2016 Skoda Fabia & Citygo not DTC scan
Gizmo
S.E.Kent UK
C?ID=49193
I have recently tried to scan a 2016 Skoda Fabia but I get the message "Function not supported by the gateway" the Fabia was done using 16.3.0 and the Citygo gave me the same message using 16.5.0
I was able to access the controllers and make coding changes on the Citygo (16.5.0) but did not try on the Fabia (courtesy car) as my time was very limited with both cars.
Is this something you are aware of?
This was with HEX+CAN & HEX-NET (connected via USB - I did not try via wifi as I was away from home and I get hit and miss connection problems with the HEX-NET anyway).
Gizmo
S.E.Kent UK
C?ID=49193
FWIW I had the same results with my MY16 Superb, but did manage a scan via VCDS mobile:
#hndoc:?docid=00001CB6&xt=hnh:F8A800B034ED91B3E1B1AD182253AC342ED85CAC3F444B41AF8D11EC6436A93BVCDS Mobile 0.4316.0.4
VIN: EEPR0M-READ-ERR0R
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
     5F 6C 6D A5
Address 01: Engine  (DFCA2 J623)    Labels: None
    Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
    Component: R4 2,0L EDC   X23 1195
    Revision: B4X23---
    Coding: 021D0032036501083000
    Shop #: WSC 92521 052 12345
    ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
    ROD: EV_ECM20TDI01104L906026FN.rod
    VCID: 7BB964EF62E4E8BFF6D14DD79E-802E
No fault codes found.
Address 02: Auto Trans  (J743)    Labels: 0D-02.lbl
    Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
    Component: DQ250-6F MQB  H53 4803
    Revision: 06253104
    Shop #: WSC 33361 790 00063
    ROD: EV_TCMDQ250021.rod
    VCID: 1771585F7E8C2CDF72E90107F2-8042
Address 03: ABS Brakes  (J104)    Labels: None
    Revision: 00000000
    Coding: 1D07929C34220B750780060141CB49B8492CD0E0608292F53861F0F8C2A9
    ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
    VCID: 7AB761EB6DDED1B7EDC740ABE9-802F
8291 - Databus
Address 05: Acc/Start Auth.  (J518)    Labels: 5Q0-959-435.clb
    Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
    Component: VWKESSYMQB    036 0710
    Revision: 00036000
    Coding: 030C0C0703
    ASAM Dataset: EV_KessyHellaMQBAB 004032
    VCID: 3A37A1EB2D5E11B7AD4780AB29-806F
Address 08: Auto HVAC  (E87)    Labels: None
    Part No SW: 3V0 907 044 AN    HW: 3V0 907 044 AN
    Component: AC Automat    H32 3601
    Revision: 20K04000
    Coding: 11110104000400011005104100101102
    ASAM Dataset: EV_ACClimaPrehVW37X 002009
    ROD: EV_ACClimaPrehVW37X.rod
    VCID: 804393038B020B67230382135F-80D5
Address 09: Cent. Elect.  (J519)    Labels: None
    Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
    Coding: 0F019E66C2C72AFB17844086B118172C0800000000000000000000000000
    ROD: EV_BCMBOSCH_SK48.rod
    VCID: 89558E27B8384A2F745DE77F24-80DC
    Subsystem 1 -     Part No SW: 3V2-955-119    Labels: 5Qx-955-119-V1.clb
    Component: ]Ý
    Subsystem 2 -     Component: ˆß
    Subsystem 3 -
    Subsystem 4 -
    Subsystem 5 -     Component: ]�
    Subsystem 6 -
    Subsystem 7 -
Address 10: Park/Steer Assist  (J791)    Labels: 5Q0-919-298.clb
    Part No SW: 5QA 919 298    HW: 5Q0 919 298 C
    Component: PLA 3.0 12K
    Coding: 0371167851
    ASAM Dataset: EV_EPHVA2CAU3700000 009017
    ROD: EV_EPHVA2CAU3700000_SK48.rod
    VCID: 0D5D3A374C50D60FD885938F70-8058
