I have been using a HEX-CAN for years professionally, and due to the continued stress/failure on usb ports as well as convenience of wireless, decided HEX-NET was the way to go. I have owned the tool almost 2 weeks now, and have used on at least 20 vehicles.
Computer is an ACER Aspire V5. (cheap, but for shop use only, does what it needs to do)
When using the HEX-NET in infrastructure mode (IN SHOP), it works flawlessly. Auto scans are lightning fast, and can be done with the laptop on my tool box!
When using wifi mode (outside of shop), I experience some issues:
- Sporadic error messages "interface not initialized"
- Multiple connection attempts to connect to a control module
- MVB continually freeze, even when not reading data
- Complete freezing of VCDS, forced to kill VCDS and re-open
Things I have checked:
- Uninstalled/re-installed newest version of VCDS
- WIFI signal shows to be full strength from interface. (laptop is usually in passenger seat, or in my lap in drivers seat)
- Has been tried in multiple vehicles
- Exempted all processes from C:\VCDS in Windows defender
- Tried using Options>Test. Sometimes will not connect. Sometimes will give OK, then hardly connect to control module.
I am not using the Cloud based services, as the laptop does not have internet access when out of the shop, hence the reason for using wifi mode and not infrastructure mode. I have also not tried using the cable, as the hex-net was purchased to cease direct USB connections. I only have 1 reliable USB port left!
Any ideas are greatly appreciated. If anything else is needed, please let me know. Thank you in advance!
1st scan is with infrastructure, 2nd is over wifi. Oddly enough, the scan looks good, time is great. Unfortunately does not show any of the issues I have experienced.
Sunday,12,June,2016,14:03:24:23112
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: 3VWPG31C69M502250 License Plate:
Mileage: 231330km-143741mi Repair Order:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWPG31C69M502250 Mileage: 231330km-143741miles
Address 01: Engine (BPR) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 CK HW: 07K 906 032 AA
Component: NB R5 AT G 3414
Revision: 1SH04--- Serial number: VWX5Z0H6147126
Coding: 0000003
VCID: F4A492B797E1E79EEA-80A0
P0300 - 001 - - Intermittent
Fault Status: 00100001
Mileage: 231155 km
RPM: 1496 /min
Load: 86.6 %
Speed: 39.0 km/h
Temperature: 99.0°C
Temperature: 61.0°C
Absolute Pres.: 940.0 mbar
Voltage: 13.589 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - Intermittent
Mileage: 231155 km
RPM: 1496 /min
Load: 86.6 %
Speed: 39.0 km/h
Temperature: 99.0°C
Temperature: 61.0°C
Voltage: 13.589 V
Part No SW: 09G 927 750 JT HW: 09G 927 750 JT
Component: AQ 250 6F 1380
Revision: 00H77000 Serial number:
Coding: 0000008
VCID: 8C54EA57EE119F5E92-5184
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 Q
Coding: 0019978
VCID: B83C6687CA0943FE06-5184
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 AK
Component: 01 AIRBAG VW71 0911
Coding: 0012337
VCID: 804CCE67D759CB3EFE-80D4
Subsystem 1 - Component: BF-Gewichtsens.
Address 17: Instruments Labels: None
Part No: 1C0 920 801 L
Component: KOMBI+WEGFAHRS. M73 V05
Coding: 11234
Shop #: WSC 00066
VCID: A404A2F73681371EBA-4B3C
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN V052
Coding: 00006
Shop #: WSC 00066
VCID: F0AC9EA7B2F9DBBE0E-4B3C
Address 25: Immobilizer Labels: 1C0-920-xxx-25.clb
Part No SW: 1C0 920 801 L HW: 1C0 920 801 L
Component: IMMO X007
Revision: xxxxxxxx Serial number: VWX5Z0H6147126
Shop #: WSC 24330 444 54723
VCID: A404A2F76681371EBA-5184
Address 35: Centr. Locks Labels: 1C0-962-258-III.lbl
Part No: 1C0 962 258 AC
Component: 4G Zentr.Verriegel. 0004
Coding: 00016
Shop #: WSC 00066
VCID: E89CF6C78A29137E56-4B3C
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 196 CK
Component: RADIO DE2 0006
Coding: 00401
Shop #: WSC 00066
VCID: EA988CCF9425216E40-51F2
Address 65: Tire Pressure Labels: None
Part No SW: 1C0 907 273 HW: 1C0 907 273
Component: RDK H02 0220
Revision: --H02-D0 Serial number: 12830781038330
Coding: 0100101
VCID: E08CEEE733196B3E9E-80B4
End-------------------------(Elapsed Time: 05:52)--------------------------
Sunday,12,June,2016,16:23:28:23112
Coding: 0000003
Mileage: 231155 km
RPM: 1496 /min
Load: 86.6 %
Speed: 39.0 km/h
Temperature: 99.0°C
Temperature: 61.0°C
Voltage: 13.589 V
000773 - Cylinder 5
Mileage: 231155 km
RPM: 1496 /min
Load: 86.6 %
Speed: 39.0 km/h
Temperature: 99.0°C
Temperature: 61.0°C
Voltage: 13.589 V
Coding: 0000008
Coding: 0019978
Coding: 0012337
Coding: 11234
Shop #: WSC 00066
Coding: 00006
Shop #: WSC 00066
Coding: 00016
Shop #: WSC 00066
Coding: 00401
Shop #: WSC 00066
Coding: 0100101
End-------------------------(Elapsed Time: 06:43)--------------------------
