobucket.com/albums/r...607_230927.jpg
    VCDS Version: Release 15.7.4 Running on Windows 10 x86
    Data version: 20160216
    Monday,13,June,2016,14:38:09:42750
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZDP010048   Mileage: 46580km-28943miles
    Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 E    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 7695
       Revision: WAH08---
       Coding: 01110032232415082000
       Shop #: WSC 51969 000 1048576
       ASAM Dataset: EV_ECM12TFS01104E906016E 001011
       ROD: EV_ECM12TFS01104E906016H.rod
       VCID: 2468B6F82F7D011E3A-8070
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
       Shop #: WSC 12345 123 123465
       VCID: 7DDEA39CEC5790D615-8028
       Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00020004200100011005000000101000
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 364C7CB089E1838E94-8062
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 L
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011227800350
       Coding: 00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 77D2B1B4CE6BBA864F-8022
       Slave 1:
       Component: WWS    120910  042 0551
       Serial number:         120924160900
       Coding: 0E4DD5
       Slave 2:
       Component: RLFS  024 0042
       Serial number: Y12M09D26H11M47S40S4
       Coding: 06A8DD
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY1306406H5
       Serial number: 00000000000056969920
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
       Component: PARKHILFE PLA 011 0029
       Revision: --------    Serial number: 61131204002703
       Coding: 0031161041
       ASAM Dataset: EV_EPHVA2CAU3700000 003014
       ROD: EV_EPHVA2CAU3700000_VW37.rod
       VCID: 3D5E639CACD750D655-8068
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R00E6ZJ
       Shop #: WSC 00028 028 00057
       VCID: 40A01A68DB253D3E3E-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 310 12
       Serial number: 35767000000E2845EB00
       Subsystem 2 - Part No SW: -----------    HW: 480 001 708 13
       Serial number: 35867000000ED2CC6D0F
       Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3516502A90D19C31C0EK
       Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3526502AD0CD5EB313CY
       Subsystem 5 - Part No SW: -----------    HW: 480 400 210 12
       Serial number: 3556502B30CD5EB4531M
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 1510120003004H
       Coding: 8400
       Shop #: WSC 51454 001 104857
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 75CEBBBCD467C8965D-8020
       Part No SW: 5G0 920 871     HW: 5G0 920 871
       Component: KOMBI         353 2200
       Coding: 07A50F002390000800086E00040000
       VCID: 67F2E1F49ECB2A06DF-8032
       Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
       Component: GW MQB Mid    121 1144
       Revision: --------    Serial number: 0000104516
       Coding: 030100042B086400EF000648080F00010001000000000000000000000000
       Shop #: WSC 51454 001 1048576
       ASAM Dataset: EV_GatewLear 009013
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
       Component: E221__MFL-DC1  H14 0035
       Serial number: 23130000529820100291
       Coding: 280000
       Serial number: 5430458201
    1537 - Data Set Implausible
              B2012 00 [009] -  -
                        Reset counter: 10
                        Mileage: 46443 km
                        Date: 2016.06.05
                        Time: 20:19:43
       Serial number: 29051301100188
       Coding: 001F0220D000020000001000
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Serial number: 00000000000000243883
       Coding: 03
       ROD: EV_SteerAssisMQB.rod
       Component: TSG BFS       020 0023
       Serial number: 06031302090088
       Coding: 001F0020DE00020000801000
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 3FA21994A6DB42C647-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Serial number: 00000000000000247280
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846
       Component: MU-S-N-ER     038 0421
       Serial number: V1F01510120522
       Coding: 02730001FF00000011110001000800001F0100940100010045
       Shop #: WSC 12345 666 54321
       Media Player Position 1:
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9NJ902C5F
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 5G0 919 866 AD    HW: -----------
       Component:  ECE 2016/17  --- 0059
    End-------------------------(Elapsed Time: 02:44)--------------------------
    Jun 2016
    Old Gateway Adaptations
    SW:5Q0-907-530-L   HW:5Q0-907-530-E ---  Diagnoseinterface
    	Bauteil:GW MQB Mid    121 1144, Codierung:030100042B086400EF000648080F00010001000000000000000000000000
    	EV_GatewLear,009013,EV_GatewLear.rod
    	Sonntag,05,Juni,2016,20:27:18:42750
    	VCDS Version: DRV 15.7.4  Datenstand: 20160223
    Aktivieren und Deaktivieren aller Entwicklungsbotschaften,nicht aktiv
    (1)-Anforderung Einschaltverbot Standheizung-Switch_on_ban_activation,Modus nicht aktiv
    (2)-Anforderung Einschaltverbot Standheizung-Set_point_target_time,--
    (1)-Batterieanpassung-Batterienennkapazität,69 Ah
    (2)-Batterieanpassung-Batterietechnologie,EFB
    (3)-Batterieanpassung-Batteriehersteller,JCB
    (4)-Batterieanpassung-Batterieseriennummer,1111111111
    Batterieanschlusserkennung,angeschlossen
    Showroommodus für Komponentenschutz,nicht aktiv
    Zähler für inkonsistente Zustände,0
    Produktionsmodus deaktivieren,0
    Deaktivierung der Start-Stopp-Funktion,Modus nicht aktiv
    Fahrstrecke für Deaktivierung Ruhestrommessmodus,2
    Fahrstrecke für Deaktivierung Transportmodus,50
    (1)-Anzeige für Effizienzprogramm-Livetipp Luftwiderstand: Fenster/Schiebedach schließen,aktiviert
    (2)-Anzeige für Effizienzprogramm-Livetipp Motorbremse: Erst unter 1300 1/min auskuppeln,aktiviert
    (3)-Anzeige für Effizienzprogramm-Livetipp Bei Motorstart Gaspedal nicht betätigen,aktiviert
    (4)-Anzeige für Effizienzprogramm-Livetipp Schaltanzeige beachten (nur Handschalter),aktiviert
    (5)-Anzeige für Effizienzprogramm-Livetipp Start-Stop-System nutzen,aktiviert
    (6)-Anzeige für Effizienzprogramm-Livetipp Start-Stop-System einschalten,aktiviert
    (7)-Anzeige für Effizienzprogramm-Livetipp Klimaanlage: Fenster/Schiebedach schließen,aktiviert
    (8)-Anzeige für Effizienzprogramm-Livetipp Fahrstufe D verwenden,aktiviert
    (9)-Anzeige für Effizienzprogramm-Livetipp Im Stand Gaspedal nicht betätigen,aktiviert
    (10)-Anzeige für Effizienzprogramm-Livetipp Verdeck offen: Klimaanlage ausschalten(AC-Taste),aktiviert
    (11)-Anzeige für Effizienzprogramm-Livetipp Motorwarmlauf im Stand vermeiden,aktiviert
    (12)-Anzeige für Effizienzprogramm-Schalttafeleinsatz,aktiviert
    (13)-Anzeige für Effizienzprogramm-Komfortverbrauch Klimaanlage,aktiviert
    (14)-Anzeige für Effizienzprogramm-Komfortverbrauch Standheizung,aktiviert
