How to install fogs on S model Mk7's (long version)
   #21
IceRacerX
C?ID=275929
I just noticed that the BCM part number from VW parts is different than what the VCDS reads. Supersession possibly? 5Q0937087T
Hello, i have a 2016 Sportwagen S MT with halogen headlight no fogs. My BCM is 5Q0937087ABZ00. VCDS says "this module does not support fog lights". I called my VW guy at the dealer for a SE with fog and a SE LP with fog. VW says they all use the same BCM. Should i just try to scan the cars to get long coding to update mine? I am dumbfounded on why they all have the same part number but mine wont support fogs. Anyone have any ideas? thanks!!
   #22
IceRacerX
C?ID=275929
I just scanned 3 vehicles at my local VW dealer because my salesman is awesome!!
2016 Golf SE Halogen HL with fogs
Wednesday,11,May,2016,12:11:37:58344
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: 3VW217AU8GM009694   License Plate: 2196GOLFSE
Mileage: 218km-135mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VW217AU8GM009694   Mileage: 218km-135miles
Address 01: Engine (J623-CXBB)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00122424002F1000
   Shop #: WSC 00066 790 00228
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: N/A
   VCID: 3FA3BB32A69E54C647-806A
No ASAM data for: "EV_ECM18TFS0208V0906264F" (VW37)
Readiness: 0010 0101
Address 02: Auto Trans (J217)       Labels: 09G-927-749.clb
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   Shop #: WSC 00066 790 00221
   ROD: EV_TCMAQ250031_AU37.rod
   VCID: 073363D2BECEDC063F-8052
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 51885000001797
   Coding: 01FA6AA124200975007D020981C7298056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 4BBB9FE2E226F866DB-801E
   Revision: 00021000    Serial number: 0370897869
   Coding: 030C0C
   VCID: 3A55CA26BDBC71EE70-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Revision: 00001K01
   Coding: 00020004200100000000000000000002
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 46ADAED6F944050E04-8012
          B10CD 00 [008] -  -
                    Reset counter: 65
                    Mileage: 191 km
                    Date: 2016.02.20
                    Time: 15:31:40
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86581206151040
   Coding: 001118464041826969E44000001407001800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7AD50A26FD3CB1EE30-802E
   Slave 1:
   Component: WWS    150508  043 0581
   Serial number:         150727142113
   Slave 2:
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S4Y15M05D26H17M24S50
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694818510102150802
   Coding: 181803
   Serial number: 003GCR029GPO
   VCID: 47B3A3D2FE4E1C06FF-8012
   Seat occupant detection; front passenger side:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH00000000000344GL8
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 357000000004F154741D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 3580000000063764741B
   Subsystem 4 - Part No SW: -----------    HW: 480 402 705 15
   Serial number: 3510002C31A2DCD2C3DL
   Subsystem 5 - Part No SW: -----------    HW: 480 402 705 15
   Serial number: 35200029B1B41485408Z
   Subsystem 6 - Part No SW: -----------    HW: 480 401 106 15
   Serial number: 3550002A11B5A8749230
   Subsystem 7 - Part No SW: -----------    HW: 480 401 106 15
   Serial number: 3560002A71B5A87081A8
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150616501293
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 042974DE8FF8F71E5A-8050
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BA4191AA180CF0502086A001000000000000000
   VCID: 256F095A2402EE162D-8070
   Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2223
   Revision: --------    Serial number: 07071510001320
   Coding: 0101000830085900FB0000081C0F00000001050000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 74C9241EDF58C79E6A-8020
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150001157410055232
   Coding: 31FFFF
   Revision: 00000000    Serial number: 15000149509003
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 00322
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449E41E9FD8879EAA-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 300615060509IL
   Coding: 003013200000040000000000
   VCID: 41A7BDCAD06A223631-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000001576037
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   VCID: 43ABB7C2CA76302623-8016
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 0107150605051V
   VCID: 40A1B8CEDB602B3E3E-8014
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000001536485
   Coding: 091000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 027300000000000051220002001808001F0100F40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6CF93C7E87681F5EB2-8038
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES00ATE
          B201A 00 [009] -  -
                    Reset counter: 25
                    Mileage: 190 km
                    Date: 2016.01.28
                    Time: 11:18:29
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0564
   Coding: 02730002C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:13)--------------------------
2016 Sportwagen SE with foglights
Wednesday,11,May,2016,11:56:23:58344
VIN: 3VWC17AU5GM517559   License Plate: 2016SPORTWAGENSE
Mileage: 34km-21mi   Repair Order: 5-11-16
VIN: 3VWC17AU5GM517559   Mileage: 34km-21miles
   Revision: --H13---
   Shop #: WSC 00066 790 00060
   ROD: N/A
   Revision: 00000000    Serial number: 53145000001693
   Coding: 04FA6AA124210973007C020581CC292056249000408194B400400050C002
   Revision: 00021000    Serial number: 0382559207
   Coding: 030C0C
   Revision: 00001K01
   Coding: 02020004200100000000000000000002
   Revision: --------    Serial number: 86580711150586
   Coding: 005118464041826969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00150
   Slave 1:
   Component: WWS    150727  043 0581
   Serial number:         151217150455
   Slave 2:
   Serial number: S4Y15M07D28H05M16S18
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000MET8100000
   Coding: 191800
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000MET7000000
   Coding: 191800
   Serial number: 003GCR03MJL.
