Fault code information!
Trade Member
C?ID=271231
I have searched the wiki files codes for 18062 and the closest is 18061/18063. Is there any information available regarding code 18062 please?
Gavra
Melbourne/Belgrade
C?ID=240855
18062
P1654
Please check DTC Memory of Instrument Cluster
Trade Member
C?ID=271231
Thanks I checked using VCDS and no faults are reported. Apparently it is intermittent and because no data seems to be available I can't carryout a checking procedure.
I'm not sure I understand what you're trying to tell us here. Maybe an Auto-Scan would shed some light on things?
bigjohn84
Edinburgh/Leith
C?ID=276781
It's an oil sensor I think mate, also if there's no fault codes how did you get this code?
Trade Member
C?ID=271231
I completed an auto scan, its on my other computer :banghead: which is why I have not loaded it up, however what I can say is this, Address 01 engine, 1 fault found 18062 please check DTC memory of instrument cluster, P1654 - 000 -- intermittent.
Freeze frame data;
RPM 2058 /min
Torque; 6.0 Nm
Speed 27 km/h [17 mph]
Load; 6.3%
Voltage 14.44V
Temperature; 25.2 degrees C
Temperature; 66.6 degrees C
Temperature; 16.2 degrees C
Unfortunately VCDS can't or I can't seem to establish which temperature reading refers to what?
Readiness; 0 0 x x x
I looked into the instruments using VCDS and this is where VCDS says that no faults are recorded, the fault code has been found using the auto scan function.
I read on the internet that others have had this fault code and one person said that the coolant temperature sensor was the cause, so I decided to get the scope out and have a look, using the Snap On Vantage Pro, snap on says;
The coolant sensor is a NTC type, the resistance decreases as temperature increases, this causes a change in signal voltage, which is interpreted by the ECM
Snap On say that it is a two pin sensor and pin 1 is the ground and pin 2 is the signal voltage. (good job their vantage pro is not polarity sensitive) :facepalm:
Snap On then provide a list of sensor circuit resistances to compare, all this is in the component information provided before a test is performed.
Tests. DC Voltage Test.
At the engine coolant sensor connect yellow channel lead to pin 2, and black channel to pin 1.
Key on, engine off, expected result 5V. I got [ - 2.18V] See above polarity.
I decided to start the engine and run it, as the engine was warming up the voltage did drop but once it got to about 1.5V the voltage was violently fluctuating between 1.5V and 0.5V constantly up and down. I wanted to scope it as the vantage is a scope, however I could not get a trace.
I have concluded that the temperature sensor is faulty based on the voltage fluctuations so am going to install a new sensor and retest it and see what readings I then get.
Robski
Yorkshire
C?ID=111643
what a palaver :facepalm: why didn't you just check its plausibility in MVB's ?
Is there a problem with the car ???????
Trade Member
C?ID=271231
The customer advises that the engine first time won't start and then afterwards it will start all the time, however I have not experienced this. MVB? anyone
Zenerdiode
Newcastle, England
C?ID=24330
It would help a little if we knew the age and model of vehicle, at least. Auto-Scan would be even better. You do know that some sensors (pressure and temperature, among others) are actually tiny micro-controllers and don't send a voltage level any more, they actually send a data-stream over a single wire LIN-bus? That may well be why the "voltage was violently fluctuating between 1.5V and 0.5V constantly up and down." You meter may have been trying to assimilate a data-stream.
Dutchie
C?ID=125479
You do know that some sensors (pressure and temperature, among others) are actually tiny micro-controllers and don't send a voltage level any more, they actually send a data-stream over a single wire LIN-bus? .
Little hijack -sorry-, do you have some manufacture information on that. I have never heard of that. As far i can tell a engine temp sensor is a NTC or PTC.
Dutchie
C?ID=125479
18062 refers to the Instrument Cluster
18062 Please check DTC Memory of Instrument Cluster
Zenerdiode
Newcastle, England
C?ID=24330
(LIN-Bus)...do you have some manufacture information on that. I have never heard of that. As far i can tell a engine temp sensor is a NTC or PTC.
Read about LIN on Wikipedia. For a real example - and when you've got a bit of time - read this thread. It shows there is a sensor for the HVAC that is in fact on the front Central Electrics LIN. It incorporates a temperature sender and pressure transducer in the one housing and transmits its data via the Homelink Garage door opener to the Cent Elec Module (09). Cent Elec then transmits the pressure/temp data over CAN to the HVAC controller.
