How to install fogs on S model Mk7's (long version)
IceRacerX
C?ID=275929
Hello, i have a 2016 Sportwagen S MT with halogen headlight no fogs. My BCM is 5Q0937087ABZ00. VCDS says "this module does not support fog lights". I called my VW guy at the dealer for a SE with fog and a SE LP with fog. VW says they all use the same BCM. Should i just try to scan the cars to get long coding to update mine? I am dumbfounded on why they all have the same part number but mine wont support fogs. Anyone have any ideas? thanks!!
It sure wouldn't hurt to post a scan from yours and one from a car that supports what you want.
Oh, and in the case of MQB (Mk.7) lighting questions, a scan might not be enough. Get Adaptation Channel Maps from both cars as well.
IceRacerX
C?ID=275929
How do i scan the Adaptation Channels?
[Applications]
[Controller Channel Map]
Controller Address = 09
Login or security access: leave blank
Function: Adaptation
Output: CSV File
[Go]
IceRacerX
C?ID=275929
Will do that this weekend. I am afraid that my BCM coding might be different already as I had a 3rd party change my taillight coding for my EuroTails with amber sidemarkers. I will try to scan a stock S model as well. Does AT make a huge diff compared to MT for BCM? My car was a special order with manual so it is going to be hard to find one anywhere to scan.
thanks UWE!
I'm reasonably confident that any differences due to AT vs. MT can be accounted for.
DV52
C?ID=194404
Ice racer: Hello. That's a very interesting project indeed!!
Uwe's suggestion will go a long way to help those reading your post to understand what kind of DNA is in the car (particularly the BCM admap). While you are doing this, I provide some further information below as a thought prompt for other considerations that might aid your project:
Regardless of what your "VW guy" has said, IMO it's always a good first step to physically sight the pertinent pins on the BCM - whilst it's not an absolute guarantee, seeing that the BCM has the correct pins actually installed on the connector is always a good sign (and if the pins are not installed, then you can be guaranteed that the BCM doesn't support the function). To this end, I enclose the picture below, which I have cut-and-paste from the Sportswagon wiring diagram.
As you can see, I've also included a picture of the physical BCM (my apology if you are already familiar with the socket structure for the BCM). You will find that the actual pin numbers are embossed into the bottom of the plastic housing, near the cut-outs for the pins.
So the pins to sight are pin #45 and #5 on the A socket (for the actual lamps) and pin #29 on the A socket (for the rotary light switch). If these pins are evident, then I suspect that the project is live - alas if these pins are absent, then you will not be able to proceed with your current BCM.
I've also included a picture of the coding change that will be required to the BCM to tell it that you have installed the actual fog lights and the new rotary light switch (with fog light capabilities). Note: the P/N from which the long coding screen was taken is slightly different to the BCM P/N that you posted - so you will need to confirm the Bit structure in my picture on your car.
Finally, you will doubtless need to do some Leuchte programming to instruct the BCM how to energise the wires that you have connected from the new fog light fittings. This is where the admap that Uwe requested becomes important (incidentally, it takes about 40 minutes to create a BCM admap on my mk7, so make sure that the battery is in a good condition, or have the car running). The two pertinent Leuchte-sets will be
  • Leuchte12NL LB45 - this is the left side fog lamp
  • Leuchte13NL RB5 - this is the right side fog lamp
I suspect that the boffins at VW HQ have set the 19 x adaptation channels for these two Leuchte-sets to "not active", but let's wait until you post-up the admap and you have confirmed that the BCM is fog-light ready before we discuss how to change these channels
EDIT: Ooops - I forgot to mention that even if the factory fitted fog light pins may be missing on your existing BCM, Leuchte-programming can be used to "apply" the fog light function on another, unused set of BCM pins. The only thing that's necessary if you want to try this alternative, is that there is a set of unused Leuchte pins on the BCM (generally there is) and that the fog light pin from the rotary switch is present (i.e. pin #29 -A socket)
IceRacerX
C?ID=275929
Bits 2 and 3 dont exsist in ky coding. I can try to screen shot it for you.
DV52
C?ID=194404
IceRacer: The absence, or presence of the bits on the long coding screen is less important than posting-up the autoscan/admap information (as Uwe suggested) and sighting the pins on the BCM (IMO).
IceRacerX
C?ID=275929
a couple of notes, I have ROW taillights with Amber turn signals installed and power folding mirrors before I purchased my VAGCOM.
so my codes are different than stock and I do not have an original scan. ding the adaptation one now.
and
how do I shrink this?
VCDS Version: Release 15.7.4 Running on Windows 10 x86
Data version: 20160216
Sunday,08,May,2016,17:55:57:58344
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWA17AU1GM516884   Mileage: 2820km-1752miles
Address 01: Engine (J623-CXBA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091100122424002F0000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: N/A
   VCID: 3FA3BB32A69E54C647-806A
No ASAM data for: "EV_ECM18TFS0208V0906264F" (VW37)
17178 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:13
21320 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:13
23128 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:13
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 53165000000809
   Coding: 04FA6AA124210972007F020881C7292056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 4BBB9FE2E226F866DB-801E
0040 - Front Left Wheel Speed Sensor
          C101A 01 [008] - Electrical Failure
                    Reset counter: 175
                    Mileage: 2143 km
16417 - Display for Tire Pressure Monitoring
                    Reset counter: 175
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:24
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020004200100000000000000000002
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 052F69DA84C2CE164D-8050
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 T    HW: 5Q0 937 087 T
   Revision: --------    Serial number: 86582310150599
   Coding: 000008424041804169E44000000407001000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 4CB99CFEE728FF5ED2-8018
   Slave 1:
   Component: WWS    150801  043 0581
   Serial number:         151211180657
   Serial number: 003GCR03KV3T
   VCID: 47B3A3D2FE4E1C06FF-8012
   Seat occupant detection; front passenger side:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003ZUE32
   Coding: 303133
   Subsystem 2 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 35700000000C8064E61N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 35800000000E172DF61W
   Subsystem 4 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3510002C71CF1D1522C8
   Subsystem 5 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3520002AB1CF1D2212A6
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3550002C91D1B621A252
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3560002C71D1B62071B2
9483008 - Seat Occupied Recognition
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 175
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:31
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151102500369
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3A55CA26BDBC71EE70-806E
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BB51102A180CF0502086A001000000000000000
   VCID: 256F095A2402EE162D-8070
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 196
                    Mileage: 2800 km
                    Date: 2016.05.07
                    Time: 17:13:52
   Part No SW: 5Q0 907 530 AH    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2246
   Revision: --------    Serial number: 24101510800925
   Coding: 0101000830085900FB000008080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti.rod
   VCID: 77D31312CE2EAC864F-8022
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150001515720025325
   Coding: 30FFFF
   Serial number: 9601152730397
   Coding: 001103205000040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000002389556
   Coding: 011000
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 2014 km
                    Date: 2016.04.26
                    Time: 14:40:23
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   VCID: 44A9B4DECF78371E1A-8010
20228 - Databus
                    Reset counter: 175
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:14
20740 - Databus
                    Reset counter: 175
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:14
19716 - Databus
                    Reset counter: 175
                    Mileage: 2143 km
                    Date: 2016.04.29
                    Time: 13:38:14
   Serial number: 9901153100925
   Coding: 003103205C00020000000000
   Shop #: WSC 12345 813 111111
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 46ADAED6F944050E04-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000002391317
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730200FF00000051220001001808001F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6CF93C7E87681F5EB2-8038
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9RJW001SF
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730202C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43ABB7C2CA76302623-8016
End-------------------------(Elapsed Time: 02:47)--------------------------
IceRacerX
C?ID=275929
;SW:5Q0-937-087-T   HW:5Q0-937-087-T ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0162, Coding:000008424041804169E44000000407001000000000000000000000000000
;EV_BodyContrModul1UDSBosc,015002,EV_BCMBOSCH_AU37.rod
;Sunday,08,May,2016,18:07:24:58344
;VCDS Version: Release 15.7.4  Data version: 20160216
;VCID: 4CB99CFEE728FF5ED2-8018
(1)-Access control-Funk bei Klemme 15 ein,not active
(2)-Access control-Notschließfunktion,active
(3)-Access control-automatisches Verriegeln bei Geschwindigkeit,active
(4)-Access control-automatisches Entriegeln,active
(5)-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
(6)-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
(7)-Access control-CAN Wecken bei Softtouchbetaetigung,not active
(8)-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
(9)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
(10)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
(11)-Access control-Valet Parking,not active
(12)-Access control-Direkter Auswurf des Heckdeckels,not active
(13)-Access control-ZV entriegelt auch Heckdeckel,active
(14)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
(15)-Access control-Autolock Autounlock wirkt auf Heck,active
(16)-Access control-ZV Heck nur direkt auswerfen,not active
(17)-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,active
(18)-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
(19)-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
(20)-Access control-ZV-Entriegelung nach Seitencrash,not active
(21)-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
(22)-Access control-Elektrische Laderaumabdeckung,not active
(23)-Access control-Menuesteuerung Tuerentriegelung,active
(24)-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
(25)-Access control-Autounlock NAR,active
(26)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
(27)-Access control-Softtouch-Betaetigung senden,Always
(28)-Access control-Servoheck Schlossansteuerung,Always
(29)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
(30)-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
(31)-Access control-Vorrastenhaenger_Freigabe,not active
(32)-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
(33)-Access control-Deaktivierung_Laderaumschliessung_extern,not active
(34)-Access control-LS_Taster_Togglefunktion,not active
(35)-Access control-Nutzfahrzeug_Schliessung,not active
(36)-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
(37)-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
(1)-Access control 2-Komfortbedienung global,active
(2)-Access control 2-Comfort opening,not active
(3)-Access control 2-Comfort closing,active
(4)-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
(5)-Access control 2-Nachsaven_nach_Verdecklauf,not active
(6)-Access control 2-Funk Komfort schliessen,not active
(7)-Access control 2-Funk Komfort oeffnen,not active
(8)-Access control 2-Schliesszylinder Komfort oeffnen,not active
(9)-Access control 2-Schliesszylinder Komfort schliessen,not active
(10)-Access control 2-SAD Richtung Komfortoeffnen,tilting
(11)-Access control 2-SAD Komfort schliessen,not active
(12)-Access control 2-SAD Komfort oeffnen,not active
(13)-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
(14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
(15)-Access control 2-Regenschliessen_ein_aus,not active
(16)-Access control 2-Regenschliessen_art,once
(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active
(18)-Access control 2-Spiegelverstellung Synchron,not active
(19)-Access control 2-Kessy Komfort oeffnen,not active
(20)-Access control 2-Kessy Komfort schliessen,active
(21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
(22)-Access control 2-Menuesteuerung Spiegelabsenkung,not active
(23)-Access control 2-Funk Spiegelanklappen,not active
(24)-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key
(25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active
(26)-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
(27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
(28)-Access control 2-Menuesteuerung Regenschliessen,not active
(29)-Access control 2-SAD PreCrash Konturschliessen,not active
(30)-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
(31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
(32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active
(33)-Access control 2-Remote_Unlock_Lock,Via ZV-Absicherung Light
(34)-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active
(35)-Access control 2-Signalisierung_Spiegelanklappung,active
(36)-Access control 2-Virtuelles_Pedal,not active
(37)-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
(38)-Access control 2-easycloselight_aktiv,not active
(39)-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active
(1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
(2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
(3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
(4)-Acknowledgement signals-Optical feedback during locking,Decelerate
(5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
(6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
(7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
(8)-Acknowledgement signals-Akustische Rueckmeldung global,active
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active
(10)-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
(11)-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
Activating and deactivating all development messages,not active
(1)-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
(2)-After-run for park light-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit
(3)-After-run for park light-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit
(4)-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten
(5)-After-run for park light-Standlicht-Nachlaufzeit,30 min
(6)-After-run for park light-Standlicht-Verfügbarkeit,6 s
Alternating park position 1,7.49 °
Alternating park position 2,29.49 °
(1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
(2)-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
(3)-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %
(4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
(5)-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
(6)-Ambient lighting-Innenlichtinszenierung,not enabled
(1)-Ambientelicht Farbliste-Rotwert Farbe 4,E1
(2)-Ambientelicht Farbliste-Gruenwert Farbe 4,E1
(3)-Ambientelicht Farbliste-Blauwert Farbe 4,E1
(4)-Ambientelicht Farbliste-Rotwert Farbe 5,E1
(5)-Ambientelicht Farbliste-Gruenwert Farbe 5,E1
