Page 1 of 11 123 ... LastLast
Results 1 to 10 of 109
Thread: 07 A4 3.2L P0172 rich code
    May 2016
    Canada
    Hi there,
    first time poster Never had to use my VCDS since 2007! Crazy huh?!?!
    So I'm getting the infamous P0172 error. Normally it's either, from what I could read, a vaccum leak or something dumb like that.
    This is the full scan of the car: could anyone help me figure it out?
    Thanks in advance
    Wednesday,25,May,2016,18:24:47:55111
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WAUEH78E87A046474   License Plate:
    Mileage: 201620km-125280mi   Repair Order:
              67 69 75 76 77
    VIN: WAUEH78E87A046474   Mileage: 201620km-125280miles
    Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
       Part No SW: 8E1 910 559 F    HW: 8E0 907 559 J
       Component: 3.2l V6 FSI         0080
       Revision: --H19---    Serial number:
       Coding: 01040109190F0120
       Shop #: WSC 93009 999 04862
       VCID: 3169D31DA8FE1DB6C1-8064
    6 Faults Found:
    004376 - Oxygen (Lambda) Sensor Heating; B1 S2
                   P1118 - 009 - Open Circuit - Intermittent
                        Fault Status: 00000100
                        Reset counter: 36
                        Mileage: 201190 km
                        RPM: 768 /min
                        Mass Air / Rev.: 179.9 mg/str
                        Temperature: 69.0°C
                            Idle
                        Voltage: 12.44 V
                        Bin. Bits: 00000001
    004407 - Fuel Trim: Bank 1 (Add)
                   P1137 - 007 - System too Rich - Intermittent
                        Reset counter: 38
                        Mileage: 201193 km
                        RPM: 768 /min
                        Mass Air / Rev.: 207.1 mg/str
                        Temperature: 93.0°C
                            Idle
                        Time: 256.0 s
                        Bin. Bits: 00000010
    004506 - Fuel Pressure Sensor (G247)
                   P119A - 007 - Malfunction - Intermittent
                        Fault Status: 00000010
                        Reset counter: 38
                        Mileage: 201210 km
                        RPM: 2752 /min
                        Mass Air / Rev.: 615.9 mg/str
                        Temperature: 90.0°C
                            Part Throttle
                        Pressure: 77.0 bar
                        Speed: 93.0 km/h
    008304 - Intake Manifold Tuning Valve (Bank 1)
                   P2070 - 006 - Stuck Open - Intermittent
                        Fault Status: 00100001
                        Reset counter: 40
                        Mileage: 201620 km
                        RPM: 864 /min
                        Temperature: 30.0°C
                            Idle
                        Absolute Pres.: 441.6 mbar
    004386 - Oxygen (Lambda) Sensor Heating; B2 S2
                   P1122 - 009 - Open Circuit
                        Reset counter: 40
                        Mileage: 201620 km
                        RPM: 768 /min
                        Mass Air / Rev.: 130.8 mg/str
                        Temperature: 57.0°C
                            Idle
                        Voltage: 13.16 V
                        Bin. Bits: 00000001
    000310 - Oxygen (Lambda) Sensor B1 S2
                   P0136 - 007 - Malfunction in Circuit
                        Reset counter: 40
                        Mileage: 201623 km
                        RPM: 768 /min
                        Mass Air / Rev.: 103.6 mg/str
                        Temperature: 93.0°C
                            Idle
                        Load: 14.9 %
       Part No SW: 8E1 910 156 L    HW: 09L 927 156 B
       Component: AG6 09L 3,2 FSI USA 0010
       Revision: --H01---    Serial number:        4207022
       Shop #: WSC 06335 000 00000
       VCID: 306FD619A3F414BECE-8064
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Coding: 0004532
       VCID: 2E53C861B9C0024EDC-807A
                000 -  -  - Intermittent
                        Reset counter: 39
                        Hex Value: 0x0000
                        Hex Value: 0x0202
                        Hex Value: 0x0024
                        Hex Value: 0x0192
                        Hex Value: 0x0001
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2833
       Coding: 00000
       VCID: 6DD10F6D2746B956A5-5124
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  USA 0907
       Coding: 01023
       Shop #: WSC 06335
       VCID: 3D71FF2D37A6E9D655-4B00
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H12 3840
       Revision: 91H12384    Serial number: 0036N0023U5T
       Coding: 0033607
       VCID: 3C77F2297FBCE0DE62-8068
       Subsystem 1 - Serial number: 6332DRB4039A46AC.
