Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Tis’ the HVAC Season
    16.4905° S, 151.7375° W
    By: DrPeter
    Intro:
    In this Tech Tip I will be explaining some quick and easy diagnostic tips for the Volkswagen/Audi HVAC systems. We will be focusing on the systems that are diagnosable with the VCDS scan-tool. Even though the system designs maybe slightly different between brands and models, they are generally similar enough that we can diagnose them using the information contain herein. It is always advisable to use the current repair information and training materials available and understand the system that you are working on, a little time spent learning will save you a lot of wasted time fixing your mistakes when you could have been fixing the vehicle.
    Warning:
    Yep, got to say this stuff because frostbite hurts more when the flesh thaws and blindness caused by refrigerant gases blasting out at 400psi can really suck when trying to work on cars, so... As with any potentially hazardous system of the automobile, we must remember to follow all of the manufacture’s safety, caution and warning notices found in the Factory Repair information. Also pay attention to any local, state or government laws regarding properly trained and/or licensed personal when working with regulated materials, such as refrigerants. If you do NOT know what you are doing or have not been properly trained, STOP! HALT! ARRÊT ¡ALTO! 停止
    Training:
    I have been trained in many aspects of the automotive and commercial HVAC systems (and living in SW Florida helps, AC season 365). I suggest anyone who is working with the HVAC systems in the Automotive world to get the right training and certifications, in 1993 I became a member of http://www.macsw.org , Mobile Air Conditioning Society (MACS) Worldwide, went to the class and became certified, so I suggest to cover your butt!
    Diagnose first, then fix:
    Diagnosing the modern Volkswagen/Audi HAVC system can be a bit challenging at times, certainly not impossible and troubleshooting is now easier with newer HVAC Controllers having more diagnostic capabilities compared to older generations. Yes, I will try to do a small tech tip on the older MK4 systems, though these systems are not completely diagnosable with the VCDS tool.
    Here are the quick and easy checks you can use to help identify the cause of the concern within the HVAC system.
    1) Check the basics in the [08-Auto HVAC] controller with VCDS.
    • Address any fault codes accordingly, use the Ross-Tech wiki and or repair manual
    • Make sure Basic Setting are complete
    • Verify coding is correct
    • Check for correct part numbers or controller updates
    2) Check the Measuring Value Blocks(MVBs) for the following (most MVBs will be labeled and you will be able to identify the data in the field):
    • Compressor shut off code
    • Refrigerant Pressure from the Sensor G65
    • Outside Temperature (filtered and unfiltered) (adjusted vs. not adjusted)
    • Evaporator Temperature
    • Vent Temperatures
    3) Check actual Refrigerant pressure
    • The best way to check AC system pressure is to use a good quality AC Gauge set. Verify the system has pressure, because the Refrigerant Pressure Sensor G65 maybe incorrect and the MVB data could show a different pressure. Also remember what Jef says, check the charge, pressure will not indicate a full charge.
    • Learn how to read the gauges, it is like reading between the lines, it will tell you a lot!
    4) Check for proper operation of cooling fans
    • In many vehicles an [01-Engine] [Output Test] will activate BOTH fans, if equipped
    • The HVAC system in many cases will not function when the fans have failed. Check ECM for codes too.
    5) Check for damage:
    • Compressor shaft is spinning (shear hub is not damaged)
    • Wiring, connections’
    • Hoses, fittings and missing valve caps(primary seal)
    Addition notes, tips:
    On some 2006 to 2009 vehicles it may be necessary to reset the Temperature Sensor, this can occur when the AC controller or ambient temperature sensor were replaced. To reset the Temperature Sensor, drive the vehicle above 30mph or let the vehicle sit, engine idling, for about 20 minutes.
    2012 and newer Jetta sedans may have a customer concern of A/C shutting off when coming to a stop. When checking the HVAC controller for the Compressor Shut off code, [12- Shut-Off requested by Engine Control] maybe found, this is usually considered normal, the ECM is programmed to command the HVAC controller to shut off the compressor to allow increased engine rpm/vacuum when braking, mostly when the engine is cold, pre-catalyst operating temperature.