(6)-Ambientelicht Farbliste-Blauwert Farbe 5,E1
(7)-Ambientelicht Farbliste-Rotwert Farbe 6,E1
(8)-Ambientelicht Farbliste-Gruenwert Farbe 6,E1
(9)-Ambientelicht Farbliste-Blauwert Farbe 6,E1
(10)-Ambientelicht Farbliste-Rotwert Farbe 7,E1
(11)-Ambientelicht Farbliste-Gruenwert Farbe 7,E1
(12)-Ambientelicht Farbliste-Blauwert Farbe 7,E1
(13)-Ambientelicht Farbliste-Rotwert Farbe 8,E1
(14)-Ambientelicht Farbliste-Gruenwert Farbe 8,E1
(15)-Ambientelicht Farbliste-Blauwert Farbe 8,E1
(16)-Ambientelicht Farbliste-Rotwert Farbe 9,E1
(17)-Ambientelicht Farbliste-Gruenwert Farbe 9,E1
(18)-Ambientelicht Farbliste-Blauwert Farbe 9,E1
(19)-Ambientelicht Farbliste-Rotwert Farbe 10,E1
(20)-Ambientelicht Farbliste-Gruenwert Farbe 10,E1
(21)-Ambientelicht Farbliste-Blauwert Farbe 10,E1
(1)-Anti-theft device-Alarmsignal,frequency modulated
(2)-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
(3)-Anti-theft device-DWA Alarmverzoegerung,not active
(4)-Anti-theft device-DWA Camper Modus,not active
(5)-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
(6)-Anti-theft device-Sirenen Alarmzahl,1 Alarm
(7)-Anti-theft device-Akustischer Alarm Signalhorn,active
(1)-Assistance light functions-Notbremsanzeige NBA,not active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
(4)-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active
(5)-Assistance light functions-Fernlichtassistent Reset,not active
(6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
(7)-Assistance light functions-Assistenzfahrlicht bei Regen,active
(8)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
(9)-Assistance light functions-LS_Error_Ausgabe,not active
(10)-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
(11)-Assistance light functions-AFL Zeitverzoegerung,0 ms
(12)-Assistance light functions-Lichtsensorempfindlichkeit,sensitive
(1)-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
(2)-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
(3)-Auxiliary functions-Signalhorn ohne KL15,active
(4)-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
(1)-Button in center console-Funktion Taster 1,Start-stop
(2)-Button in center console-Funktion Taster 2,Laderaumschließung
(3)-Button in center console-Funktion Taster 3,Driving program
(4)-Button in center console-Funktion Taster 4,Steering wheel heater
Characteristics in production mode,2000 ms
(1)-Comfort illumination-Coming Home Verbaustatus,Not Present
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active
(3)-Comfort illumination-Menueeinstellung Cominghome,0 s
(4)-Comfort illumination-Coming Home Leuchten,Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis,ignition
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0 lx
(7)-Comfort illumination-Leaving-Home Verbausstatus,not enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,not active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,0 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 lx
(1)-Convert. top oper.-Komfortbedienung Verdeck global,active
(2)-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
(3)-Convert. top oper.-Komfortbedienung Verdeck schließen,active
(4)-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
(5)-Convert. top oper.-Verdeck schließen via Schließzylinder,active
(6)-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
(7)-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
(8)-Convert. top oper.-Verdeck oeffnen via Kessy,active
(9)-Convert. top oper.-Verdeck schließen via Kessy,active
(10)-Convert. top oper.-Doppelpuls nur Verdeck,active
(11)-Convert. top oper.-Verdeck mit Schiebedach,not active
(12)-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
(13)-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
(14)-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
(15)-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
(16)-Convert. top oper.-Remote Lock Unlock Timer s1,0 s
(17)-Convert. top oper.-Remote Lock Unlock Timer s3,0.000 ms
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
(8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
Deactivate production mode,0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
(3)-Driving light and parking light-Standlicht aus,active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert,not active
(5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,not active
(6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
(10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
(3)-Dyn. turn signal modes-ZV_Blinken_zu,not active
(4)-Dyn. turn signal modes-ZV_Blinken_auf,not active
(5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
(8)-Dyn. turn signal modes-Taxialarmblinken,not active
(9)-Dyn. turn signal modes-Panikblinken,not active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
(13)-Dyn. turn signal modes-Richtungs_blinken_links,not active
(14)-Dyn. turn signal modes-ABBA_Blinken,not active
(15)-Dyn. turn signal modes-Crashblinken,not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
(18)-Dyn. turn signal modes-Emergency_alert_blinken,not active
(1)-Energy management-Energy_Management_Adaptation,Energy management active
(2)-Energy management-Praediktives_Energiemanagement,not active
(1)-Head area heater-blower_speed,1
(2)-Head area heater-Temperature,-2
(1)-Int. light; 2nd generation-Aufloesung Dimmzeit,0.10 s
(2)-Int. light; 2nd generation-weicher Farbwechsel,not active
(3)-Int. light; 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
(4)-Int. light; 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
(5)-Int. light; 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
(6)-Int. light; 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
(7)-Int. light; 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
(8)-Int. light; 2nd generation-Dachbeleuchtung mehrfarbig,not active
(9)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
(10)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
(11)-Int. light; 2nd generation-BAP Farbwert Farbe 1,2
(12)-Int. light; 2nd generation-BAP Farbwert Farbe 2,3
(13)-Int. light; 2nd generation-BAP Farbwert Farbe 3,1
(14)-Int. light; 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
(15)-Int. light; 2nd generation-Defaultwert Ambienteprofil Dach,80 %
(16)-Int. light; 2nd generation-Defaultwert Ambienteprofil Farbe,2
(17)-Int. light; 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
(18)-Int. light; 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
(19)-Int. light; 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
(20)-Int. light; 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
(21)-Int. light; 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
(22)-Int. light; 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
(23)-Int. light; 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
(24)-Int. light; 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
(25)-Int. light; 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
(26)-Int. light; 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
(27)-Int. light; 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
(28)-Int. light; 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
(29)-Int. light; 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
(30)-Int. light; 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
(31)-Int. light; 2nd generation-Rotwert Farbe 1,225
(32)-Int. light; 2nd generation-Gruenwert Farbe 1,225
(33)-Int. light; 2nd generation-Blauwert Farbe 1,225
(34)-Int. light; 2nd generation-Rotwert Farbe 2,225
(35)-Int. light; 2nd generation-Gruenwert Farbe 2,225
(36)-Int. light; 2nd generation-Blauwert Farbe 2,225
(37)-Int. light; 2nd generation-Rotwert Farbe 3,225
(38)-Int. light; 2nd generation-Gruenwert Farbe 3,225
(39)-Int. light; 2nd generation-Blauwert Farbe 3,225
(1)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed
(2)-Interior light; light configuration-Ambiente_Lautsprecher,not installed
(3)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
(4)-Interior light; light configuration-Cockpitbeleuchtung,not installed
(5)-Interior light; light configuration-Mittelkonsolenbeleuchtung,not installed
(6)-Interior light; light configuration-Dachbeleuchtung,not installed
(7)-Interior light; light configuration-Panoramaschiebedachbeleuchtung,not installed
(8)-Interior light; light configuration-Foot well lighting,not installed
(9)-Interior light; light configuration-Farbwahl ueber HMI,not installed
(10)-Interior light; light configuration-Farbwahl ueber Fahrprofil,not installed
(11)-Interior light; light configuration-LIN-Dachkonsole lokal aktivierbar,not active
(12)-Interior light; light configuration-Ambientemenue mit globalem aus,not active
(13)-Interior light; light configuration-Ambientemenue mit alle Zonen,not active
(14)-Interior light; light configuration-Ambient_Farbliste_HMI,not active
(15)-Interior light; light configuration-Frei_Farbwahl_ueber_HMI,not active
(1)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
(2)-Interior lighting-KL30G ohne PWM,not active
(3)-Interior lighting-KL58 Einschalten mit Rampe,not active
(4)-Interior lighting-KL58 Verriegelungsausschalten,not active
(5)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
(6)-Interior lighting-Suchbeleuchtung Festwert,100 %
(1)-Interior lighting; parameter-p_t_verzoegerung_einstieg_innenlicht,0 s
(2)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_innenlicht,0 s
(3)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_innenlicht,0 s
(4)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_innenlicht,0 s
(5)-Interior lighting; parameter-p_t_verzoegerung_schliessen_innenlicht,0 s
(6)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0 s
(7)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_innenlicht,0 s
(8)-Interior lighting; parameter-p_t_verzoegerung_einstieg_tueren,0 s
(9)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_tueren,0 s
(10)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_tueren,0 s
(11)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_tueren,0 s
(12)-Interior lighting; parameter-p_t_verzoegerung_schliessen_tueren,0 s
(13)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_tueren,0 s
(14)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_tueren,0 s
(15)-Interior lighting; parameter-p_t_verzoegerung_einstieg_fussraum,0 s
(16)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_fussraum,0 s
(17)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_fussraum,0 s
(18)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_fussraum,0 s
(19)-Interior lighting; parameter-p_t_verzoegerung_schliessen_fussraum,0 s
(20)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_fussraum,0 s
(21)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_fussraum,0 s
(22)-Interior lighting; parameter-p_t_verzoegerung_einstieg_cockpit,0 s
(23)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_cockpit,0 s
(24)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_cockpit,0 s
(25)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_cockpit,0 s
(26)-Interior lighting; parameter-p_t_verzoegerung_schliessen_cockpit,0 s
(27)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_cockpit,0 s
(28)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_cockpit,0 s
(29)-Interior lighting; parameter-p_t_verzoegerung_einstieg_miko,0 s
(30)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_miko,0 s
(31)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_miko,0 s
(32)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_miko,0 s
(33)-Interior lighting; parameter-p_t_verzoegerung_schliessen_miko,0 s
(34)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_miko,0 s
(35)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_miko,0 s
(36)-Interior lighting; parameter-p_t_verzoegerung_einstieg_dach,0 s
(37)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_dach,0 s
(38)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_dach,0 s
(39)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_dach,0 s
(40)-Interior lighting; parameter-p_t_verzoegerung_schliessen_dach,0 s
(41)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_dach,0 s
(42)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_dach,0 s
(43)-Interior lighting; parameter-p_helligkeit_entriegelt_innenlicht,100 %
(44)-Interior lighting; parameter-p_helligkeit_max_innenlicht,100 %
(45)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %
(46)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %
(47)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %
(48)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %
(49)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %
(50)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %
(51)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %
(52)-Interior lighting; parameter-p_helligkeit_einausstieg_innenlicht,100 %
(53)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %
(54)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %
(55)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %
(56)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %
(57)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %
(58)-Interior lighting; parameter-p_adaption_kundenwunsch_tuer,00
(59)-Interior lighting; parameter-p_helligkeit_entriegelt_tueren,0 %
(60)-Interior lighting; parameter-p_helligkeit_max_tueren,0 %
(61)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %
(62)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %
(63)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %
(64)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %
(65)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %
(66)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %
(67)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %
(68)-Interior lighting; parameter-p_helligkeit_einausstieg_tueren,0 %
(69)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %
(70)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %
(71)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %
(72)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %
(73)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %
(74)-Interior lighting; parameter-p_adaption_kundenwunsch_fussraum,00
(75)-Interior lighting; parameter-p_helligkeit_entriegelt_fussraum,0 %
(76)-Interior lighting; parameter-p_helligkeit_max_fussraum,0 %
(77)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %
(78)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %
(79)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %
(80)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %
(81)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %
(82)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %
(83)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %
(84)-Interior lighting; parameter-p_helligkeit_einausstieg_fussraum,0 %
(85)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %
(86)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %
(87)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %
(88)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %
(89)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %
(90)-Interior lighting; parameter-p_adaption_kundenwunsch_lautsprecher,64
(91)-Interior lighting; parameter-p_helligkeit_entriegelt_lautsprecher,100 %
(92)-Interior lighting; parameter-p_helligkeit_max_lautsprecher,100 %
(93)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %
(94)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %
(95)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %
(96)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %
(97)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %
(98)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %
(99)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %
(100)-Interior lighting; parameter-p_helligkeit_einausstieg_lautsprecher,100 %
(101)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %
(102)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %
(103)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %
(104)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %
(105)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %
(106)-Interior lighting; parameter-p_adaption_kundenwunsch_itafel,64
(107)-Interior lighting; parameter-p_helligkeit_entriegelt_itafel,100 %
(108)-Interior lighting; parameter-p_helligkeit_max_itafel,100 %
(109)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %
(110)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %
(111)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %
(112)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %
(113)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %
(114)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %
(115)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %
(116)-Interior lighting; parameter-p_helligkeit_einausstieg_itafel,100 %
(117)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %
(118)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %
(119)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %
(120)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %
(121)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,0 %
(122)-Interior lighting; parameter-p_adaption_kundenwunsch_cockpit,01
(123)-Interior lighting; parameter-p_helligkeit_entriegelt_cockpit,152 %
(124)-Interior lighting; parameter-p_helligkeit_max_cockpit,144 %
(125)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,87 %
(126)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,205 %
(127)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,0 %
(128)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,216 %
(129)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,216 %
(130)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,216 %
(131)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,216 %
(132)-Interior lighting; parameter-p_helligkeit_einausstieg_cockpit,216 %
(133)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,216 %
(134)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,216 %
(135)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,216 %
(136)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,233 %
(137)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,112 %
(138)-Interior lighting; parameter-p_adaption_kundenwunsch_miko,00
(139)-Interior lighting; parameter-p_helligkeit_entriegelt_miko,96 %
(140)-Interior lighting; parameter-p_helligkeit_max_miko,0 %
(141)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_miko,216 %
(142)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_miko,147 %
(143)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,96 %
(144)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,0 %
(145)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,0 %
(146)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,74 %
(147)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,7 %
(148)-Interior lighting; parameter-p_helligkeit_einausstieg_miko,8 %
(149)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,255 %
(150)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,0 %
(151)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,216 %
(152)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,216 %
(153)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,186 %
(154)-Interior lighting; parameter-p_adaption_kundenwunsch_dach,2C
(155)-Interior lighting; parameter-p_helligkeit_entriegelt_dach,191 %
(156)-Interior lighting; parameter-p_helligkeit_max_dach,5 %
(157)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_dach,60 %
(158)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_dach,248 %
(159)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,228 %
(160)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,1 %
(161)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,6 %
(162)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,96 %
(163)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,216 %
(164)-Interior lighting; parameter-p_helligkeit_einausstieg_dach,254 %
(165)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,216 %
(166)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,245 %
(167)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,10 %
(168)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,216 %
(169)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %
(170)-Interior lighting; parameter-p_adaption_kundenwunsch_psd,00
(171)-Interior lighting; parameter-p_helligkeit_entriegelt_psd,204 %
(172)-Interior lighting; parameter-p_helligkeit_max_psd,1 %
(173)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_psd,185 %
(174)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_psd,59 %
(175)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,64 %
(176)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %
(177)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,224 %
(178)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,80 %
(179)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,10 %
(180)-Interior lighting; parameter-p_helligkeit_einausstieg_psd,0 %
(181)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,1 %
(182)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %
(183)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,8 %
(184)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,124 %
(185)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,80 %
(186)-Interior lighting; parameter-p_dimmfaktor_farbwechsel_auf,CD
(187)-Interior lighting; parameter-p_dimmfaktor_farbwechsel_ab,FE
(188)-Interior lighting; parameter-p_farbwechsel_delay,6C
(189)-Interior lighting; parameter-p_farbauswahl_HMI,7F
(190)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI,B8
(191)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_2,0F
(192)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_3,00
(193)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_4,91
(194)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI,00
(195)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_2,00
(196)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_3,01
(197)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_4,00
(198)-Interior lighting; parameter-p_verzoegerung_berechnen,00
(199)-Interior lighting; parameter-p_t_HMI_verzoegerung_helligkeitswerte,233 ms
(1)-Light configuration-Lasttyp 0,12 - Blinkleuchten
(2)-Light configuration-BAP Bitposition 0,34
(3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Light configuration-Lichtfunktion A 0,2
(5)-Light configuration-Lichtfunktion B 0,0
(6)-Light configuration-Dimmwert AB 0,100
(7)-Light configuration-Lichtansteuerung HD AB 0,Always
(8)-Light configuration-Lichtfunktion C 0,0
(9)-Light configuration-Lichtfunktion D 0,0
(10)-Light configuration-Dimmwert CD 0,0
(11)-Light configuration-Dimming Direction CD 0,maximize
(12)-Light configuration-Lichtfunktion E 0,0
(13)-Light configuration-Lichtfunktion F 0,0
(14)-Light configuration-Dimmwert EF 0,0
(15)-Light configuration-Dimming Direction EF 0,maximize
(16)-Light configuration-Lichtfunktion G 0,0
(17)-Light configuration-Lichtfunktion H 0,0
(18)-Light configuration-Dimmwert GH 0,0
(19)-Light configuration-Dimming Direction GH 0,maximize
(20)-Light configuration-Lasttyp 1,12 - Blinkleuchten
(21)-Light configuration-BAP Bitposition 1,3E
(22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
(23)-Light configuration-Lichtfunktion A 1,4
(24)-Light configuration-Lichtfunktion B 1,0
(25)-Light configuration-Dimmwert AB 1,100
(26)-Light configuration-Lichtansteuerung HD AB 1,Always
(27)-Light configuration-Lichtfunktion C 1,0
(28)-Light configuration-Lichtfunktion D 1,0
(29)-Light configuration-Dimmwert CD 1,0
(30)-Light configuration-Dimming Direction CD 1,maximize
(31)-Light configuration-Lichtfunktion E 1,0
(32)-Light configuration-Lichtfunktion F 1,0
(33)-Light configuration-Dimmwert EF 1,0
(34)-Light configuration-Dimming Direction EF 1,maximize
(35)-Light configuration-Lichtfunktion G 1,0
(36)-Light configuration-Lichtfunktion H 1,0
(37)-Light configuration-Dimmwert GH 1,0
(38)-Light configuration-Dimming Direction GH 1,maximize
(39)-Light configuration-Lasttyp 2,8 - allgemeine Glühlampe 12W
(40)-Light configuration-BAP Bitposition 2,00
(41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,45
(42)-Light configuration-Lichtfunktion A 2,8
(43)-Light configuration-Lichtfunktion B 2,0
(44)-Light configuration-Dimmwert AB 2,100
(45)-Light configuration-Lichtansteuerung HD AB 2,Always
(46)-Light configuration-Lichtfunktion C 2,0
(47)-Light configuration-Lichtfunktion D 2,0
(48)-Light configuration-Dimmwert CD 2,0
(49)-Light configuration-Dimming Direction CD 2,maximize
(50)-Light configuration-Lichtfunktion E 2,0
(51)-Light configuration-Lichtfunktion F 2,0
(52)-Light configuration-Dimmwert EF 2,0
(53)-Light configuration-Dimming Direction EF 2,maximize
(54)-Light configuration-Lichtfunktion G 2,0
(55)-Light configuration-Lichtfunktion H 2,0
(56)-Light configuration-Dimmwert GH 2,0
(57)-Light configuration-Dimming Direction GH 2,maximize
(58)-Light configuration-Lasttyp 3,8 - allgemeine Glühlampe 12W
(59)-Light configuration-BAP Bitposition 3,00
(60)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,46
(61)-Light configuration-Lichtfunktion A 3,8
(62)-Light configuration-Lichtfunktion B 3,0
(63)-Light configuration-Dimmwert AB 3,100
(64)-Light configuration-Lichtansteuerung HD AB 3,Always
(65)-Light configuration-Lichtfunktion C 3,0
(66)-Light configuration-Lichtfunktion D 3,0
(67)-Light configuration-Dimmwert CD 3,0
(68)-Light configuration-Dimming Direction CD 3,maximize
(69)-Light configuration-Lichtfunktion E 3,0
(70)-Light configuration-Lichtfunktion F3,0
(71)-Light configuration-Dimmwert EF 3,0
(72)-Light configuration-Dimming Direction EF 3,maximize
(73)-Light configuration-Lichtfunktion G 3,0
(74)-Light configuration-Lichtfunktion H 3,0
(75)-Light configuration-Dimmwert GH 3,0
(76)-Light configuration-Dimming Direction GH 3,maximize
(77)-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W; auch H15
(78)-Light configuration-BAP Bitposition 4,48
(79)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43
(80)-Light configuration-Lichtfunktion A 4,20
(81)-Light configuration-Lichtfunktion B 4,0
(82)-Light configuration-Dimmwert AB 4,100
(83)-Light configuration-Lichtansteuerung HD AB 4,Always
(84)-Light configuration-Lichtfunktion C 4,6
(85)-Light configuration-Lichtfunktion D 4,0
(86)-Light configuration-Dimmwert CD 4,0
(87)-Light configuration-Dimming Direction CD 4,minimize
(88)-Light configuration-Lichtfunktion E 4,8
(89)-Light configuration-Lichtfunktion F 4,0
(90)-Light configuration-Dimmwert EF 4,31
(91)-Light configuration-Dimming Direction EF 4,maximize
(92)-Light configuration-Lichtfunktion G 4,0
(93)-Light configuration-Lichtfunktion H 4,0
(94)-Light configuration-Dimmwert GH 4,0
(95)-Light configuration-Dimming Direction GH 4,maximize
(96)-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W; auch H15
(97)-Light configuration-BAP Bitposition 5,4C
(98)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44
(99)-Light configuration-Lichtfunktion A 5,20
(100)-Light configuration-Lichtfunktion B 5,0
(101)-Light configuration-Dimmwert AB 5,100
(102)-Light configuration-Lichtansteuerung HD AB 5,Always
(103)-Light configuration-Lichtfunktion C 5,7
(104)-Light configuration-Lichtfunktion D 5,0
(105)-Light configuration-Dimmwert CD 5,0
(106)-Light configuration-Dimming Direction CD 5,minimize
(107)-Light configuration-Lichtfunktion E 5,8
(108)-Light configuration-Lichtfunktion F5,0
(109)-Light configuration-Dimmwert EF 5,31
(110)-Light configuration-Dimming Direction EF 5,maximize
(111)-Light configuration-Lichtfunktion G 5,0
(112)-Light configuration-Lichtfunktion H 5,0
(113)-Light configuration-Dimmwert GH 5,0
(114)-Light configuration-Dimming Direction GH 5,maximize
(115)-Light configuration-Lasttyp 6,11 - Abblendlicht
(116)-Light configuration-BAP Bitposition 6,36
(117)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
(118)-Light configuration-Lichtfunktion A 6,11
(119)-Light configuration-Lichtfunktion B 6,0
(120)-Light configuration-Dimmwert AB 6,100
(121)-Light configuration-Lichtansteuerung HD AB 6,Always
(122)-Light configuration-Lichtfunktion C 6,0
(123)-Light configuration-Lichtfunktion D 6,0
(124)-Light configuration-Dimmwert CD 6,0
(125)-Light configuration-Dimming Direction CD 6,maximize
(126)-Light configuration-Lichtfunktion E 6,0
(127)-Light configuration-Lichtfunktion F 6,0
(128)-Light configuration-Dimmwert EF 6,0
(129)-Light configuration-Dimming Direction EF 6,maximize
(130)-Light configuration-Lichtfunktion G 6,0
(131)-Light configuration-Lichtfunktion H 6,0
(132)-Light configuration-Dimmwert GH 6,0
(133)-Light configuration-Dimming Direction GH 6,maximize
(134)-Light configuration-Lasttyp 7,11 - Abblendlicht
(135)-Light configuration-BAP Bitposition 7,40
(136)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
(137)-Light configuration-Lichtfunktion A 7,12
(138)-Light configuration-Lichtfunktion B 7,0
(139)-Light configuration-Dimmwert AB 7,100
(140)-Light configuration-Lichtansteuerung HD AB 7,Always
(141)-Light configuration-Lichtfunktion C 7,0
(142)-Light configuration-Lichtfunktion D 7,0
(143)-Light configuration-Dimmwert CD 7,0
(144)-Light configuration-Dimming Direction CD 7,maximize
(145)-Light configuration-Lichtfunktion E 7,0
(146)-Light configuration-Lichtfunktion F 7,0
(147)-Light configuration-Dimmwert EF 7,0
(148)-Light configuration-Dimming Direction EF 7,maximize
(149)-Light configuration-Lichtfunktion G 7,0
(150)-Light configuration-Lichtfunktion H 7,0
(151)-Light configuration-Dimmwert GH 7,0
(152)-Light configuration-Dimming Direction GH 7,maximize
(153)-Light configuration-Lasttyp 8,1 - LED Tagfahrlichtmodul Versorgung
(154)-Light configuration-BAP Bitposition 8,98
(155)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,57
(156)-Light configuration-Lichtfunktion A 8,205
(157)-Light configuration-Lichtfunktion B 8,0
(158)-Light configuration-Dimmwert AB 8,88
(159)-Light configuration-Lichtansteuerung HD AB 8,only_if_closed
(160)-Light configuration-Lichtfunktion C 8,216
(161)-Light configuration-Lichtfunktion D 8,216
(162)-Light configuration-Dimmwert CD 8,88
(163)-Light configuration-Dimming Direction CD 8,minimize
(164)-Light configuration-Lichtfunktion E 8,216
(165)-Light configuration-Lichtfunktion F 8,216
(166)-Light configuration-Dimmwert EF 8,88
(167)-Light configuration-Dimming Direction EF 8,minimize
(168)-Light configuration-Lichtfunktion G 8,216
(169)-Light configuration-Lichtfunktion H 8,233
(170)-Light configuration-Dimmwert GH 8,112
(171)-Light configuration-Dimming Direction GH 8,maximize
(172)-Light configuration-Lasttyp 9,not active
(173)-Light configuration-BAP Bitposition 9,60
(174)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,D8
(175)-Light configuration-Lichtfunktion A 9,147
(176)-Light configuration-Lichtfunktion B 9,96
(177)-Light configuration-Dimmwert AB 9,100
(178)-Light configuration-Lichtansteuerung HD AB 9,Always
(179)-Light configuration-Lichtfunktion C 9,0
(180)-Light configuration-Lichtfunktion D 9,74
(181)-Light configuration-Dimmwert CD 9,7
(182)-Light configuration-Dimming Direction CD 9,maximize
(183)-Light configuration-Lichtfunktion E 9,8
(184)-Light configuration-Lichtfunktion F 9,255
(185)-Light configuration-Dimmwert EF 9,0
(186)-Light configuration-Dimming Direction EF 9,maximize
(187)-Light configuration-Lichtfunktion G 9,216
(188)-Light configuration-Lichtfunktion H 9,216
(189)-Light configuration-Dimmwert GH 9,58
(190)-Light configuration-Dimming Direction GH 9,minimize
(191)-Light configuration-Lasttyp 10,44 - LED Fußraum- oder -Innenleuchte
(192)-Light configuration-BAP Bitposition 10,BF
(193)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,3C
(194)-Light configuration-Lichtfunktion A 10,248
(195)-Light configuration-Lichtfunktion B 10,228
(196)-Light configuration-Dimmwert AB 10,1
(197)-Light configuration-Lichtansteuerung HD AB 10,Always
(198)-Light configuration-Lichtfunktion C 10,6
(199)-Light configuration-Lichtfunktion D 10,96
(200)-Light configuration-Dimmwert CD 10,88
(201)-Light configuration-Dimming Direction CD 10,minimize
(202)-Light configuration-Lichtfunktion E 10,254
(203)-Light configuration-Lichtfunktion F 10,216
(204)-Light configuration-Dimmwert EF 10,117
(205)-Light configuration-Dimming Direction EF 10,minimize
(206)-Light configuration-Lichtfunktion G 10,10
(207)-Light configuration-Lichtfunktion H 10,216
(208)-Light configuration-Dimmwert GH 10,0
(209)-Light configuration-Dimming Direction GH 10,maximize
(210)-Light configuration-Lasttyp 11,not active
(211)-Light configuration-BAP Bitposition 11,CC
(212)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,B9
(213)-Light configuration-Lichtfunktion A 11,59