       Subsystem 2 - Serial number: 6342DRB4039D4F9D7
       Subsystem 3 - Serial number: 6352ARB40162AD0FT
       Subsystem 4 - Serial number: 6362ARB4016018177
       Subsystem 5 - Serial number: 63729RB40173B171E
       Subsystem 6 - Serial number: 63829RB40173B181G
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                        Reset counter: 39
                        Reset counter: 39
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0701
       Coding: 04141
       Shop #: WSC 06335
       VCID: 418983DD4B5E8D3631-4AE8
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 901 E    HW: 8E0 920 901 E
       Component: KOMBI+WFS 4     H14 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0023361
       Shop #: WSC 93204 999 83903
       VCID: 275D3D45953A53061F-5140
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023361
       VCID: 275D3D45953A53061F-5124
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71E9131D3B7E5DB681-4B00
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 CG
       Component: Komfortgerát T7B    4135
       Coding: 11820
       Shop #: WSC 06335
       VCID: 78FF2E3958040CFE46-4B00
       Component: Tőrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tőrsteuer.BF BRM 0706
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
    6 Faults Found:
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
    00956 - Key 2
                35-00 -  -
       Coding: 0000019
       VCID: 29593B7D802E657609-807C
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H03 0010
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH03 0010
       Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
       Component: R Symphony2+    H02 0070
       Revision: 00H02000    Serial number: AUZ1Z4F2825142
       Coding: 0610112
       VCID: 68DF7E7958A49C7ED6-5140
    No Faults Found
       Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
       Component: FSE_255x BT     H21 0290
       Revision: 00000001    Serial number: 00000000497438
       Coding: 0001677
       VCID: 3D71FF2D67A6E9D655-5140
    No Faults Found
    End-------------------------(Elapsed Time: 06:10)--------------------------
    OBD DTCs erased
    OBD DTCs erased
    Please check fuses and isolate faulty OXS heater/sensors and all shared tracks.
    Is this car tuned?
    Some of those fault codes are definitely electrical in nature, not just a vacuum leak.
    May 2016
    Canada
    hi, i must say i'm a learner in the field
    I just got p0036 pending as well.
    the car is absolutely bone stock!
    OXS shared tracks? ill have to look it up because i dont know what is.
    thanks
    OXS = Oxygen sensor and it can be searched in WD very easy.
    May 2016
    Canada
    it appears both of my o2 sensor post-cat gets a reading of 7.2 ohms (reading with the 200ohms) if that makes sense. Looks to be good!
    May 2016
    Canada
    Oh my ... I should've read the whole auto-scan before posting! I have like 8 service engine soon codes.
    What's the logical steps here? If the o2 sensors are good.
    Thanks in advance
  9. #8
    May 2016
    Canada
    One more thing that I would like to add. Sometimes, no always, I'll get a rough cold start. The engine will stumble and then it will be ok.
  10. #9
    Ahhh you have DTC's for open circuits...........
    Don't rely on block values at this time and find the shorted, open or missing link.
    Consider changing the OXS sensors if fuses and wiring are good.
  11. #10
    May 2016
    Canada
    Considering that I have a P0032, which is bank 1 sensor 2 and the fuel mixture too rich, my first play would be to change that OXS. It's 140$ CAD so i'm in luck
    Thanks once more Jack!
  12. Likes Jack@European_Parts liked this post
