- Joined
- Apr 9, 2014
- Messages
- 2,303
- Reaction score
- 2,250
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Hello.
I'm upgrading current Bluetooth module to 3c8... D version with hotspot version.
Will the keyboard remain working or should i disconnect it, as I've heard it may cause battery drain.
And yes, it's bit old scan, but i don't have newer scan. And Yes, i know the 3c8 module is BAP, for that the white clocks are coming approx the same time as the new module for bluetooth.
Sunday,16,February,2014,12:19:08:01666
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ3CZ8E194348 License Plate: WORLDONFIRE
Mileage: 190520km-118383mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 55 56 5D 62 72
76 77
VIN: WVWZZZ3CZ8E194348 Mileage: 190520km/118383miles
5D-Operations -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EM HW: 03G 906 018 EM
Component: R4 2.0l PPD1.2 G 4369
Revision: --H52--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 27928 141 87345
VCID: 74E72E9517BDADBE80B-8021
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
Component: J104 C4 440 V1 0003
Revision: --020--- Serial number: 00000776640808
Coding: 0000282
Shop #: WSC 05311 000 00000
VCID: 1E332C3DC9B157EE86F-804B
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
VCID: 63C55DC9A2533A06E91-8036
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 01000008094723
Coding: EF0A8F0700041A00470000000F000000801B5D435C000100000000000000
Shop #: WSC 05124 123 12345
VCID: 71E9278168AF98966BD-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 280108 003 0205
Coding: 00049045
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 260208 046 0204
Coding: 00471077
Shop #: WSC 05124
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP36XVHB
Coding: 0012341
VCID: 3B75C5A97A6322C6811-806E
Subsystem 1 - Serial number: 6333FTS603550368
Subsystem 2 - Serial number: 6343FTS646170118
Subsystem 3 - Serial number: 6353ETS6VBRHSVNH
Subsystem 4 - Serial number: 6363ETS61POHSVNH
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AT
Coding: 0000312
VCID: 6FED21F97E9B8E667D9-803A
Component: E0221 002 0010
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 27928 141 81929
VCID: 264304DD91E18F2ECEF-8073
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0822001A7
Coding: F9817F0E4026022002
VCID: 23451DC9E2D37A06A91-8076
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 3979DFA1705F10D693D-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 37: Navigation Labels: 1K0-035-191.lbl
Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
Component: J401 0303
Revision: 00018000 Serial number: VWZ1Z2H8044242
Coding: 0043400
Shop #: WSC 05314 000 00000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000100188211
Coding: 0000247
VCID: 3C77C6B57F6D25FE88B-8069
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3561D3915C47F4B6775-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 009102005103407F3F02941D70084F0E707C41
Shop #: WSC 14149 123 104857
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000626188203
Coding: 0000246
VCID: 3D71CBB164772CF6BF5-8068
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000360920
Coding: 0000056
VCID: 29590FE180FFA056E3D-807C
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 B HW: 5M0 907 357 B
Component: AFS-Steuergeraet X024
Revision: 00H01000 Serial number:
Coding: 2311169
VCID: 3365ED895233EA86591-8066
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
Address 56: Radio Labels: 1K0-035-191.lbl
Component: R 0303
Coding: 0043400
Address 5D: Operations Labels: 3C0-035-151.lbl
Part No SW: 3C0 035 151 C HW: 3C0 035 151 C
Component: J738 011 0019
Revision: 00011000
VCID: 183F3A252B9529DE4C3-804D
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000233246
Coding: 0000208
VCID: 70EF228563A5919E643-8025
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000243464
Coding: 0000208
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90640805304266
Coding: 0000024
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 HW: 5N0 035 730
Component: Telefon 2510
Revision: 00011000 Serial number: 0000000058806
Coding: 0020055
VCID: E5C1C3D12C67C436875-80B0
End ---------------------------------------------------------------------
