2007 Passat 2.0T - bucking under load around 4k rpm
KraftwerkTurbo
Brighton, MI
C?ID=102239
Symptoms:
- bucking under load starting around 4000 rpm
- no misfires
- observed tachometer needle (RPM) swinging (unstable). NOT normal
Possible that G28 engine speed sensor is causing all issues?
Or is bucking under load caused by failing boost control (bypass valve (DV) and control vavle (N75)?
Engine codes that return after erase:
Wednesday,01,June,2016,20:45:22:36008
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
                Address 01: Engine       Labels: 06F-907-115-AXX.clb
Control Module Part Number: 3C0 907 115 F    HW: 3C0 907 115 F
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 040C010A19070160
            Work Shop Code: WSC 02132 444 84388
                      VCID: 2345571DE259502643-8076
001112 - Evap System Purge Control Valve (N80)
               P0458 - 002 - Short to Ground - Intermittent
                    Mileage: 213641 km
                    Date: 2016.06.01
                    Time: 20:43:13
                    Load: 78.0 %
                    Speed: 62.0 km/h
                    Temperature: 78.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
000052 - Turbocharger Bypass Valve Control Circuit
               P0034 - 002 - Low - Intermittent
                    Mileage: 213641 km
                    Date: 2016.06.01
                    Time: 20:43:13
                    Load: 78.0 %
                    Speed: 62.0 km/h
                    Temperature: 78.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
000581 - Solenoid Valve  for Boost Pressure Control (N75)
               P0245 - 002 - Short to Ground - Intermittent
                    Mileage: 213641 km
                    Date: 2016.06.01
                    Time: 20:43:13
                    Load: 78.0 %
                    Speed: 62.0 km/h
                    Temperature: 78.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0031 - 002 - Short to Ground - Intermittent
                    Mileage: 213641 km
                    Date: 2016.06.01
                    Time: 20:43:13
                    Load: 78.0 %
                    Speed: 62.0 km/h
                    Temperature: 78.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
000801 - Engine Speed Sensor (G28)
               P0321 - 008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Mileage: 213641 km
                    Date: 2016.06.01
                    Time: 20:43:13
                    Load: 61.5 %
                    Speed: 62.0 km/h
                    Temperature: 78.0°C
                    Temperature: 30.0°C
                    Voltage: 14.224 V
Readiness: 0110 0101
Full scan for information only:
Data version: 20160216
Wednesday,01,June,2016,19:55:49:36008
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 6D
          72
VIN: WVWLK73C17E008739   Mileage: 213630km-132743miles
   Part No SW: 3C0 907 115 F    HW: 3C0 907 115 F
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZCZ000000000
   Shop #: WSC 02132 444 84388
001092 - EVAP Purge Control Valve (N80)
               P0444 - 004 - Circuit Open - Intermittent - MIL ON
                    Fault Status: 10100100
                    Mileage: 213627 km
                    Date: 2016.05.23
                    Time: 16:12:02
                    Speed: 17.0 km/h
                    Temperature: 81.0°C
                    Temperature: 57.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.716 V
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit - Intermittent
                    Mileage: 213627 km
                    Date: 2016.05.23
                    Time: 16:12:02
                    Speed: 17.0 km/h
                    Temperature: 81.0°C
                    Temperature: 57.0°C
                    Voltage: 13.843 V
000579 - Solenoid Valve  for Boost Pressure Control (N75)
               P0243 - 004 - Malfunction - Intermittent - MIL ON
                    Mileage: 213627 km
                    Date: 2016.05.23
                    Time: 16:12:02
                    Speed: 17.0 km/h
                    Temperature: 81.0°C
                    Temperature: 57.0°C
                    Voltage: 13.843 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0030 - 004 - Malfunction / Open Circuit - Intermittent
                    Mileage: 213627 km
                    Date: 2016.05.23
                    Time: 16:12:02
                    Speed: 17.0 km/h
                    Temperature: 81.0°C
                    Temperature: 57.0°C
                    Voltage: 13.843 V
               P0321 - 008 - Implausible Signal - Intermittent
                    Mileage: 213627 km
                    Date: 2016.05.23
                    Time: 16:12:03
                    RPM: 2230 /min
                    Load: 60.4 %
                    Speed: 18.0 km/h
                    Temperature: 81.0°C
                    Temperature: 57.0°C
                    Voltage: 13.589 V
Readiness: 0100 0101
   Part No SW: 09G 927 750 CJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           0841
