Results 11 to 20 of 25
Thread: Fault code information!
    Mar 2016
    18062 refers to the Instrument Cluster
    18062 Please check DTC Memory of Instrument Cluster
  2. Likes LN-TAL liked this post
  3. #12
    Jun 2014
    Newcastle, England
    Quote Originally Posted by Dutchie View Post
    (LIN-Bus)...do you have some manufacture information on that. I have never heard of that. As far i can tell a engine temp sensor is a NTC or PTC.
    Read about LIN on Wikipedia. For a real example - and when you've got a bit of time - read this thread. It shows there is a sensor for the HVAC that is in fact on the front Central Electrics LIN. It incorporates a temperature sender and pressure transducer in the one housing and transmits its data via the Homelink Garage door opener to the Cent Elec Module (09). Cent Elec then transmits the pressure/temp data over CAN to the HVAC controller.
    For absolutely specific data, please read the fantastic Self Study Programs (SSP) - available from here.
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #13
    Mar 2016
    Just a quick update on this, changed the coolant temperature sensor, yes there are two but one is for the radiator fan as the technical data advises. The new temperature switch initially read approx 2.5V and as the engine warmed up the voltage was stabilized and as temperature increased the voltage level dropped gradually, at about 1.21V the fluctuations were back as before, the scope started producing a square wave pulse and even after switching off the engine the square wave pulse continued for a good few seconds until a relay of some sort switched and the trace flat lined.
    The fault will still be present, tomorrow when I have a bit more time I'll upload the auto scan. Its made things a bit difficult not being able to carryout a checking procedure for the fault code that is present that I can't do any research on.
  6. #14
    Verified VCDS User bigjohn84's Avatar
    May 2016
    Edinburgh/Leith
    Try the oil sensor mate
  7. #15
    Verified VCDS User Gavra's Avatar
    Mar 2015
    Melbourne/Belgrade
    Why would you change anything ?! Because it's written on some forum with similar fault ?! Sometimes non start will need to be confirmed so you can chase cause of it......and in 99% of those kind of faults it's something really simple , just need to catch it. And to do so you must be organized ,not changing random parts.....
  8. Likes Robski liked this post
  9. #16
    Mar 2016
    I agree fully with you, I didn't want to change the sensor but allowed myself to be mislead by someone else who thought changing the sensor cured their none starting issue. I just wished I had the checking procedure for the fault code. Auto scan to follow...
  10. #17
    Magdeburg, Germany
    I am tempted to lock this topic, you have been asked for an Auto-Scan more than once now and you still haven't provided it. In many cases it isn't just about the fault code but more so about what other components say or what they are... Please don't waste peoples don't with incomplete inquiries, post an Auto-Scan and complete vehicle details!
  11. Likes Robski, Uwe liked this post
  12. #18
    Mar 2016
    One auto scan as requested.
    Sunday,29,May,2016,10:34:52:61979
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WV1ZZZ7HZ6H036014   License Plate:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ6H036014   Mileage: 209350km-130084miles
       Part No SW: 038 906 016 M    HW: 028 101 185 6
       Component: R4 1,9L EDC 0000SG  6278
       Revision: 12345678    Serial number: VWZ7Z0E2628424
       Coding: 0101031
       Shop #: WSC 02756 785 00200
       VCID: 1E33B01ECA45CECE6C-5140
    18062 - Please check DTC Memory of Instrument Cluster
                P1654 - 000 -  - Intermittent
                        RPM: 2058 /min
                        Torque: 6.0 Nm
                        Speed: 27.0 km/h
                        Load: 6.3 %
                        Voltage: 14.44 V
                        Temperature: 25.2°C
                        Temperature: 66.6°C
                        Temperature: 16.2°C
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ASR-F.lbl
       Part No: 7H0 907 379 G
       Component: ASR FRONT MK25      0103
       Coding: 0007205
       VCID: 3979438273AB89F679-5124
    Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
       Part No: 7H0 937 049 M
       Component: BORDNETZ SGVER 1.0  0901
       Coding: 0000004
       Shop #: WSC 02770 785 00200
       VCID: 3C775A967C99BCDE62-5124
       Part No: 1C0 909 605 A
       Component: 3B AIRBAG VW51      0008
       Coding: 13122
       Shop #: WSC 02756
       VCID: 224B84EEAE3DEA2E48-5124
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 951 F
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 01411
       Shop #: WSC 00001
       VCID: 2F6D7DDAEDEF5746D7-5106
       WV1ZZZ7HZ6H036014     VWZ7Z0E2628424
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02770
       VCID: 70EFBEA6305108BE8E-5124
    Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
       Part No: 7H0 951 171
       Component: Innenraumueberw.    2815
       Coding: 0000021
       VCID: 67DDD5FA559FCF06DF-517C
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C2B Komfortgerát     0004
       Coding: 00016
       VCID: 326B74AEFEDD7AAEB8-4B00
    01134 - Alarm Horn (H12)
                77-00 - Internal Supply Voltage
                36-00 - Open Circuit
    End-------------------------(Elapsed Time: 06:45)--------------------------
  13. Likes Uwe, Jack@European_Parts liked this post
  14. #19
    Is it the correct part # sensor replaced?
    "Beware of FOD ...........Give before it hurts".
  15. #20
    Mar 2016
    Thanks for replying Jack. With regards the part # sensor replaced I am assuming that you are referring to the coolant sensor I just replaced!
    Can I ask please from members that when you use abbreviations like MVB's, FOD etc, I can try and look up their meanings on the internet but there are many variations, so can I ask that members spell their meanings out please to avoid confusion and misunderstanding.
