Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 62
Thread: How to install fogs on S model Mk7's (long version)
  1. #41
    ^^^^^^^ "adaptation log" - what's that? Appears to be another copy of the auto-scan
    Why not start by getting the coding-string in your new BCM to look-like the original (see your original autoscan)? This at least gets you a stable base from which to start further investigations. Then clear all the DTCs and see what error messages re-appear ?
    PS: Factory mode?? Are you referring to "transport mode" - which is a kind-of sleep-state that the car is put into when the car leaves the factory?
    PPS: The CP error will need to be addressed as a priority to assimilating the new BCM
  2. Likes Uwe liked this post
  3. #42
    Apr 2016
    Just noticed i posted the same scan twice. I spent 4 hours using the software Uwe pointed out comparing both BCM adaptation logs side by side. The lights inside are the ony thing i didnt finish yet. I can barely see the HUD and infotainment right now. But i am not done. Then i need to get the keys to work again. Car starts. No remote lock-unlock tho.
  4. #43
    Apr 2016
    Took to dealer had them "reset" new BCM to vehicle. Keys and everything works like it did stock. Tried to recode taillamps as they are not stock and it says "component not initialized" on the BCM. How is that possible? I tried the current shop codes on the vcds but no avail. How do i lookup the old "shop" codes that were on my vcds before the car went to the dealer? Thanks again for all your help.
  5. #44
    You mean this message?
    Your old BCM had:
    Shop #: WSC 01383 790 50316
    Post up a scan so we can see what's in the new one.
  6. #45
    Apr 2016
    Your old BCM had:
    yes to above
    newest scan (car was running, it was hot today):
    Tuesday,24,May,2016,15:37:51:58344
    VCDS Version: 16.5.0.4
    Data version: 20160506 DS251
    VIN: 3VWA17AU1GM516884   License Plate: NEWBCMRESET
    Mileage: 3335km-2072mi   Repair Order: NEWBCMRESET
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75
    VIN: 3VWA17AU1GM516884   Mileage: 3335km-2072miles
    Address 01: Engine (J623-CXBA)       Labels: 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 091100122424002F0000
       Shop #: WSC 00790 002 1048576
       ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
       ROD: EV_ECM18TFS0208V0906264F.rod
       VCID: 3FA3BB32A69E54BB42-806A
    15077 - Idle Control System RPM
              P0507 00 [036] - Higher than Expected.
                        Mileage: 3333 km
                        Date: 2016.05.24
                        Time: 22:23:43
                        Engine speed: 1003.75 /min
                        Normed load value: 22.0 %
                        Coolant temperature: 100 °C
                        Intake air temperature: 69 °C
                        Voltage terminal 30: 13.515 V
                        Engine; operating status: IS
                        STATE_LS_SAE[1]: CL
                        T_AST_SAE: 11 s
                        MAP_MES_SAE: 33 kPa
                        Lambda probe voltage; bank 1; probe 1 (broadband probe): 1.987 V
                        FAC_TPS_1_SAE: 12.500000 %
                        FUP_H_SAE: 4350.0 kPa
    Readiness: 0010 1101
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 53165000000809
       Coding: 04FA6AA124210972007F020881C7292056249000408194B400430050C002
       ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
       VCID: 4BBB9FE2E226F81BDE-801E
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5GM 907 426     HW: 5GM 907 426
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 02020004200100000000000000000002
       ROD: EV_ACManueBHBVW37X.rod
       VCID: 052F69DA84C2CE6B48-8050
       Part No SW: 5Q0 937 087 AB    HW: 5Q0 937 087 AB
       Revision: --------    Serial number: 86580801160508
       Coding: 000008424041804169E44000000407001000000000000000000000000000
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 7BDB0F22F206889B2E-802E
       Component: WWS    150801  043 0581
       Serial number:         151211180657
       Serial number: 003GCR03KV3T
       VCID: 47B3A3D2FE4E1C7BFA-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003ZUE32
       Coding: 303133
       Subsystem 2 - Part No SW: -----------    HW: 480 001 510 15
       Serial number: 35700000000C8064E61N
       Subsystem 3 - Part No SW: -----------    HW: 480 001 510 15
       Serial number: 35800000000E172DF61W
       Subsystem 4 - Part No SW: -----------    HW: 480 402 010 15
       Serial number: 3510002C71CF1D1522C8
       Subsystem 5 - Part No SW: -----------    HW: 480 402 010 15
       Serial number: 3520002AB1CF1D2212A6
       Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 3550002C91D1B621A252
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 3560002C71D1B62071B2
       Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20151102500369
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3A55CA26BDBC719375-806E
       Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
       Component: KOMBI         242 6420
       Coding: 0BB51102A180CF0502086A001000000000000000
