Results 1 to 10 of 12
Thread: Coding Radio for Aux Input, 2006 Jetta TDI
    Jun 2014
    Hi All, My first post here.
    I have a 2006 Jetta TDI that came with an AUX input jack mounted just below the radio. I bought the car used and the AUX has never worked. I found on TDIclub forum that I should change the radio coding from 0040400 to 0040401 to enable the AUX. When I try that code i get an error 31 that the code is invalid. in the Coding helper screen on VCDS it suggest the coding should be 0040402. I have tried that coding, and while it will accept that code, the AUX still does not work, and I get an error code set by the radio module (00857) having to do with the nonexistent cd changer. Any I deas on what I am doing wrong? Picture attached.
    Thanks,
    Todd
    Tartu, Estonia
    Double press CD button, and you should get AUX.
    The world is my oyster...
    Jun 2014
    Sorry I should have stated in the original post that I have pressed the CD button twice, and held it down for a few seconds everything I can think of. It tells me there is no CD, AUX does not function.
    Tartu, Estonia
    I have RCD300
    http://i1.ytimg.com/vi/-4u0sjJ0tkg/hqdefault.jpg
    The coding matches yours. I think, if currently you can't access aux menu, you don't have any possibility to access it. The +2 means you have a cd changer somewhere.
    I think you should buy CD emulator for USB and AUX connection.
    http://upload.ecvv.com/upload/Produc...8171211095.jpg
    Jun 2014
    I'm assuming the AUX did work at some point. I just want to get it working again. I don't want to have to buy something else to get a working AUX input. If I can't get this one working I'll just do without. I only tried the +2 because it says ipod on it.
    Lansdale, PA
    What values do you have listed under workshop code, and importer number?
    Can you post a scan so we can see more information about the radio.
  7. #7
    Jun 2014
    Quote Originally Posted by Santos View Post
    Please let me know if you need anything else.
    Tuesday,10,June,2014,20:32:20:06155
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN:    License Plate: EMILY
    Gateway Installation List:  1K0 907 530 F
    46-Central Conv. -- Status: Sporadic communication error 1000
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWST81K46M695763   Mileage: 303320km/188474miles
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AB    HW: 028 101 223 8
       Component: R4 1,9L EDC G000SG  7550
       Revision: --H01---    Serial number: VWZ7Z0E2664665
       Coding: 0050071
       Shop #: WSC 66565 257 00032
       VCID: 63C56DB7A24DB306E65-8036
       Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
       Revision: 00T12001
       Coding: 0021122
       VCID: 408F823B139BC81EDB7-8015
       Part No: 1K0 820 047 DL
       Component: Climatic PQ35   090 0505
       VCID: 71E917FF68B11196649-8024
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000182606
       Coding: 14018E234004180000140000001400000008730B5C
       Shop #: WSC 07134 444 00070
       VCID: 2A5BC09385E7224EE53-807F
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0402
       Coding: 00065493
       Shop #: WSC 07134
    00834 - Signal for Activation of Heated Rear Window
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 200
                        Mileage: 296649 km
                        Voltage: 14.35 V
                        Reset counter: 224
                        Mileage: 303013 km
                        Voltage: 12.55 V
    00975 - Heated Rear Window (Z1)
                        Fault Status: 01111100
                        Reset counter: 200
                        Mileage: 296646 km
                        Voltage: 14.35 V
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
       Component: SDAR XM         H03 0080
       Revision: 00000000    Serial number: AUZ4Z7E0033192
       VCID: 2B55C5978A1D3B461E5-807E
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 140
                        Mileage: 247889 km
                        Time: 02:11:54
    02788 - Internal Communications Error
                        Fault Frequency: 103
                        Reset counter: 240
                        Mileage: 302957 km
                        Time: 06:45:39
                        Bin. Bits: 00000010
                        Bin. Bits: 00000000
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1R AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD044XMK
       Coding: 0012626
       VCID: 2E53CC83B90F4E6E39B-807B
       Subsystem 1 - Part No: 1K0 959 339 E
       Component: BF-Gewichtsens. 006 0005
       Subsystem 2 - Serial number: 6332MSME0B206B49E
       Subsystem 3 - Serial number: 6342MSME0B1B4C18K
       Subsystem 4 - Serial number: 6351HSME083F43123
       Subsystem 5 - Serial number: 6361HSME08320E4A9
       Subsystem 6 - Serial number: 63727SME073E4F6EN
       Subsystem 7 - Serial number: 63827SME0762444F3
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           034 0070
       Coding: 0000021
       VCID: 78FF2ADB0BCB40DEA37-802D
       Part No: 1K0 920 952 D
       Component: KOMBIINSTRUMENT 3HL 1212
       Coding: 0023203
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 2800105815838C
       Coding: 3D3F0B60071002
                        Reset counter: 224
                        Mileage: 303013 km
                        Time: 08:41:59
       Component: IMMO            3HL 1212
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2377
       Coding: 0001269
       VCID: 3663E4E3415F76AE71B-8063
       Part No: 1K1 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 326BD8F3AD376A8E5D3-8067
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AF
       Coding: 1A7803083F2D0505480F048051A0
       Shop #: WSC 00066 123 12345
       VCID: 74E71EEB17A324BE8FF-8021
       Part No: 1K0 959 702 K
       Coding: 0001269
       VCID: 377DE9E746558FA66AD-8062
       Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
       Component: Radio ZSW       016 0017
       Revision: 00016000    Serial number: VWZ5Z7E6012354
       Coding: 0040400
       VCID: 204F22BBF3DBE81EBB7-8075
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2434
       Coding: 0000144
       VCID: 3169D7FFA8315196249-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
       Revision: 00800000    Serial number:
       VCID: 2D51CB8FB4093576001-8078
  8. #8
    Lansdale, PA
    Some modules will reject coding due to Zero'd importer number and equipment number.
    Try the following info:
    Soft coding:0040401
    workshop code: 00066
    importer number: 444
    Equipment Number: 12345
  9. #9
    Jun 2014
    Soft coding:0040401
    I tried this:
    Still the same error.
  10. #10
    Lansdale, PA
    Have you looked at the wiring for the AUX port? I do not remember any MKV Jetta with an Aux port below the radio. Usually they are routed to the glove box or the arm rest.
    I also found:
    Quote Originally Posted by http://forums.tdiclub.com/showpost.php?p=3834831&postcount=2 User Fixmy59bug
    Then there was 2 versions of the upgraded Premium 7. Why it has the same name, I do not know. It is completely different. It has a built in 6 disc changer. It has 4 buttons on the Left of the screen, 2 larger buttons on the right, 6 buttons below the screen, and 5 knobs below the buttons.
    The first version is the all black button version. The button left button should say MIX. If it does, This radio does not support an AUX in.
    The second version is a Silver Button Version. This version will have a SAT button on the bottom left. This radio DOES support an AUX in. This is the one you want.
    Which version do you have? I suspect you will need an aftermarket aux/ipod solution.