    If your compressor shut off code is [0], check the N280-Refrigerant Regulating Valve** valve, this is what regulates the amount of refrigerant that the compressor ‘pumps’ through the system. The N280-Refrigerant Regulating Valve activation signal can be checked with an incandescent light bulb in its place. Unplug the N280-Refrigerant Regulating Valve, connect a test bulb to the connector from the HVAC controller and start the vehicle, turn on the AC and watch for the activation command from the HVAC controller. If the bulb lights and the compressor had failed to operate prior, then the N280-Refrigerant Regulating Valve and/or compressor has most likely failed.
    Here is a list of typical Compressor Shut off codes:
    - 0 = Compressor ON
    - 1 = Compressor OFF: Refrigerant Pressure too high (> 32 bar)
    - 2 = compressor OFF: Basic setting not performed
    - 3 = Compressor OFF: Refrigerant Pressure too low (< 2.0 bar)
    - 5 = Compressor OFF: Engine Start Detection
    - 6 = Compressor OFF: ECON Mode active
    - 7 = Compressor OFF: A/C System / FAN OFF
    - 8 = Compressor OFF: Outside Temperature too low (< 3.0 °C)
    - 10 = Compressor OFF: Vehicle System Voltage too low (< 10.1 V)
    - 11 = Compressor OFF: Engine Temperature too high (> 118 °C)
    - 12 = Compressor OFF: Shut-Off requested by Engine Control
    - 13 = Compressor OFF: Vehicle System Voltage too high (> 17 V)
    - 14 = Compressor OFF: Evaporator Temperature too low
    - 16 = Compressor OFF: Compressor Activation faulty
    - 17 = Compressor OFF: No or implausible Signal Pressure Sensor
    - 18 = Compressor OFF: Vehicle Speed Shut-Off
    - 19 = Compressor OFF: Shut-Off requested by Central Electronics Control (Load Management)
    (This list may vary form vehicle to vehicle, Example: The Audi A6 (4F) is different, so check your repair manual or Measuring Value Block pop-up)
    The newer HVAC systems use a pressure sensor – G65, not a pressure switch. The G65 can send information about the refrigerant pressure to the HVAC controller, a pressure switch, like the F129 cannot.
    • Located in the same place as the F129, the G65 is different, yet does the same functions as the F129.
    • It uses a pressure sensor and a microprocessor to create a PWM (Pulsed-width Modulated) signal
    • Pin 1 & 3 provide Ground and Power, PWM signal is on Pin2.
    Update: August 31, 2015
    The following Information has been deemed useful:
    - 2006+ Volkswagen New Beetle/Convertible, the N280-Refrigerant Regulating Valve is controlled by the ECM.
    Use Measuring Value Block 135, 136 and 137 for information about,
    ... the Duty cycle of the coolant fan
    ... the Relay 1 for the coolant fan
    ... the coolant fan after-run
    ... Condition of the AC
    ... Condition of the AC Compressor
    ... A/C-Pressure
    ... Fan request from A/C-System
    -2006 to 2010 Volkswagen New Beetle/Convertible.
    Fault codes P2612 and P2613 - may caused by wiring connections and or wiring harness routing/damage.
    see the Ross-Tech wiki page for more information.