   Serial number: IBH00000000000427GI7
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 002 310 15
   Serial number: 357000000001BA3D371L
   Subsystem 3 - Part No SW: -----------    HW: 480 002 310 15
   Serial number: 3580000000029CF8171S
   Subsystem 4 - Part No SW: -----------    HW: 480 402 410 15
   Serial number: 3510002AB1D3F974439E
   Subsystem 5 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 3520002A31CF1D20415-
   Subsystem 6 - Part No SW: -----------    HW: 480 401 210 15
   Serial number: 3550002B71CF1D15C2DM
   Subsystem 7 - Part No SW: -----------    HW: 480 401 210 15
   Serial number: 3560002B11CF1D151292
   Revision: FF033033    Serial number: 20151024400462
   Coding: 0410
   Coding: 0BA4111AA180CF0502086A001000000000000000
   Part No SW: 5Q0 907 530 AH    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2246
   Revision: --------    Serial number: 06121510801735
   Coding: 0901000830085900FB0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   VCID: 77D31312CE2EAC864F-8022
   Serial number: 29150001516800055325
   Coding: 31FFFF
   Inverter power receptacle:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0113471
   Revision: 00000000    Serial number: 15000215803005
   Serial number: 281115060501Z5
   Coding: 003013200000020000000000
   Serial number: 00000000000002311798
   Coding: 011000
65639 - Motor for Window Regulator
          B1487 29 [008] - Signal Implausible
                    Reset counter: 50
                    Mileage: 17 km
                    Date: 2011.04.16
                    Time: 12:44:03
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0102
   VCID: 44A9B4DECF78371E1A-8010
   Serial number: 281115060508L6
   Serial number: 00000000000002356737
   Coding: 091000
   Coding: 027302000000000051220002001808001F0100F40120010002
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9RJW0009M
   Component: OCULowMQBUS   007 0568
   Coding: 02730202C2823A017F1E06000000
End-------------------------(Elapsed Time: 03:21)--------------------------
2016 Sportwagen SE W/LP and foglights
Wednesday,11,May,2016,12:03:44:58344
VIN: 3VWC17AU3GM516748   License Plate: 21016SPORTWAGENSE/LP
Mileage: 33km-20mi   Repair Order:
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75
VIN: 3VWC17AU3GM516748   Mileage: 33km-20miles
   Revision: --H13---
   ROD: N/A
   Revision: 00000000    Serial number: 53145000000534
   Coding: 04FA6AA124210972007E020481CB292056249000408194B400400050C002
   Revision: 00021000    Serial number: 0379425033
   Coding: 030C0C
   Revision: 00001K01
   Revision: --------    Serial number: 86582909151866
   Coding: 00511A464041A26969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 00219
   Slave 1:
   Component: WWS    150801  043 0581
   Serial number:         151211184643
   Slave 2:
   Serial number: S4Y15M11D19H09M34S55
   Coding: 90A8DD
   Serial number: 0000FST000GCFKR00000
   Coding: 191800
   Serial number: 0000FST000GCFMT00000
   Coding: 191800
   Serial number: 003GCR03HT7S
   Serial number: IBH000000000003W8OF%
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 3570000000042D91671F
   Subsystem 3 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 35800000000F2C84E61Z
   Subsystem 4 - Part No SW: -----------    HW: 480 402 310 15
   Serial number: 3510002B71CF1D21B379
   Subsystem 5 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3520002C71CF1D1550EC
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3550002B11CF2D850366
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3560002B11CF2D82D3FQ
   Revision: FF033033    Serial number: 20151013401272
   Coding: 0410
   Coding: 0BA4111AA980CF0502086A001000000000000000
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 11101510522022
   Coding: 0901000830085900FB00000A1C0F00000001050000000000000000000000
   VCID: 79D7152AF83ABAF639-802C
   Serial number: 29150001515850045325
   Coding: 31FFFF
   Serial number: 0110106
   Revision: 00000000    Serial number: 15000215963007
   Serial number: 20111506050AMZ
   Coding: 003A13200000020000000000
   Serial number: 00000000000002349147
   Coding: 011000
   Coding: 0102
   Serial number: 20111506050C2E
   VCID: 42A5B2C6D56C392E28-8016
   Serial number: 00000000000002391958
   Coding: 091000
   Coding: 061A00010B000400
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Serial number: VWZ8Z9RES00ZNV
End-------------------------(Elapsed Time: 03:30)--------------------------
they all seem to have the same BCM. I need to talk to my parts guy again and recheck my vin with him, or the parts catalog is just not up to date.