    (15)-Anzeige für Effizienzprogramm-Komfortverbrauch Heckscheibenheizung,aktiviert
    (16)-Anzeige für Effizienzprogramm-Komfortverbrauch Sitzheizung vorn,aktiviert
    (17)-Anzeige für Effizienzprogramm-Komfortverbrauch Sitzlüftung vorn,aktiviert
    (18)-Anzeige für Effizienzprogramm-Komfortverbrauch Nackenheizung,aktiviert
    (19)-Anzeige für Effizienzprogramm-Komfortverbrauch Nebellicht,aktiviert
    (20)-Anzeige für Effizienzprogramm-Komfortverbrauch Nebelschlusslicht,aktiviert
    (21)-Anzeige für Effizienzprogramm-Komfortverbrauch Verbrauchsausgabe Standheizung,aktiviert
    (22)-Anzeige für Effizienzprogramm-Komfortverbrauch Frontscheibenheizung,aktiviert
    (23)-Anzeige für Effizienzprogramm-Komfortverbrauch Lenkradheizung,aktiviert
    (24)-Anzeige für Effizienzprogramm-Komfortverbrauch Spiegelheizung,aktiviert
    (25)-Anzeige für Effizienzprogramm-Komfortverbrauch Sitzheizung hinten,aktiviert
    (26)-Anzeige für Effizienzprogramm-Komfortverbrauch Sitzlüftung hinten,aktiviert
    Energiemanagement Abschaltstufe,Modus nicht aktiv
    Energiemanagement Heizleistungsregelung	 Status,Modus nicht aktiv
    Generatorsollwertspannung variabel,10.6 V
    (1)-Hysteresespannung-Voltage_lowering,12.1 V
    (2)-Hysteresespannung-Voltage_elevation,12.1 V
    Anforderung Leerlaufanhebung,Modus nicht aktiv
    (1)-Verbauliste Sollverbau-Diagnoseinterface für Datenbus,codiert
    (2)-Verbauliste Sollverbau-Node_0x01,Nicht codiert
    (3)-Verbauliste Sollverbau-Node_0x02,Nicht codiert
    (4)-Verbauliste Sollverbau-Node_0x03,Nicht codiert
    (5)-Verbauliste Sollverbau-Node_0x04,Nicht codiert
    (6)-Verbauliste Sollverbau-Node_0x05,Nicht codiert
    (7)-Verbauliste Sollverbau-Node_0x06,Nicht codiert
    (8)-Verbauliste Sollverbau-Node_0x07,Nicht codiert
    (9)-Verbauliste Sollverbau-Node_0x08,Nicht codiert
    (10)-Verbauliste Sollverbau-Node_0x09,Nicht codiert
    (11)-Verbauliste Sollverbau-Einparkhilfe,codiert
    (12)-Verbauliste Sollverbau-Reifendrucküberwachung,Nicht codiert
    (13)-Verbauliste Sollverbau-Lenksäulenelektronik,codiert
    (14)-Verbauliste Sollverbau-Node_0x0D,Nicht codiert
    (15)-Verbauliste Sollverbau-Elektronische Zentralelektrik,codiert
    (16)-Verbauliste Sollverbau-Allradelektronik,Nicht codiert
    (17)-Verbauliste Sollverbau-Node_0x11,Nicht codiert
    (18)-Verbauliste Sollverbau-Lenkhilfe,codiert
    (19)-Verbauliste Sollverbau-Bremsenelektronik,codiert
    (20)-Verbauliste Sollverbau-Schalttafeleinsatz,codiert
    (21)-Verbauliste Sollverbau-Airbag,codiert
    (22)-Verbauliste Sollverbau-Node_0x16,Nicht codiert
    (23)-Verbauliste Sollverbau-Node_0x17,Nicht codiert
    (24)-Verbauliste Sollverbau-Radio,Nicht codiert
    (25)-Verbauliste Sollverbau-Klimakompressor,Nicht codiert
    (26)-Verbauliste Sollverbau-Node_0x1A,Nicht codiert
    (27)-Verbauliste Sollverbau-Node_0x1B,Nicht codiert
    (28)-Verbauliste Sollverbau-Aktuator für Körperschall,Nicht codiert
    (29)-Verbauliste Sollverbau-Node_0x1D,Nicht codiert
    (30)-Verbauliste Sollverbau-Sperrenelektronik,Nicht codiert
    (31)-Verbauliste Sollverbau-Node_0x1F,Nicht codiert
    (32)-Verbauliste Sollverbau-Node_0x20,Nicht codiert
    (33)-Verbauliste Sollverbau-Node_0x21,Nicht codiert
    (34)-Verbauliste Sollverbau-Node_0x22,Nicht codiert
    (35)-Verbauliste Sollverbau-Heckdeckelelektronik,Nicht codiert
    (36)-Verbauliste Sollverbau-Node_0x24,Nicht codiert
    (37)-Verbauliste Sollverbau-Node_0x25,Nicht codiert
    (38)-Verbauliste Sollverbau-Node_0x26,Nicht codiert
    (39)-Verbauliste Sollverbau-Node_0x27,Nicht codiert
    (40)-Verbauliste Sollverbau-Node_0x28,Nicht codiert
    (41)-Verbauliste Sollverbau-Node_0x29,Nicht codiert
    (42)-Verbauliste Sollverbau-Node_0x2A,Nicht codiert
    (43)-Verbauliste Sollverbau-Sonderfunktion 2,Nicht codiert
    (44)-Verbauliste Sollverbau-Sonderfunktion,Nicht codiert
    (45)-Verbauliste Sollverbau-Elektrische Dachbetätigung,Nicht codiert
    (46)-Verbauliste Sollverbau-Node_0x2E,Nicht codiert
    (47)-Verbauliste Sollverbau-Node_0x2F,Nicht codiert
    (48)-Verbauliste Sollverbau-Fernlichtassistent,Nicht codiert
    (49)-Verbauliste Sollverbau-Lenksäulenverriegelung,Nicht codiert
    (50)-Verbauliste Sollverbau-Interface für Zugang- und Startsystem,Nicht codiert
    (51)-Verbauliste Sollverbau-Schiebetür hinten links,Nicht codiert
    (52)-Verbauliste Sollverbau-Schiebetür hinten rechts,Nicht codiert
    (53)-Verbauliste Sollverbau-Node_0x35,Nicht codiert
    (54)-Verbauliste Sollverbau-Node_0x36,Nicht codiert
    (55)-Verbauliste Sollverbau-Node_0x37,Nicht codiert
    (56)-Verbauliste Sollverbau-Node_0x38,Nicht codiert
    (57)-Verbauliste Sollverbau-Node_0x39,Nicht codiert
    (58)-Verbauliste Sollverbau-Node_0x3A,Nicht codiert
    (59)-Verbauliste Sollverbau-Bremskraftverstärkung,Nicht codiert
    (60)-Verbauliste Sollverbau-Node_0x3C,Nicht codiert
    (61)-Verbauliste Sollverbau-Node_0x3D,Nicht codiert
    (62)-Verbauliste Sollverbau-Türelektronik Fahrerseite hinten,Nicht codiert
    (63)-Verbauliste Sollverbau-Türelektronik Beifahrerseite hinten,Nicht codiert
    (64)-Verbauliste Sollverbau-Node_0x40,Nicht codiert
    (65)-Verbauliste Sollverbau-Node_0x41,Nicht codiert
    (66)-Verbauliste Sollverbau-Thermomanagement,Nicht codiert
    (67)-Verbauliste Sollverbau-Node_0x43,Nicht codiert
    (68)-Verbauliste Sollverbau-Hochvolt-Batterieladegerät,Nicht codiert
    (69)-Verbauliste Sollverbau-Node_0x45,Nicht codiert
    (70)-Verbauliste Sollverbau-Klima-/ Heizungselektronik,codiert
    (71)-Verbauliste Sollverbau-Anhängerfunktion,Nicht codiert
    (72)-Verbauliste Sollverbau-Node_0x48,Nicht codiert
    (73)-Verbauliste Sollverbau-Node_0x49,Nicht codiert
    (74)-Verbauliste Sollverbau-Türelektronik Fahrer,codiert
    (75)-Verbauliste Sollverbau-Türelektronik Beifahrer,codiert
    (76)-Verbauliste Sollverbau-Sitzverstellung Fahrerseite,Nicht codiert
    (77)-Verbauliste Sollverbau-Sitzverstellung Beifahrerseite,Nicht codiert
    (78)-Verbauliste Sollverbau-Spurwechselassistent,Nicht codiert
    (79)-Verbauliste Sollverbau-Frontsensorik für Fahrerassistenzsysteme,Nicht codiert
    (80)-Verbauliste Sollverbau-Fahrzeuglageerkennung,Nicht codiert
    (81)-Verbauliste Sollverbau-Node_0x51,Nicht codiert
    (82)-Verbauliste Sollverbau-Node_0x52,Nicht codiert
    (83)-Verbauliste Sollverbau-Node_0x53,Nicht codiert
    (84)-Verbauliste Sollverbau-Leuchtweitenregelung,Nicht codiert
    (85)-Verbauliste Sollverbau-Node_0x55,Nicht codiert
    (86)-Verbauliste Sollverbau-Node_0x56,Nicht codiert
    (87)-Verbauliste Sollverbau-Distanzregelung,Nicht codiert
    (88)-Verbauliste Sollverbau-Node_0x58,Nicht codiert
    (89)-Verbauliste Sollverbau-Node_0x59,Nicht codiert
    (90)-Verbauliste Sollverbau-Node_0x5A,Nicht codiert
    (91)-Verbauliste Sollverbau-Node_0x5B,Nicht codiert
    (92)-Verbauliste Sollverbau-Node_0x5C,Nicht codiert
    (93)-Verbauliste Sollverbau-Node_0x5D,Nicht codiert
