Monday,16,May,2016,12:50:06:47536
VCDS Version: 16.5.0.4 HexNet CB: 0.4317.4
Data version: 20160506 DS251
VIN: 3VW217AU8GM029766 License Plate:
Mileage: 62km-38mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VW217AU8GM029766 Mileage: 62km-38miles
Address 01: Engine (J623-CXBB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00122424002F0000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: BFC140B126C48CBBC2-80EA
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels: 09G-927-749.clb
Part No SW: 09G 927 749 AP HW: 09G 927 749 AP
Component: AISIN AG6 G3 129 2943
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031.rod
VCID: 875198513E94047BBA-80D2
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 52345000001819
Coding: 01FA6AA124220975007E020681C9298056249000408194B400430050C002
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: CBD96461627C201B5E-809E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 HW: 5GM 907 426
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000000000000000002
ROD: EV_ACManueBHBVW37X.rod
VCID: 854D92590498166BC8-80D0
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 087 T HW: 5Q0 937 087 T
Revision: -------- Serial number: 86582308150143
Coding: 000018424041804169E44000000403001000000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
VCID: CCDB677D6772272357-8098
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150520 043 0581
Serial number: 151023010543
Component: AirbagVW20 010 0830
Serial number: 003GCR0311XA
VCID: C7D158517E14C47B7A-8092
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH000000000003GKDNZ
Coding: 303133
Subsystem 2 - Part No SW: ----------- HW: 480 001 408 15
Serial number: 357000000004D714E51L
Subsystem 3 - Part No SW: ----------- HW: 480 002 008 15
Serial number: 358000000005378D661M
Subsystem 4 - Part No SW: ----------- HW: 480 402 908 15
Serial number: 3510002B31C1EFA24288
Subsystem 5 - Part No SW: ----------- HW: 480 401 808 15
Serial number: 3520002AB1CB0C02427+
Subsystem 6 - Part No SW: ----------- HW: 480 401 408 15
Serial number: 3550002B31D1B622A2E5
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 408 15
Serial number: 3560002C11D1B623B3A4
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150920500541
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 5G1 920 840 A HW: 5G1 920 840 A
Component: KOMBI 242 6420
Coding: 0BB4190AA180CF0502086A001000000000000000
VCID: A50DF2D9A458366BA8-80F0
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2223
Revision: -------- Serial number: 11091510803692
Coding: 0101000830085900FB0000081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
ROD: EV_GatewConti.rod
VCID: F4ABDF9D5F021FE3EF-80A0
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P
Component: E221__MFL-DC1 H16 0101
Serial number: 29150001398750055274
Coding: 31FFFF
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 20081506050184
Coding: 003003200000040000000000
VCID: C1C546495030FA4BB4-8094
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000001910665
Coding: 011000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0102
VCID: C4CB4F5D4F22EF639F-8090
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 1809150605015D
VCID: C0C3434D5B3AF343BB-8094
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000001918606
Coding: 091000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 02730000FF00000051220001001808001F0100D40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: EC9BC7FD0732C72337-80B8
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RES00QLA
6 Faults Found:
1600 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 53
Mileage: 7 km
Date: 2011.01.06
Time: 22:32:41
Voltage terminal 30: 11.9 V
1659 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 53
Mileage: 7 km
Date: 2011.01.06
Time: 22:32:41
1660 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 53
Mileage: 7 km
Date: 2011.01.06
Time: 22:32:41
1661 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 53
Mileage: 7 km
Date: 2011.01.06
Time: 22:32:41
6691 - Local Data Bus
U10BA 00 [008] - No Communication
Reset counter: 54
Mileage: 49 km
Date: 2016.04.02
Time: 17:49:08
Voltage terminal 30: 14.2 V
Network diagnosis-Status: not enabled
7169 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 42
Mileage: 7 km
Date: 2011.01.06
Time: 20:07:06
Voltage terminal 30: 12.3 V
BAP-BAP_Function_ID: 0D
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
ROD: EV_OCULowMQB.rod
VCID: C3C94C414A2CE85BA6-8096
End-------------------------(Elapsed Time: 01:30)--------------------------