(214)-Light configuration-Lichtfunktion B 11,64
(215)-Light configuration-Dimmwert AB 11,0
(216)-Light configuration-Lichtansteuerung HD AB 11,Always
(217)-Light configuration-Lichtfunktion C 11,224
(218)-Light configuration-Lichtfunktion D 11,80
(219)-Light configuration-Dimmwert CD 11,10
(220)-Light configuration-Dimming Direction CD 11,maximize
(221)-Light configuration-Lichtfunktion E 11,0
(222)-Light configuration-Lichtfunktion F 11,1
(223)-Light configuration-Dimmwert EF 11,0
(224)-Light configuration-Dimming Direction EF 11,maximize
(225)-Light configuration-Lichtfunktion G 11,8
(226)-Light configuration-Lichtfunktion H 11,124
(227)-Light configuration-Dimmwert GH 11,80
(228)-Light configuration-Dimming Direction GH 11,maximize
(230)-Light configuration-BAP Bitposition 12,FE
(231)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,7F
(232)-Light configuration-Lichtfunktion A 12,184
(233)-Light configuration-Lichtfunktion B 12,15
(234)-Light configuration-Dimmwert AB 12,0
(235)-Light configuration-Lichtansteuerung HD AB 12,Always
(236)-Light configuration-Lichtfunktion C 12,145
(237)-Light configuration-Lichtfunktion D 12,0
(238)-Light configuration-Dimmwert CD 12,0
(239)-Light configuration-Dimming Direction CD 12,maximize
(240)-Light configuration-Lichtfunktion E 12,1
(241)-Light configuration-Lichtfunktion F 12,0
(242)-Light configuration-Dimmwert EF 12,0
(243)-Light configuration-Dimming Direction EF 12,maximize
(244)-Light configuration-Lichtfunktion G 12,233
(245)-Light configuration-Lichtfunktion H 12,44
(246)-Light configuration-Dimmwert GH 12,54
(247)-Light configuration-Dimming Direction GH 12,maximize
(249)-Light configuration-BAP Bitposition 13,18
(250)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,E0
(251)-Light configuration-Lichtfunktion A 13,160
(252)-Light configuration-Lichtfunktion B 13,184
(253)-Light configuration-Dimmwert AB 13,15
(254)-Light configuration-Lichtansteuerung HD AB 13,Always
(255)-Light configuration-Lichtfunktion  C 13,0
(256)-Light configuration-Lichtfunktion D 13,0
(257)-Light configuration-Dimmwert CD 13,52
(258)-Light configuration-Dimming Direction CD 13,maximize
(259)-Light configuration-Lichtfunktion E 13,64
(260)-Light configuration-Lichtfunktion F 13,154
(261)-Light configuration-Dimmwert EF 13,65
(262)-Light configuration-Dimming Direction EF 13,maximize
(263)-Light configuration-Lichtfunktion G 13,10
(264)-Light configuration-Lichtfunktion H 13,196
(265)-Light configuration-Dimmwert GH 13,0
(266)-Light configuration-Dimming Direction GH 13,maximize
(267)-Light configuration-Lasttyp 14,5 - LED Abblendlicht
(268)-Light configuration-BAP Bitposition 14,D0
(269)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,C2
(270)-Light configuration-Lichtfunktion A 14,0
(271)-Light configuration-Lichtfunktion B 14,106
(272)-Light configuration-Dimmwert AB 14,1
(273)-Light configuration-Lichtansteuerung HD AB 14,Always
(274)-Light configuration-Lichtfunktion C 14,10
(275)-Light configuration-Lichtfunktion D 14,1
(276)-Light configuration-Dimmwert CD 14,1
(277)-Light configuration-Dimming Direction CD 14,maximize
(278)-Light configuration-Lichtfunktion E 14,1
(279)-Light configuration-Lichtfunktion F 14,1
(280)-Light configuration-Dimmwert EF 14,64
(281)-Light configuration-Dimming Direction EF 14,maximize
(282)-Light configuration-Lichtfunktion G 14,246
(283)-Light configuration-Lichtfunktion H 14,12
(284)-Light configuration-Dimmwert GH 14,2
(285)-Light configuration-Dimming Direction GH 14,maximize
(286)-Light configuration-Lasttyp 15,9 - allgemeine Glühlampe 27W; auch H15
(287)-Light configuration-BAP Bitposition 15,FF
(288)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,98
(289)-Light configuration-Lichtfunktion A 15,70
(290)-Light configuration-Lichtfunktion B 15,152
(291)-Light configuration-Dimmwert AB 15,0
(292)-Light configuration-Lichtansteuerung HD AB 15,Always
(293)-Light configuration-Lichtfunktion C 15,248
(294)-Light configuration-Lichtfunktion D 15,0
(295)-Light configuration-Dimmwert CD 15,120
(296)-Light configuration-Dimming Direction CD 15,minimize
(297)-Light configuration-Lichtfunktion E 15,102
(298)-Light configuration-Lichtfunktion F 15,160
(299)-Light configuration-Dimmwert EF 15,41
(300)-Light configuration-Dimming Direction EF 15,minimize
(301)-Light configuration-Lichtfunktion G 15,72
(302)-Light configuration-Lichtfunktion H 15,88
(303)-Light configuration-Dimmwert GH 15,3
(304)-Light configuration-Dimming Direction GH 15,minimize
(305)-Light configuration-Lasttyp 16,10 - allgemeine Scheinwerfer
(306)-Light configuration-BAP Bitposition 16,4E
(307)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00
(308)-Light configuration-Lichtfunktion A 16,78
(309)-Light configuration-Lichtfunktion B 16,205
(310)-Light configuration-Dimmwert AB 16,0
(311)-Light configuration-Lichtansteuerung HD AB 16,Always
(312)-Light configuration-Lichtfunktion C 16,208
(313)-Light configuration-Lichtfunktion D 16,78
(314)-Light configuration-Dimmwert CD 16,112
(315)-Light configuration-Dimming Direction CD 16,minimize
(316)-Light configuration-Lichtfunktion E 16,26
(317)-Light configuration-Lichtfunktion F 16,208
(318)-Light configuration-Dimmwert EF 16,70
(319)-Light configuration-Dimming Direction EF 16,minimize
(320)-Light configuration-Lichtfunktion G 16,240
(321)-Light configuration-Lichtfunktion H 16,248
(322)-Light configuration-Dimmwert GH 16,61
(323)-Light configuration-Dimming Direction GH 16,maximize
(325)-Light configuration-BAP Bitposition 17,D0
(326)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,6A
(327)-Light configuration-Lichtfunktion A 17,36
(328)-Light configuration-Lichtfunktion  B 17,1
(329)-Light configuration-Dimmwert AB 17,0
(330)-Light configuration-Lichtansteuerung HD AB 17,Always
(331)-Light configuration-Lichtfunktion C 17,0
(332)-Light configuration-Lichtfunktion D 17,112
(333)-Light configuration-Dimmwert CD 17,127
(334)-Light configuration-Dimming Direction CD 17,minimize
(335)-Light configuration-Lichtfunktion E 17,255
(336)-Light configuration-Lichtfunktion F 17,39
(337)-Light configuration-Dimmwert EF 17,120
(338)-Light configuration-Dimming Direction EF 17,minimize
(339)-Light configuration-Lichtfunktion G 17,208
(340)-Light configuration-Lichtfunktion H 17,0
(341)-Light configuration-Dimmwert GH 17,0
(342)-Light configuration-Dimming Direction GH 17,maximize
(343)-Light configuration-Lasttyp 18,not active
(344)-Light configuration-BAP Bitposition 18,00
(345)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,00
(346)-Light configuration-Lichtfunktion A 18,0
(347)-Light configuration-Lichtfunktion B 18,0
(348)-Light configuration-Dimmwert AB 18,1
(349)-Light configuration-Lichtansteuerung HD AB 18,Always
(350)-Light configuration-Lichtfunktion C 18,185
(351)-Light configuration-Lichtfunktion D 18,117
(352)-Light configuration-Dimmwert CD 18,7
(353)-Light configuration-Dimming Direction CD 18,maximize
(354)-Light configuration-Lichtfunktion E 18,125
(355)-Light configuration-Lichtfunktion F 18,184
(356)-Light configuration-Dimmwert EF 18,80
(357)-Light configuration-Dimming Direction EF 18,maximize
(358)-Light configuration-Lichtfunktion G 18,237
(359)-Light configuration-Lichtfunktion H 18,254
(360)-Light configuration-Dimmwert GH 18,32
(361)-Light configuration-Dimming Direction GH 18,maximize
(363)-Light configuration-BAP Bitposition 19,0A
(364)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,C7
(365)-Light configuration-Lichtfunktion A 19,0
(366)-Light configuration-Lichtfunktion B 19,0
(367)-Light configuration-Dimmwert AB 19,0
(368)-Light configuration-Lichtansteuerung HD AB 19,Always
(369)-Light configuration-Lichtfunktion C 19,216
(370)-Light configuration-Lichtfunktion D 19,40
(371)-Light configuration-Dimmwert CD 19,123
(372)-Light configuration-Dimming Direction CD 19,minimize
(373)-Light configuration-Lichtfunktion E 19,165
(374)-Light configuration-Lichtfunktion F 19,64
(375)-Light configuration-Dimmwert EF 19,18
(376)-Light configuration-Dimming Direction EF 19,minimize
(377)-Light configuration-Lichtfunktion G 19,211
(378)-Light configuration-Lichtfunktion H 19,10
(379)-Light configuration-Dimmwert GH 19,78
(380)-Light configuration-Dimming Direction GH 19,maximize
(382)-Light configuration-BAP Bitposition 20,00
(383)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,5C
(384)-Light configuration-Lichtfunktion A 20,172
(385)-Light configuration-Lichtfunktion B 20,78
(386)-Light configuration-Dimmwert AB 20,93
(387)-Light configuration-Lichtansteuerung HD AB 20,only_if_closed
(388)-Light configuration-Lichtfunktion C 20,0
(389)-Light configuration-Lichtfunktion D 20,216
(390)-Light configuration-Dimmwert CD 20,97
(391)-Light configuration-Dimming Direction CD 20,minimize
(392)-Light configuration-Lichtfunktion E 20,196
(393)-Light configuration-Lichtfunktion F 20,219
(394)-Light configuration-Dimmwert EF 20,78
(395)-Light configuration-Dimming Direction EF 20,maximize
(396)-Light configuration-Lichtfunktion G 20,231
(397)-Light configuration-Lichtfunktion H 20,49
(398)-Light configuration-Dimmwert GH 20,19
(399)-Light configuration-Dimming Direction GH 20,minimize
(401)-Light configuration-BAP Bitposition 21,0A
(402)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,90
(403)-Light configuration-Lichtfunktion A 21,19
(404)-Light configuration-Lichtfunktion B 21,5
(405)-Light configuration-Dimmwert AB 21,0
(406)-Light configuration-Lichtansteuerung HD AB 21,Always
(407)-Light configuration-Lichtfunktion C 21,0
(408)-Light configuration-Lichtfunktion D 21,0
(409)-Light configuration-Dimmwert CD 21,0
(410)-Light configuration-Dimming Direction CD 21,maximize
(411)-Light configuration-Lichtfunktion E 21,188
(412)-Light configuration-Lichtfunktion F 21,225
(413)-Light configuration-Dimmwert EF 21,4
(414)-Light configuration-Dimming Direction EF 21,maximize
(415)-Light configuration-Lichtfunktion G 21,189
(416)-Light configuration-Lichtfunktion H 21,40
(417)-Light configuration-Dimmwert GH 21,127
(418)-Light configuration-Dimming Direction GH 21,minimize
(420)-Light configuration-BAP Bitposition 22,98
(421)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,00
(422)-Light configuration-Lichtfunktion A 22,49
(423)-Light configuration-Lichtfunktion B 22,106
(424)-Light configuration-Dimmwert AB 22,0
(425)-Light configuration-Lichtansteuerung HD AB 22,Always
(426)-Light configuration-Lichtfunktion C 22,10
(427)-Light configuration-Lichtfunktion D 22,78
(428)-Light configuration-Dimmwert CD 22,7
(429)-Light configuration-Dimming Direction CD 22,maximize
(430)-Light configuration-Lichtfunktion E 22,9
(431)-Light configuration-Lichtfunktion F 22,78
(432)-Light configuration-Dimmwert EF 22,16
(433)-Light configuration-Dimming Direction EF 22,maximize
(434)-Light configuration-Lichtfunktion G 22,131
(435)-Light configuration-Lichtfunktion H 22,10
(436)-Light configuration-Dimmwert GH 22,78
(437)-Light configuration-Dimming Direction GH 22,maximize
(438)-Light configuration-Lasttyp 23,17 - 4* 3W
(439)-Light configuration-BAP Bitposition 23,00
(440)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,CD
(441)-Light configuration-Lichtfunktion A 23,0
(442)-Light configuration-Lichtfunktion B 23,52
(443)-Light configuration-Dimmwert AB 23,78
(444)-Light configuration-Lichtansteuerung HD AB 23,Always
(445)-Light configuration-Lichtfunktion C 23,168
(446)-Light configuration-Lichtfunktion D 23,26
(447)-Light configuration-Dimmwert CD 23,52
(448)-Light configuration-Dimming Direction CD 23,maximize
(449)-Light configuration-Lichtfunktion E 23,126
(450)-Light configuration-Lichtfunktion F 23,168
(451)-Light configuration-Dimmwert EF 23,120
(452)-Light configuration-Dimming Direction EF 23,minimize
(453)-Light configuration-Lichtfunktion G 23,61
(454)-Light configuration-Lichtfunktion H 23,45
(455)-Light configuration-Dimmwert GH 23,0
(456)-Light configuration-Dimming Direction GH 23,maximize
(458)-Light configuration-BAP Bitposition 24,6A
(459)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,01
(460)-Light configuration-Lichtfunktion A 24,0
(461)-Light configuration-Lichtfunktion B 24,0
(462)-Light configuration-Dimmwert AB 24,112
(463)-Light configuration-Lichtansteuerung HD AB 24,Always
(464)-Light configuration-Lichtfunktion C 24,255
(465)-Light configuration-Lichtfunktion D 24,255
(466)-Light configuration-Dimmwert CD 24,39
(467)-Light configuration-Dimming Direction CD 24,maximize
(468)-Light configuration-Lichtfunktion E 24,248
(469)-Light configuration-Lichtfunktion F 24,52
(470)-Light configuration-Dimmwert EF 24,0
(471)-Light configuration-Dimming Direction EF 24,maximize
(472)-Light configuration-Lichtfunktion G 24,0
(473)-Light configuration-Lichtfunktion H 24,0
(474)-Light configuration-Dimmwert GH 24,0
(475)-Light configuration-Dimming Direction GH 24,maximize
(476)-Light configuration-Lasttyp 25,not active
(477)-Light configuration-BAP Bitposition 25,00
(478)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,00
(479)-Light configuration-Lichtfunktion A 25,1
(480)-Light configuration-Lichtfunktion B 25,59
(481)-Light configuration-Dimmwert AB 25,45
(482)-Light configuration-Lichtansteuerung HD AB 25,Always
(483)-Light configuration-Lichtfunktion C 25,7
(484)-Light configuration-Lichtfunktion D 25,53
(485)-Light configuration-Dimmwert CD 25,88
(486)-Light configuration-Dimming Direction CD 25,maximize
(487)-Light configuration-Lichtfunktion E 25,80
(488)-Light configuration-Lichtfunktion F 25,237
(489)-Light configuration-Dimmwert EF 25,126
(490)-Light configuration-Dimming Direction EF 25,minimize
(491)-Light configuration-Lichtfunktion G 25,0
(492)-Light configuration-Lichtfunktion H 25,58
(493)-Light configuration-Dimmwert GH 25,10
(494)-Light configuration-Dimming Direction GH 25,maximize
(496)-Light configuration-BAP Bitposition 26,4B
(497)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,CC
(498)-Light configuration-Lichtfunktion A 26,1
(499)-Light configuration-Lichtfunktion B 26,10
(500)-Light configuration-Dimmwert AB 26,56
(501)-Light configuration-Lichtansteuerung HD AB 26,only_if_closed
(502)-Light configuration-Lichtfunktion C 26,176
(503)-Light configuration-Lichtfunktion D 26,184
(504)-Light configuration-Dimmwert CD 26,72
(505)-Light configuration-Dimming Direction CD 26,minimize
(506)-Light configuration-Lichtfunktion E 26,1
(507)-Light configuration-Lichtfunktion F 26,200
(508)-Light configuration-Dimmwert EF 26,0
(509)-Light configuration-Dimming Direction EF 26,maximize
(510)-Light configuration-Lichtfunktion G 26,10
(511)-Light configuration-Lichtfunktion H 26,90
(512)-Light configuration-Dimmwert GH 26,0
(513)-Light configuration-Dimming Direction GH 26,maximize
(515)-Light configuration-BAP Bitposition 27,00
(516)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,24
(517)-Light configuration-Lichtfunktion A 27,74
(518)-Light configuration-Lichtfunktion B 27,97
(519)-Light configuration-Dimmwert AB 27,0
(520)-Light configuration-Lichtansteuerung HD AB 27,Always
(521)-Light configuration-Lichtfunktion C 27,1
(522)-Light configuration-Lichtfunktion D 27,6
(523)-Light configuration-Dimmwert CD 27,96
(524)-Light configuration-Dimming Direction CD 27,maximize
(525)-Light configuration-Lichtfunktion E 27,87
(526)-Light configuration-Lichtfunktion F 27,161
(527)-Light configuration-Dimmwert EF 27,100
(528)-Light configuration-Dimming Direction EF 27,maximize
(529)-Light configuration-Lichtfunktion G 27,52
(530)-Light configuration-Lichtfunktion H 27,88
(531)-Light configuration-Dimmwert GH 27,125
(532)-Light configuration-Dimming Direction GH 27,maximize
(533)-Light configuration-Lasttyp 28,1 - LED Tagfahrlichtmodul Versorgung
(534)-Light configuration-BAP Bitposition 28,00
(535)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,10
(536)-Light configuration-Lichtfunktion A 28,96
(537)-Light configuration-Lichtfunktion B 28,0
(538)-Light configuration-Dimmwert AB 28,6
(539)-Light configuration-Lichtansteuerung HD AB 28,only_if_closed
(540)-Light configuration-Lichtfunktion C 28,216
(541)-Light configuration-Lichtfunktion D 28,216
(542)-Light configuration-Dimmwert CD 28,112
(543)-Light configuration-Dimming Direction CD 28,minimize
(544)-Light configuration-Lichtfunktion E 28,96
(545)-Light configuration-Lichtfunktion F 28,1
(546)-Light configuration-Dimmwert EF 28,124
