Results 11 to 20 of 33
Thread: IMMOBILIZER END OF LINE Error
    Magdeburg, Germany
    Thank you for the clarification, that sure explains some of the weird PR-codes. FWIW, it never hurts to tell the full story up-front - usually saves us a lot of questions.
    Were the car(s) stored with the battery disconnected and/or did the battery die in the process and/or was completely discharged? Some of the ideas posted above may still apply, due to low voltage conditions it isn't impossible that the immobilizer information in the cluster was corrupted. In order to look at this closer, please provide the following information...
    #01 (Engine) > Adaptation - 10 > Channel 91 > What is the current Value?
    #17 (Instruments) > Meas. Values - 08 > Block 001, 002 & 003 > What are the current Values?
    Nichts erweitert das eigene Wissen mehr,
    als die Meinung eines Andersdenkenden.
  2. Likes Uwe, mirkiaei liked this post
  3. #12
    May 2016
    IRAN
    Quote Originally Posted by Sebastian View Post
    Thank you Sebastian,
    I'm back to home, will read the values tomorrow.
    Best regards,
  4. #13
    Dallas (McKinney) ,TX ,USA
    On this car Need to go to 25 Immobilizer Meas. Values - 08 > Block 001, 002 & 003
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  5. Likes mirkiaei liked this post
  6. #14
    Like I said I know what happened here , had to dig in my old PC .
    Measuring block 003 files 4 will be 5.0 ( Malfunction in line mode(LED 4Hz)
    Immobilizer/ECU
  7. Likes mirkiaei, Uwe liked this post
  8. #15
    May 2016
    IRAN
    Measured Data
    I read the channels:
    Sunday,05,June,2016,14:04:09:37122
    VCDS Version: 15.7.4.1
    Data version: 20160216
    VIN: WV2ZZZ2KZ9X086586   License Plate: YARD
    Adaptation Channel 091:
    Stored value 4
    Test value ERROR
    Address 25: Immobilizer  (1T0 920 863 F)
    14:05:04 Group 001: System Status
      Yes  Engine Start permitted
      Yes  Engine (ECU) responds
      Yes  Key Status OK
      2.0  Number of adapted Keys
    14:05:04 Group 002: Key && Adaptation Status
      Yes  Variable Code authorized
      Yes  Key Status (Transponder Lock)
      Yes  Fixed Code authorized
      6.0  Immobilizer Status
    14:05:04 Group 003: Lock Times && System Status
      0.0  Lock Time Immobilizer
      0.0  Lock Time Engine
      0.0  Lock Time Transponder
      5.0  Immobilizer (LED) Status
    We have Abrites Tool too. I also used it to extract the 5-Digit PIN, then checked it within VCDS Security and it worked.
    Since the car is running, I have to work carefully, not harming the IMMO.
    Once again I appreciate your help.
    With regards.
  9. #16
    Verified VCDS User Gavra's Avatar
    Mar 2015
    Melbourne/Belgrade
    He offered his help first , so I would suggest to install Team Viewer and send PM to Jetta
  10. Likes Jetta ,97 liked this post
  11. #17
    May 2016
    IRAN
    Dear Jetta,
    I'm afraid I don't understand. Would you please kindly write a little more clearly. I really appreciate it.
  12. #18
    May 2016
    IRAN
    Dear Gavra, I don't understand. Jetta's first reply asks for the panel to be sent to him. The second reply gives no clue to me
    Quote Originally Posted by Gavra View Post
  13. #19
    Mar 2015
    Melbourne/Belgrade
    That's because dealer can not fix this ,only replace cluster
    Send him PM and maybe he can try to help you with other tool. VCDS can not be used at this stage to help you. And if you have really good tools and can read binary from your cluster no need to send it
  14. #20
    May 2016
    IRAN
    As I mentioned before, we are importer, so I can replace it a new one, which costs hundred euros.
    About the tools: I have VCDS, and a Programmer.
    Do you guys mean that it's only possible by changing some binary values of the IMMO dump? No suggestion for solving the problem without removing IC from Dash Panel ?
    I hope you excuse me for so many question, but I have to convince my employer here
    Best regards
