Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 69
Thread: VW Golf 7 Instrument cluster retrofit to Premium 1 fault
  1. #21
    May 2014
    barstanders: I know that the tweak for fixing the situation in some later models of NAR mk7s where the dash lights don't illuminate when the rotary light switch is on the "parker" position is changing (1)-Illumination_algorithm-Scale_switching_algorithm from parking light to lds.
    I'm aware of quite a few drivers in the US that have successfully implemented this tweak (using 25327). So at least this channel is accessable in these cars
  2. #22
    Jun 2016
    Hello DV52,
    My cars dash lights illuminate when the rotary light switch is on the "parker" position.
    I cant change it with 15.7.4 maybe the beta version 16.6 will do this
    Can anyone confirm that this can be changed with beta.
  3. #23
    May 2014
    Quote Originally Posted by barstanders View Post
    Hello DV52,
    barstanders: OK - just checked my car which has the following instrument control module
    Part No SW: 5G0 920 860 HW: 5G0 920 860
    Component: KOMBI 235 0555
    Coding: 27A501082380800801087E00040000
    Shop #: WSC 00028 028 00025
    VCID: 658274FC64206E16ED-8030
    Using both Version 15.7.4 and Beta version 16.6.0 and with my HEXT NET dongle I was unable to access both these adapatation channels. I guess these two channels aren't in the firmware for my control module- which was confirmed when I generated an admap using 15.7.4 (they don't appear in my latest admap either - I was wrong in my earlier reply, sorry )!!
    However, it's real strange that these two channels suddenly appeared in the admap for your new cluster (see your post #8), but you can't access the channels in the adaptation screen. What version SW were you using to get the admap table in your post #8?
  4. #24
    Jun 2016
    Englisch 15.7.4 latest
    German DVI 15.7.4 latest
  5. #25
    Jun 2016
    I have olso cheked this setting, i see this settings.
    I have changed some of this setting because i have a retrofitted led tail lights a couple months ago.
    I thinks this was to light up both sides when you hit the brake.
    (1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
    (2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
    (3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
    (4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
    (5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
    (6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
    (7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
    (8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
    (9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
    Deactivate production mode,0
    (1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
    (2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
    (3)-Driving light and parking light-Standlicht aus,active
    (4)-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
    (5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active
    (6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
    (7)-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
    (8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
    (9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
    (10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
    (11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
    (12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
    (13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
    (14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
    (1)-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W auch H15
    (2)-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
    (3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
    (4)-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht Positionslicht Begrenzungslicht)
    (5)-Leuchte23SL HLC10-Lichtfunktion B 23,not active
    (6)-Leuchte23SL HLC10-Dimmwert AB 23,28
    (7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
    (8)-Leuchte23SL HLC10-Lichtfunktion C 23,Brake light
    (9)-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    (10)-Leuchte23SL HLC10-Dimmwert CD 23,100
    (11)-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
    (12)-Leuchte23SL HLC10-Lichtfunktion E 23,not active
    (13)-Leuchte23SL HLC10-Lichtfunktion F 23,not active
    (14)-Leuchte23SL HLC10-Dimmwert EF 23,0
    (15)-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
    (16)-Leuchte23SL HLC10-Lichtfunktion G 23,not active
    (17)-Leuchte23SL HLC10-Lichtfunktion H 23,not active
    (18)-Leuchte23SL HLC10-Dimmwert GH 23,0
    (19)-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
    (1)-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W auch H15
    (2)-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
    (3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
    (4)-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht Positionslicht Begrenzungslicht)
    (5)-Leuchte24SL HRA65-Lichtfunktion B 24,not active
    (6)-Leuchte24SL HRA65-Dimmwert AB 24,28
    (7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
    (8)-Leuchte24SL HRA65-Lichtfunktion C 24,Brake light
    (9)-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right
    (10)-Leuchte24SL HRA65-Dimmwert CD 24,100
    (11)-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
    (12)-Leuchte24SL HRA65-Lichtfunktion E 24,not active
    (13)-Leuchte24SL HRA65-Lichtfunktion F 24,not active
    (14)-Leuchte24SL HRA65-Dimmwert EF 24,0
    (15)-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
    (16)-Leuchte24SL HRA65-Lichtfunktion G 24,not active
    (17)-Leuchte24SL HRA65-Lichtfunktion H 24,not active
    (18)-Leuchte24SL HRA65-Dimmwert GH 24,0
    (19)-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
  6. #26
    May 2014
    Barstanders: The version 15.7.4 that I used was the English version (same as the Beta version that I tried)! I apologise for disagreeing, but I suspect that you are mixing the BCM modification in your latest post above (^^^) -for the LED tails and the two adaptation channels in the instrument control module. The two are very different, and they are not connected (IMO). Unusually for VW, in this case the name of the two adaptation channels clearly indicates their purpose - I beleive
    Question for Ross Tech - how is it possible for the admap process to identify a set of two adaptation channels (and their settings), but these channels are not accessible from the adaptation screen?
  7. #27
    Jun 2016
    Hello DV52,
    This was just a sugestion because the adaptation channel on the cluster says about parking light, and the BCM 09 shows adaptations parklicht.