DV52
C?ID=194404
I connected to B for fogs, and switch to A.
IceRacer- Thanks - means that the VW Sportswagon WD information is not correct- someone in the Vaterland has lied!!
   #24
IceRacerX
C?ID=275929
Im not sure what u mean by that...
i can get a notice saying check l/r fogs when i pull the switch if i change the byte/bit for fogs(manually in the long coding, not checks)They do not light up though.
I honestly think that the S models without KESSEY have a low/midline BCM. I have yet to check a GTI yet. But do all GTI's have KESSEY? If so they would have the same as the others for BCM.
This sucks lol.
   #25
DV52
C?ID=194404
This sucks lol.
IceRacerX: No offence intended to you - my reply was a (badly implemented) attempt at humour - clearly not successful . "Vaterland" is German for "Father land" - what I was trying to say is that the VW folk in Germany have made an error in their WD for the Sportswagon because it says that the two fog light wires are connected to the A socket, when clearly they were connected to the B socket. That's all
But it appears from your experience that accurate documentation is a problem generally with the Sportswagon - not your fault, it's a failure of VW (in the Vaterland)
IceRacerX
C?ID=275929
The fact that it reads no fog lights present means the coding is correct? Like i said the fogs do not work as of yet. I am not sure what to do besides replace the BCM. But i do know rhat there a different frequencies for BCMs based on Mhz. Mine is 315Mhz and others are 434mhz. So am hesitant to order one yet. Carsystems.eu website has some good info on it that has helped me so far.
   #27
IceRacerX
C?ID=275929
Just spoke to my VW guy again to get some clarity. He said the parts catalogue shows "5W0 937 087 ABZ00". I asked him if there was a supersession. He said it does show that the "ABZ00" replaces both the "T" and the "AA" in the catalogue. VW might replace them all with one part number instead of having multiples for such a low production car. That being said I feel a new BCM might be my only option at this point.:banghead:
before I go that route. Would the correct coding allow the car to look for fog lights even if the pins are not in the current BCM? Or could I have bad wiring?? As in it is sending a signal but note making it to the fog lights? I don't quite understand yet where the display and error codes come from in the HUD and in my MIB2 display under "CAR". You know like when your door is open or hood is open it can appear in either place. It says it for the fogs when I leave the coding in.:confused:
any help from anyone is appreciated.:thumbs:
and thanks for all the responses DV52, I really appreciate the info.:thumbs::thumbs:
   #28
DV52
C?ID=194404
IceRacerX: For the avoidance of doubt:
  1. you made the coding changes in my screen shot on post#7 (i.e. Byte 7, Bit 3 ticked) - yes?
  2. you made changes to the two Leuchte-sets that are associated with Pin #5 and Pin 45 on Socket B as per the spreadsheet in my previous post- which I have replicated in the table below (depending on whether the new fittings were incandescent, or LED) - yes?
IceRacerX
C?ID=275929
I dont have bit three on byte 7. That is where the problem lies at the moment.
I will try to screen shot tomorrow for u.
   #30
DV52
C?ID=194404
IceRacer: OK. So - using my handy-dandy code-string to Byte-list converter on the BCM code in your autoscan report in your post #10. I get the first three columns in the table below:
I've emphasised Byte 7 for the purpose of my reply and in case your not aware, the bits in the binary field are: Bit 0 on the extreme RHS and Bit 7 on the extreme LHS). Hopefully you can see that I have replicated your existing code-string in the Hex column with the heading "IceRacer New BCM". Also, I have set Bit 3 of Byte 7 in the Binary field and the equivalent Hex value for this Byte has become 49 (it is currently Hex 41). This shows (I hope) what the new code string should be for your BCM
So here's what I suggest that you do:
  1. Open the BCM and go to the Recode Module screen (see below)- but DON'T select the long coding helper
  2. Make sure that you select the entire code-string in the Current coding box and copy this to the clipboard
  3. Paste the clipboard to the New coding box
  4. Change the digit in Byte 7 from "1" to "9" - don't confuse this with the last digit in Byte 5 which has the same Hex value, 41.