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 05311 000 00000
   VCID: 7BF54F7D3A69C8E62B-802E
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0100006606
   Coding: 0046523
   VCID: 326BA259ADA3C9AEB8-8066
   Part No: 1K0 820 047 EB
   Component: Climatic PQ35   090 0505
   VCID: 68DF00315BFF737ED6-803C
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Revision: 00H46000    Serial number: 00000005473342
   Coding: 108C0F0340041A00470A00000F00000000285D435C0000
   VCID: 377D934D46C12C868F-8062
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 05311
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P6PZ16S
   Coding: 0012366
   VCID: 2E53B629B99BED4EDC-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 0000000003A6LP
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ† 63
   Subsystem 4 - Serial number: 000000ÿ† 6332MSME0D16605BDÿ† 63
   Subsystem 5 - Serial number: 6605BDÿ† 6342MSME10453B073ÿ† 63
   Subsystem 6 - Serial number: 53B073ÿ† 6351HTS6TLL6MJ536ÿ† 63
   Subsystem 7 - Serial number: 6MJ536ÿ† 6361HTS6OLLI87B3.ÿ† 63
   Subsystem 8 - Serial number: I87B3.ÿ† 63727TS64IK68I53+ÿ† 63
   Subsystem 9 - Serial number: 68I53+ÿ† 63827TS63IKAU7L2Sÿ
   Subsystem 10 - Serial number: AU7L2Sÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Revision: 00005000    Serial number: 3C9953507R
   Coding: 0002014
   VCID: 3169AD55A8A5F2B6C1-8064
00888 - Wiper Switch for Intermittent Operation (E22)
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 02132 444 53356
   VCID: 3365A75D52B9C0A6B3-8066
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C0632600B8
   Coding: 3FFD0E0CD22002
   VCID: 21495D15F845423651-8074
   Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1339817TQ3V502
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 02132 444 177402
   VCID: 2A5BBA398573816E00-807E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
01176 - Key
                    Reset counter: 108
                    Mileage: 203695 km
                    Date: 2015.05.20
                    Time: 13:16:01
02861 - Electronic Steering Column Lock Check Sum Error
                    Reset counter: 151
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2801
   Coding: 0001205
   VCID: 36639E4941CBD58E94-8062
   Part No: 1K1 909 144 K
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13900E88D1032E521804141FF00A0F0E081800
00896 - Trunk Lock Unit (F256)
                    Reset counter: 44
                    Mileage: 200213 km
                    Date: 2015.02.07
                    Time: 06:34:51
00955 - Key 1
                    Fault Status: 00100101
                    Reset counter: 154
   Part No: 1K0 959 702 K
   Coding: 0001204
   Revision:   013
   Coding: 0000013
                    Reset counter: 153
                    Mileage: 213624 km
                    Date: 2016.05.23
                    Time: 09:17:53
                    Voltage: 8.28 V
                    Count: 202
02443 - Control Head
                    Fault Status: 00111000
                    Reset counter: 153
                    Mileage: 212392 km
                    Date: 2015.10.16
                    Time: 06:08:39
                    Voltage: 14.18 V
                    Count: 46
            012 - Electrical Fault in Circuit - MIL ON
                    Fault Status: 11111100
                    Fault Frequency: 79
                    Reset counter: 113
                    Voltage: 12.42 V
                    Count: 40
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 A    HW: 1K0 035 161 A
   Component: Radio DE2       012 0015
   Revision: 00012000    Serial number: VWZ4Z7F6135743
   Coding: 0040400
   VCID: 1D3161E5C43D66D675-8048
   Part No: 3C9 959 703 A
   Component: Tuer-SG         021 2507
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
00667 - Ambient Temperature Signal
                    Reset counter: 153
                    Mileage: 213626 km
                    Date: 2016.02.29
                    Time: 15:50:56
   Part No SW: 3C9 827 383 B    HW: 3C9 827 383 C
   Component: J605  HECKDECKEL    0405
   Revision: 00H20001
   Shop #: WSC 23250 384 715754
   VCID: 306FA851A3AFFBBECE-8064
   Subsystem 1 - Part No: 3C9 827 384 B
   Component: J756  HECKDECKEL    0405
   Subsystem 2 - Serial number: 0600H20001001A0179ÿ
                    Fault Frequency: 7
                    Reset counter: 154
                    Mileage: 196901 km
                    Date: 2014.12.15
                    Time: 13:53:15
02786 - Module 2 for Hatch / Trunk Lid (J756)
                    Fault Status: 00101011
                    Reset counter: 154
                    Mileage: 205814 km
                    Date: 2015.07.18
                    Time: 23:21:37
02364 - Closing Assistance
                    Reset counter: 154
                    Mileage: 200910 km
                    Date: 2015.02.20
                    Time: 16:21:40
   Part No: 3C9 959 704 A
   Coding: 0000144
End-------------------------(Elapsed Time: 01:57)--------------------------
G28 is the single most important sensor on the engine. I'd certainly focus on it first.