(547)-Light configuration-Dimming Direction EF 28,minimize
(548)-Light configuration-Lichtfunktion G 28,98
(549)-Light configuration-Lichtfunktion H 28,5
(550)-Light configuration-Dimmwert GH 28,43
(551)-Light configuration-Dimming Direction GH 28,minimize
(552)-Light configuration-Lasttyp 29,19 - 3* 5W
(553)-Light configuration-BAP Bitposition 29,60
(554)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,0C
(555)-Light configuration-Lichtfunktion A 29,96
(556)-Light configuration-Lichtfunktion B 29,96
(557)-Light configuration-Dimmwert AB 29,72
(558)-Light configuration-Lichtansteuerung HD AB 29,only_if_closed
(559)-Light configuration-Lichtfunktion C 29,27
(560)-Light configuration-Lichtfunktion D 29,0
(561)-Light configuration-Dimmwert CD 29,77
(562)-Light configuration-Dimming Direction CD 29,maximize
(563)-Light configuration-Lichtfunktion E 29,12
(564)-Light configuration-Lichtfunktion F 29,0
(565)-Light configuration-Dimmwert EF 29,15
(566)-Light configuration-Dimming Direction EF 29,maximize
(567)-Light configuration-Lichtfunktion G 29,16
(568)-Light configuration-Lichtfunktion H 29,0
(569)-Light configuration-Dimmwert GH 29,24
(570)-Light configuration-Dimming Direction GH 29,minimize
(572)-Light configuration-BAP Bitposition 30,AC
(573)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,FF
(574)-Light configuration-Lichtfunktion A 30,15
(575)-Light configuration-Lichtfunktion B 30,152
(576)-Light configuration-Dimmwert AB 30,32
(577)-Light configuration-Lichtansteuerung HD AB 30,Always
(578)-Light configuration-Lichtfunktion C 30,224
(579)-Light configuration-Lichtfunktion D 30,40
(580)-Light configuration-Dimmwert CD 30,48
(581)-Light configuration-Dimming Direction CD 30,minimize
(582)-Light configuration-Lichtfunktion E 30,204
(583)-Light configuration-Lichtfunktion F 30,248
(584)-Light configuration-Dimmwert EF 30,76
(585)-Light configuration-Dimming Direction EF 30,maximize
(586)-Light configuration-Lichtfunktion G 30,255
(587)-Light configuration-Lichtfunktion H 30,0
(588)-Light configuration-Dimmwert GH 30,120
(589)-Light configuration-Dimming Direction GH 30,maximize
(591)-Light configuration-BAP Bitposition 31,00
(592)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,95
(593)-Light configuration-Lichtfunktion A 31,19
(594)-Light configuration-Lichtfunktion B 31,5
(595)-Light configuration-Dimmwert AB 31,104
(596)-Light configuration-Lichtansteuerung HD AB 31,Always
(597)-Light configuration-Lichtfunktion C 31,24
(598)-Light configuration-Lichtfunktion D 31,96
(599)-Light configuration-Dimmwert CD 31,0
(600)-Light configuration-Dimming Direction CD 31,maximize
(601)-Light configuration-Lichtfunktion E 31,132
(602)-Light configuration-Lichtfunktion F 31,219
(603)-Light configuration-Dimmwert EF 31,19
(604)-Light configuration-Dimming Direction EF 31,maximize
(605)-Light configuration-Lichtfunktion G 31,5
(606)-Light configuration-Lichtfunktion H 31,0
(607)-Light configuration-Dimmwert GH 31,83
(608)-Light configuration-Dimming Direction GH 31,minimize
(610)-Light configuration-BAP Bitposition 32,90
(611)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,F6
(612)-Light configuration-Lichtfunktion A 32,19
(613)-Light configuration-Lichtfunktion B 32,3
(614)-Light configuration-Dimmwert AB 32,0
(615)-Light configuration-Lichtansteuerung HD AB 32,Always
(616)-Light configuration-Lichtfunktion C 32,0
(617)-Light configuration-Lichtfunktion D 32,0
(618)-Light configuration-Dimmwert CD 32,0
(619)-Light configuration-Dimming Direction CD 32,maximize
(620)-Light configuration-Lichtfunktion E 32,188
(621)-Light configuration-Lichtfunktion F 32,225
(622)-Light configuration-Dimmwert EF 32,4
(623)-Light configuration-Dimming Direction EF 32,maximize
(624)-Light configuration-Lichtfunktion G 32,189
(625)-Light configuration-Lichtfunktion H 32,40
(626)-Light configuration-Dimmwert GH 32,52
(627)-Light configuration-Dimming Direction GH 32,maximize
(629)-Light configuration-BAP Bitposition 33,58
(630)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00
(631)-Light configuration-Lichtfunktion A 33,164
(632)-Light configuration-Lichtfunktion B 33,106
(633)-Light configuration-Dimmwert AB 33,0
(634)-Light configuration-Lichtansteuerung HD AB 33,Always
(635)-Light configuration-Lichtfunktion C 33,144
(636)-Light configuration-Lichtfunktion D 33,19
(637)-Light configuration-Dimmwert CD 33,5
(638)-Light configuration-Dimming Direction CD 33,maximize
(639)-Light configuration-Lichtfunktion E 33,0
(640)-Light configuration-Lichtfunktion F 33,19
(641)-Light configuration-Dimmwert EF 33,80
(642)-Light configuration-Dimming Direction EF 33,minimize
(643)-Light configuration-Lichtfunktion G 33,131
(644)-Light configuration-Lichtfunktion H 33,144
(645)-Light configuration-Dimmwert GH 33,19
(646)-Light configuration-Dimming Direction GH 33,maximize
(647)-Light configuration-Lasttyp 34,5 - LED Abblendlicht
(648)-Light configuration-BAP Bitposition 34,00
(649)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,CD
(650)-Light configuration-Lichtfunktion A 34,0
(651)-Light configuration-Lichtfunktion B 34,52
(652)-Light configuration-Dimmwert AB 34,19
(653)-Light configuration-Lichtansteuerung HD AB 34,Always
(654)-Light configuration-Lichtfunktion C 34,104
(655)-Light configuration-Lichtfunktion D 34,26
(656)-Light configuration-Dimmwert CD 34,52
(657)-Light configuration-Dimming Direction CD 34,maximize
(658)-Light configuration-Lichtfunktion E 34,144
(659)-Light configuration-Lichtfunktion F 34,19
(660)-Light configuration-Dimmwert EF 34,5
(661)-Light configuration-Dimming Direction EF 34,maximize
(662)-Light configuration-Lichtfunktion G 34,0
(663)-Light configuration-Lichtfunktion H 34,237
(664)-Light configuration-Dimmwert GH 34,88
(665)-Light configuration-Dimming Direction GH 34,maximize
(1)-Light sensor-Einschaltgrenze_CHO_LHO,30 lx
(2)-Light sensor-Daemmerungsgrenze; Hysterese_obergrenze,60 lx
(3)-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,110 lx
(4)-Light sensor-Helligkeitsgrenze_sehr_hell,100 lx
(5)-Light sensor-Helligkeitsgrenze_Licht__einschalten,60 lx
(6)-Light sensor-Helligkeitsgrenze_Licht_ausschalten,110 lx
(7)-Light sensor-Minimale_Beleuchtungsstaerke,0 lx
(8)-Light sensor-Maximale_Beleuchtungsstaerke,300 lx
(9)-Light sensor-Minimale_Ausgangsspannung,2000 mV
(10)-Light sensor-Maximale_Ausgangsspannung,4500 mV
(11)-Light sensor-Tunnel_einschalt_verzoegerung,02
(12)-Light sensor-ECE_Lichteinschaltschwelle,1000 lx
(13)-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,80
lower turn position,31.49 °
Position during interval mode,31.49 °
(1)-Production mode-Scheinwerferreinigung,not active
(2)-Production mode-Frontwischer deaktivieren,not active
(3)-Production mode-Heckwischer,not active
(4)-Production mode-Interior lighting,not active
(5)-Production mode-Aussenbeleuchtung,not active
(6)-Production mode-Access control,not active
(7)-Production mode-Virtuel_pedal,not active
Read parameter address,FE 00 00
(1)-Rear Window Wiper-Komfortwischen Heck,active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
(3)-Rear Window Wiper-Automatisches Heckwischen,not active
(4)-Rear Window Wiper-Traenenwischen Heck,active
(5)-Rear Window Wiper-Heckwischer Weiterlauf,not active
(6)-Rear Window Wiper-Kein automatisches Abparken,not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
(11)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
(12)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
(13)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
Roller test bench mode; functional,not active
(1)-Seat fan charac. curve-Level_1_Sitz,25 %
(2)-Seat fan charac. curve-Level_1_Lehne,30 %
(3)-Seat fan charac. curve-Level_2_Sitz,25 %
(4)-Seat fan charac. curve-Level_2_Lehne,30 %
(5)-Seat fan charac. curve-Level_3_Sitz,53 %
(6)-Seat fan charac. curve-Level_3_Lehne,58 %
(7)-Seat fan charac. curve-Level_4_Sitz,53 %
(8)-Seat fan charac. curve-Level_4_Lehne,58 %
(9)-Seat fan charac. curve-Level_5_Sitz,80 %
(10)-Seat fan charac. curve-Level_5_Lehne,85 %
(11)-Seat fan charac. curve-Level_6_Sitz,80 %
(12)-Seat fan charac. curve-Level_6_Lehne,85 %
(1)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C
(2)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C
(3)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C
(4)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C
(5)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C
(6)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C
(7)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C
(8)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C
(9)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C
(10)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C
(11)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C
(12)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C
(13)-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
(14)-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
Service position,170.49 °
(1)-static AFS light-bei Rueckwaertsfahrt,both sides
(2)-static AFS light-Vorschrift,ECE R119
(3)-static AFS light-Lower speed threshold,0.00 km/h
(4)-static AFS light-Upper speed threshold,40.00 km/h
(5)-static AFS light-Steering wheel angle; offset,-63.75 °
(6)-static AFS light-Unterer Lenkradwinkel,180 °
(7)-static AFS light-Oberer Lenkradwinkel,120 °
(8)-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
(9)-static AFS light-Maximaltemperatur,100.00 °C
(10)-static AFS light-obere Grenztemperatur,95.00 °C
(11)-static AFS light-untere Grenztemperatur,80.00 °C
Transport mode,active
(1)-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
(2)-Turn signal control-Komfortblinken Blinkzyklen,3
(3)-Turn signal control-Sonderfunktionen,not enabled
(4)-Turn signal control-Signalprioritaet fuer Blinker,MFG
(5)-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
(6)-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
(7)-Turn signal control-Komfortblinken,active
(8)-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %
(9)-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
(10)-Turn signal control-Abbruch Komfortblinken,active
upper turn position,170.49 °
(1)-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
(2)-Window heater-Temperaturabhaengige Einschaltzeit FSH,active
(3)-Window heater-FSH Automatik,active
(4)-Window heater-Heckscheibenheizung Zeitwert,320 s
(5)-Window heater-Running time of heated front window,240 s
(6)-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
(7)-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
(1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
(2)-Windshield wiper-SRA Verzoegerungszeit,0 ms
(3)-Windshield wiper-SRA Waschzeit,0 ms
(4)-Windshield wiper-SRA Einweichpausenzeit,0 ms
(5)-Windshield wiper-SRA Nachwaschzeit,0 ms
(6)-Windshield wiper-SRA Pausenzeit,0 ms
(7)-Windshield wiper-SRA bei Waschwassermangel,not active
(8)-Windshield wiper-Frontwischer Referenzlauf,active
(9)-Windshield wiper-Variable Regensensoraktivierung,not active
(10)-Windshield wiper-Wischer stop bei KL15 aus,not active
(11)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
(12)-Windshield wiper-Regensensor aktivieren,Deactivating
(13)-Windshield wiper-Menuesteuerung Frontwischer,not active
(14)-Windshield wiper-Frontwischer Notlaufprogramm,active
(15)-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
(16)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
(17)-Windshield wiper-Traenenwischen Front Status,not active
(18)-Windshield wiper-Washer_Tipwiping_Variant,0
(19)-Windshield wiper-Adaptives Nachwischen bei SRA,not active
(20)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
(21)-Windshield wiper-Tippendes_Frontwaschen,not active
(22)-Windshield wiper-Frontwischer_Abtauposition,not active
(1)-Writing parameter-Parameter address,FE 00 00
(2)-Writing parameter-Value,130
(1)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed
(2)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door
(3)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00
(4)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed
(5)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door
(6)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00
(7)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed
(8)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door
(9)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00
(10)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed
(11)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door
(12)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00
(13)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed
(14)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door
(15)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00
(16)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed
(17)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door
(18)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00
(19)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed
(20)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door
(21)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00
(22)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed
(23)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door
(24)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00
(25)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed
(26)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door
(27)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00
(28)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed
(29)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door
(30)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00
(31)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed
(32)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door
(33)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00
(34)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed
(35)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door
(36)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00
(37)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed
(38)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door
(39)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00
(40)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed
(41)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door
(42)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00
(43)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed
(44)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door
(45)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00
(1)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0
(2)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed
(3)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00
(4)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0
(5)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed
(6)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0
(7)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0
(8)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed
(9)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0
(10)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0
(11)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed
(12)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0
(13)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0
(14)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed
(15)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0
(16)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0
(17)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed
(18)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0
(19)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0
(20)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed
(21)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0
(22)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0
(23)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed
(24)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0
(25)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0
(26)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed
(27)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0
(28)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0
(29)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed
(30)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0
