Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Hex-NET vs HEX+CAN speed test
    OK: I'll readily admit that my spanking-new HEX-NET was a thing of wonder and glory to behold when I carefully unpacked it from its box this afternoon! After removing my drool from the dongle, I immediately gave it my first challenge: a speed test against my faithful old HEX+CAN for a straight-out autoscan.
    Three test were performed:
    1. HEX+CAN (cable mode - of course)
    2. HEX NET connected in the traditional cable mode
    3. HEX NET in WIFI Mode (Access Point Mode)
    The Laptop is a Surface Pro 3 x64, Core i7, 8 GB RAM, Windows 10 (no nannyware)
    RESULTS:
    HEX+CAN
    Friday,06,May,2016,20:37:11:03521
    VCDS Version: 16.3.1.1 (x64)
    Data version: 20160325
    VIN:    License Plate: HEX+CAN SPEED-TEST
    Mileage: 22679km-14092mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN:   Mileage: 22679km-14092miles
    Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 G    HW: 04E 907 309 A
       Component: 1,4l R4 TSI   H08 7862
       Revision: WAH08---
       Coding: 01250032242405082000
       Shop #: WSC 04363 002 1048576
       ASAM Dataset: EV_ECM14TFS01104E906016G 002011
       ROD: EV_ECM14TFS01104E906016G.rod
       VCID: 26431A2059EACC0CEE-8072
       Part No SW: 0CW 300 045     HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5240
       Revision: 00043014    Serial number: CU501212296246
       Shop #: WSC 00028 028 00025
       ROD: EV_TCMDQ200021.rod
       VCID: 76E30A60C9CAFC8C9E-8022
    25472 - No Communication with Gear Selector Module
              U0103 00 [072] - -
                        Mileage: 22310 km
                        Date: 2016.04.17
                        Time: 12:26:17
                        Engine speed: 18.75 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 61 km/h
                        Control Module temperature: 11 °C
                        CURRENT pressure: -10.0 bar
                        Clutch; primary stat: Fahren
                        selected gear: GANG_5
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 7168
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
       VCID: 7DF1154CECFCAFD4DF-8028
       Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00120004200100011005004012101800
       ROD: EV_ACClimaBHBVW37X_VW37.rod
       VCID: 3561CD6C944CB79457-8060
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
       Component: BCM MQBAB M   H14 0106
       Serial number: 00011234701612
       Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 4385A3B4CA981924E9-8016
       Component: WWS    121120  042 0551
       Serial number:         121206042218
       Coding: 0E4DD5
       Component: RLFS  024 0042
       Serial number: Y13M01D03H20M05S37S1
       Coding: 00A8DD
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  002 0026
       Revision: --------    Serial number: 94231233000504
       Coding: 0031151011
       ASAM Dataset: EV_EPHVA18AU3700000 002016
       VCID: 3A7BDE50BD5258ECBA-806E
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R01UHNZ
       Coding: 98CCC000000000005C00000000C800000065
       Shop #: WSC 00028 028 00061
       VCID: 408FACB8DB8E023CF4-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 201 13
       Serial number: 357670000007612C7C0W
       Subsystem 2 - Part No SW: -----------    HW: 480 000 201 13
       Serial number: 358670000006332C7C0V
       Subsystem 3 - Part No SW: -----------    HW: 480 400 301 13
       Serial number: 3516502AF0CD5EC471C+
       Subsystem 4 - Part No SW: -----------    HW: 480 400 201 13
       Serial number: 3526502B30CD5EC2136J
       Subsystem 5 - Part No SW: -----------    HW: 480 401 112 12
       Serial number: 3556502B30CD5EC4008M
       Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 08011304220489
       Coding: 0500
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 79F9015CF8D493F4F3-802C
       Part No SW: 5G0 920 860     HW: 5G0 920 860
       Component: KOMBI         235 0555
       Coding: 27A501082380800801087E00040000
       VCID: 65C15D2C646C071427-8030
       Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
       Component: GW MQB Mid    121 1109
       Revision: --------    Serial number: 0000188941
       Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear.rod
       VCID: 3365F3749A38A9A479-8066
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
       Component: E221__MFL-DC1  H13 0035