I disagree.......
I would sort the short to ground first, because if the controller is disrupted on consumer side, it makes this disruption to the G28; and which is not a dead G28, but a Implausible Signal.
Same stamp for miles too.
This ones left hand drive though......:D
I'd unplug all those sensors on consumer bus, and road test in limp mode to see if the G28 shuts down though..
Isolate!
KraftwerkTurbo
Brighton, MI
C?ID=102239
From older engines (1.8T, 2.7T): crank (engine speed) is used for starting, then switching to cam sensor?
Is the G28 (here) the crank or cam sensor?
Ordering G28 now. First thing.
Also had ripped bladder in DV (no upgraded to piston style I think). Is 2007 still using bladder style? Fairly massive bucking under load ight be boost control?
Yes it could be boost control or any consumer on the bus shorting to ground that you have a DTC for or even other shared tracks.
The G28 is the Engine speed and you would know that if you RTFB a search in the WD or repair manual.
The G28 doesn't switch to G40 either which is the cam sensor you reference.
You need a "KISS". Keep It Simple Silly!
KraftwerkTurbo
Brighton, MI
C?ID=102239
Googled RTFB. Thanks for the tip. Always find it amusing that people take the time to dish out ADVISE instead of answers.
I found that bad crank sensor still can result in car starting after longer cranking (i.e. long cranking often an indicator that cranks sensor is on its way out). I was under the impression that cam signal is used to 'support' (located TDC for ignition).
Also: I had engine continuing to run with crank going bad, using the low resolution cam signal as timing reference (also just an assumption).
Awful lot of assumptions today going on.
You want magic answers....... go see the fortune teller, or buy some lottery tickets.
If you said "Jack I have so and so ohms here, on this track, and this does this here", I could recant with maybe an idea by myself looking in WD.
RTFB means "Read The Repair Book"
I prefer to fix cars vicariously through you, to stay sharp myself as an exercise.
I can't do that if you just want answers, with no valid input, or argument through speculations.
Here's another KISS.........I can only help you......... if you let me.
:facepalm:
:p
slevanto
C?ID=273817
I have the same problem on my 2010 A4
No codes
Auto scan attached
Ideas?
VIN: WAUDFAFL7AN012266
Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
Address 01: Engine (CAEB
DL0MA)	Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AA	HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0001
Revision: E1H15---
Coding: 0104010A180F0160
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TFS8K2907115AA A01002
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 6E9F5DBB259D8D6E754FBC3B7A-803B
No fault codes found.