(31)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0
(32)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed
(33)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0
(34)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0
(35)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed
(36)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0
(37)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0
(38)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed
(39)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0
(40)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0
(41)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed
(42)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0
(43)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0
(44)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed
(45)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0
(46)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0
(47)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed
(48)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0
(49)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0
(50)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed
(51)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0
(52)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0
(53)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed
(54)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0
(55)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0
(56)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed
(57)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0
(58)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0
(59)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed
(60)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0
(1)-debug_light_function-Adresse,0
(2)-debug_light_function-Bitmask,0
(3)-debug_light_function-Offset,0
(4)-debug_light_function-Divisor,0
(5)-debug_light_function-Polaritaet,0
(6)-debug_light_function-Activation,0
(7)-debug_light_function-WBT-Ausgabe,0
(1)-Innenbeleuchtung Abdimmen-x0,0 ms
(2)-Innenbeleuchtung Abdimmen-X1,200 ms
(3)-Innenbeleuchtung Abdimmen-X2,400 ms
(4)-Innenbeleuchtung Abdimmen-X3,600 ms
(5)-Innenbeleuchtung Abdimmen-X4,800 ms
(6)-Innenbeleuchtung Abdimmen-X5,1000 ms
(7)-Innenbeleuchtung Abdimmen-X6,1200 ms
(8)-Innenbeleuchtung Abdimmen-x7,1400 ms
(9)-Innenbeleuchtung Abdimmen-x8,1600 ms
(10)-Innenbeleuchtung Abdimmen-x9,1800 ms
(11)-Innenbeleuchtung Abdimmen-x10,2000 ms
(12)-Innenbeleuchtung Abdimmen-y0,100.00 %
(13)-Innenbeleuchtung Abdimmen-Y1,72.00 %
(14)-Innenbeleuchtung Abdimmen-Y2,48.00 %
(15)-Innenbeleuchtung Abdimmen-Y3,33.00 %
(16)-Innenbeleuchtung Abdimmen-Y4,18.00 %
(17)-Innenbeleuchtung Abdimmen-Y5,12.00 %
(18)-Innenbeleuchtung Abdimmen-Y6,8.00 %
(19)-Innenbeleuchtung Abdimmen-y7,6.00 %
(20)-Innenbeleuchtung Abdimmen-y8,4.00 %
(21)-Innenbeleuchtung Abdimmen-y9,2.00 %
(22)-Innenbeleuchtung Abdimmen-y10,0.00 %
(1)-Innenbeleuchtung Fotosensor-x0,0
(2)-Innenbeleuchtung Fotosensor-X1,50
(3)-Innenbeleuchtung Fotosensor-X2,100
(4)-Innenbeleuchtung Fotosensor-X3,200
(5)-Innenbeleuchtung Fotosensor-X4,253
(6)-Innenbeleuchtung Fotosensor-X5,0
(7)-Innenbeleuchtung Fotosensor-X6,0
(8)-Innenbeleuchtung Fotosensor-x7,0
(9)-Innenbeleuchtung Fotosensor-x8,0
(10)-Innenbeleuchtung Fotosensor-x9,0
(11)-Innenbeleuchtung Fotosensor-x10,0
(12)-Innenbeleuchtung Fotosensor-y0,0 lx
(13)-Innenbeleuchtung Fotosensor-Y1,50 lx
(14)-Innenbeleuchtung Fotosensor-Y2,100 lx
(15)-Innenbeleuchtung Fotosensor-Y3,200
(16)-Innenbeleuchtung Fotosensor-Y4,500
(17)-Innenbeleuchtung Fotosensor-Y5,0
(18)-Innenbeleuchtung Fotosensor-Y6,0 lx
(19)-Innenbeleuchtung Fotosensor-y7,0 lx
(20)-Innenbeleuchtung Fotosensor-y8,0 lx
(21)-Innenbeleuchtung Fotosensor-y9,0 lx
(22)-Innenbeleuchtung Fotosensor-y10,0 lx
(1)-Innenbeleuchtung Hochdimmen-x0,0 ms
(2)-Innenbeleuchtung Hochdimmen-X1,200 ms
(3)-Innenbeleuchtung Hochdimmen-X2,400 ms
(4)-Innenbeleuchtung Hochdimmen-X3,600 ms
(5)-Innenbeleuchtung Hochdimmen-X4,800 ms
(6)-Innenbeleuchtung Hochdimmen-X5,1000 ms
(7)-Innenbeleuchtung Hochdimmen-X6,1200 ms
(8)-Innenbeleuchtung Hochdimmen-x7,1400 ms
(9)-Innenbeleuchtung Hochdimmen-x8,1600 ms
(10)-Innenbeleuchtung Hochdimmen-x9,1800 ms
(11)-Innenbeleuchtung Hochdimmen-x10,2000 ms
(12)-Innenbeleuchtung Hochdimmen-y0,0.00 %
(13)-Innenbeleuchtung Hochdimmen-Y1,1.00 %
(14)-Innenbeleuchtung Hochdimmen-Y2,3.00 %
(15)-Innenbeleuchtung Hochdimmen-Y3,5.00 %
(16)-Innenbeleuchtung Hochdimmen-Y4,11.00 %
(17)-Innenbeleuchtung Hochdimmen-Y5,22.00 %
(18)-Innenbeleuchtung Hochdimmen-Y6,40.00 %
(19)-Innenbeleuchtung Hochdimmen-y7,80.00 %
(20)-Innenbeleuchtung Hochdimmen-y8,95.00 %
(21)-Innenbeleuchtung Hochdimmen-y9,100.00 %
(22)-Innenbeleuchtung Hochdimmen-y10,100.00 %
(1)-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
(2)-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
(3)-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
(4)-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
(5)-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
(6)-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
(7)-Innenbeleuchtung KL 58xd log Bus-y0,10
(8)-Innenbeleuchtung KL 58xd log Bus-Y1,10
(9)-Innenbeleuchtung KL 58xd log Bus-Y2,100
(10)-Innenbeleuchtung KL 58xd log Bus-Y3,150
(11)-Innenbeleuchtung KL 58xd log Bus-Y4,220
(12)-Innenbeleuchtung KL 58xd log Bus-Y5,253
(1)-Innenbeleuchtung KL 58xd max-x0,0 lx
(2)-Innenbeleuchtung KL 58xd max-X1,8 lx
(3)-Innenbeleuchtung KL 58xd max-X2,200 lx
(4)-Innenbeleuchtung KL 58xd max-X3,300 lx
(5)-Innenbeleuchtung KL 58xd max-X4,500 lx
(6)-Innenbeleuchtung KL 58xd max-y0,16.00
(7)-Innenbeleuchtung KL 58xd max-Y1,16.00
(8)-Innenbeleuchtung KL 58xd max-Y2,100.00
(9)-Innenbeleuchtung KL 58xd max-Y3,100.00
(10)-Innenbeleuchtung KL 58xd max-Y4,100.00
(1)-Innenbeleuchtung KL 58xd min-x0,0 lx
(2)-Innenbeleuchtung KL 58xd min-X1,8 lx
(3)-Innenbeleuchtung KL 58xd min-X2,220 lx
(4)-Innenbeleuchtung KL 58xd min-X3,300 lx
(5)-Innenbeleuchtung KL 58xd min-X4,500 lx
(6)-Innenbeleuchtung KL 58xd min-y0,6.00
(7)-Innenbeleuchtung KL 58xd min-Y1,6.00
(8)-Innenbeleuchtung KL 58xd min-Y2,100.00
(9)-Innenbeleuchtung KL 58xd min-Y3,100.00
(10)-Innenbeleuchtung KL 58xd min-Y4,100.00
(1)-Innenbeleuchtung KL 58xd PWM-x0,0
(2)-Innenbeleuchtung KL 58xd PWM-X1,10
(3)-Innenbeleuchtung KL 58xd PWM-X2,50
(4)-Innenbeleuchtung KL 58xd PWM-X3,100
(5)-Innenbeleuchtung KL 58xd PWM-X4,220
(6)-Innenbeleuchtung KL 58xd PWM-X5,253
(7)-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
(8)-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
(9)-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
(10)-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
(11)-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
(12)-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
(1)-Innenbeleuchtung KL 58xs max-x0,0 lx
(2)-Innenbeleuchtung KL 58xs max-X1,8 lx
(3)-Innenbeleuchtung KL 58xs max-X2,50 lx
(4)-Innenbeleuchtung KL 58xs max-X3,500 lx
(5)-Innenbeleuchtung KL 58xs max-y0,100.00
(6)-Innenbeleuchtung KL 58xs max-Y1,100.00
(7)-Innenbeleuchtung KL 58xs max-Y2,100.00
(8)-Innenbeleuchtung KL 58xs max-Y3,100.00
(1)-Innenbeleuchtung KL 58xs min-x0,0 lx
(2)-Innenbeleuchtung KL 58xs min-X1,8 lx
(3)-Innenbeleuchtung KL 58xs min-X2,50 lx
(4)-Innenbeleuchtung KL 58xs min-X3,500 lx
(5)-Innenbeleuchtung KL 58xs min-y0,6.00
(6)-Innenbeleuchtung KL 58xs min-Y1,6.00
(7)-Innenbeleuchtung KL 58xs min-Y2,100.00
(8)-Innenbeleuchtung KL 58xs min-Y3,100.00
(1)-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
(2)-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
(3)-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
(4)-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
(5)-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
(6)-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
(1)-Innenbeleuchtung KL 58xt max-x0,0 lx
(2)-Innenbeleuchtung KL 58xt max-X1,8 lx
(3)-Innenbeleuchtung KL 58xt max-X2,50 lx
(4)-Innenbeleuchtung KL 58xt max-X3,500 lx
(5)-Innenbeleuchtung KL 58xt max-y0,100.00
(6)-Innenbeleuchtung KL 58xt max-Y1,100.00
(7)-Innenbeleuchtung KL 58xt max-Y2,100.00
(8)-Innenbeleuchtung KL 58xt max-Y3,100.00
(1)-Innenbeleuchtung KL 58xt min-x0,0 lx
(2)-Innenbeleuchtung KL 58xt min-X1,8 lx
(3)-Innenbeleuchtung KL 58xt min-X2,50 lx
(4)-Innenbeleuchtung KL 58xt min-X3,500 lx
(5)-Innenbeleuchtung KL 58xt min-y0,6.00
(6)-Innenbeleuchtung KL 58xt min-Y1,6.00
(7)-Innenbeleuchtung KL 58xt min-Y2,100.00
(8)-Innenbeleuchtung KL 58xt min-Y3,100.00
(1)-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
(2)-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
(3)-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
(4)-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
(5)-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
(6)-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
(1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
(2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms
(3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms
(4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms
(5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms
(6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
(7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
(8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
(9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00
(10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
(1)-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
(2)-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
(3)-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
(7)-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
(1)-Leuchte10SHUTTER LB23-Lasttyp 10,not active
(2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00
(3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00
(4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active
(5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active
(6)-Leuchte10SHUTTER LB23-Dimmwert AB 10,0
(7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
(8)-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
(9)-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
(10)-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
(11)-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
(12)-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
(13)-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
(14)-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
(15)-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
(16)-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
(17)-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
(18)-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
(19)-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
(1)-Leuchte11SHUTTER RB22-Lasttyp 11,not active
(2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00
(3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00
(4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active
(5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active
(6)-Leuchte11SHUTTER RB22-Dimmwert AB 11,0
(7)-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
(8)-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
(9)-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
(10)-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
(11)-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
(12)-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
(13)-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
(14)-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
(15)-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
(16)-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
(17)-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
(18)-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
(19)-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
(1)-Leuchte12NL LB45-Lasttyp 12,not active
(2)-Leuchte12NL LB45-Lampendefektbitposition 12,00
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00
(4)-Leuchte12NL LB45-Lichtfunktion A 12,not active
(5)-Leuchte12NL LB45-Lichtfunktion B 12,not active
(6)-Leuchte12NL LB45-Dimmwert AB 12,0
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
(8)-Leuchte12NL LB45-Lichtfunktion C 12,not active
(9)-Leuchte12NL LB45-Lichtfunktion D 12,not active
(10)-Leuchte12NL LB45-Dimmwert CD 12,0
(11)-Leuchte12NL LB45-Dimming Direction CD 12,maximize
(12)-Leuchte12NL LB45-Lichtfunktion E 12,not active
(13)-Leuchte12NL LB45-Lichtfunktion F 12,not active
(14)-Leuchte12NL LB45-Dimmwert EF 12,0
(15)-Leuchte12NL LB45-Dimming Direction EF 12,maximize
(16)-Leuchte12NL LB45-Lichtfunktion G 12,not active
(17)-Leuchte12NL LB45-Lichtfunktion H 12,not active
(18)-Leuchte12NL LB45-Dimmwert GH 12,0
(19)-Leuchte12NL LB45-Dimming Direction GH 12,maximize
(1)-Leuchte13NL RB5-Lasttyp 13,not active
(2)-Leuchte13NL RB5-Lampendefektbitposition 13,00
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00
(4)-Leuchte13NL RB5-Lichtfunktion A 13,not active
(5)-Leuchte13NL RB5-Lichtfunktion B 13,not active
(6)-Leuchte13NL RB5-Dimmwert AB 13,0
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
(8)-Leuchte13NL RB5-Lichtfunktion C 13,not active
(9)-Leuchte13NL RB5-Lichtfunktion D 13,not active
(10)-Leuchte13NL RB5-Dimmwert CD 13,0
(11)-Leuchte13NL RB5-Dimming Direction CD 13,maximize
(12)-Leuchte13NL RB5-Lichtfunktion E 13,not active
(13)-Leuchte13NL RB5-Lichtfunktion F 13,not active
(14)-Leuchte13NL RB5-Dimmwert EF 13,0
(15)-Leuchte13NL RB5-Dimming Direction EF 13,maximize
(16)-Leuchte13NL RB5-Lichtfunktion G 13,not active
(17)-Leuchte13NL RB5-Lichtfunktion H 13,not active
(18)-Leuchte13NL RB5-Dimmwert GH 13,0
(19)-Leuchte13NL RB5-Dimming Direction GH 13,maximize
(1)-Leuchte15AL RB44-Lasttyp 15,not active
(2)-Leuchte15AL RB44-Lampendefektbitposition 15,00
(3)-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
(4)-Leuchte15AL RB44-Lichtfunktion A 15,not active
(5)-Leuchte15AL RB44-Lichtfunktion B 15,not active
(6)-Leuchte15AL RB44-Dimmwert AB 15,0
(7)-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
(8)-Leuchte15AL RB44-Lichtfunktion C 15,not active
(9)-Leuchte15AL RB44-Lichtfunktion D 15,not active
(10)-Leuchte15AL RB44-Dimmwert CD 15,0
(11)-Leuchte15AL RB44-Dimming Direction CD 15,maximize
(12)-Leuchte15AL RB44-Lichtfunktion E 15,not active
(13)-Leuchte15AL RB44-Lichtfunktion F 15,not active
(14)-Leuchte15AL RB44-Dimmwert EF 15,0
(15)-Leuchte15AL RB44-Dimming Direction EF 15,maximize
(16)-Leuchte15AL RB44-Lichtfunktion G 15,not active
(17)-Leuchte15AL RB44-Lichtfunktion H 15,not active
(18)-Leuchte15AL RB44-Dimmwert GH 15,0
(19)-Leuchte15AL RB44-Dimming Direction GH 15,maximize
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active
(2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00
(3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00
(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active
(5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0
(7)-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
(8)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
(9)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
(10)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
(11)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
(12)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
(13)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
(14)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
(15)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
(16)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
(17)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
(18)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
(19)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active
(2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00
(3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00
(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active
(5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active
(6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0
(7)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
(8)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
(9)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
(10)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
(11)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
(12)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