    19044/P2612/009746 - A/C Refrigerant Distribution Valve: Short to Ground
    -2011 to 2015? Jetta and 2012 to 2015? Beetle - A/C Controller Basic Settings. (just in case you did not see the wiki page)
    - 00898 - Control Circuit A/C Compressor: No or incorrect Basic Settings
    Added Information (12 July 2016):
    G65 Pressure vs. Temperature chart
    (When key is on, engine is off, static system pressure)
    15C - 59F - 4.0 bar
    20C - 68F - 5.0 bar
    25C - 77F - 6.0 bar
    30C - 86F - 7.0 bar
    35C - 95F - 8.0 bar
    40C - 104F - 9.0 bar
    Important to note about the G65 sensor:
    - A reading of 0.0 bar would indicate an absolute vacuum
    - At Sea Level (atmospheric pressure) the typical reading is 1.0 bar
    Typical N280-Refrigerant Regulating Valve resistance (on working vehicle) = 10-12 Ω
    Added Information (1 June 2018):
    We strongly recommend NOT to plug the 'V51 - Coolant after run pump' connector to the N280-Refrigerant Regulating Valve.
    -If this is done, the HVAC system will not cool the vehicle.
    - This can happen, usually when there was repair work to the front of the vehicle.
    Someone accidentally swaps the two connectors.
    - There should be a fault code for the N280, see below example, mostly this happens with the 2.0L Volkswagen, where the connectors are close enough to each other so that they can be swapped.
    Example from a 2011 Passat CC 2.0L(CBFA-engine)
    This vehicle had a fault code in the [08-Auto HVAC] controller: B10A9-Control Circuit for A/C Compressor
    N280 connector
    Pin1 = br/sw
    Pin2 = gn/sw
    V51 connector
    Pin1 = vi/rt
    Pin2 = br
    Well, hope this helps and remember to check your basics, that includes any technical service bulletins TSBs that may apply,
    drpeter
    Last edited by DrPeter; 06-01-2018 at 02:40 PM. Reason: Added Information (12 July 2016)
    Mar 2014
    2009 A5 3.2 6 speed in AC hell. AC was working fine. Car sat idle for a few weeks, started car, no AC. Car has just over 75K miles, I have worked on my own AC for some time now as it seems every car I own has AC problems. I am not by any means an expert but I do okay, used to a 1967 Chrysler where if the compressor was bad you could pull the head on it and replace the reed valves. I am, however, a high mileage driver (put 290K on my 98 2.8 A4 stick, mostly NYC miles- two Denso compressors). Seems the A5 does not have an AC clutch, but rather a drive hub. I cannot see a wire going to it and cannot find one on the electrical diagram or a fuse for it (Bentleys). I could not get a signal going to the N280 Regulator valve with a Fluke VOM (Did read a small signal 0.07V DC, reading measuring blocks it was switching 0-.7 Amp reading 8.6 Bar). Bentleys calls for using an oscilloscope looking at the square wave, apparently runs off pulse width (PWM). Going through measuring blocks did not see much for labels of what I was looking at. I do take suggestions.
    At stand still I am measuring about 85 PSIG high and low side with gauges which would appear to be a full charge, 80 deg. F.
    I am posting the autoscan Previous fault codes were the right door lock, Headlight leveler, radio codes, (works fine), seat memory (who cares) and the left floorwell flap motor as below.
    I hope I pasted this okay.
    I sincerely appreciate any and all help. I am also going by Audi in the morning and will attempt to talk to a tech.