       Serial number: 02120005290300060291
       Coding: 280000
       Serial number: 3451678601
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Component: TSG FS        007 0006
       Serial number: 0000046453458
       Coding: 003A02208001020000001000
       VCID: 020B66B09502D02CA2-8056
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Serial number: 00000000000000502227
       Coding: 0D0000
       Coding: 01
       VCID: 3D71D54CAC7C6FD49F-8068
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Component: TSG BFS       007 0006
       Serial number: 0000048027940
       Coding: 003A00208E01020000801000
       VCID: 010969BC9004CB34BB-8054
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Serial number: 00000000000000502825
       Coding: 050000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846
       Component: MU-S-N-ER     039 0450
       Serial number: V1F00501130081
       Coding: 02730008FF00000011510001000900001F0104960100010047
       Shop #: WSC 12345 123 61029
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 275D17245EE0D504D5-8072
       Component: ABT_Std_Nav  H44 0022
       Serial number: VWZ8Z9M3400KZM
       Subsystem 2 - Part No SW: 5G0 919 866 A    HW: -----------
       Component:  ROW 2013  --- 0022
    End-------------------------(Elapsed Time: 03:10)--------------------------
    NEX-NET (Cable)
     Friday,06,May,2016,20:40:46:16808
    VIN:    License Plate: HEX-NET CABLE SPEED-TEST
    VIN: WVWZZZAUZDP034070   Mileage: 22679km-14092miles
       Revision: WAH08---
       VCID: 260033F059A6A50CEE-8072
       VCID: 76A023B0C986958C9E-8022
              U0103 00 [072] - -
                        Mileage: 22310 km
                        Date: 2016.04.17
                        Time: 12:26:17
                        Driving position: N
       VCID: 7DB23C9CECB0C6D4DF-8028
       Revision: 00001K06
       VCID: 3522E4BC9400DE9457-8060
       VCID: 43C68A64CAD47024E9-8016
       Coding: 0E4DD5
       Coding: 00A8DD
       Coding: 0031151011
       VCID: 3A38F780BD1E31ECBA-806E
       VCID: 40CC8568DBC26B3CF4-8014
       Coding: 0500
       VCID: 79BA288CF898FAF4F3-802C
       VCID: 658274FC64206E1427-8030
       VCID: 3326DAA49A74C0A479-8066
    H13 0035
       Coding: 280000
       VCID: 02484F60954EB92CA2-8056
       Coding: 0D0000
       Coding: 01
       VCID: 3D32FC9CAC3006D49F-8068
       VCID: 014A406C9048A234BB-8054
       Coding: 050000
       VCID: 271E3EF45EACBC04D5-8072
    End----------(Elapsed Time: 01:28, VBatt start/end: 11.6V/11.6V)-----------
    HEX-NET WIFI
    Friday,06,May,2016,19:46:29:16808
    VIN:    License Plate: 1ST HEX-NET WIFI SPEED-TEST
       Revision: WAH08---
       VCID: A600B3F0D9A6250C6E-80F2
       VCID: F6A0A3B04986158C1E-80A2
              U0103 00 [072] - -
                        Mileage: 22310 km
                        Date: 2016.04.17
                        Time: 12:26:17
                        Driving position: N
       VCID: FDB2BC9C6CB046D45F-80A8
       Revision: 00001K06
       VCID: B52264BC14005E94D7-80E0
    Address 09: Cent. Elect.        Labels: 5Q0-937-08X-MV1.clb
       Component: BCM MQBAB M   H14 BCM MQBAB M   H14 01060106
       ROD: N/A
       VCID: C3C60A644AD4F02469-8096
       Subsystem 1 - Part No: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Coding: 0E4DD5
       Subsystem 2 - Part No: 5Q0 955 547   Labels: 5Q0-955-547.CLB
       Component: RLFS
       Coding: 00A8DD
       Coding: 0031151011
       VCID: BA3877803D1EB1EC3A-80EE
    Address 15: Airbags        Labels: 5Q0-959-655.clb
       ROD: N/A
       VCID: C0CC05685BC2EB3C74-8094
       Coding: 0500
       ROD: N/A
       VCID: F9BAA88C78987AF473-80AC
       VCID: E582F4FCE420EE14A7-80B0
       VCID: B3265AA41A7440A4F9-80E6
    H13 0035
       Coding: 280000
       VCID: 8248CF60154E392C22-80D6
       Coding: 0D0000
       Coding: 01
       VCID: BD327C9C2C3086D41F-80E8
       VCID: 814AC06C104822343B-80D4
       Coding: 050000
    Address 5F: Information Electr.        Labels: 5G0-035-MIB-STD1.clb
       VCID: A71EBEF4DEAC3C0455-FFFE
    End----------(Elapsed Time: 20:49, VBatt start/end: 11.7V/0.0V)------------
    So, I'm delighted that the NEX-NET cable speed (1:28 min) has halved the time for an autoscan compared to the HEX+CAN (3:08 Min), but I'm a little disappointed at the performance of the HEX-NET's WIFI speed (20:49 Min). What can be done about the latter. I assume internet speed (which is atrocious here) is not an issue in Access Point Mode?