    So that channels have a nother purpose and not connected with the cluster.
  8. #28
    Jun 2016
    I think it is not the Fuel Tank Variant what caused the error.
    I code every option from 1 to 8.
    So when i code one of the options and disconnect the battery for half an hour then reconnect
    The error comes after four and a half day!!!
    And when i erase the code with the same Tank variant the error comes with 15 hours
    Suspect that this is another cause and not the tank.
    Why after four and a half day!!
    Maybe it has to do with the infotainment.
    So what i dont understand the old cluster coded to 02 Feul Tank Variant 3 and Model variant 0
    Do i need to recode the new cluster to Fuel Tank variant 3.
    So Model variant 0 old cluster was for a 5 doors
    And when i use variant 0 then this shows 3 doors.
  9. #29
  10. #30
    Jun 2016
    I have try everthing but the fehler coms wit 4 days and couple hours again.
    VCDS Version: Release 15.7.4 Running on Windows 10 x86
    Data version: 20160216
    Thursday,07,July,2016,15:15:24:42750
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZDP010048   Mileage: 47339km-29415miles
    Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 E    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 7695
       Revision: WAH08---
       Coding: 01110032232415082000
       Shop #: WSC 51969 000 1048576
       ASAM Dataset: EV_ECM12TFS01104E906016E 001011
       ROD: EV_ECM12TFS01104E906016H.rod
       VCID: 2468B6F82F7D011E3A-8070
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA6AA120212A6C0377060401CB2580560454C06080A4F30028F02AC0
       Shop #: WSC 12345 123 123465
       VCID: 7DDEA39CEC5790D615-8028
       Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
       Revision: 00001K06
       Coding: 00020004200100011005000000101000
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 364C7CB089E1838E94-8062
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 L
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011227800350
       Coding: 00040846C2C102FB0BA44080B11C0708100A000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 77D2B1B4CE6BBA864F-8022
       Slave 1:
       Component: WWS    120910  042 0551
       Serial number:         120924160900
       Coding: 0E4DD5
       Slave 2:
       Component: RLFS  024 0042
       Serial number: Y12M09D26H11M47S40S4
       Coding: 06A8DD
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY1306406H5
       Serial number: 00000000000056969920
       Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
       Revision: --------    Serial number: 61131204002703
       Coding: 0031161041
       ROD: EV_EPHVA2CAU3700000_VW37.rod
       VCID: 3D5E639CACD750D655-8068
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R00E6ZJ
       Shop #: WSC 00028 028 00057
       VCID: 40A01A68DB253D3E3E-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 310 12
       Serial number: 35767000000E2845EB00
       Subsystem 2 - Part No SW: -----------    HW: 480 001 708 13
       Serial number: 35867000000ED2CC6D0F
       Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3516502A90D19C31C0EK
       Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
       Serial number: 3526502AD0CD5EB313CY
       Subsystem 5 - Part No SW: -----------    HW: 480 400 210 12
       Serial number: 3556502B30CD5EB4531M
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 1510120003004H
       Coding: 8400
       Shop #: WSC 51454 001 104857
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 75CEBBBCD467C8965D-8020
       Part No SW: 5G0 920 871     HW: 5G0 920 871
       Component: KOMBI         353 2200
       Coding: 07AD1900239000080D086E00040000
       VCID: 67F2E1F49ECB2A06DF-8032
    13639427 - Databus
                        Reset counter: 117
                        Mileage: 47335 km
                        Date: 2016.07.07
                        Time: 14:52:53
       Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
       Component: GW MQB Mid    121 1144
       Revision: --------    Serial number: 0000104516
       Coding: 030100042B086400EF000648080F00010001000000000000000000000000
       Shop #: WSC 51454 001 1048576
       ROD: EV_GatewLear.rod
       VCID: 3A546880BDF967EE70-806E
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
       Component: E221__MFL-DC1  H14 0035
       Serial number: 23130000529820100291
       Coding: 280000
       Serial number: 5430458201
    1537 - Data Set Implausible
              B2012 00 [009] -  -
                        Fault Frequency: 6
                        Reset counter: 77
                        Mileage: 47049 km
                        Date: 2016.06.26
                        Time: 10:52:06
       Serial number: 29051301100188
       Coding: 001F0220D000020000001000
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Serial number: 00000000000000243883
       Coding: 03
       ROD: EV_SteerAssisMQB.rod
       Component: TSG BFS       020 0023
       Serial number: 06031302090088
       Coding: 001F0020DE00020000801000
       VCID: 3FA21994A6DB42C647-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Serial number: 00000000000000247280
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846
       Component: MU-S-N-ER     038 0421
       Serial number: V1F01510120522
       Coding: 02730001FF00000011110001000800001F0100940100010045
       Shop #: WSC 12345 666 54321
       ROD: EV_MUStd4CPASE_SK37.rod
       VCID: 2772A1F45E4BEA061F-8072
       Media Player Position 1:
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9NJ902C5F
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 5G0 919 866 AD    HW: -----------
       Component:  ECE 2016/17  --- 0059
    End-------------------------(Elapsed Time: 02:43)--------------------------
