- Joined
- Mar 30, 2015
- Messages
- 194
- Reaction score
- 135
- Location
- Melbourne/Belgrade
- VCDS Serial number
- C?ID=240855
I still do not have HEX-NET so I would like to know is it connected over router or directly to the laptop?
Correct. The Windows version of VCDS continues to work just as it always has, even when using a HEX-NET via WiFi.Ok, so that is correct ONLY for mobile version? PC can do all coding and basic setting without cloud?
If you have hotspot in your phone then you can set it up to work in infrastructure mode,and you will be surprised how low data usage is.Ok, so that is correct ONLY for mobile version? PC can do all coding and basic setting without cloud?
I like new technology and new gadgets , but I hate to depend on mu ISP or mobile 4G coverage to finish job ,that's why I am trying to get all info before I make any purchase....
I'm confused.. How do your laptop or tablet connect to the 4G modem if it doesn't act as a router? Can you provide a link to some specs for the 4G modem so we can better understand what you have?I have a WIFI mobile telephone modem that connects to my laptop and tablet .
I can't setup a profile for IM using the mobile telephone modem because it won't register an IP address on the NEX-NET configuration Utility (the 4G modem is not a router). Is there a way of using my 4G WIFI modem as the comms link to my tablet/laptop for the purpose of HEX-NET?
Well, it claims it's a "mobile Wi-Fi router".
However, sometimes such "routers" give internet access to multiple devices, but block those devices from seeing each other. Still, the HEX-NET should be able to connect to it.
Plug the HEX-NET into your PC via USB. Make sure the 4G modem/router is on and active.
Verify this using your tablet.
Start the Configuration Utility on your PC.
[Configure WiFi]
[Scan for Network]
Does your 4G Modem/Router not show up in the results?
There better be some characters in his password. I think you mean "unusual" characters?Are there any characters or spaces in your password?
that can happen if the password is rejected. Are there any unusual characters or spaces in your password?