Address 13: Auto Dist. Reg  (J428)    Labels: 3Q0-907-572.clb
    Component: ACC BOSCH MQB H04 0192
    Coding: 320067C355FFC428949C804D
    ASAM Dataset: EV_ACCBOSCHVW48X 001008
    ROD: EV_ACCBOSCHVW48X.rod
    VCID: 342B8FD30F3AE7C7770B3E637B-8061
1538 - Sensor for Automatic Distance Control
1542 - Sensor for Automatic Distance Control
1067 - Databus
1088 - Databus
2065 - Databus
Address 14: Susp. Elect.  (J250)    Labels: 5Q0-907-376.clb
    Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
    Component: DAEMPFUNGS-SG H17 0120
    Shop #: WSC 00000 000
    ROD: EV_DRCONTITEMIC.rod
    VCID: 3731B8DF1E4C0CDF5229618712-8062
Address 15: Airbags  (J234)    Labels: 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
    Component: AirbagVW21    005 0130
    Coding: 98FCC0C0000000005C5400CF00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
    ROD: EV_AirbaVW20SMEVW37X.rod
    VCID: 83499C0F9A14107F3E21A53776-80D6
    Subsystem 1 -     Part No SW: 4M0-980-945-A
    Component: €
    Subsystem 2 -     Component: €
    Subsystem 3 -     Component: ---
    Subsystem 4 -     Component: ---
    Subsystem 5 -     Component: ---
    Subsystem 6 -     Component: ---
Address 16: Steering wheel  (J524)    Labels: 3Q-16.lbl
    Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
    Revision: FF033033
    Coding: 6010
    ROD: EV_SMLSVALEOMQB.rod
    VCID: 70A343C33BA29BE75363D2536F-8025
Address 17: Instruments  (J285)    Labels: None
    Part No SW: 3V0 920 911    HW: 3V0 920 911
    Component: KOMBI         305 6422
    Coding: 27A5011A7F84A600008B7E0B5001000000000000
    Shop #: WSC 73430 031 00063
    ROD: EV_DashBoardVDDMQBAB_SK25.rod
    VCID: EFA1C0BFA69C041FCA594927FA-80BA
Address 19: CAN Gateway  (J533)    Labels: 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
    Component: GW MQB High   212 2227
    Revision: --------
    Coding: 030100044F087300FB00025E9C0F00010001070000000000000000000000
    Shop #: WSC 73430 790 00063
    ROD: EV_GatewConti.rod
    VCID: 75AD72D744C0BECF80950B6F28-8020
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
Address 2B: Steer. Col. Lock  (J764)    Labels: 5Q0-905-861.clb
    Part No SW: 3Q0 905 861    HW: 3Q0 905 861
    Coding: 0800000000000000
    ROD: EV_ELVMarquMQBB.rod
    VCID: F1A5C6C7B0A812EFDC6D5F5F9C-80A4
Address 36: Seat Mem. Drvr  (J810)    Labels: None
    Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
    Component: Sitzmemory    H06 0009
    Coding: 001400000000010001A080808080000000008181000000D4
    ASAM Dataset: EV_SeatMemorDriveSide 001015
    ROD: EV_SeatMemorDriveSide_SK37.rod
    VCID: 3B39A4EF226428BFB6518DD7DE-806E
Address 3C: Lane Change  (J1086)    Labels: None
    Component: HRE_Master    H11 0071
    Coding: 02011203
    ROD: EV_HREntryHella.rod
    VCID: 3C3BA7F3276A2F87BF5B96C3D3-8069
Address 42: Door Elect, Driver  (J386)    Labels: None
    Coding: 001D0820DE01048000001100
    VCID: 43C9DC0F5A94507FFEA1E537B6-8016
Address 44: Steering Assist  (J500)    Labels: 5Q0-909-144.clb
    Component: EPS_MQB_ZFLS  125 1063
    Coding: 9303
    VCID: 44CBDF135F9A5747C7ABEE23AB-8011
Address 52: Door Elect, Pass.  (J387)    Labels: None
    Coding: 001D0220DE01048000001100
    VCID: 42C7D90B458E5977F597D80B81-8017
Address 55: Xenon Range  (J745)    Labels: 7P6-907-357.clb
    Revision: --------
