Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: IMMOBILIZER END OF LINE Error
    May 2016
    IRAN
    Hi mates,
    I'm new to VCDS. We have a VW CADDY 2009 in stock, the engine starts with no problem, but the message: "immobilizer end of line" appears for a few seconds and the yellow Immobilizer alarm blinks permanently on the Dash panel.
    Any tip is much appreciated.
    The Auto Scan Shows no Fault:
    Tuesday,31,May,2016,12:11:35:37122
    VCDS Version: 15.7.4.1
    Data version: 20160216
    VIN: WV2ZZZ2KZ9X086586   License Plate: HAYAT
    Mileage: 200km-124mi   Repair Order:
    Chassis Type: 2K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WV2ZZZ2KZ9X086586   Mileage: 200km-124miles
    Address 01: Engine (   )       Labels: Redir Fail!
       Part No SW: 06G 906 022 E    HW: 06G 906 022 A
       Component: 4220 CNG 26A5V0     2809
       Revision: 1RH03---    Serial number: VWX7Z0HN3NL0EL
       Coding: 0030071
       Shop #: WSC 35110 377 00158
       VCID: 2578770EEC7004162D-8070
    Readiness: 0110 0101
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
       Component: MABS MK70M          0104
       Revision: 00H32001
       Coding: 0020801
       VCID: 76DA604201563F8E54-8022
       Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
       Component: Climatic PQ35   143 1313
       Revision: 00143033    Serial number: 00000000000000
       VCID: 6FD455267E0C0E4697-803A
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 01000009164623
       Coding: 018C4F030004100057000000000000000009FF075C000120000000000000
       Shop #: WSC 35110 377 08192
       VCID: 335C995652A46AA6B3-8066
       Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 131108 021  0501
       Coding: 00038805
       Shop #: WSC 35110
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AJ    HW: 6Q0 909 605 AJ
       Component: Z7 AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037UR0155PH
       Coding: 0023095
       VCID: 7F3485662E6C7EC607-802A
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           853 0111
       Coding: 0000004
       VCID: 033C099642841A2663-8056
       Part No: 1T0 920 863 F
       Component: KOMBIINSTRUMENT VDD 0622
       Coding: 0016101
       Shop #: WSC 00099 757 173712
       VCID: 3744AD4646DC86868F-8062
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 S    HW: 1K0 907 951
       Component: J533  Gateway   H07 0071
       Revision:   H07 01    Serial number: 281108F1001967
       Coding: E9801F06000202007400
       Component: IMMO            VDD 0622
       Part No SW: 1T0 959 701 M    HW: 1T0 959 701 M
       Component: Tuer-SG         008 2005
       Coding: 0000048
       VCID: 41B0C39E1818C83631-8014
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 140    2301
       Revision: 00H15000
       VCID: 2A628432856E2B6E00-807E
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 808B0C087F2D8405484A036010C0
       VCID: 0036069A5392013E7E-8054
       Part No SW: 1T0 959 702 M    HW: 1T0 959 702 M
       Coding: 0000048
       VCID: 42B2CC921D1ED32E28-8016
       Part No: 1K0 035 186 AF
       Component: Radio GR0       036 0034
       Revision: 0003606S    Serial number: VWZ2Z2H1236336
       Coding: 0020200
       VCID: 6AE2443245EEEB6EC0-803E
    End-------------------------(Elapsed Time: 00:59)--------------------------
    Tuesday,31,May,2016,12:35:08:37122
       Coding: 0030071
       Revision: 00H32001
       Coding: 0020801
       Coding: 00038805
       Shop #: WSC 35110
       Coding: 0023095
       Coding: 0000004
       Coding: 0016101
       Coding: 0000048
       Revision: 00H15000
       Coding: 0000048
       Coding: 0020200
    Jul 2014
    Hi Mirkiaei,
    A 2009 Caddy with 124 miles suggests to me that someone has been screwing with the instrument cluster.
    Regards HMC
  3. Likes Gavra, mirkiaei liked this post
    Verified VCDS User Gavra's Avatar
    Mar 2015
    Melbourne/Belgrade
    You have immo-off and it's a bad one ........
  5. Likes mirkiaei liked this post
    May 2016
    IRAN
    Hi HMC,
    I mentioned that the car has been in stock.
    Regards Mirkiaei
    May 2016
    IRAN
    Hi Gavra,
    Thank u for the reply. How did u figure it out? Any suggestion for fixing?
    I don't have SKC or and PIN, but we have a few more cars of the same model.
    Regards Mirkiaei
    Mar 2015
    Melbourne/Belgrade
    Well I am not sure is it OK to give you detailed advice as you are not verified yet.......please verify your VCDS and we will continue then
  9. Likes mirkiaei liked this post
  10. #7
    May 2016
    IRAN
    Quote Originally Posted by Gavra View Post
    Thank you again. I registered yesterday, received Dongle Registration but don't know what else to do?
  11. #8
    Magdeburg, Germany
    Registration should happen soon, nevertheless it is rather unlikely that a car build in 12/2008 has only 200 km on the clock. Hence HMCs assessment being fairly realistic. Can you give us some background as to why this car has been sitting this long and supposedly hasn't been driven? As far as the immobilizer question goes - what current value do you have in the ECM, Adaptation Channel 91?
  12. Likes Uwe, mirkiaei liked this post
  13. #9
    Dallas (McKinney) ,TX ,USA
    I know exactly what happen here.
    Someone try to add key with low quality tool and mess up immobilizer side in cluster, This can be fixed but need really high quality tool and brain.exe.
    VCDS can not help you on this.
    I can fix it but need to have cluster.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  14. #10
    May 2016
    IRAN
    Quote Originally Posted by Sebastian View Post
    Dear Sebastian,
    I work for the official importer. In 2009 we imported 60 units of EcoFuel Caddy, as the sample for an order of thousand units. But due to sanctions against Iran, VW refused further orders and we had to sell the cars to private customers.
    This car plus 2 others, are remained from that import. All 3 are faulty, and there is no access to Geko in Iran. So we bought VCDS and I an starting with this car.
    I hope this details clarifies the reason why the car has not been sold yet.
    Best regards
  15. Likes Sebastian, Uwe, jyoung8607 liked this post