    (94)-Verbauliste Sollverbau-Node_0x5E,Nicht codiert
    (95)-Verbauliste Sollverbau-Node_0x5F,Nicht codiert
    (96)-Verbauliste Sollverbau-Node_0x60,Nicht codiert
    (97)-Verbauliste Sollverbau-Node_0x61,Nicht codiert
    (98)-Verbauliste Sollverbau-Node_0x62,Nicht codiert
    (99)-Verbauliste Sollverbau-Mikrofonsteuergerät,Nicht codiert
    (100)-Verbauliste Sollverbau-Aktuator für Aussengeräusch,Nicht codiert
    (101)-Verbauliste Sollverbau-Hochvolt-Batterielademanagement,Nicht codiert
    (102)-Verbauliste Sollverbau-Node_0x66,Nicht codiert
    (103)-Verbauliste Sollverbau-Notrufmodul und Kommunikationseinheit,Nicht codiert
    (104)-Verbauliste Sollverbau-Node_0x68,Nicht codiert
    (105)-Verbauliste Sollverbau-Rückfahrkamerasystem,Nicht codiert
    (106)-Verbauliste Sollverbau-Zu-/ Standheizung,Nicht codiert
    (107)-Verbauliste Sollverbau-Node_0x6B,Nicht codiert
    (108)-Verbauliste Sollverbau-Node_0x6C,Nicht codiert
    (109)-Verbauliste Sollverbau-TV-Tuner,Nicht codiert
    (110)-Verbauliste Sollverbau-Node_0x6E,Nicht codiert
    (111)-Verbauliste Sollverbau-Soundsystem,Nicht codiert
    (112)-Verbauliste Sollverbau-Media Player 1,Nicht codiert
    (113)-Verbauliste Sollverbau-Fahrtenschreiber,Nicht codiert
    (114)-Verbauliste Sollverbau-Raddämpfungselektronik,Nicht codiert
    (115)-Verbauliste Sollverbau-Informationselektronik 1,codiert
    (116)-Verbauliste Sollverbau-Node_0x74,Nicht codiert
    (117)-Verbauliste Sollverbau-Node_0x75,Nicht codiert
    (118)-Verbauliste Sollverbau-Motorelektronik,codiert
    (119)-Verbauliste Sollverbau-Getriebeelektronik,Nicht codiert
    (120)-Verbauliste Sollverbau-Node_0x78,Nicht codiert
    (121)-Verbauliste Sollverbau-Node_0x79,Nicht codiert
    (122)-Verbauliste Sollverbau-Node_0x7A,Nicht codiert
    (123)-Verbauliste Sollverbau-Hybrid Batteriemanagement,Nicht codiert
    (124)-Verbauliste Sollverbau-Elektroantrieb,Nicht codiert
    (125)-Verbauliste Sollverbau-Node_0x7D,Nicht codiert
    (126)-Verbauliste Sollverbau-Node_0x7E,Nicht codiert
    (127)-Verbauliste Sollverbau-Node_0x7F,Nicht codiert
    (128)-Verbauliste Sollverbau-Node_0x80,Nicht codiert
    (129)-Verbauliste Sollverbau-Node_0x81,Nicht codiert
    (130)-Verbauliste Sollverbau-Node_0x82,Nicht codiert
    (131)-Verbauliste Sollverbau-Node_0x83,Nicht codiert
    (132)-Verbauliste Sollverbau-Steuergerät für Schiebedach,Nicht codiert
    (133)-Verbauliste Sollverbau-Node_0x85,Nicht codiert
    (134)-Verbauliste Sollverbau-Node_0x86,Nicht codiert
    (135)-Verbauliste Sollverbau-Node_0x87,Nicht codiert
    (136)-Verbauliste Sollverbau-Node_0x88,Nicht codiert
    (137)-Verbauliste Sollverbau-Node_0x89,Nicht codiert
    (138)-Verbauliste Sollverbau-Steuergerät 2 für Spurwechselassistent,Nicht codiert
    (139)-Verbauliste Sollverbau-Node_0x8B,Nicht codiert
    (140)-Verbauliste Sollverbau-Node_0x8C,Nicht codiert
    (141)-Verbauliste Sollverbau-Node_0x8D,Nicht codiert
    (142)-Verbauliste Sollverbau-Node_0x8E,Nicht codiert
    (143)-Verbauliste Sollverbau-Node_0x8F,Nicht codiert
    (144)-Verbauliste Sollverbau-Node_0x90,Nicht codiert
    (145)-Verbauliste Sollverbau-Node_0x91,Nicht codiert
    (146)-Verbauliste Sollverbau-Node_0x92,Nicht codiert
    (147)-Verbauliste Sollverbau-Node_0x93,Nicht codiert
    (148)-Verbauliste Sollverbau-Node_0x94,Nicht codiert
    (149)-Verbauliste Sollverbau-Node_0x95,Nicht codiert
    (150)-Verbauliste Sollverbau-Node_0x96,Nicht codiert
    (151)-Verbauliste Sollverbau-Node_0x97,Nicht codiert
    (152)-Verbauliste Sollverbau-Node_0x98,Nicht codiert
    (153)-Verbauliste Sollverbau-Node_0x99,Nicht codiert
    (154)-Verbauliste Sollverbau-Node_0x9A,Nicht codiert
    (155)-Verbauliste Sollverbau-Node_0x9B,Nicht codiert
    (156)-Verbauliste Sollverbau-Node_0x9C,Nicht codiert
    (157)-Verbauliste Sollverbau-Node_0x9D,Nicht codiert
    (158)-Verbauliste Sollverbau-Node_0x9E,Nicht codiert
    (159)-Verbauliste Sollverbau-Node_0x9F,Nicht codiert
    (160)-Verbauliste Sollverbau-Node_0xA0,Nicht codiert
    (161)-Verbauliste Sollverbau-Node_0xA1,Nicht codiert
    (162)-Verbauliste Sollverbau-Node_0xA2,Nicht codiert
    (163)-Verbauliste Sollverbau-Node_0xA3,Nicht codiert
    (164)-Verbauliste Sollverbau-Node_0xA4,Nicht codiert
    (165)-Verbauliste Sollverbau-Node_0xA5,Nicht codiert
    (166)-Verbauliste Sollverbau-Node_0xA6,Nicht codiert
    (167)-Verbauliste Sollverbau-Node_0xA7,Nicht codiert
    (168)-Verbauliste Sollverbau-Node_0xA8,Nicht codiert
    (169)-Verbauliste Sollverbau-Node_0xA9,Nicht codiert
    (170)-Verbauliste Sollverbau-Node_0xAA,Nicht codiert
    (171)-Verbauliste Sollverbau-Node_0xAB,Nicht codiert
    (172)-Verbauliste Sollverbau-Node_0xAC,Nicht codiert
    (173)-Verbauliste Sollverbau-Node_0xAD,Nicht codiert
    (174)-Verbauliste Sollverbau-Node_0xAE,Nicht codiert
    (175)-Verbauliste Sollverbau-Node_0xAF,Nicht codiert
    (176)-Verbauliste Sollverbau-Node_0xB0,Nicht codiert
    (177)-Verbauliste Sollverbau-Node_0xB1,Nicht codiert
    (178)-Verbauliste Sollverbau-Node_0xB2,Nicht codiert
    (179)-Verbauliste Sollverbau-Node_0xB3,Nicht codiert
    (180)-Verbauliste Sollverbau-Node_0xB4,Nicht codiert
    (181)-Verbauliste Sollverbau-Node_0xB5,Nicht codiert
    (182)-Verbauliste Sollverbau-Node_0xB6,Nicht codiert
    (183)-Verbauliste Sollverbau-Node_0xB7,Nicht codiert
    (184)-Verbauliste Sollverbau-Node_0xB8,Nicht codiert
    (185)-Verbauliste Sollverbau-Node_0xB9,Nicht codiert
    (186)-Verbauliste Sollverbau-Node_0xBA,Nicht codiert
    (187)-Verbauliste Sollverbau-Node_0xBB,Nicht codiert
    (188)-Verbauliste Sollverbau-Node_0xBC,Nicht codiert
    (189)-Verbauliste Sollverbau-Node_0xBD,Nicht codiert
    (190)-Verbauliste Sollverbau-Node_0xBE,Nicht codiert
    (191)-Verbauliste Sollverbau-Node_0xBF,Nicht codiert
    (192)-Verbauliste Sollverbau-Node_0xC0,Nicht codiert
    (193)-Verbauliste Sollverbau-Node_0xC1,Nicht codiert
    (194)-Verbauliste Sollverbau-Node_0xC2,Nicht codiert
    (195)-Verbauliste Sollverbau-Node_0xC3,Nicht codiert
    (196)-Verbauliste Sollverbau-Node_0xC4,Nicht codiert
    (197)-Verbauliste Sollverbau-Node_0xC5,Nicht codiert
    (198)-Verbauliste Sollverbau-Node_0xC6,Nicht codiert
    (199)-Verbauliste Sollverbau-Node_0xC7,Nicht codiert
    (200)-Verbauliste Sollverbau-Node_0xC8,Nicht codiert
    (201)-Verbauliste Sollverbau-Node_0xC9,Nicht codiert
    (202)-Verbauliste Sollverbau-Node_0xCA,Nicht codiert
    (203)-Verbauliste Sollverbau-Node_0xCB,Nicht codiert
    (204)-Verbauliste Sollverbau-Node_0xCC,Nicht codiert
    (205)-Verbauliste Sollverbau-Node_0xCD,Nicht codiert
    (206)-Verbauliste Sollverbau-Node_0xCE,Nicht codiert
    (207)-Verbauliste Sollverbau-Node_0xCF,Nicht codiert
    (208)-Verbauliste Sollverbau-Node_0xD0,Nicht codiert
    (209)-Verbauliste Sollverbau-Node_0xD1,Nicht codiert
    (210)-Verbauliste Sollverbau-Node_0xD2,Nicht codiert
    (211)-Verbauliste Sollverbau-Node_0xD3,Nicht codiert