       Shop #: WSC 00066 790 00221
       VCID: 256F095A2402EE6B28-8070
       Part No SW: 5Q0 907 530 AH    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2246
       Revision: --------    Serial number: 24101510800925
       Coding: 0101000830085900FB000008080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti.rod
       VCID: 77D31312CE2EACFB4A-8022
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
       Component: E221__MFL-DC1  H16 0101
       Serial number: 29150001515720025325
       Coding: 30FFFF
       Serial number: 9601152730397
       Coding: 003103205000040000000000
       Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
       Serial number: 00000000000002389556
       Coding: 011000
    589827 - Window Regulator; Rear Driver Side
              B131F 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 189
                        Mileage: 1048574 km
                        Time: 00:00:00
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0102
       VCID: 44A9B4DECF7837631F-8010
       Serial number: 9901153100925
       Coding: 003103205C00040000000000
       Shop #: WSC 12345 813 111111
       VCID: 46ADAED6F944057301-8012
       Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
       Serial number: 00000000000002391317
       Coding: 091000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 844     HW: 3Q0 035 844
       Component: MU-S-S-US     620 0613
       Coding: 02730200FF00000051220001001808001F0100D40120010002
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 6CF93C7E87681F23B7-8038
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9RJW001SF
              B11CF 53 [009] - Deactivated
                        Reset counter: 189
                        Mileage: 3333 km
                        Date: 2016.05.24
                        Time: 22:22:45
                        Voltage terminal 30: 12.4 V
                        SDARS_tuner_status_2-Antenna current: 128 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Tuner für Satellitenradio; Status der Voraktivierung: 05
                        SDARS_tuner_status_2-Tuner für Satellitenradio; Wert der Voraktivierung: 05
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0568
       Coding: 02730202C2821A017F1E06000000
       ROD: EV_OCULowMQB.rod
       VCID: 43ABB7C2CA76305B26-8016
    End-------------------------(Elapsed Time: 02:29)--------------------------
    just noticed this:
    Reset counter: 189
    Mileage: 1048574 km
    Time: 00:00:00
    1048574 km???? wtf?
    on a side note, after making several changes to the BCM admap it starts to say "function not allowed" or " no connectivity" is this just a BETA thing? I would then have to exit VCDS and restart it to continue.
    and when attempting to recode "central electronics" it says either error 81 or 7f. I am only trying to change one bit/byte thing for front fogs. like it did before the dealer messed with it.
  7. #46
    Yep, that's a module that hasn't had any "proper" WSC info stored. Hint: Look at those numbers in hexadecimal or binary.
    1048574 km???? wtf?
    Again, look at that number in binary. Speculation: The module wasn't able to get the mileage (or the date!) from the rest of the car at the time that fault code was stored. Re-synch the window, no big deal. Run it all the way down by holding the switch in the down position, and continue to hold the switch in the down position for a two-count after it stops at the bottom. Run it all the way up by holding the switch in the up position, and continue to hold the switch in the up position for a two-count after it stops at the top. You may need to repeat this once or twice.
  8. #47
    Apr 2016
    Is this in the wiki or how to?
  9. #48
    "There are 10 kinds of people in the world; those who understand binary and those who don't."
  10. Likes Zenerdiode liked this post
  11. #49
    Apr 2016
    That actually took 11 times to get it ... lol
    By converting the number to either, what i am i supposed to do with them? Is there a place to enter them as binary/hexi?
    Sorry for such noobness. I get how most of this works, but i am no software guy by any means.
    Should i just try some of the other codes i have in the scan until one takes?
    I was able to remap the adaptation channels by hitting the "no" option every time. Got my tailights back to ROW amber turns and front fogs adapted. I just cant change the long coding. 😩
  12. #50
    Quote Originally Posted by IceRacerX View Post
    Just observe that the WSC, Importer, and Equipment number in the last BCM data you posted is basically all 1's in binary, as is the mileage in the freeze-frame data for the B131F fault.
    Should i just try some of the other codes i have in the scan until one takes? [...] I just cant change the long coding. ��
    I've lost track of exactly what you're trying to do here, nor am I an expert on the coding of those BCMs. If the BCM still has WSC 131071 1023 2097151 in it, you're going to need to put different values in those fields. These values have no functional effect on anything, they simply record what dealer and what tool did it.