    Coding: 06D602007F010000
    VCID: 40C3D3034B824B67E383C2139F-8015
    Subsystem 1 -     Part No SW: 4H0-941-329    Labels: 3D0-941-329.clb
    Component: ³
Address 5F: Information Electr.  (J794)    Labels: None
    Part No SW: 3V0 035 020 A    HW: 3V0 035 020
    Component: MU-H-ND-EU    H42 0318
    Coding: 038401010000000011111202008808002F0003E6012001009E
    VCID: 240B7F93BFDA7747E76B8EA30B-8071
    Subsystem 1 -     Part No SW: 3V0-919-606
    Component: ABT_High-2
    Subsystem 2 -
Address 6C: Back-up Cam.  (J772)    Labels: 5Q-6c.lbl
    Part No SW: 5Q0 980 556    HW: 5Q0 980 556
    Component: RVC Compact   H07 0100
    Coding: 04840101A600201F000040
    ROD: EV_CamSysRVRVCPANAMQBAB.rod
    VCID: F7B1F8DFDECC4CDF12A9A18752-80A2
Address 6D: Trunk Elect.  (J605)    Labels: None
    Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
    Component: HDSG-Modul    H12 0250
    Revision: --------
    Coding: 1008
    ASAM Dataset: EV_DeckLidCONTIAU736 001011
Address A5: Frt Sens. Drv. Assist  (R242)    Labels: None
    Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
    Component: MQB_B_MFK     H04 0024
    Coding: 020408010000040100062346C040A00098000E100040
    ROD: EV_MFKBoschMQBB.rod
    VCID: 3833BBE3135203A75B336AB307-806D
Keithuk
Stoke on Trent, England
C?ID=122432
I have a similar problem,
I click on Test and it shows:
K1: OK
K2: OK
CAN: Not Ready
An AutoScan shows:
Function not supported by gateway.
I did a scan a couple of weeks ago and it worked when I asked about my DPF picture
http://forums.ross-tech.com/showthread.php?2265-DPF-readings-and-health-of-DPF
I can't find Adaptation Channel 13?
I found Channel 13 in Engine Long Adaptation 0A
It shows ERROR Security access required
Beta shows:
K1: OK
K2: OK
CAN: OK
It does an AutoScan.
Virus and malware scan clear.
I reinstalled the same software but its the same error on Gateway.
CAN: Not Ready
Means that the interface is unable to see any CAN messages at all from the car.
Ignition on?
Interface fully seated in car's OBD-II socket?
Check condition of pins in car's OBD-II socket.
Eric
HC800000
If the beta shows OK and you don't have a hexnet, what you're seeing with the release is entirely expected. For more details, see the beta release notes :)
Keithuk
C?ID=122432
Thank you for the reply Eric.
I've read the Current Beta notes but that doesn't explain my problem which is the same as OP.
Why would the Beta work and scan but the current version won't. The led light is green all the time. I've never had this problem with any VCDS or Beta software that I've installed previously.
I see there is a new Beta 16.5 out I will give that a go.
Gizmo
S.E.Kent UK
C?ID=49193
Keith I have currently tried to scan 4 cars: 2005 MKI Fabia, 2015 MKIII Superb, 2016 MKIII Superb & 2016 Citygo) and non of them will do an auto scan via a USB lead (with HEX+CAN or HEX-NET)
I can autoscan via VCDS-Mobile, the only problem there is I need to do a reset of the HEX-NET everytime I use it.
This is the same results with 16.3 and 16.5
Keithuk
C?ID=122432
I tried the new Beta 16.5.0 and the Test showed:
K1: OK
K2: OK
CAN: OK
Green LED lit all the time.
I did an AutoScan and it showed a message Function not supported by gateway or cannot connect to gateway when the previous Beta scanned as normal.