    (212)-Verbauliste Sollverbau-Node_0xD4,Nicht codiert
    (213)-Verbauliste Sollverbau-Node_0xD5,Nicht codiert
    (214)-Verbauliste Sollverbau-Node_0xD6,Nicht codiert
    (215)-Verbauliste Sollverbau-Node_0xD7,Nicht codiert
    (216)-Verbauliste Sollverbau-Node_0xD8,Nicht codiert
    (217)-Verbauliste Sollverbau-Node_0xD9,Nicht codiert
    (218)-Verbauliste Sollverbau-Node_0xDA,Nicht codiert
    (219)-Verbauliste Sollverbau-Node_0xDB,Nicht codiert
    (220)-Verbauliste Sollverbau-Node_0xDC,Nicht codiert
    (221)-Verbauliste Sollverbau-Node_0xDD,Nicht codiert
    (222)-Verbauliste Sollverbau-Node_0xDE,Nicht codiert
    (223)-Verbauliste Sollverbau-Node_0xDF,Nicht codiert
    (224)-Verbauliste Sollverbau-Node_0xE0,Nicht codiert
    (225)-Verbauliste Sollverbau-Node_0xE1,Nicht codiert
    (226)-Verbauliste Sollverbau-Node_0xE2,Nicht codiert
    (227)-Verbauliste Sollverbau-Node_0xE3,Nicht codiert
    (228)-Verbauliste Sollverbau-Node_0xE4,Nicht codiert
    (229)-Verbauliste Sollverbau-Node_0xE5,Nicht codiert
    (230)-Verbauliste Sollverbau-Node_0xE6,Nicht codiert
    (231)-Verbauliste Sollverbau-Node_0xE7,Nicht codiert
    (232)-Verbauliste Sollverbau-Node_0xE8,Nicht codiert
    (233)-Verbauliste Sollverbau-Node_0xE9,Nicht codiert
    (234)-Verbauliste Sollverbau-Node_0xEA,Nicht codiert
    (235)-Verbauliste Sollverbau-Node_0xEB,Nicht codiert
    (236)-Verbauliste Sollverbau-Node_0xEC,Nicht codiert
    (237)-Verbauliste Sollverbau-Node_0xED,Nicht codiert
    (238)-Verbauliste Sollverbau-Node_0xEE,Nicht codiert
    (239)-Verbauliste Sollverbau-Node_0xEF,Nicht codiert
    (240)-Verbauliste Sollverbau-Node_0xF0,Nicht codiert
    (241)-Verbauliste Sollverbau-Node_0xF1,Nicht codiert
    (242)-Verbauliste Sollverbau-Node_0xF2,Nicht codiert
    (243)-Verbauliste Sollverbau-Node_0xF3,Nicht codiert
    (244)-Verbauliste Sollverbau-Node_0xF4,Nicht codiert
    (245)-Verbauliste Sollverbau-Node_0xF5,Nicht codiert
    (246)-Verbauliste Sollverbau-Node_0xF6,Nicht codiert
    (247)-Verbauliste Sollverbau-Node_0xF7,Nicht codiert
    (248)-Verbauliste Sollverbau-Node_0xF8,Nicht codiert
    (249)-Verbauliste Sollverbau-Node_0xF9,Nicht codiert
    (250)-Verbauliste Sollverbau-Node_0xFA,Nicht codiert
    (251)-Verbauliste Sollverbau-Node_0xFB,Nicht codiert
    (252)-Verbauliste Sollverbau-Node_0xFC,Nicht codiert
    (253)-Verbauliste Sollverbau-Node_0xFD,Nicht codiert
    (254)-Verbauliste Sollverbau-Node_0xFE,Nicht codiert
    (255)-Verbauliste Sollverbau-Node_0xFF,Nicht codiert
    MKE Checkbox,nicht aktiviert
    (1)-Produktionsmodus-p_mode_deactivate_mfl_keys,deaktivieren
    (2)-Produktionsmodus-p_mode_deactivate_recuperation,deaktivieren
    Produktionsprozessdaten 1,00 01
    (1)-Rollenprüfstandmodus	 funktional-Aktivierungsstufen,nicht aktiviert
    (2)-Rollenprüfstandmodus	 funktional-Fehlerzustände,kein Fehler
    Auswahl der Freischaltcodes einer SWaP Funktion,FF FF FF FF
    Start/Stopp Startspannungsgrenze,6.0 V
    Ruhestrommessmodus,nicht aktiviert
    Freischaltcode einer SWaP Funktion übertragen,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 1454A8 1499A0 65E3492 DCF8D30 145470 5130D8 5130D8 5130D8 5130D8 5130D8 5130D8 5130D8 5130D8 5E9 1499A0 00 146670 00 5130D8 FA6D0F3F 146670 00 00 65E3485 07 FFFFFFFF 180 9C 722ECC8 728B610 417530 14593C 4D33DE 05 14594C 408FDB 1454F4 01 283 146670 1466E8 DCF8D84 5130D8 6D19B680 AAB65DD9 5130D8 6D1241E2 6D122E37 6D1225D0 14E 6D1226C2 00 14E 01 50334 01 01 01 01 FFFFFFFF 77179E47 7717A118 FFFFFFFF 14E 77BD4298 146 77BD4298 00 00 77BD4AF8 00 77BD4AF8 10 DCF8CE0 1000 C78B3BC5 1455A4 77195D93 50334 14E 14E 00 14E DCBAABCD 00 6D1225D0 14E 14563C 77179F3A FE698BA3 50334 14563C 7717A118 77179F5D DCF8F54 6D1225D0 50334 77179F8A 24 01 00 00 70 FFFFFFFF FFFFFFFF 77179E47 7717A118 6D1225D0 00 00 00 00 00 00 00 00 01 14E DCF8F54 284 DCF8F2C 145704 7719EE60 7AC59F50 FFFFFFFE 14566C 7717970E 50334 14E 14E 00 00 00 1466E8 50D4558 7717971B DCF8F04 14568C 4A0A9B FFFF02B3 50334 14E 14E 00 1466E8 1456A8 4A0BB5 14E 14E 00 1466E8 14E 145710 4A2EE5 14E 14E 4A2F3B FA6D0CFB 4A2F3E 50334 00 50372 113 05 00 00 00 00 4A6CD6 4A6BFB 4A721E 4A27C7 FFFFFFFF 14E 77BD4298 1457E4 4D0DED 00 4A2F3B 4A2F74 00 50334 14E 14E 14E 14E 14575C 77195D93 50334 14E 14E 00 14E DCBAABCD 00 4A2F3E 14E 1457F4 77179F3A FE6989EB 50334 1457F4 7717A118 77179F5D DCF8E9C 40000000 00 77179F8A 24 01 00 00 70 FFFFFFFF FFFFFFFF 77179E47 7717A118 4A2F3E 00 00 00 00 00 00 00 00 01 14E DCF8E9C 284 DCF8E94 145840 7719EE60 7AC59F50 FFFFFFFE 145850 77179D15 50334 14E 14E 00 55B638C 01 DCF8138 3B 77C32F40 00 00 00 50334 00 14E 145814 00 145890
    Transportmodus,nicht aktiv
    (1)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,200 ms
    (2)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,125000 ms
    (3)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,0 ms
    (4)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
    (5)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms
    (6)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms
    (7)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms
    (8)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100
    (9)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms
    (10)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,aktiv
    (1)-EM_energy_management_warning_displays-Generatormeldungen,Modus nicht aktiv
    (2)-EM_energy_management_warning_displays-Batteriemeldungen,Modus nicht aktiv
    (3)-EM_energy_management_warning_displays-MMI Vorwarnungen,Modus nicht aktiv
    (4)-EM_energy_management_warning_displays-Ladezustand,Modus nicht aktiv
    EM_nominal_voltage_limitation_low_beams,12.1 V
    EM_requirement_cyclic_time_voltage_measurement,0 s
    EM_requirement_reduction_air_blowers,Modus nicht aktiv
    (1)-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C
    (2)-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C
    (1)-GW_Enable_CAN_Timeout_DTC-Diagnoseinterface für Datenbus,freigeschaltet
    (2)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,freigeschaltet
    (3)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,freigeschaltet
    (4)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,freigeschaltet
    (5)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,freigeschaltet
    (6)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,freigeschaltet
    (7)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,freigeschaltet
    (8)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,freigeschaltet
    (9)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,freigeschaltet
    (10)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,freigeschaltet
    (11)-GW_Enable_CAN_Timeout_DTC-Einparkhilfe,freigeschaltet
    (12)-GW_Enable_CAN_Timeout_DTC-Reifendrucküberwachung,freigeschaltet
    (13)-GW_Enable_CAN_Timeout_DTC-Lenksäulenelektronik,freigeschaltet
    (14)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,freigeschaltet
