Results 1 to 5 of 5
Thread: Surface Pro Communication fix, Alter the Power settings.
Hybrid View
    Lansdale, PA
    We've had a few reports of HEX-NET users having coms issues with the Surface Pro tablet. We've found a fix requiring a registry tweak, and a power management setting. By default, the surface pro will only have balanced power settings with very little control over the management. The following instructions will re-enable the individual settings.
    Registry Modification: Script:
    Right Click, Save As
    Then run the file and reboot.
    Come back to this thread and see "Disable wireless Adapter power savings"
    If you are not comfortable running a registry script, follow the instructions below.
    Registry Modification Manual Instructions:
    Step 1: Open Regedit.exe (search from start menu is the fastest way to get to it)
    Step 2: navigate down the registry tree:
    HKEY_local_Machine -> System -> ControlSet001 -> Control -> Power
    Double Click CsEnabled and change the stored value to 0. Then press ok.
    Step 3: reboot
    Last edited by Santos; 05-12-2016 at 02:39 PM. Reason: Splitting into two posts for hyperlinking.
  2. Likes Eric, Uwe, Dana, Andy, DrPeter, Jef, gawied, Adam liked this post
  3. #2
    Lansdale, PA
    Disable wireless Adapter power savings:
    Step 1: right click on the window start menu, and select power options
    Step2: to the right of the Balanced (recommended) profile, Click on Change plan settings.
    Step 3: click on the Changed Advanced Power settings link
    Step 4: click on + next to Wireless Adapter Settings. Click on + next to Power Saving Mode:
    Change the On battery profile to Maximum Performance.
    Click ok.
    Reboot, and rescan!
  4. Likes Dana, Uwe, mattylondon, gawied, Boki Ar liked this post
  5. #3
    Oct 2014
    Arandjelovac, Serbia
    Arrow
    Santos, screen-shot above You make on Win 10? I ask because i don't want W10 on my PC, even Win8 but i have to know when customer come with another machine & OS... My screen on W7:
    Lansdale, PA
    Hi Bojan, Yes, it was taken with win 10. Win 8 should look very similar as well.
  7. Likes Boki Ar liked this post
  8. #5
    Oct 2014
    Tnx dear friend!
