Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 109
Thread: 07 A4 3.2L P0172 rich code
    Correct but don't forget this is "ADD trim" which means you could have other underlined conditions such as a stuck N80 etc..
    Conduct 071 and 070 tests to win the prize.
    0x01-04-071/070
  2. #12
    May 2016
    Canada
    as I said, i'm a noob
    I found info about this test in one of your older posts:
    This test in VCDS is 0x01-04-071 to pump the tank mechanically with air, using vacuum to operate pulsed by a solenoid.
    If air leaks out there is a leak!
    That air that pumps in is recycled via the N80 to the intake to burn off the vapors.
    I'll have to read up on how to perform this test
    Thanks once more for helping, really appreciate it. I love learning about this stuff.
  3. Likes Uwe, Jack@European_Parts liked this post
  4. #13
    May 2016
    Canada
    would dirty connection do the trick? i cleaned all my OXS with electro cleaner and no more errors?!?!?!?!?!
  5. #14
    It's possible, however, to have these faults on multiple banks I'm not thinking so.
    I'd clean the MAF and check air filter........+ check MAF part # to be correct for FOD.
  6. #15
    May 2016
    Canada
    latest and greatest.
    Monday,23,May,2016,19:52:54:55111
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WAUEH78E87A046474   License Plate:
                    Address 01: Engine  (8E1 910 559 F)
    19:52:41 Group 032: Lambda Control (Mixture Adaptation)
      -19.7 %  Adaptation (Idle) Bank 1 Sensor 1
      -2.3 %  Adaptation (Partial) Bank 1 Sensor 1
      -11.4 %  Adaptation (Idle) Bank 2 Sensor 1
      -2.8 %  Adaptation (Partial) Bank 2 Sensor 1
    19:52:41 Group 033: Lambda Control
      -0.4 %  Lambda Control Bank 1 Sensor 1
      2.035 V  Sensor Voltage Bank 1 Sensor 1
      2.1 %  Lambda Control Bank 2 Sensor 1
      2.021 V  Sensor Voltage Bank 2 Sensor 1
    Thursday,26,May,2016,13:46:37:55111
    Mileage: 201680km-125318mi   Repair Order:
              67 69 75 76 77
    VIN: WAUEH78E87A046474   Mileage: 201680km-125318miles
    Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
       Part No SW: 8E1 910 559 F    HW: 8E0 907 559 J
       Component: 3.2l V6 FSI         0080
       Revision: --H19---    Serial number:
       Coding: 01040109190F0120
       Shop #: WSC 93009 999 04862
       VCID: 3169D31DA8FE1DB6C1-8064
    004376 - Oxygen (Lambda) Sensor Heating; B1 S2
                   P1118 - 009 - Open Circuit - Intermittent
                        Fault Status: 00000100
                        Reset counter: 38
                        Mileage: 201623 km
                        RPM: 768 /min
                        Mass Air / Rev.: 109.0 mg/str
                        Temperature: 91.5°C
                            Idle
                        Voltage: 13.87 V
                        Bin. Bits: 00000010
    008304 - Intake Manifold Tuning Valve (Bank 1)
                   P2070 - 006 - Stuck Open - Intermittent
                        Fault Status: 00100001
                        Reset counter: 39
                        Mileage: 201623 km
                        RPM: 768 /min
                        Mass Air / Rev.: 114.5 mg/str
                        Temperature: 91.5°C
                            Idle
                        Absolute Pres.: 340.5 mbar
    000611 - Fuel Injector #1 (N30)
                   P0263 - 007 - Contribution/Balance Fault
                        Reset counter: 40
                        Mileage: 201623 km
                        RPM: 768 /min
                        Temperature: 91.5°C
                            Idle
                        Load: 15.7 %
       Part No SW: 8E1 910 156 L    HW: 09L 927 156 B
       Component: AG6 09L 3,2 FSI USA 0010
       Revision: --H01---    Serial number:        4207022
       Shop #: WSC 06335 000 00000
       VCID: 306FD619A3F414BECE-8064
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Coding: 0004532
       VCID: 2E53C861B9C0024EDC-807A
                000 -  -  - Intermittent
                        Reset counter: 35
                        Hex Value: 0x0000
                        Hex Value: 0x0202
                        Hex Value: 0x0024
                        Hex Value: 0x0192
                        Hex Value: 0x0001
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2833
       Coding: 00000
       VCID: 6DD10F6D2746B956A5-5124
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  USA 0907
       Coding: 01023
       Shop #: WSC 06335
       VCID: 3D71FF2D37A6E9D655-4B00
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H12 3840
       Revision: 91H12384    Serial number: 0036N0023U5T
       Coding: 0033607
       VCID: 3C77F2297FBCE0DE62-8068
       Subsystem 1 - Serial number: 6332DRB4039A46AC.
       Subsystem 2 - Serial number: 6342DRB4039D4F9D7
       Subsystem 3 - Serial number: 6352ARB40162AD0FT
       Subsystem 4 - Serial number: 6362ARB4016018177
       Subsystem 5 - Serial number: 63729RB40173B171E
       Subsystem 6 - Serial number: 63829RB40173B181G
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                        Reset counter: 39
                        Reset counter: 39
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0701
       Coding: 04141
       Shop #: WSC 06335
       VCID: 418983DD4B5E8D3631-4B00
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 901 E    HW: 8E0 920 901 E
       Component: KOMBI+WFS 4     H14 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0023361
       Shop #: WSC 93204 999 83903
       VCID: 275D3D45953A53061F-5140
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023361
       VCID: 275D3D45953A53061F-5124
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71E9131D3B7E5DB681-4B00
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 CG
       Component: Komfortgerát T7B    4135
       Coding: 11820
       Shop #: WSC 06335
       VCID: 78FF2E3958040CFE46-4AE8
       Component: Tőrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tőrsteuer.BF BRM 0706
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
    7 Faults Found:
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
    00955 - Key 1
                35-10 -  -  - Intermittent
    00956 - Key 2
       Coding: 0000019
       VCID: 29593B7D802E657609-807C
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H03 0010
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH03 0010
       Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
       Component: R Symphony2+    H02 0070
       Revision: 00H02000    Serial number: AUZ1Z4F2825142
       Coding: 0610112
       VCID: 68DF7E7958A49C7ED6-5140
       Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
       Component: FSE_255x BT     H21 0290
       Revision: 00000001    Serial number: 00000000497438
       Coding: 0001677
       VCID: 3D71FF2D67A6E9D655-5140
    End-------------------------(Elapsed Time: 07:17)--------------------------
  7. #16
    Suspect Vehicle is FOD!
    Please verify controller not tampered.
    Check MAF and change the OXS sensors.......
  8. #17
    May 2016
    Canada
    Unfortunetely, there is no MAF on this car but a manifold absolute pressure device.
  9. #18
    May 2016
    Canada
    The car is not trowing any more codes!?! Well, at least there is pending codes but no longer logged codes. I went for a very long drive, about 60kms and no lights. I've posted the output in my previous posts.
  10. #19
    May 2016
    Canada
    wait do you mean my engine is damaged?
  11. #20
    004506 - Fuel Pressure Sensor (G247)
    P119A - 007 - Malfunction - Intermittent
    Fault Status: 00000010
    Reset counter: 38
    Mileage: 201210 km
    Shared tracks........
    Opps forgot than have a look at these.........That dam D51 caught me in WD for going to G70
    G42 - Intake Air Temperature (IAT) Sensor
    G71 - Manifold Absolute Pressure (MAP) Sensor
    G247 - Fuel Pressure Sensor
  12. Likes Uwe liked this post
