Thursday,12,May,2016,14:35:15:57576
VCDS Version: 16.5.0.4 (x64)
Data version: 20160506 DS251
VIN: WAUZZZ8V1F1133450 License Plate: xxxxx
Mileage: 17923km-11136mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 47 52 55 5F
A9 BB BC
VIN: WAUZZZ8V1F1133450 Mileage: 17923km-11136miles
Address 01: Engine (J623-CJXF) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A1D00322426010B3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259A 001005
ROD: EV_ECM20TFS0205G0906259E.rod
VCID: 3E7373BBA1975DB349-806A
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4517
Revision: 05853104 Serial number: TFK01503171538
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1F4DAE3F065D34BB62-804A
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 60885000001210
Coding: 31F193A254232A6F037B070541C3698CC92A54C0E08296F7024100B88208
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 489F1563F3531303F3-801C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0363129107
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_VW37.rod
VCID: 3A7B7FABBDBF719375-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000611057
Coding: 03100004110000011000000000001500
VCID: 326B578B65CF89D3BD-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011508506729
Coding: 07051C42C24106FD03804004B11007A80800000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
VCID: 000FCD439BE3EB437B-8054
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150314 041 0585
Serial number: 150321152545
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23846585
Coding: 07006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 21 01 2015 00000600
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1505111WK
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000062133930
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39391507903134
Coding: 0030050011
VCID: 428B074BD56F39532D-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 230315028
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide_AU37.rod
VCID: 4385024FCA75305B26-8016
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR03APF+
Coding: 98CCC000000000005C54000000C800000065
Subsystem 1 - Part No SW: ----------- HW: 480 002 703 15
Serial number: 35767000000EBC4C3312
Subsystem 2 - Part No SW: ----------- HW: 480 002 703 15
Serial number: 358670000006CC4C331$
Subsystem 3 - Part No SW: ----------- HW: 480 402 303 15
Serial number: 3516502C119EFD2531FR
Subsystem 4 - Part No SW: ----------- HW: 480 402 303 15
Serial number: 3526502C319EFD22137J
Subsystem 5 - Part No SW: ----------- HW: 480 402 711 14
Serial number: 3556502A1188FC20627C
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 05041504220282
Coding: A018
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0A1BEF6BADDFA11325-805E
Part No SW: 8V0 920 871 D HW: 8V0 920 871 D
Component: KOMBI H02 4292
Coding: 27AD181A3B8000080101EA001000000000000000
VCID: 3D7174B7AC9146AB50-8068
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 28031510803342
Coding: 030100043F085A005B0002689C0B00000001010000000000000000000000
ROD: EV_GatewConti.rod
VCID: 72EB978BA54FC9D37D-8026
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0001
Serial number: 20150515155045 RD415
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001503171163
8531970 - Quiescent Current
U1406 00 [008] - Too High
Reset counter: 32
Mileage: 17837 km
Date: 2016.05.11
Time: 19:27:01
Supply voltage; Terminal 30: 12.4 V
Terminal 15: OFF
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Serial number: HA1-00019.02.15
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_VW48.rod
VCID: 46831B5BF947057301-8012
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000084346001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_VW37.rod
VCID: 346751939FDB87E3AF-8060
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 180315BBG1276A
Coding: 005D1E205C01040000001002
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
VCID: 377D669F8EAD6CFB8A-8062
Part No SW: 8V0 035 465 C HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0410
Serial number: AUZ8ZAFN90164Q/
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_AU37.rod
VCID: 387F65A383B3638383-806C
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 220315BCK05016
Coding: 005D16205E01040000001002
VCID: 41890847D069224B34-8014
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 01A600002B200200
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
VCID: 3F8D0EBFA69D54BB42-806A
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7050
Coding: E00100
5545009 - LED Headlamp Power Output Stage; Left
B149C 31 [008] - No Signal
Reset counter: 33
Mileage: 17868 km
Date: 2016.05.12
Time: 08:20:24
Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 045 E HW: 8V0 035 045 C
Component: MU-H-N-RW H44 0357
Serial number: A307C0F7522288
Coding: 017301070000000021110002000A00002F000226010001005E
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 TF HW: -----------
Component: ROW 2016 --- 0055
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY202W4R
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000007021500040045
Component: Gracenote --- 4006
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 150311201323
VCID: 7DF1B4B7EC1186AB10-8028
Address BB: Door Rear Drv Labels: None
Part No HW: 5Q0 959 395 B
Revision: J388
Coding: 004D16204001040000001002
VCID: 55A1CC1734E1BEEB78-8000
No ASAM data for: "Unknown" (AU37)
Address BC: Door Rear Pass Labels: None
Revision: J389
End-------------------------(Elapsed Time: 05:43)--------------------------