    (15)-GW_Enable_CAN_Timeout_DTC-Elektronische Zentralelektrik,freigeschaltet
    (16)-GW_Enable_CAN_Timeout_DTC-Allradelektronik,freigeschaltet
    (17)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,freigeschaltet
    (18)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,freigeschaltet
    (19)-GW_Enable_CAN_Timeout_DTC-Lenkhilfe,freigeschaltet
    (20)-GW_Enable_CAN_Timeout_DTC-Bremsenelektronik,nicht freigeschaltet
    (21)-GW_Enable_CAN_Timeout_DTC-Schalttafeleinsatz,freigeschaltet
    (22)-GW_Enable_CAN_Timeout_DTC-Airbag,nicht freigeschaltet
    (23)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,freigeschaltet
    (24)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,freigeschaltet
    (25)-GW_Enable_CAN_Timeout_DTC-Radio,freigeschaltet
    (26)-GW_Enable_CAN_Timeout_DTC-Klimakompressor,freigeschaltet
    (27)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,freigeschaltet
    (28)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,freigeschaltet
    (29)-GW_Enable_CAN_Timeout_DTC-Aktuator für Körperschall,freigeschaltet
    (30)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,freigeschaltet
    (31)-GW_Enable_CAN_Timeout_DTC-Sperrenelektronik,freigeschaltet
    (32)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,freigeschaltet
    (33)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,freigeschaltet
    (34)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,freigeschaltet
    (35)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,freigeschaltet
    (36)-GW_Enable_CAN_Timeout_DTC-Heckdeckelelektronik,freigeschaltet
    (37)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,freigeschaltet
    (38)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,freigeschaltet
    (39)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,freigeschaltet
    (40)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,freigeschaltet
    (41)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,freigeschaltet
    (42)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,freigeschaltet
    (43)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,freigeschaltet
    (44)-GW_Enable_CAN_Timeout_DTC-Sonderfunktion 2,freigeschaltet
    (45)-GW_Enable_CAN_Timeout_DTC-Sonderfunktion,freigeschaltet
    (46)-GW_Enable_CAN_Timeout_DTC-Elektrische Dachbetätigung,freigeschaltet
    (47)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,freigeschaltet
    (48)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,freigeschaltet
    (49)-GW_Enable_CAN_Timeout_DTC-Fernlichtassistent,freigeschaltet
    (50)-GW_Enable_CAN_Timeout_DTC-Lenksäulenverriegelung,freigeschaltet
    (51)-GW_Enable_CAN_Timeout_DTC-Interface für Zugang- und Startsystem,freigeschaltet
    (52)-GW_Enable_CAN_Timeout_DTC-Schiebetür hinten links,freigeschaltet
    (53)-GW_Enable_CAN_Timeout_DTC-Schiebetür hinten rechts,freigeschaltet
    (54)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,freigeschaltet
    (55)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,freigeschaltet
    (56)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,freigeschaltet
    (57)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,freigeschaltet
    (58)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,freigeschaltet
    (59)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,freigeschaltet
    (60)-GW_Enable_CAN_Timeout_DTC-Bremskraftverstärkung,freigeschaltet
    (61)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,freigeschaltet
    (62)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,freigeschaltet
    (63)-GW_Enable_CAN_Timeout_DTC-Türelektronik Fahrerseite hinten,freigeschaltet
    (64)-GW_Enable_CAN_Timeout_DTC-Türelektronik Beifahrerseite hinten,freigeschaltet
    (65)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,freigeschaltet
    (66)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,freigeschaltet
    (67)-GW_Enable_CAN_Timeout_DTC-Thermomanagement,freigeschaltet
    (68)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,freigeschaltet
    (69)-GW_Enable_CAN_Timeout_DTC-Hochvolt-Batterieladegerät,freigeschaltet
    (70)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,freigeschaltet
    (71)-GW_Enable_CAN_Timeout_DTC-Klima-/ Heizungselektronik,freigeschaltet
    (72)-GW_Enable_CAN_Timeout_DTC-Anhängerfunktion,freigeschaltet
    (73)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,freigeschaltet
    (74)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,freigeschaltet
    (75)-GW_Enable_CAN_Timeout_DTC-Türelektronik Fahrer,freigeschaltet
    (76)-GW_Enable_CAN_Timeout_DTC-Türelektronik Beifahrer,freigeschaltet
    (77)-GW_Enable_CAN_Timeout_DTC-Sitzverstellung Fahrerseite,freigeschaltet
    (78)-GW_Enable_CAN_Timeout_DTC-Sitzverstellung Beifahrerseite,freigeschaltet
    (79)-GW_Enable_CAN_Timeout_DTC-Spurwechselassistent,freigeschaltet
    (80)-GW_Enable_CAN_Timeout_DTC-Frontsensorik für Fahrerassistenzsysteme,freigeschaltet
    (81)-GW_Enable_CAN_Timeout_DTC-Fahrzeuglageerkennung,freigeschaltet
    (82)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,freigeschaltet
    (83)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,freigeschaltet
    (84)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,freigeschaltet
    (85)-GW_Enable_CAN_Timeout_DTC-Leuchtweitenregelung,freigeschaltet
    (86)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,freigeschaltet
    (87)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,freigeschaltet
    (88)-GW_Enable_CAN_Timeout_DTC-Distanzregelung,freigeschaltet
    (89)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,freigeschaltet
    (90)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,freigeschaltet
    (91)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,freigeschaltet
    (92)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,freigeschaltet
    (93)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,freigeschaltet
    (94)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,freigeschaltet
    (95)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,freigeschaltet
    (96)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,freigeschaltet
    (97)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,freigeschaltet
    (98)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,freigeschaltet
    (99)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,freigeschaltet
    (100)-GW_Enable_CAN_Timeout_DTC-Mikrofonsteuergerät,freigeschaltet
    (101)-GW_Enable_CAN_Timeout_DTC-Aktuator für Aussengeräusch,freigeschaltet
    (102)-GW_Enable_CAN_Timeout_DTC-Hochvolt-Batterielademanagement,freigeschaltet
    (103)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,freigeschaltet
    (104)-GW_Enable_CAN_Timeout_DTC-Notrufmodul und Kommunikationseinheit,freigeschaltet
    (105)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,freigeschaltet
    (106)-GW_Enable_CAN_Timeout_DTC-Rückfahrkamerasystem,freigeschaltet