    Rich
    Wednesday,25,June,2014,18:40:36:42395
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUDK78T29A046369   License Plate:
    Mileage: 123280km-76602mi   Repair Order:
    Chassis Type: 8T (8T0)
    Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 3C 42 46
              47 52 53 55 56 65 67 6C 77
    VIN: WAUDK78T29A046369   Mileage: 123280km/76602miles
    55-Xenon Range -- Status: Malfunction 0010
    Address 01: Engine (J623-CALA)       Labels: 06E-907-559-CAL.clb
       Part No SW: 8T0 907 559 G    HW: 8T0 907 559 B
       Component: 3.2 SIMOS8.2  H04 0002
       Revision: --------
       Coding: 01140009180F0121
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM32FSI8T0907559G A01004
       ROD: EV_ECM32FSI8T0907559G.rod
       VCID: 4683ED7DF902762EE1B-8013
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
       Component: ESP8 quattro  H04 0210
       Coding: 0D0500
       VCID: 7DF14291E454F5F6F01-8028
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 0145
       Coding: 0F0000
       VCID: 75E15AB1DC64ADB6B81-8020
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
    03286 - Sensor for Contact with Door Handle; Front Right
                008 - Implausible Signal
                        Fault Status: 01101000
                        Fault Frequency: 109
                        Reset counter: 169
                        Mileage: 120204 km
                        Date: 2014.05.01
                        Time: 18:39:55
                        Fault Status: 00100111
                        Reset counter: 190
                        Mileage: 121778 km
                        Date: 2014.05.16
                        Time: 18:41:37
    Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
       Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
       Component: MEM-BFS       H09 0043
       Revision: AA000000    Serial number: 00001001236533
       Coding: 08017025002400001000
       VCID: 428BF16DDD2A4A0ECD3-8017
                        Fault Frequency: 62
                        Mileage: 119713 km
                        Date: 2014.02.07
                        Time: 19:16:57
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 340BK097519422
       Coding: 0005003
       VCID: 4385F46902304306C65-8016
       Subsystem 1 - Part No: 8T0 919 609 D
       Subsystem 2 - Serial number: 00000000236262
       Subsystem 3 - Serial number: 0107.02.090000000100010532ˇ
       Subsystem 4 - Serial number: 010532ˇ
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0150
       Revision: C1000000    Serial number: 01180220090164
       Coding: 46022000
       VCID: 72EB61ADAD0ABA8E9D3-8027
    00711 - Left Footwell Flap Positioning Motor (V108)
                        Fault Status: 00100001
                        Reset counter: 206
                        Mileage: 123042 km
                        Date: 2014.06.22
                        Time: 13:02:44
                        Voltage: 14.00 V
                        Temperature: 24.0∞C
                        Temperature: 23.0∞C
                        Count: 15855
                        Count: 16291
                        Bin. Bits: 01000000
                        Bin. Bits: 10000001
                        Time: 29.00 s
                        Fault Status: 00101101
                        Reset counter: 209
                        Mileage: 123284 km
                        Date: 2014.07.23
                        Time: 14:03:46
    00256 - A/C Pressure/Temperature Sensor (G395)
                        Reset counter: 209
                        Mileage: 123284 km
                        Date: 2014.07.23
                        Time: 14:03:46
                        Temperature: 27.0∞C
                        Reset counter: 209
                        Mileage: 123284 km
                        Date: 2014.07.23
                        Time: 14:04:44
                        Temperature: 27.0∞C
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H24 0253
       Revision: 05024001    Serial number: 00000000326538
       Coding: 26001091063CAF010000080300003D3D0F1C138800010161000000
       VCID: 306FABA56386C89E2B7-8065
       Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 090209  H13 0040
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 AC    HW: 8K0 941 531 AC
       Component: E1 - LDS  H07 0090
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
                        Reset counter: 209
                        Mileage: 123284 km
                        Date: 2014.07.23
                        Time: 14:03:00
                        Reset counter: 209
                        Mileage: 123284 km
                        Date: 2014.07.23
                        Time: 14:04:00
       Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
       Component: MP3-Changer     H43 0390
       Revision: 00043003    Serial number: AUZ5ZBI8752472