(13)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
(14)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
(15)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
(16)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
(17)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
(18)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
(19)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
(1)-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten
(2)-Leuchte18BLK HLA60-Lampendefektbitposition 18,08
(3)-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16
(4)-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase
(5)-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
(6)-Leuchte18BLK HLA60-Dimmwert AB 18,100
(7)-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
(8)-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
(9)-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
(10)-Leuchte18BLK HLA60-Dimmwert CD 18,0
(11)-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize
(12)-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
(13)-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
(14)-Leuchte18BLK HLA60-Dimmwert EF 18,0
(15)-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
(16)-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
(17)-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
(18)-Leuchte18BLK HLA60-Dimmwert GH 18,0
(19)-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
(1)-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten
(2)-Leuchte19BLK HRC31-Lampendefektbitposition 19,18
(3)-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18
(4)-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase
(5)-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
(6)-Leuchte19BLK HRC31-Dimmwert AB 19,100
(7)-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
(8)-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
(9)-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
(10)-Leuchte19BLK HRC31-Dimmwert CD 19,0
(11)-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize
(12)-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
(13)-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
(14)-Leuchte19BLK HRC31-Dimmwert EF 19,0
(15)-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
(16)-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
(17)-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
(18)-Leuchte19BLK HRC31-Dimmwert GH 19,0
(19)-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
(1)-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
(2)-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
(3)-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
(6)-Leuchte1BLK VRB20-Dimmwert AB 1,100
(7)-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
(13)-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
(14)-Leuchte1BLK VRB20-Dimmwert EF 1,0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
(17)-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
(18)-Leuchte1BLK VRB20-Dimmwert GH 1,0
(19)-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
(1)-Leuchte20BR LA71-Lasttyp 20,13 - Bremsleuchten
(2)-Leuchte20BR LA71-Lampendefektbitposition 20,12
(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39
(4)-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
(5)-Leuchte20BR LA71-Lichtfunktion B 20,not active
(6)-Leuchte20BR LA71-Dimmwert AB 20,100
(7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte20BR LA71-Lichtfunktion D 20,not active
(10)-Leuchte20BR LA71-Dimmwert CD 20,25
(11)-Leuchte20BR LA71-Dimming Direction CD 20,maximize
(12)-Leuchte20BR LA71-Lichtfunktion E 20,not active
(13)-Leuchte20BR LA71-Lichtfunktion F 20,not active
(14)-Leuchte20BR LA71-Dimmwert EF 20,0
(15)-Leuchte20BR LA71-Dimming Direction EF 20,maximize
(16)-Leuchte20BR LA71-Lichtfunktion G 20,not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20,not active
(18)-Leuchte20BR LA71-Dimmwert GH 20,0
(19)-Leuchte20BR LA71-Dimming Direction GH 20,maximize
(1)-Leuchte21BR RC8-Lasttyp 21,13 - Bremsleuchten
(2)-Leuchte21BR RC8-Lampendefektbitposition 21,22
(3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A
(4)-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
(5)-Leuchte21BR RC8-Lichtfunktion B 21,not active
(6)-Leuchte21BR RC8-Dimmwert AB 21,100
(7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte21BR RC8-Lichtfunktion D 21,not active
(10)-Leuchte21BR RC8-Dimmwert CD 21,25
(11)-Leuchte21BR RC8-Dimming Direction CD 21,maximize
(12)-Leuchte21BR RC8-Lichtfunktion E 21,not active
(13)-Leuchte21BR RC8-Lichtfunktion F 21,not active
(14)-Leuchte21BR RC8-Dimmwert EF 21,0
(15)-Leuchte21BR RC8-Dimming Direction EF 21,maximize
(16)-Leuchte21BR RC8-Lichtfunktion G 21,not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21,not active
(18)-Leuchte21BR RC8-Dimmwert GH 21,0
(19)-Leuchte21BR RC8-Dimming Direction GH 21,maximize
(1)-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
(2)-Leuchte22BR MA57-Lampendefektbitposition 22,29
(3)-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
(4)-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
(5)-Leuchte22BR MA57-Lichtfunktion B 22,not active
(6)-Leuchte22BR MA57-Dimmwert AB 22,100
(7)-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
(8)-Leuchte22BR MA57-Lichtfunktion C 22,not active
(9)-Leuchte22BR MA57-Lichtfunktion D 22,not active
(10)-Leuchte22BR MA57-Dimmwert CD 22,0
(11)-Leuchte22BR MA57-Dimming Direction CD 22,maximize
(12)-Leuchte22BR MA57-Lichtfunktion E 22,not active
(13)-Leuchte22BR MA57-Lichtfunktion F 22,not active
(14)-Leuchte22BR MA57-Dimmwert EF 22,0
(15)-Leuchte22BR MA57-Dimming Direction EF 22,maximize
(16)-Leuchte22BR MA57-Lichtfunktion G 22,not active
(17)-Leuchte22BR MA57-Lichtfunktion H 22,not active
(18)-Leuchte22BR MA57-Dimmwert GH 22,0
(19)-Leuchte22BR MA57-Dimming Direction GH 22,maximize
(1)-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte23SL HLC10-Lichtfunktion B 23,not active
(6)-Leuchte23SL HLC10-Dimmwert AB 23,25
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
(8)-Leuchte23SL HLC10-Lichtfunktion C 23,not active
(9)-Leuchte23SL HLC10-Lichtfunktion D 23,not active
(10)-Leuchte23SL HLC10-Dimmwert CD 23,0
(11)-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23,not active
(13)-Leuchte23SL HLC10-Lichtfunktion F 23,not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23,0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23,not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23,not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23,0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
(1)-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte24SL HRA65-Lichtfunktion B 24,not active
(6)-Leuchte24SL HRA65-Dimmwert AB 24,25
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
(8)-Leuchte24SL HRA65-Lichtfunktion C 24,not active
(9)-Leuchte24SL HRA65-Lichtfunktion D 24,not active
(10)-Leuchte24SL HRA65-Dimmwert CD 24,0
(11)-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24,not active
(13)-Leuchte24SL HRA65-Lichtfunktion F 24,not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24,0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24,not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24,not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24,0
(19)-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
(1)-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED
(2)-Leuchte25KZL HA59-Lampendefektbitposition 25,28
(3)-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
(4)-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte25KZL HA59-Lichtfunktion B 25,not active
(6)-Leuchte25KZL HA59-Dimmwert AB 25,127
(7)-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
(8)-Leuchte25KZL HA59-Lichtfunktion C 25,not active
(9)-Leuchte25KZL HA59-Lichtfunktion D 25,not active
(10)-Leuchte25KZL HA59-Dimmwert CD 25,0
(11)-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
(12)-Leuchte25KZL HA59-Lichtfunktion E 25,not active
(13)-Leuchte25KZL HA59-Lichtfunktion F 25,not active
(14)-Leuchte25KZL HA59-Dimmwert EF 25,0
(15)-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
(16)-Leuchte25KZL HA59-Lichtfunktion G 25,not active
(17)-Leuchte25KZL HA59-Lichtfunktion H 25,not active
(18)-Leuchte25KZL HA59-Dimmwert GH 25,0
(19)-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
(1)-Leuchte26NSL LA72-Lasttyp 26,not active
(2)-Leuchte26NSL LA72-Lampendefektbitposition 26,00
(3)-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,00
(4)-Leuchte26NSL LA72-Lichtfunktion A 26,not active
(5)-Leuchte26NSL LA72-Lichtfunktion B 26,not active
(6)-Leuchte26NSL LA72-Dimmwert AB 26,0
(7)-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
(8)-Leuchte26NSL LA72-Lichtfunktion C 26,not active
(9)-Leuchte26NSL LA72-Lichtfunktion D 26,not active
(10)-Leuchte26NSL LA72-Dimmwert CD 26,0
(11)-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
(12)-Leuchte26NSL LA72-Lichtfunktion E 26,not active
(13)-Leuchte26NSL LA72-Lichtfunktion F 26,not active
(14)-Leuchte26NSL LA72-Dimmwert EF 26,0
(15)-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
(16)-Leuchte26NSL LA72-Lichtfunktion G 26,not active
(17)-Leuchte26NSL LA72-Lichtfunktion H 26,not active
(18)-Leuchte26NSL LA72-Dimmwert GH 26,0
(19)-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
(1)-Leuchte27NSL RC6-Lasttyp 27,36 - LED Kleinleistung
(2)-Leuchte27NSL RC6-Lampendefektbitposition 27,00
(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,47
(4)-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte27NSL RC6-Lichtfunktion B 27,not active
(6)-Leuchte27NSL RC6-Dimmwert AB 27,127
(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
(8)-Leuchte27NSL RC6-Lichtfunktion C 27,not active
(9)-Leuchte27NSL RC6-Lichtfunktion D 27,not active
(10)-Leuchte27NSL RC6-Dimmwert CD 27,0
(11)-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
(12)-Leuchte27NSL RC6-Lichtfunktion E 27,not active
(13)-Leuchte27NSL RC6-Lichtfunktion F 27,not active
(14)-Leuchte27NSL RC6-Dimmwert EF 27,0
(15)-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
(16)-Leuchte27NSL RC6-Lichtfunktion G 27,not active
(17)-Leuchte27NSL RC6-Lichtfunktion H 27,not active
(18)-Leuchte27NSL RC6-Dimmwert GH 27,0
(19)-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
(1)-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
(3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
(4)-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
(5)-Leuchte28RFL LC11-Lichtfunktion B 28,not active
(6)-Leuchte28RFL LC11-Dimmwert AB 28,100
(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
(8)-Leuchte28RFL LC11-Lichtfunktion C 28,not active
(9)-Leuchte28RFL LC11-Lichtfunktion D 28,not active
(10)-Leuchte28RFL LC11-Dimmwert CD 28,0
(11)-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
(12)-Leuchte28RFL LC11-Lichtfunktion E 28,not active
(13)-Leuchte28RFL LC11-Lichtfunktion F 28,not active
(14)-Leuchte28RFL LC11-Dimmwert EF 28,0
(15)-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
(16)-Leuchte28RFL LC11-Lichtfunktion G 28,not active
(17)-Leuchte28RFL LC11-Lichtfunktion H 28,not active
(18)-Leuchte28RFL LC11-Dimmwert GH 28,0
(19)-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
(1)-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
(3)-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
(4)-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
(5)-Leuchte29RFL RA64-Lichtfunktion B 29,not active
(6)-Leuchte29RFL RA64-Dimmwert AB 29,100
(7)-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
(8)-Leuchte29RFL RA64-Lichtfunktion C 29,not active
(9)-Leuchte29RFL RA64-Lichtfunktion D 29,not active
(10)-Leuchte29RFL RA64-Dimmwert CD 29,0
(11)-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
(12)-Leuchte29RFL RA64-Lichtfunktion E 29,not active
(13)-Leuchte29RFL RA64-Lichtfunktion F 29,not active
(14)-Leuchte29RFL RA64-Dimmwert EF 29,0
(15)-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
(16)-Leuchte29RFL RA64-Lichtfunktion G 29,not active
(17)-Leuchte29RFL RA64-Lichtfunktion H 29,not active
(18)-Leuchte29RFL RA64-Dimmwert GH 29,0
(19)-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
(1)-Leuchte2SL VLB10-Lasttyp 2,8 - allgemeine Glühlampe 12W
(2)-Leuchte2SL VLB10-Lampendefektbitposition 2,00
(3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,45
(4)-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte2SL VLB10-Lichtfunktion B 2,not active
(6)-Leuchte2SL VLB10-Dimmwert AB 2,100
(7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
(8)-Leuchte2SL VLB10-Lichtfunktion C 2,not active
(9)-Leuchte2SL VLB10-Lichtfunktion D 2,not active
(10)-Leuchte2SL VLB10-Dimmwert CD 2,0
(11)-Leuchte2SL VLB10-Dimming Direction CD 2,maximize
(12)-Leuchte2SL VLB10-Lichtfunktion E 2,not active
(13)-Leuchte2SL VLB10-Lichtfunktion F 2,not active
(14)-Leuchte2SL VLB10-Dimmwert EF 2,0
(15)-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
(16)-Leuchte2SL VLB10-Lichtfunktion G 2,not active
(17)-Leuchte2SL VLB10-Lichtfunktion H 2,not active
(18)-Leuchte2SL VLB10-Dimmwert GH 2,0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
(1)-Leuchte30FR LC72-Lasttyp 30,not active
(2)-Leuchte30FR LC72-Lampendefektbitposition 30,00
(3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00
(4)-Leuchte30FR LC72-Lichtfunktion A 30,not active
(5)-Leuchte30FR LC72-Lichtfunktion B 30,not active
(6)-Leuchte30FR LC72-Dimmwert AB 30,0
(7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
(8)-Leuchte30FR LC72-Lichtfunktion C 30,not active
(9)-Leuchte30FR LC72-Lichtfunktion D 30,not active
(10)-Leuchte30FR LC72-Dimmwert CD 30,0
(11)-Leuchte30FR LC72-Dimming Direction CD 30,maximize
(12)-Leuchte30FR LC72-Lichtfunktion E 30,not active
(13)-Leuchte30FR LC72-Lichtfunktion F 30,not active
(14)-Leuchte30FR LC72-Dimmwert EF 30,0
(15)-Leuchte30FR LC72-Dimming Direction EF 30,maximize
(16)-Leuchte30FR LC72-Lichtfunktion G 30,not active
(17)-Leuchte30FR LC72-Lichtfunktion H 30,not active
(18)-Leuchte30FR LC72-Dimmwert GH 30,0
(19)-Leuchte30FR LC72-Dimming Direction GH 30,maximize
(1)-Leuchte31AMBL 1C61-Lasttyp 31,not active
(2)-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
(3)-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00
(4)-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active
(5)-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
(6)-Leuchte31AMBL 1C61-Dimmwert AB 31,0
(7)-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
(8)-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
(9)-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
(10)-Leuchte31AMBL 1C61-Dimmwert CD 31,0
(11)-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
(12)-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
(13)-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
(14)-Leuchte31AMBL 1C61-Dimmwert EF 31,0
(15)-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
(16)-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
(17)-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
(18)-Leuchte31AMBL 1C61-Dimmwert GH 31,0
(19)-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
(1)-Leuchte32AMBL 2C35-Lasttyp 32,not active
(2)-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
(3)-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00
(4)-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active
(5)-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
(6)-Leuchte32AMBL 2C35-Dimmwert AB 32,0
(7)-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
(8)-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
(9)-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
(10)-Leuchte32AMBL 2C35-Dimmwert CD 32,0
(11)-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
(12)-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
(13)-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
(14)-Leuchte32AMBL 2C35-Dimmwert EF 32,0
(15)-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
(16)-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
(17)-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
(18)-Leuchte32AMBL 2C35-Dimmwert GH 32,0
(19)-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
(1)-Leuchte33AMBL 3C36-Lasttyp 33,not active
(2)-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
(3)-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00
(4)-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active