    (107)-GW_Enable_CAN_Timeout_DTC-Zu-/ Standheizung,freigeschaltet
    (108)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,freigeschaltet
    (109)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,freigeschaltet
    (110)-GW_Enable_CAN_Timeout_DTC-TV-Tuner,freigeschaltet
    (111)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,freigeschaltet
    (112)-GW_Enable_CAN_Timeout_DTC-Soundsystem,freigeschaltet
    (113)-GW_Enable_CAN_Timeout_DTC-Media Player 1,freigeschaltet
    (114)-GW_Enable_CAN_Timeout_DTC-Fahrtenschreiber,freigeschaltet
    (115)-GW_Enable_CAN_Timeout_DTC-Raddämpfungselektronik,freigeschaltet
    (116)-GW_Enable_CAN_Timeout_DTC-Informationselektronik 1,freigeschaltet
    (117)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,freigeschaltet
    (118)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,freigeschaltet
    (119)-GW_Enable_CAN_Timeout_DTC-Motorelektronik,freigeschaltet
    (120)-GW_Enable_CAN_Timeout_DTC-Getriebeelektronik,freigeschaltet
    (121)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,freigeschaltet
    (122)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,freigeschaltet
    (123)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,freigeschaltet
    (124)-GW_Enable_CAN_Timeout_DTC-Hybrid Batteriemanagement,freigeschaltet
    (125)-GW_Enable_CAN_Timeout_DTC-Elektroantrieb,freigeschaltet
    (126)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,freigeschaltet
    (127)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,freigeschaltet
    (128)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,freigeschaltet
    (129)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,freigeschaltet
    (130)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,freigeschaltet
    (131)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,freigeschaltet
    (132)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,freigeschaltet
    (133)-GW_Enable_CAN_Timeout_DTC-Steuergerät für Schiebedach,freigeschaltet
    (134)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,freigeschaltet
    (135)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,freigeschaltet
    (136)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,freigeschaltet
    (137)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,freigeschaltet
    (138)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,freigeschaltet
    (139)-GW_Enable_CAN_Timeout_DTC-Steuergerät 2 für Spurwechselassistent,freigeschaltet
    (140)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,freigeschaltet
    (141)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,freigeschaltet
    (142)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,freigeschaltet
    (143)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,freigeschaltet
    (144)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,freigeschaltet
    (145)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,freigeschaltet
    (146)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,freigeschaltet
    (147)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,freigeschaltet
    (148)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,freigeschaltet
    (149)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,freigeschaltet
    (150)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,freigeschaltet
    (151)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,freigeschaltet
    (152)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,freigeschaltet
    (153)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,freigeschaltet
    (154)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,freigeschaltet
    (155)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,freigeschaltet
    (156)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,freigeschaltet
    (157)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,freigeschaltet
    (158)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,freigeschaltet
    (159)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,freigeschaltet
    (160)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,freigeschaltet
    (161)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,freigeschaltet
    (162)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,freigeschaltet
    (163)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,freigeschaltet
    (164)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,freigeschaltet
    (165)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,freigeschaltet
    (166)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,freigeschaltet
    (167)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,freigeschaltet
    (168)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,freigeschaltet
    (169)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,freigeschaltet
    (170)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,freigeschaltet
    (171)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,freigeschaltet
    (172)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,freigeschaltet
    (173)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,freigeschaltet
    (174)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,freigeschaltet
    (175)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,freigeschaltet
    (176)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,freigeschaltet
    (177)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,freigeschaltet
    (178)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,freigeschaltet
    (179)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,freigeschaltet
    (180)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,freigeschaltet
    (181)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,freigeschaltet
    (182)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,freigeschaltet
    (183)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,freigeschaltet
    (184)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,freigeschaltet
    (185)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,freigeschaltet
    (186)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,freigeschaltet
    (187)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,freigeschaltet
    (188)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,freigeschaltet
    (189)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,freigeschaltet
    (190)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,freigeschaltet
    (191)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,freigeschaltet
    (192)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,freigeschaltet
    (193)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,freigeschaltet
    (194)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,freigeschaltet
    (195)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,freigeschaltet
    (196)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,freigeschaltet