       VCID: 2A5BB9CD855AB24EE53-807F
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7I0517809
       Coding: 0000100
       VCID: 3169AEA1A88CC196249-8064
                        Reset counter: 163
                        Mileage: 122742 km
                        Date: 2014.06.20
                        Time: 19:02:41
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 F    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0040
       Revision: 11001001    Serial number: 40140906201564
       Coding: 200001
       VCID: 3C778F95BFCE3CFE87F-8069
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Serial number: 0039KD14WFGR
       Coding: 303333334330303030304A55304C38543053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 408FFB65DB26581EDB7-8015
       Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
       Component: BF-Gewichtss.  H01 0050
       Serial number: 5810000R0900003B7Z
       Serial number: 6334MSME45140D37A
       Crash sensor for side airbag; passenger side:
       Serial number: 6344MSME454256415
       Crash sensor for side airbag; rear driver side:
       Serial number: 6352QSME7E222F04N
       Crash sensor for side airbag; rear passenger side:
       Serial number: 6362QSME15220018/
       Serial number: 63732SME3C210D00U
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME4A213B3C3
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90319IBN0006E
       Coding: 000016
       VCID: 3D718291A4D435F6B01-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 981 D    HW: 8T0 920 981 D
       Component: KOMBIINSTR.   H32 0224
       Revision: 00200000    Serial number: 9D434VR29
       Coding: 8B1501000B00D705020000
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 Q    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0095
       Revision: FB600048    Serial number: 4800F092130010
       Coding: 000303
       VCID: 4FADC8591E78B76652D-801A
       Component: J367-BDM  H06 0160
    Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H20 0850
       Revision: 00000000
       Coding: 020000
       VCID: 2B55BCC94AA0AB461E5-807E
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Component: MEM-FS        H09 0043
       Revision: AA000000    Serial number: 00001001237366
       Coding: 08197B25002400001000
                        Fault Frequency: 33
                        Mileage: 119713 km
                        Date: 2014.02.10
                        Time: 13:36:05
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
       Component: MNS US          H52 1100
       Revision: 00000000    Serial number: 341BN097524482
       VCID: 387F93854BF610DE637-806D
    Address 3C: Lane Change        Labels: None
       Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0050
       Revision: 00H01000    Serial number: 6PZ 009 014-13
       Coding: 0000004
       VCID: 36639DBD41E2E6AE71B-8063
       Subsystem 1 - Part No: 8K0 907 568 B
       Component: J0770_SWA_Slave_H01 0050
       Subsystem 2 - Serial number: 6PZ 009 014-33
       Subsystem 3 - Serial number: 5F27.02.0900H010003CD10153ˇ
       Subsystem 4 - Serial number: D10153ˇ
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000008546662
       Coding: 011C13224E00120102
       VCID: 4189FE61D82C5116D49-8014
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0116831091
       Coding: 0106029A007A444500B000
       Component: GTO BF  H06 0040
       Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
       Component: J245EE16SKB10  H01 0180
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 207
                        Mileage: 111078 km
                        Date: 2013.06.21
                        Time: 16:59:42
    02616 - Fuel Tank Cap; Unlock
                        Fault Frequency: 11
                        Reset counter: 165
                        Mileage: 111078 km
                        Date: 2013.06.21
                        Time: 17:00:24
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
       Component: DSP Prem      H14 0400
       Revision: 00H14003    Serial number: 34814004112301
       Coding: 030101
       Shop #: WSC 12336 024 394758
       VCID: 3F8DF899AED827E6A2D-806A
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000008494927
       VCID: 408FFB65D326581EDB7-8015
       Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
       Component: EPB Audi B8   H08 0080
       Revision: 00000003    Serial number: 00000000319528
       VCID: 3365A4A99290F386565-8066
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                        Fault Status: 00101011
                        Reset counter: 28
                        Mileage: 115378 km
                        Date: 2013.09.18
                        Time: 18:56:38
                        Voltage: 12.70 V
                        Count: 28
                        Hex Value: 0x0163
                        Hex Value: 0x0008