Address 03: ABS Brakes (J104)	Labels: None
Part No SW: 8K0 907 379 CA	HW: 8K0 907 379 AN
Component: ESP8 quattro H04 0010
Revision: --------
Coding: 070D10
Shop #: WSC 02391 823 56573
VCID: 7AB761EB69D5C9CED9C740ABD6-802F
Address 05: Acc/Start Auth. (J393)	Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DF	HW: 8K0 907 064 DF
Component: BCM2 1.1 H02 0321
Coding: 0B0100
Shop #: WSC 02399 823 56573
VCID: 77B178DF5AC7D4A6A6A92187ED-8022
Subsystem 1 - Part No SW: 8T0-959-754-A
Component: FBSAUDIB8 IDGH37 0060
Subsystem 2 - Part No SW: 8K0-905-852-D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255)	Labels: None
Part No SW: 8T1 820 043 AN	HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0160
Revision: A1000000
Coding: 64002000
VCID: 7DBD6AF778FBFEF6FCE563CFBF-8028
01271 - Positioning Motor for Temperature Flap (V68)
001 - Upper Limit Exceeded
Address 09: Cent. Elect. (J519)	Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P	HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001
Coding: 690000B1063C00010000080300007F5F0F14120800000021000000
VCID: 3C3BA7F3236137FE8B5B96C3EC-8069
Subsystem 1 - Part No SW: 8K1-955-119-A	Labels: 1Kx-955-119.clb
Component: WWS 120709 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0-941-531-AK	Labels: 8K-09-02.lbl
Component: E1 - LDS H08 0090
Subsystem 3 - Part No SW: 8K0-907-410-B
Component: HOMELINK H01 0010
Address 15: Airbags (J234)	Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 H	HW: 8K0 959 655 H
Component: AirbagVW-AU10 H37 0520
Coding: 303836354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 42C7D90B4185590EC197D80BBE-8017
Subsystem 1 - Part No SW: 8K0-959-339-B
Component: BF-Gewichtss.H01 0030
Serial Number: 5810000R0900004K4R��
Subsystem 2 - Serial Number: 6334MSME49647279LR��
Subsystem 3 - Serial Number: 6344MSME464034656R��
Subsystem 4 - Serial Number: 6352QSME623103080R��
Subsystem 5 - Serial Number: 6362QSME56315010R��
Subsystem 6 - Serial Number: 63732SME35324400KR��
Subsystem 7 - Serial Number: 63832SME1032491EYR��
Address 16: Steering wheel (J527)	Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F	HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: --------
Coding: 000014
VCID: 3D3DAAF7387B3EF6BC65A3CFFF-8068
Subsystem 1 - Component: E221 - MFL H02 0003
Address 17: Instruments (J285)	Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 E	HW: 8K0 920 950 E
Component: KOMBIINSTR. H19 0253
Revision: 00100000
Coding: 8B1809000300D705020000
VCID: 312586C7F423CA9628ED1F5F63-8064
Address 19: CAN Gateway (J533)	Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 R	HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0101
Revision: GB500049
Coding: 00C303
VCID: 50E3E3439FE9A39E472372D3F0-8005
Subsystem 1 - Part No SW: 8K0-915-181-E
Component: J367-BDM H06 0160
Address 2E: Media Player 3 (R199)	Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A	HW: 8T0 035 785
Component: SG ext.Player H08 0280
Revision: 00000000
Coding: 020302
VCID: 3935BEE72C5302D6903D77BF0B-806C
Address 42: Door Elect, Driver (J386)	Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H	HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision:
Coding: 011C03204000410001
VCID: 45CDC21750AB7636E4B5FB2F67-8010
Address 46: Central Conv. (J393)	Labels: 8K0-907-064-46.clb
Coding: 01060638007A404400B0010000000000
Subsystem 1 - Part No SW: 8K0-959-719
Component: GTO BF H06 0050
Subsystem 2 - Part No SW: 1K0-951-605-C
Component: LIN BACKUP HOH03 1301
Subsystem 3 - Part No SW: 8K0-959-591-A
Component: J245 PS037 H06 0041
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
02616 - Fuel Tank Cap; Unlock
Address 47: Sound System (J525)	Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH	HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74AB4FD34BB1BFBE838BFE6304-8021
Address 52: Door Elect, Pass. (J387)	Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H	HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision:
VCID: 44CBDF135B914F3EF3ABEE2394-8011
Address 53: Parking Brake (J540)	Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H	HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003
VCID: 342B8FD30B31FFBE430B3E6344-8061
Address 56: Radio (J503)	Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R	HW: 8T1 035 186 R
Component: Con3 Sirius H03 0301
Revision: 00000005
Coding: 04020002010185004119070800
VCID: 46CFC51B6DAD7D2EEDBF045B72-8013
Address 62: Door, Rear Left (J388)	Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C	HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision:
Coding: 010C03204000210001
VCID: 42C7D90B4185410EC197D80BBE-8017
Address 72: Door, Rear Right (J389)	Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision:
Address 77: Telephone	Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 D	HW: 8T0862336D
Component: FSE_256x BT H37 0600
Revision: 00000000	Serial Number: 00000005046470
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3C3BA7F32361B7FE8B5B96C3EC-8069
Show logs at point of shut down..........
At boost offset?
Describe condition because OP had DTC's ........so not the same........
