Results 1 to 4 of 4
Thread: Audi TT - 8N0 - change abs module
    Sketchy
    Mar 2015
    Poland
    Hi firends,
    I have little problem, abs module is dead, 8N0309379D, I put used 8N0309379 E (quattro), I can't change coding to FWD, only accept AWD. How change coding ?
    I read on uncle google, that this pump have hard method codign, what is ?
    THX for help
    Wednesday,01,June,2016,14:35:33:27911
    VCDS Version: 15.7.4.1
    Data version: 20160216
    VIN:    License Plate: AUDI TT
    Mileage: 226050km-140460mi   Repair Order:
    Chassis Type: 8N - Audi TT (1999 > 2007)
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
       Mileage: 226050km-140460miles
    Address 01: Engine        Labels: 06A-906-032-AJQ.lbl
       Part No: 8N0 906 018 AB
       Component: 1.8L R4/5VT         0002
       Coding: 05500
       Shop #: WSC 06435
       VCID: 71E9DD883BC41DB681-515E
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.lbl
       Part No: 8N0 907 379 E
       Component: ESP     20    CAN  V005
       Coding: 18448
       Shop #: WSC 06435
       VCID: 3E7336B43A1AB2CE4C-4B00
                35-00 -  -
                57-00 - Electric Circuit Failure
                49-00 - No Communications
                62-00 - No or Incorrect Adjustment
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043
       Component: TT-KLIMAVOLLAUTOMAT D00
       Coding: 00040
       Shop #: WSC 06435
       VCID: 67DDB3D00500D306DF-2580
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 0004
       Coding: 10102
       Shop #: WSC 06435
       VCID: 77FDE39055A043864F-5198
    Address 17: Instruments        Labels: 8Nx-919-xxx-17.lbl
       Part No: 8N1 919 880 E
       Component: KOMBI+WEGFAHRS. M73 D30
       Coding: 00044
       Shop #: WSC 23060
       VCID: 3F8D4BB03D10BBC647-4B1A
       Subsystem 1 - Part No: Ident
       Component: Nr. Wegfahrs.:AUZ5Z0DD146110
       Ident.-Nr. Wegfahrs.:AUZ5Z0DD146110
    Address 35: Centr. Locks        Labels: 8Nx-962-267.lbl
       Part No: 8N8 962 267
       Component: Zentralverrieg.,DWA D01
       Coding: 04682
       Shop #: WSC 27022
       VCID: 7EF3F6B47A9A72CE0C-4F20
    6 Faults Found:
    01366 - Opened Due to Crash Signal
                35-00 -  -
    01370 - Alarm triggered by Interior Monitoring
                35-00 -  -
    01616 - Signal Wire to Interior Monitor
    00956 - Key 2
                09-10 - Adaptation Limit Surpassed - Intermittent
    01560 - Passenger Door
                60-00 - Won't Safe
    01617 - Please Check DTC Memory of Interior Monitoring
                35-10 -  -  - Intermittent
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8N8 951 177
       Component: Innenraumueberw.    D07
       Coding: 00001
       VCID: 7CF7FCBC6C8660DE22-5198
    01463 - Alarm triggered by Sensor for anti-theft alarm System
                35-00 -  -
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 186 D
       Component:  Radio             0001
       Coding: 00517
       Shop #: WSC 06435
       VCID: 2149EDC8ABA4ED3651-4B1A
    00852 - Loudspeaker(s); Front
                36-00 - Open Circuit
    00854 - Radio Display Output in dash Panel insert
    HQ
    It looks like you can't change it... You've installed an ABS module designed for AWD, that is how it will be.
    http://forums.ross-tech.com/showthre...ed-parts-Maybe
    Jef
  3. Likes sazimam liked this post
    Nov 2014
    New Zealand
    You just need to install quattro to match, now.
    Nov 2015
    Czech Republic
    CARAT10, have you solved this somehow?
    I am facing exactly the same issue. About to move processors (with its internal Flash memories) from old bad module to the new one because recoding is not possible, unfortunatelly.
    I think you need to code your unit to : 23049, right ?
    Thank you.