    Magdeburg, Germany
    The 20+ Minutes via WiFi are NOT normal. You should see results slightly over the HN-USB but way below HUC. During that long scan, did you see where it was specifically "hanging"? You are running a slightly outdated Beta at this point, please re-test this once we have 16.5+ published - with the correlating latest version for the HN itself.
  3. Likes Uwe liked this post
    I don't know if it would affect communication for either car controllers or HEX-NET, but your battery voltage is very low (0.0 V et the end ).
    I would recommend a charger or if not possible, let it idle.
  5. Likes Uwe liked this post
  6. #4
    Magdeburg, Germany
    Quote Originally Posted by Gavra View Post
    I still do not have HEX-NET so I would like to know is it connected over router or directly to the laptop?
    Please do not hijack other peoples threads/topics, use the pre-sales support instead for these kind of questions - assuming you haven't found the answer on the website.
    EDIT: Uwe moved his question to a new thread
    I see issues with wifi in 09, 15, 16 and 5F. That it even completed the autoscan after 20 minutes of retrying shows... well, something How far was your laptop from the hexnet? Any obstacles (like a big heavy metal door or dashboard) inbetween? What's the model of your wifi adapter?
    Lansdale, PA
    Any window tint? Can you run a network analyzer via cell phone app?
    Quote Originally Posted by Eric View Post
    Eric, Sebastian: I've tried the wifi set-up with ver 15.7.4 and pretty much the same behaviour. Doesn't hang at any module in particular - seems to be very slow at random points in the scan process (then it will race through some screens). Haven't tried infrastructure mode as my internal LAN reception in the workshop is hopeless. Access Point mode autoscan works much better on my testbench with just 2 modules (09 & 19) - but it won't do a installation list for some reason - says "function not supported".
    As for the distance between dongle and laptop - it was on the driver's seat (about 12 inches away in your American measurements!). I checked the wifi signal strength during the autoscan (had the same concerns as you) and the laptop said "excellent". If I'm the only person with the problem, it must be my laptop set-up. Perhaps the firewall settings need changing?
    According to the device manager - the network adaptor is a Marvell AVASTAR Wireless- AC Network Controller. It has the original driver that came with the laptop (version 15.68.9037.59 - dated 30/11/2015). Device manager says that it's working OK
  10. Likes Uwe, Dana liked this post
  11. #8
    OK, good info. Any chance you can try another wifi-equipped PC?
  12. #9
    ^^^^ Yep... got my (t)rusty old Asus in the electronics workshop that I could try. Have to first evict the mice that have taken-up residency on the keyboard. Will report as soon as I can
    Thanks to everyone that is taking an interest in my problem
  13. Likes Eric, Uwe, Dana liked this post
  14. #10
    Eric: Looks like the problem is in my Surface Pro 3 - I'm surprised, given that it's bog standard - no changes and relatively new . The Asus autoscan results below:
    Saturday,07,May,2016,00:11:21:16808
    VCDS Version: 15.7.4.1
    Data version: 20160216
    VIN:    License Plate: ASUS - NEX NET SPEED TEST
       Revision: WAH08---
       VCID: A600B3F0D9A6250EA4-80F2
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: F6A0A3B04986158ED4-80A2
              U0103 00 [072] - -
                        Mileage: 22310 km
                        Date: 2016.04.17
                        Time: 12:26:17
       VCID: FDB2BC9C6CB046D695-80A8
       Revision: 00001K06
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: B52264BC14005E961D-80E0
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: C3C60A644AD4F026A3-8096
       Slave 1:
       Coding: 0E4DD5
       Slave 2:
       Coding: 00A8DD
       Coding: 0031151011
       ROD: EV_EPHVA18AU3700000_SK48.rod
       VCID: BA3877803D1EB1EEF0-80EE
       VCID: C0CC05685BC2EB3EBE-8094
       Coding: 0500
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: F9BAA88C78987AF6B9-80AC
       VCID: E582F4FCE420EE166D-80B0
       VCID: B3265AA41A7440A633-80E6
       Coding: 280000
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 8248CF60154E392EE8-80D6
       Coding: 0D0000
       Coding: 01
       ROD: EV_SteerAssisMQB.rod
       VCID: BD327C9C2C3086D6D5-80E8
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 814AC06C10482236F1-80D4
       Coding: 050000
       ROD: EV_MUStd4CPASE_SK37.rod
       VCID: A71EBEF4DEAC3C069F-80F2
       Media Player Position 1:
       Engine Control Module 2:
    End-------------------------(Elapsed Time: 01:47)--------------------------
    I know this is my problem and not an issue with the NEX NET, but can you suggest some areas of investigation - please
    PS: Still a good result with HEX NET - twice the speed of HEX+CAN - Woopiee............!!!
  15. Likes Eric, Uwe, jyoung8607, Dana, Sebastian liked this post