    (197)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,freigeschaltet
    (198)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,freigeschaltet
    (199)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,freigeschaltet
    (200)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,freigeschaltet
    (201)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,freigeschaltet
    (202)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,freigeschaltet
    (203)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,freigeschaltet
    (204)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,freigeschaltet
    (205)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,freigeschaltet
    (206)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,freigeschaltet
    (207)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,freigeschaltet
    (208)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,freigeschaltet
    (209)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,freigeschaltet
    (210)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,freigeschaltet
    (211)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,freigeschaltet
    (212)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,freigeschaltet
    (213)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,freigeschaltet
    (214)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,freigeschaltet
    (215)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,freigeschaltet
    (216)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,freigeschaltet
    (217)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,freigeschaltet
    (218)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,freigeschaltet
    (219)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,freigeschaltet
    (220)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,freigeschaltet
    (221)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,freigeschaltet
    (222)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,freigeschaltet
    (223)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,freigeschaltet
    (224)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,freigeschaltet
    (225)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,freigeschaltet
    (226)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,freigeschaltet
    (227)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,freigeschaltet
    (228)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,freigeschaltet
    (229)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,freigeschaltet
    (230)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,freigeschaltet
    (231)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,freigeschaltet
    (232)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,freigeschaltet
    (233)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,freigeschaltet
    (234)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,freigeschaltet
    (235)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,freigeschaltet
    (236)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,freigeschaltet
    (237)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,freigeschaltet
    (238)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,freigeschaltet
    (239)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,freigeschaltet
    (240)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,freigeschaltet
    (241)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,freigeschaltet
    (242)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,freigeschaltet
    (243)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,freigeschaltet
    (244)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,freigeschaltet
    (245)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,freigeschaltet
    (246)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,freigeschaltet
    (247)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,freigeschaltet
    (248)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,freigeschaltet
    (249)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,freigeschaltet
    (250)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,freigeschaltet
    (251)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,freigeschaltet
    (252)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,freigeschaltet
    (253)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,freigeschaltet
    (254)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,freigeschaltet
    (255)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,freigeschaltet
    (256)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,freigeschaltet
    (1)-GW_mirror_mode-mirror_mode_typ,nicht aktiv
    (2)-GW_mirror_mode-mirror_mode_bus,Datenbus Antrieb
    GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00
    GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00
    (1)-Multi_function_steering_wheel_control_module Coding Value-Tiptronic,nicht verbaut
    (2)-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor,nicht verbaut
    (3)-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VW,GRA-High
    (4)-Multi_function_steering_wheel_control_module Coding Value-development_1,aktiv
    (5)-Multi_function_steering_wheel_control_module Coding Value-development_2,nicht aktiv
    WakeUpMonitor_Activation,aktiviert
    (1)-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
    (2)-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
    (3)-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
    Jun 2016
    New Gateway
    SW:5Q0-907-530-AC   HW:5Q0-907-530-F ---  Diagnoseinterface
    	Bauteil:GW MQB High   128 1203, Codierung:030100042B086400EF000648080F00010001000000000000000000000000
    	EV_GatewLear,011020,EV_GatewLear.rod
    	Freitag,03,Juni,2016,15:11:51:42750
    (2)-Batterieanpassung-Batterietechnologie,Vlies
    Zyklisierungsgrenze Anforderung Batterieservice,0
    (8)-Anzeige für Effizienzprogramm-Livetipp Fahrstufe D verwenden,nicht aktiviert
    (20)-Anzeige für Effizienzprogramm-Komfortverbrauch Nebelschlusslicht,nicht aktiviert
    MKE Checkbox,aktiviert
    Produktionsprozessdaten 1,00 40
    (1)-Reichweitengewinn-Reichweitengewinn Klimaanlage,aktiviert
    (2)-Reichweitengewinn-Reichweitengewinn Standheizung,aktiviert
    (3)-Reichweitengewinn-Reichweitengewinn Heckscheibenheizung,aktiviert
    (4)-Reichweitengewinn-Reichweitengewinn Sitzheizung vorn,aktiviert
    (5)-Reichweitengewinn-Reichweitengewinn Sitzlüftung vorn,aktiviert
    (6)-Reichweitengewinn-Reichweitengewinn Nackenheizung,aktiviert
    (7)-Reichweitengewinn-Reichweitengewinn Nebellicht,aktiviert
    (8)-Reichweitengewinn-Reichweitengewinn Nebelschlusslicht,aktiviert
    (9)-Reichweitengewinn-Reichweitengewinn Frontscheibenheizung,aktiviert
    (10)-Reichweitengewinn-Reichweitengewinn Lenkradheizung,aktiviert
    (11)-Reichweitengewinn-Reichweitengewinn Spiegelheizung,aktiviert