For absolutely specific data, please read the fantastic Self Study Programs (SSP) - available from here.
Trade Member
C?ID=271231
Just a quick update on this, changed the coolant temperature sensor, yes there are two but one is for the radiator fan as the technical data advises. The new temperature switch initially read approx 2.5V and as the engine warmed up the voltage was stabilized and as temperature increased the voltage level dropped gradually, at about 1.21V the fluctuations were back as before, the scope started producing a square wave pulse and even after switching off the engine the square wave pulse continued for a good few seconds until a relay of some sort switched and the trace flat lined.
The fault will still be present, tomorrow when I have a bit more time I'll upload the auto scan. Its made things a bit difficult not being able to carryout a checking procedure for the fault code that is present that I can't do any research on.
Gavra
Melbourne/Belgrade
C?ID=240855
Why would you change anything ?! Because it's written on some forum with similar fault ?! Sometimes non start will need to be confirmed so you can chase cause of it......and in 99% of those kind of faults it's something really simple , just need to catch it. And to do so you must be organized ,not changing random parts.....
Trade Member
C?ID=271231
I agree fully with you, I didn't want to change the sensor but allowed myself to be mislead by someone else who thought changing the sensor cured their none starting issue. I just wished I had the checking procedure for the fault code. Auto scan to follow...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I am tempted to lock this topic, you have been asked for an Auto-Scan more than once now and you still haven't provided it. In many cases it isn't just about the fault code but more so about what other components say or what they are... Please don't waste peoples don't with incomplete inquiries, post an Auto-Scan and complete vehicle details!
Trade Member
C?ID=271231
One auto scan as requested.
Sunday,29,May,2016,10:34:52:61979
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ7HZ6H036014   License Plate:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ6H036014   Mileage: 209350km-130084miles
   Part No SW: 038 906 016 M    HW: 028 101 185 6
   Component: R4 1,9L EDC 0000SG  6278
   Revision: 12345678    Serial number: VWZ7Z0E2628424
   Coding: 0101031
   Shop #: WSC 02756 785 00200
   VCID: 1E33B01ECA45CECE6C-5140
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 000 -  - Intermittent
                    RPM: 2058 /min
                    Torque: 6.0 Nm
                    Speed: 27.0 km/h
                    Load: 6.3 %
                    Voltage: 14.44 V
                    Temperature: 25.2°C
                    Temperature: 66.6°C
                    Temperature: 16.2°C
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 7H0-907-37x-ASR-F.lbl
   Part No: 7H0 907 379 G
   Component: ASR FRONT MK25      0103
   Coding: 0007205
   VCID: 3979438273AB89F679-5124
Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
   Part No: 7H0 937 049 M
   Component: BORDNETZ SGVER 1.0  0901
   Coding: 0000004
   Shop #: WSC 02770 785 00200
   VCID: 3C775A967C99BCDE62-5124
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0008
   Coding: 13122
   Shop #: WSC 02756
   VCID: 224B84EEAE3DEA2E48-5124
   Part No: 7H0 920 951 F
   Coding: 01411
   Shop #: WSC 00001
   VCID: 2F6D7DDAEDEF5746D7-5106
   WV1ZZZ7HZ6H036014     VWZ7Z0E2628424
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02770
   VCID: 70EFBEA6305108BE8E-5124
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Part No: 7H0 951 171
   Component: Innenraumueberw.    2815
   Coding: 0000021
   VCID: 67DDD5FA559FCF06DF-517C
   Part No: 7H0 959 433 B
   Component: C2B Komfortgerát     0004
   Coding: 00016
   VCID: 326B74AEFEDD7AAEB8-4B00
01134 - Alarm Horn (H12)
            77-00 - Internal Supply Voltage
            36-00 - Open Circuit
End-------------------------(Elapsed Time: 06:45)--------------------------
Is it the correct part # sensor replaced?
"Beware of FOD ...........Give before it hurts".
Trade Member
C?ID=271231
Thanks for replying Jack. With regards the part # sensor replaced I am assuming that you are referring to the coolant sensor I just replaced!
Can I ask please from members that when you use abbreviations like MVB's, FOD etc, I can try and look up their meanings on the internet but there are many variations, so can I ask that members spell their meanings out please to avoid confusion and misunderstanding.