(5)-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
(6)-Leuchte33AMBL 3C36-Dimmwert AB 33,0
(7)-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
(8)-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
(9)-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
(10)-Leuchte33AMBL 3C36-Dimmwert CD 33,0
(11)-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
(12)-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
(13)-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
(14)-Leuchte33AMBL 3C36-Dimmwert EF 33,0
(15)-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
(16)-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
(17)-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
(18)-Leuchte33AMBL 3C36-Dimmwert GH 33,0
(19)-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
(1)-Leuchte34AMBL 4C37-Lasttyp 34,not active
(2)-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
(3)-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00
(4)-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active
(5)-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
(6)-Leuchte34AMBL 4C37-Dimmwert AB 34,0
(7)-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
(8)-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
(9)-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
(10)-Leuchte34AMBL 4C37-Dimmwert CD 34,0
(11)-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
(12)-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
(13)-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
(14)-Leuchte34AMBL 4C37-Dimmwert EF 34,0
(15)-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
(16)-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
(17)-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
(18)-Leuchte34AMBL 4C37-Dimmwert GH 34,0
(19)-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
(1)-Leuchte3SL VRB21-Lasttyp 3,8 - allgemeine Glühlampe 12W
(2)-Leuchte3SL VRB21-Lampendefektbitposition 3,00
(3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,46
(4)-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte3SL VRB21-Lichtfunktion B 3,not active
(6)-Leuchte3SL VRB21-Dimmwert AB 3,100
(7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
(8)-Leuchte3SL VRB21-Lichtfunktion C 3,not active
(9)-Leuchte3SL VRB21-Lichtfunktion D 3,not active
(10)-Leuchte3SL VRB21-Dimmwert CD 3,0
(11)-Leuchte3SL VRB21-Dimming Direction CD 3,maximize
(12)-Leuchte3SL VRB21-Lichtfunktion E 3,not active
(13)-Leuchte3SL VRB21-Lichtfunktion F 3,not active
(14)-Leuchte3SL VRB21-Dimmwert EF 3,0
(15)-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3,not active
(17)-Leuchte3SL VRB21-Lichtfunktion H 3,not active
(18)-Leuchte3SL VRB21-Dimmwert GH 3,0
(19)-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
(1)-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte4TFL LB4-Lampendefektbitposition 4,48
(3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43
(4)-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights
(5)-Leuchte4TFL LB4-Lichtfunktion B 4,not active
(6)-Leuchte4TFL LB4-Dimmwert AB 4,100
(7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
(8)-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen)
(9)-Leuchte4TFL LB4-Lichtfunktion D 4,not active
(10)-Leuchte4TFL LB4-Dimmwert CD 4,0
(11)-Leuchte4TFL LB4-Dimming Direction CD 4,minimize
(12)-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte4TFL LB4-Lichtfunktion F 4,not active
(14)-Leuchte4TFL LB4-Dimmwert EF 4,31
(15)-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
(16)-Leuchte4TFL LB4-Lichtfunktion G 4,not active
(17)-Leuchte4TFL LB4-Lichtfunktion H 4,not active
(18)-Leuchte4TFL LB4-Dimmwert GH 4,0
(19)-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
(1)-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C
(3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights
(5)-Leuchte5 TFL RB32-Lichtfunktion B 5,not active
(6)-Leuchte5 TFL RB32-Dimmwert AB 5,100
(7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen)
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
(10)-Leuchte5 TFL RB32-Dimmwert CD 5,0
(11)-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte5 TFL RB32-Lichtfunktion F 5,not active
(14)-Leuchte5 TFL RB32-Dimmwert EF 5,31
(15)-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
(16)-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
(17)-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
(18)-Leuchte5 TFL RB32-Dimmwert GH 5,0
(19)-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
(1)-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht
(2)-Leuchte6ABL LC5-Lampendefektbitposition 6,36
(3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
(4)-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
(5)-Leuchte6ABL LC5-Lichtfunktion B 6,not active
(6)-Leuchte6ABL LC5-Dimmwert AB 6,100
(7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
(8)-Leuchte6ABL LC5-Lichtfunktion C 6,not active
(9)-Leuchte6ABL LC5-Lichtfunktion D 6,not active
(10)-Leuchte6ABL LC5-Dimmwert CD 6,0
(11)-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
(12)-Leuchte6ABL LC5-Lichtfunktion E 6,not active
(13)-Leuchte6ABL LC5-Lichtfunktion F 6,not active
(14)-Leuchte6ABL LC5-Dimmwert EF 6,0
(15)-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
(16)-Leuchte6ABL LC5-Lichtfunktion G 6,not active
(17)-Leuchte6ABL LC5-Lichtfunktion H 6,not active
(18)-Leuchte6ABL LC5-Dimmwert GH 6,0
(19)-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
(1)-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht
(2)-Leuchte7ABL RB1-Lampendefektbitposition 7,40
(3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
(4)-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
(5)-Leuchte7ABL RB1-Lichtfunktion B 7,not active
(6)-Leuchte7ABL RB1-Dimmwert AB 7,100
(7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
(8)-Leuchte7ABL RB1-Lichtfunktion C 7,not active
(9)-Leuchte7ABL RB1-Lichtfunktion D 7,not active
(10)-Leuchte7ABL RB1-Dimmwert CD 7,0
(11)-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
(12)-Leuchte7ABL RB1-Lichtfunktion E 7,not active
(13)-Leuchte7ABL RB1-Lichtfunktion F 7,not active
(14)-Leuchte7ABL RB1-Dimmwert EF 7,0
(15)-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
(16)-Leuchte7ABL RB1-Lichtfunktion G 7,not active
(17)-Leuchte7ABL RB1-Lichtfunktion H 7,not active
(18)-Leuchte7ABL RB1-Dimmwert GH 7,0
(19)-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
(1)-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer
(2)-Leuchte8FL LB39-Lampendefektbitposition 8,37
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C
(4)-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam
(5)-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell
(6)-Leuchte8FL LB39-Dimmwert AB 8,100
(7)-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
(8)-Leuchte8FL LB39-Lichtfunktion C 8,not active
(9)-Leuchte8FL LB39-Lichtfunktion D 8,not active
(10)-Leuchte8FL LB39-Dimmwert CD 8,0
(11)-Leuchte8FL LB39-Dimming Direction CD 8,maximize
(12)-Leuchte8FL LB39-Lichtfunktion E 8,not active
(13)-Leuchte8FL LB39-Lichtfunktion F 8,not active
(14)-Leuchte8FL LB39-Dimmwert EF 8,0
(15)-Leuchte8FL LB39-Dimming Direction EF 8,maximize
(16)-Leuchte8FL LB39-Lichtfunktion G 8,not active
(17)-Leuchte8FL LB39-Lichtfunktion H 8,not active
(18)-Leuchte8FL LB39-Dimmwert GH 8,0
(19)-Leuchte8FL LB39-Dimming Direction GH 8,maximize
(1)-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer
(2)-Leuchte9FL RB2-Lampendefektbitposition 9,41
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D
(4)-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam
(5)-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell
(6)-Leuchte9FL RB2-Dimmwert AB 9,100
(7)-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
(8)-Leuchte9FL RB2-Lichtfunktion C 9,not active
(9)-Leuchte9FL RB2-Lichtfunktion D 9,not active
(10)-Leuchte9FL RB2-Dimmwert CD 9,0
(11)-Leuchte9FL RB2-Dimming Direction CD 9,maximize
(12)-Leuchte9FL RB2-Lichtfunktion E 9,not active
(13)-Leuchte9FL RB2-Lichtfunktion F 9,not active
(14)-Leuchte9FL RB2-Dimmwert EF 9,0
(15)-Leuchte9FL RB2-Dimming Direction EF 9,maximize
(16)-Leuchte9FL RB2-Lichtfunktion G 9,not active
(17)-Leuchte9FL RB2-Lichtfunktion H 9,not active
(18)-Leuchte9FL RB2-Dimmwert GH 9,0
(19)-Leuchte9FL RB2-Dimming Direction GH 9,maximize
(1)-Leuchten14AL LB6-Lasttyp 14,not active
(2)-Leuchten14AL LB6-Lampendefektbitposition 14,00
(3)-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
(4)-Leuchten14AL LB6-Lichtfunktion A 14,not active
(5)-Leuchten14AL LB6-Lichtfunktion B 14,not active
(6)-Leuchten14AL LB6-Dimmwert AB 14,0
(7)-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
(8)-Leuchten14AL LB6-Lichtfunktion C 14,not active
(9)-Leuchten14AL LB6-Lichtfunktion D 14,not active
(10)-Leuchten14AL LB6-Dimmwert CD 14,0
(11)-Leuchten14AL LB6-Dimming Direction CD 14,maximize
(12)-Leuchten14AL LB6-Lichtfunktion E 14,not active
(13)-Leuchten14AL LB6-Lichtfunktion F 14,not active
(14)-Leuchten14AL LB6-Dimmwert EF 14,0
(15)-Leuchten14AL LB6-Dimming Direction EF 14,maximize
(16)-Leuchten14AL LB6-Lichtfunktion G 14,not active
(17)-Leuchten14AL LB6-Lichtfunktion H 14,not active
(18)-Leuchten14AL LB6-Dimmwert GH 14,0
(19)-Leuchten14AL LB6-Dimming Direction GH 14,maximize
(1)-LIN-Mirrormode-mirror_mode_typ,not active
(2)-LIN-Mirrormode-Data bus LIN 1,active
(3)-LIN-Mirrormode-Data bus LIN 2,active
(4)-LIN-Mirrormode-Data bus LIN 3,active
(5)-LIN-Mirrormode-Data bus LIN 4,active
(6)-LIN-Mirrormode-Data bus LIN 5,active
(7)-LIN-Mirrormode-Data bus LIN 6,active
(1)-LuB Lichtrouter Kennlinie 1-x0,0.00 %
(2)-LuB Lichtrouter Kennlinie 1-X1,5.00 %
(3)-LuB Lichtrouter Kennlinie 1-X2,50.00 %
(4)-LuB Lichtrouter Kennlinie 1-X3,75.00 %
(5)-LuB Lichtrouter Kennlinie 1-X4,110.00
(6)-LuB Lichtrouter Kennlinie 1-X5,126.50
(7)-LuB Lichtrouter Kennlinie 1-y0,0.00 %
(8)-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
(9)-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
(10)-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
(11)-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
(12)-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
(1)-Personalisierung-Personalisierung_aktiv,active
(2)-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,active
(3)-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active
(4)-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active
(5)-Personalisierung-Anzahl_Benutzerkonten,4
(6)-Personalisierung-Automatische_ Schluesselzuordnung,active
(7)-Personalisierung-PSO_FSG_Setup2_Bit_0,active
(8)-Personalisierung-PSO_FSG_Setup2_Bit_1,active
(9)-Personalisierung-PSO_FSG_Setup2_Bit_2,active
(10)-Personalisierung-PSO_FSG_Setup2_Bit_3,active
(11)-Personalisierung-PSO_FSG_Setup2_Bit_4,active
(12)-Personalisierung-PSO_FSG_Setup2_Bit_5,active
(13)-Personalisierung-PSO_FSG_Setup2_Bit_6,active
(14)-Personalisierung-PSO_FSG_Setup2_Bit_7,active
(1)-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active
(2)-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
(1)-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
(2)-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
(3)-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
(4)-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
(5)-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
(6)-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
(7)-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
(8)-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
(9)-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
(10)-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
DV52
C?ID=194404
IceRacerX: Well done- thanks for posting-up the information!! To stop the BCM admap taking-up so much space, you should edit the post above by adding the "Code" tags; add
at the start of the data and add [ /code] (without the space bewtween "[" and "/") at the end of the post.
OK - alas I can't tell what level of BCM you have by the data in your autoscan, or admap - the nomenclature that VW uses for NAR vehicles is not as intuitive as the numbering on RoW based BCMs. Perhaps someone else here with better access to this information could make comment.
However, I've taken your admap information (above)  and parsed it through my MS Access data-base of BCM settings from cars from around the world. Because not everyone has MS Access, I've exported the results into a Excel soreadsheet which you can download  HERE.  I've placed your car in Column T (together with the other NAR data from your compatriots' vehicles).
Hopefully with the aid of the spreadsheet, you will be able to see the difference in settings for the adaption channels for your car and other NAR vehicles. A quick look at the table for the 2 Leuchte channels that I identified in my 1st response confirms what I had thought.   The settings for  ID #1713 to ID #1750 shows that on your car, the Fog-light adaption channels have been disabled. If you look at the other vehicles, you can see how VW sets-up the fog light channels when the fittings are factory installed. If the PINS are physically installed on the BCM as per my first post, then it's likely just a simple matter of replicating these settings on adaptation channels in your BCM.
IceRacerX
C?ID=275929
Thanks for info! trying to get to the BCM is the hard part now. I can see it, but do not know how to remove it. I can see tabs on the bottom and the connectors. I dont want to break something.
DV52
C?ID=194404
hopefully you won't need to take-out the BCM - just remove the plug to the A socket to see the pins.
Press the indent (1) in the picture and swing the retainer in the direction of the arrow, then pull-off the connector
IceRacerX
C?ID=275929
I wont be able to see the BCM side of the socket where it is now. I know the pins in the socket are not there. The hard part is trying to figure out how to run the wires properly thru the engine bay.
IceRacerX
C?ID=275929
Actually, the coding is the hardest as it is an unknown.
DV52
C?ID=194404
IceRacerX: On a mk7, to get the new wires into the cabin, pierce a small hole through the grommet around the existing wire loom on the engine firewall (there's small moulding in the grommet that is made for this purpose on a mk7).
IceRacerX
C?ID=275929
sooooo. I have installed the wiring I purchased from CarSystems (shipped super fast from Poland). looks nice too!! all wires are where they are supposed to go. I did the adaptation as I have read in many forums, mk7/mytdi/vwvortex/rosstech and the switch does activate the fog light on the dash(rather have it do that for the rear not the front) and it says check left / right fog lights in my HUD display in my car. Still shows that this module does not support fog lights.
Like I said before I cannot see in the pins are on BCM side without removing it. if someone knows how to do that, please let me know.
and a side not, I removed the battery to install the wiring nicely and all the doodads are goin nutso on my, tpms, pass seat airbag, steeing etc etc.
Do I just need to drive it or let it run for a few to clear itself out?
thank you again for all of you help!!
DV52
C?ID=194404
IceRacer: sounds like all has gone well - congratulations and well done!! Can you could confirm something that's been puzzling me since your first post - please?
In my first reponse, I posted-up a cut-down version of the WD for the fog lights which I got from the VW document. Here is a "more faithful" version of that drawing for the left side Fog from that document:
The thing that I found interesting about this drawing is the connection of the Fog lamp wire to PIN 45 SOCKET A on the BCM (see the designation T46a /45 - which means in VW speak PIN 45 on the 46 pin connector, socket A). Now, the same WD for the mk7 is identical, but the drawing says that the left fog light wire is connected to PIN 45 SOCKET B. What's also interesting is that the admap that you posted-up for the sportswagon has the designations for the left fog light Leuchte-set as "Leuchte12NL LB45". The numbers at the end mean "L" for links, or left in English and connection to PIN 45 SOCKET B. Both these references appear to be in conflict with the VW WD for the sportwagon - the same is true for the right fog lamp
So here's my question - to which socket on the BCM did you connect the fog light wire?
IceRacerX
C?ID=275929
I connected to B for fogs, and switch to A.
