Results 11 to 20 of 22
Thread: WiFi Configuration & VCDS-Mobile app Questions
    Download this free app for your iPhone or and iPad and you can get all the info right there
    https://itunes.apple.com/us/app/fing-network-scanner
  2. #12
    Quote Originally Posted by jakematic View Post
    In AP mode you and the HEX-NET are the only ones on the network.
    Once you switch it to Infrastructure mode it will join an existing network and get an IP address from the DHCP server (router usually) on that network.
    EDIT I'm a pictures kind of guy so I made this, maybe it will explain it better:
    Great but one last thing photoshop the LEDs to be the correct color too
  3. #13
    Quote Originally Posted by romad View Post
    Well, I see you have the 802.11ac AirPort Extreme (if your graphic is accurate) so now I have to ask, what does Hex-Net use, 11g, 11n, etc.?
    802.11ac is a wifi standard not a specific router, all routers from Apple have been dual band for a number of years now.
  4. #14
    NC USA
    Quote Originally Posted by BaraJag View Post
    Being red/green colorblind..... um.... yeah I can't tell what color the actual LEDs are
    Correct. I used that router as an example only since it is easily identifiable.
  5. #15
    So how do you tell which mode your Hex-Net is in?
  6. #16
    NC USA
    At my desk I just check to see if it is broadcasting WiFi or if it can be pinged.
    In the car it's impossible to see since my DLC is so deeply buried I have to practically lay on the ground to connect it, but same thing.
    Reminds me of the time I terrified a rental van full of people by whizzing though a single flashing red light...
    Without 3 lamps it's difficult to tell if it's a caution or stop so I look for the sign on the side of the road.
  7. #17
    Verified VCDS User romad's Avatar
    Oroville, California People's Republic
    Yeah, I know, but I have 11n in my iMac, iPhone, iPad & AirPort Express so I was wondering what the Hex-Net unit itself used. Uwe says 11g.
    OT, but personally I don't like the design of the new AirPort Extreme Base Station; why didn't Apple just stay with the smaller case.
  8. #18
    Should have used the old 11b/g spaceship design!
  9. #19
    NC USA
    My network is the previous (flat) AirPort Extreme and 2 AirPort Express used as extenders.
    HEX-NET works perfectly attached to the N network and it is set to automatic on the AirPort.
    iNet shows it attached with a max rate of 54Mbps
  10. #20
    Does it show up as VCHN or did you have to name it?