    (12)-Reichweitengewinn-Reichweitengewinn Sitzheizung hinten,aktiviert
    (13)-Reichweitengewinn-Reichweitengewinn Sitzlüftung hinten,aktiviert
    (14)-Reichweitengewinn-Anzeige Katalogreichweite,aktiviert
    (15)-Reichweitengewinn-Anzeige Ladezustand-Katalogreichweite,aktiviert
    (16)-Reichweitengewinn-Frontscheibenheizungsverbrauch in Klimaanlage,aktiviert
    (17)-Reichweitengewinn-Frontscheibenheizungsreichweitengewinn in Klimaanlage,aktiviert
    (18)-Reichweitengewinn-PTC(Niedervolt)-Verbrauch,aktiviert
    (19)-Reichweitengewinn-PTC(Niedervolt)-Reichweitengewinn,aktiviert
    (20)-Reichweitengewinn-Liste bei Motorstillstand,aktiviert
    (21)-Reichweitengewinn-Listendarstellung Absolutwerte mit Gewichtung,aktiviert
    Start/Stopp Startspannungsgrenze,7.6 V
    Freischaltcode einer SWaP Funktion übertragen,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 145478 149970 65C34F5 522E0B11 145440 5130D8 5130D8 5130D8 5130D8 5130D8 5130D8 5130D8 5130D8 5E9 149970 00 146640 00 5130D8 C2345FC7 146640 00 00 65C34E8 07 FFFFFFFF 180 9C 84E4BB8 8514FA0 417530 14590C 4D33DE 05 14591C 408FDB 1454C4 01 283 146640 1466B8 522E0B85 5130D8 6D19B680 F53EF929 5130D8 6D1241E2 6D122E37 6D1225D0 14E 6D1226C2 00 14E 01 50338 01 01 01 01 FFFFFFFF 77179E47 7717A118 FFFFFFFF 14E 77BD4298 146 77BD4298 00 00 77BD4AF8 00 77BD4AF8 10 522E0A61 1E 98039EC5 145574 77195D93 50338 14E 14E 00 14E DCBAABCD 00 6D1225D0 14E 14560C 77179F3A 28EEBFFB 50338 14560C 7717A118 77179F5D 522E0935 6D1225D0 50338 77179F8A 24 01 00 00 70 FFFFFFFF FFFFFFFF 77179E47 7717A118 6D1225D0 00 00 00 00 00 00 00 00 01 14E 522E0935 284 522E092D 1456D4 7719EE60 25241901 FFFFFFFE 14563C 7717970E 50338 14E 14E 00 00 00 1466B8 4FE1E38 7717971B 522E0905 14565C 4A0A9B FFFF040D 50338 14E 14E 00 1466B8 145678 4A0BB5 14E 14E 00 1466B8 14E 1456E0 4A2EE5 14E 14E 4A2F3B C2345D83 4A2F3E 50338 00 602EE 113 05 00 00 00 00 4A6CD6 4A6BFB 4A721E 4A27C7 FFFFFFFF 14E 77BD4298 1457B4 4D0DED 00 4A2F3B 4A2F74 00 50338 14E 14E 14E 14E 14572C 77195D93 50338 14E 14E 00 14E DCBAABCD 00 4A2F3E 14E 1457C4 77179F3A 28EEBC33 50338 1457C4 7717A118 77179F5D 522E08FD 40000000 00 77179F8A 24 01 00 00 70 FFFFFFFF FFFFFFFF 77179E47 7717A118 4A2F3E 00 00 00 00 00 00 00 00 01 14E 522E08FD 284 522E08F5 145810 7719EE60 25241901 FFFFFFFE 145820 77179D15 50338 14E 14E 00 55C4EAC 01 522E0719 3B 77C32F40 00 00 00 50338 00 14E 1457E4 00 145860
    (1)-AGW_Calibration-AGW_Time_Fade_In,0 ms
    (2)-AGW_Calibration-AGW_Time_Fade_Out,0 ms
    (3)-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms
    (4)-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms
    (5)-AGW_Calibration-AGW_Time_Start_Sequence,0 ms
    (6)-AGW_Calibration-AGW_Time_Start_Delay,0 ms
    (7)-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %
    (8)-AGW_Calibration-AGW_fade_in_deactivation_threshold,100
    (1)-AGW_Function_Releases-AGW_Enabling_Brightness,aktiv
    (2)-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,aktiv
    (3)-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,aktiv
    (1)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms
    (2)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,1000 ms
    (1)-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,14 s
    Hmm, comparing your adaptation channel list, I get this:
    http://ross-tech.net/Temp/3A546880BDF967EE70.html
    But I don't see anything obvious that would explain it there.
    Jun 2016
    Hello Uwe,
    Thanks for your replay, when i disable the option comfort user options the error wont come back. Byte 19 bit 1.
    the tekst on the infotainment comfort users olso gone.
    Maybe this have to doo with this options bellow.
    because i have olso see that this was not enebaled on many cars.
    (1)-Reichweitengewinn-Reichweitengewinn Klimaanlage,aktiviert (2)-Reichweitengewinn-Reichweitengewinn Standheizung,aktiviert (3)-Reichweitengewinn-Reichweitengewinn Heckscheibenheizung,aktiviert (4)-Reichweitengewinn-Reichweitengewinn Sitzheizung vorn,aktiviert (5)-Reichweitengewinn-Reichweitengewinn Sitzlüftung vorn,aktiviert (6)-Reichweitengewinn-Reichweitengewinn Nackenheizung,aktiviert (7)-Reichweitengewinn-Reichweitengewinn Nebellicht,aktiviert (8)-Reichweitengewinn-Reichweitengewinn Nebelschlusslicht,aktiviert (9)-Reichweitengewinn-Reichweitengewinn Frontscheibenheizung,aktiviert (10)-Reichweitengewinn-Reichweitengewinn Lenkradheizung,aktiviert (11)-Reichweitengewinn-Reichweitengewinn Spiegelheizung,aktiviert (12)-Reichweitengewinn-Reichweitengewinn Sitzheizung hinten,aktiviert (13)-Reichweitengewinn-Reichweitengewinn Sitzlüftung hinten,aktiviert (14)-Reichweitengewinn-Anzeige Katalogreichweite,aktiviert (15)-Reichweitengewinn-Anzeige Ladezustand-Katalogreichweite,aktiviert (16)-Reichweitengewinn-Frontscheibenheizungsverbrauch in Klimaanlage,aktiviert (17)-Reichweitengewinn-Frontscheibenheizungsreichweitengewinn in Klimaanlage,aktiviert (18)-Reichweitengewinn-PTC(Niedervolt)-Verbrauch,aktiviert (19)-Reichweitengewinn-PTC(Niedervolt)-Reichweitengewinn,aktiviert (20)-Reichweitengewinn-Liste bei Motorstillstand,aktiviert (21)-Reichweitengewinn-Listendarstellung Absolutwerte mit Gewichtung,aktiviert
    Oct 2014
    Singapore
    I am planning to upgrade my Golf 7's Gateway Mid to the High version. I was told that the new MBQ Gateway must be "Activate" online via ODIS. This is something that VCDS may not be able to do.....unless I am missing something.
    The same "activate" must be done for most of the main components. Hope VCDS can come up with a solution for this....
  7. #7
    Jun 2016
    Quote Originally Posted by cbx750p View Post
    that's true must be Activate online with Odis ore a similar program from VW.
    VCDS ore other software will never get this option, because have to do with component protection.
  8. #8
    Jun 2016
    Hello All,
    I have a guestion about the adaptation setting on the gateway
    I want to put this gateway back in my car but i want to now can i change this valeu with 17.1.3 vcds.
    When its possible maybe the fehler go away!
    Because on that time 15.7.4 vcds it was not possible.
    In my car some of this setting are wrong when a compare other VW Golf 7.
    On my car this setting are activated!
    IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system not activated
    IDE10748-MAS11277-Range gain-PTC(low voltage) consumption not activated
    IDE10748-MAS11279-Range gain-List at engine still stand not activated
    I only want a confirmation if its possible CAN SOMEBODY test it for me.
    I dont want to swap when its not possible.
  9. #9
    Jun 2016
    Hello All,
    PLease i need your help. Cany anyone test for me if its possible to change this valeus activated / not activated.
    The gateway on the Golf 7 its on a verry difficult place to take it out i just want to do this if its possible.
  10. #10
    Jun 2016
    Hello All,
