- Joined
- Apr 9, 2014
- Messages
- 2,304
- Reaction score
- 2,252
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Car is retrofitted with rcd510 and bluetooth module.
Steering wheel is older style, with 8 buttons.
Is it possible to get the answer button to answer calls? VOL UP, VOL DOWN and MUTE work as they should, but not the answer.
If i look at steering wheels measurement blocks, than i can see, that the answer button changes the value on correct block.
Maybe the issue is that the rcd is from 2012 and has only BAP protocol. The view on cluster isn't important, but getting the button to work is.
Friday,30,May,2014,15:32:04:01666
VCDS Version: 14.5.3.0 (x64)
Data version: 20140522
Workshop Code: 257 66565 000032
VIN: WVWZZZ3CZ8E004036 License Plate: PASSAT RCD510
Mileage: 231820km-144046mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 36 42 44 46 52 53 56 62 6D 72 77
VIN: WVWZZZ3CZ8E004036 Mileage: 231820km-144046miles
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 NK HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 9972
Revision: --H07--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00854 461 81279
VCID: 75E113911CC7B493E2-8020
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
Component: J104 C4 440 V1 0003
Revision: --020--- Serial number: 00000775272429
Coding: 0000267
Shop #: WSC 05311 000 00000
VCID: 1E332C3DC9B157CBD3-804B
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CB HW: 3C0 907 044 CB
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
VCID: 63C55DC9A2533A23BC-8036
014 - Defective
Fault Status: 01101110
Reset counter: 54
Mileage: 231820 km
Date: 2014.05.30
Time: 14:48:54
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 01000007119229
Coding: F5888F0700041A00470A00000F00000000195D435C400100000000000000
Shop #: WSC 05124 123 12345
VCID: 71E9278168AF98B33E-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 110407 003 0205
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 240507 020 0105
Coding: 00471077
Shop #: WSC 05124
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0B AIRBAG VW8 032 2522
Revision: 12032000 Serial number: 003B1P9B9PCK
Coding: 0012354
VCID: 306FE285A325D1BB71-8065
Subsystem 1 - Serial number: 6332MSME19447C67
Subsystem 2 - Serial number: 6342MSME176C665E
Subsystem 3 - Serial number: 6351HTS6LNFCUJU6
Subsystem 4 - Serial number: 6361HTS65JH4O1N6
Part No SW: 3C0 953 549 M HW: 3C0 953 549 M
Component: J0527 0015
Revision: 00006000 Serial number: 3C9953507BJ
Coding: 0000112
Shop #: WSC 66565 257 00032
VCID: 3663D49D4141FF8B2B-8063
Component: E0221 002 0010
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00011 888 96745
VCID: 264304DD91E18F0B9B-8073
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0752500F1
Coding: F980FF060206022002
VCID: 23451DC9E2D37A23FC-8076
01304 - Radio
Reset counter: 94
Mileage: 231820 km
Date: 2014.05.30
Time: 15:11:40
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 3979DFA1705F10F3C6-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
VCID: 2D51FBF1B417BC535A-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000022378502
Coding: 0000503
VCID: 3C77C6B57F6D25DBDD-8069
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
VCID: 3561D3915C47F49322-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 00900A00D1030E76300294157008CF0E707C00
Shop #: WSC 05311 123 12345
Component: LIN BACKUP HORN H07 9001
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000575878508
Coding: 0000502
VCID: 3D71CBB164772CD3EA-8068
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000017869
Coding: 0000056
VCID: 29590FE180FFA073B6-807C
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 051 0213
Revision: 00000001 Serial number: VWZ1Z3M8402607
Coding: 00000401040000
VCID: 23451DC922D37A23FC-8076
00856 - Radio Antenna
Reset counter: 54
Mileage: 231820 km
Date: 2014.05.30
Time: 15:14:13
Fault Status: 00101011
Reset counter: 94
Mileage: 231820 km
Date: 2014.05.30
Time: 15:14:13
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1119
Revision: 11006001 Serial number: 00000001764643
Coding: 0000208
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0405
Revision: 00H21001
Shop #: WSC 23250 384 715754
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0700H21001001B0138˙
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1119
Revision: 11006001 Serial number: 00000001733500
Coding: 0000208
VCID: 3E73CCBD697137CBF3-806B
014 - Defective
Reset counter: 54
Mileage: 133209 km
Date: 2010.10.31
Time: 12:40:29
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660046344
Coding: 0201000000010110
Shop #: WSC 61912 210 94665
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 264304DD59E18F0B9B-8073
End-------------------------(Elapsed Time: 02:11)--------------------------