                        Hex Value: 0x0101
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                        Reset counter: 28
                        Mileage: 115378 km
                        Date: 2013.09.18
                        Time: 18:56:38
                        Voltage: 12.70 V
                        Count: 29
                        Hex Value: 0x0173
                        Hex Value: 0x0008
                        Hex Value: 0x0101
    Address 55: Xenon Range        Labels: 8T0-907-357.clb
       Part No SW: 8H0 907 357 A    HW: 8H0 907 357
       Coding: 0000017
       Shop #: WSC 06324 000 00000
       VCID: 306FABA5A386C89E2B7-8065
       Subsystem 1 - Part No: 7L6 941 329 C
       Component: AFS-Modul links H01 0004
       Subsystem 2 - Part No: 7L6 941 329 C
       Component: AFS-Modul rechtsH01 0004
    00496 - Sensor for Vehicle Leveling; Front
                        Fault Status: 00101010
                        Reset counter: 210
                        Mileage: 111195 km
                        Date: 2013.06.24
                        Time: 14:50:22
                        Reset counter: 184
                        Mileage: 118874 km
                        Date: 2013.12.12
                        Time: 11:41:07
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
       Revision: 00000000    Serial number: 357C.097524299
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140790108965
       Coding: 0CD154
    Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
       Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
       Component: SDS 3501 US     H46 0630
       Revision: 00000000    Serial number: 00000901290297
       VCID: 3467A7B5579EF4BE4FF-8061
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J9190RN
       Coding: 1000008
       VCID: 377D90B946E81FA66AD-8062
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4F0 910 336 H    HW: 4E0 862 335
       Component: Handyvorb2      H20 1130
       Revision: 00000000    Serial number: 00000005080854
       Coding: 0010900
       VCID: 285F43C59B56805EF37-807D
    Last edited by Uwe; 07-01-2014 at 05:52 PM. Reason: Wrapped CODE tags around Auto-Scan
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Rich View Post
    Your symptoms and your DTCs align closely with a known issue on that G395 sensor. Apparently it's common for the wiring to that sensor to fail or be damaged. Audi put out a TSB which you can find on AudiWorld thread attached to post #6.
    You do have a stack of other interesting faults, and the above doesn't explain the G238 sensor error. Has the car been in a collision, or had water damage? The TSB indicates a probable wiring problem, but your damage location might not be one of the common ones.
    Jason
  4. Likes Uwe, Dana liked this post
    Mar 2014
    Thanks, I'm trying to retrieve the TSB unsuccesfully, I am not a member of AudiWorld, I am not sure why I cannot access it from my ebahn bentleys manual.I emailed them. Audi took my VIN number and told me this morning there were no TSB's on the AC for the car.
    Thanks again for your help.
    Rich
    Cincinnati, OH
    I've placed a copy of the TSB on my own virtual host here:
    http://10104.x.rootbsd.net/~jyoung/vwvortex/AC_TSB.pdf
    Jason
    Mar 2014
    Thanks I'm printing it out now. I was also going to call Ross Tech and pay for support to help me with analyzing the signals (if any), perhaps that's why I'm not getting the proper measuring block information.
    Rich
    Cincinnati, OH
    Rich
    The "Labels: Redir Fail!" text in the address 08 scan means it found a pointer to where the label file should be, but could not find the label file itself. In your case, it's looking for the file 8Tx-820-043-3Z.CLB. I did a bit of Googling and it looks like VCDS has files similar to that in at least two regional translated versions of VCDS, but not in English. That leaves one of two possibilities: there was a packaging oops and the English label file didn't make it into the installer, or the initial label file work was done in a foreign language and hasn't been translated into English yet.
    Either way, I suspect this is something Ross-Tech can help you with very easily.
    Jason
  9. Likes Uwe, Rich liked this post
  10. #8
    Mar 2014
    Thanks The TSB had the wiring problem which looked like it, but the lines ring clear, power, signal and ground,(Fluke V-O-M)
    Rich
  11. Likes sbcncsu liked this post
  12. #9
    Mar 2014
    Update, all fixed Press Temp sensor G395.
    Rich
  13. Likes jyoung8607, Uwe, Dana, jakematic liked this post
  14. #10
    United States
    The linked attachment in Bernard's AC not working on 2008 VW Jetta TDI thread should be helpful for Mk5 (1K chassis) VW diagnosis including similar vehicles such as the (8P) A3 and (8J) TT which used Golf based CAN protocol #08 modules.
  15. Likes Sternfels liked this post