  5. THIS IS IMPORTANT - make sure that all the other digits in the New coding box are the same as those in the Current coding box (except the digit that you changed)
  6. click Doit! and check that the change has been made
Andy
Sector 7G
HC424490
Just to add another way of accomplishing the same coding change, you can use the long coding helper but make "off label" changes as described here:
http://forums.vwvortex.com/showthread.php?3993326
That may help to avoid confusion about which specific byte you are changing (and it also will change the 0's and 1's of bit values into the hexadecimal byte values for you.
IceRacerX
C?ID=275929
I did due manual change to get the error code to appear for the fog lights. I will try your coding next after work as i tried a different one before.
   #33
IceRacerX
C?ID=275929
it says
coding rejected 7F: Service not supported in active session.
:confused:
   #34
IceRacerX
C?ID=275929
it says
:confused:
nevermind, I closed app and restarted all was good.
When pulling out switch for fogs it still says "open/short check left/right foglight"
p.s. why cant I edit any posts?
   #35
IceRacerX
C?ID=275929
Ordered new BCM, now we wait...
   #37
IceRacerX
C?ID=275929
new bcm has arrived, confirming it has pins that mine does not. not hard to swap part if you know how to, and now I know how.
New autoscan before recoding:
Saturday,21,May,2016,18:15:05:58344
VIN: 3VWA17AU1GM516884   License Plate: NEWBCMSCAN
Mileage: 3270km-2031mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWA17AU1GM516884   Mileage: 3270km-2031miles
Address 01: Engine (J623-CXBA)       Labels: 06K-907-425-V1.clb
   Revision: --H13---
   Coding: 091100122424002F0000
   ROD: N/A
17178 - ROD - Unknown Error Code
          - 00 [039]
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:10
   Revision: 00000000    Serial number: 53165000000809
   Coding: 04FA6AA124210972007F020881C7292056249000408194B400430050C002
0297 - Steering angle sensor
          B1168 16 [137] - Voltage Too Low
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:10
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:20
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:20
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Revision: 00001K01
   VCID: 052F69DA84C2CE164D-8050
   Part No SW: 5Q0 937 087 AB    HW: 5Q0 937 087 AB
   Revision: --------    Serial number: 86580801160508
   Coding: 00001842C041205317A44004F10407000000000000000000000000000000
   VCID: 7BDB0F22F20688E62B-802E
   Slave 1:
   Serial number:         151211180657
7 Faults Found:
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:00:02
15361024 - Component Protection
          U1101 00 [009] - Active
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:00:02
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [009] - No Release by Immobilizer
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:11
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [009] - -
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:00:00
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [009] - -
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:11
206085 - Remote Control
          B1311 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 0
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:00:00
525056 - Production Mode Active
          U1103 00 [009] - -
                    Reset counter: 0
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:00:00
   Serial number: 003GCR03KV3T
   Serial number: IBH000000000003ZUE32
   Coding: 303133
   Serial number: 35700000000C8064E61N
   Serial number: 35800000000E172DF61W
   Subsystem 4 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3510002C71CF1D1522C8
   Serial number: 3520002AB1CF1D2212A6
   Serial number: 3550002C91D1B621A252
   Serial number: 3560002C71D1B62071B2
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151102500369
   Coding: 0400
   Shop #: WSC 66564 385 16448
   Coding: 0BB51102A180CF0502086A001000000000000000
   Revision: --------    Serial number: 24101510800925
   Coding: 0101000830085900FB000008080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   Serial number: 29150001515720025325
   Coding: 30FFFF
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:13
   Component: TSG FS        010 0031
   Serial number: 9601152730397
   Coding: 003103205000040000000000
   Shop #: WSC 12345 123 12345
   Serial number: 00000000000002389556
   Coding: 011000
65588 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 176
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:17:37
   Coding: 0102
16130 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 0
   Component: TSG BFS       010 0031
   Serial number: 9901153100925
   Shop #: WSC 12345 813 111111
   Serial number: 00000000000002391317
   Coding: 091000
65591 - Motor for Window Regulator
          B1487 4B [008] - Over temperature
                    Reset counter: 212
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:23:09
                    Reset counter: 178
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:21:42
   Coding: 02730200FF00000051220001001808001F0100D40120010002
   Serial number: VWZ8Z9RJW001SF
1600 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
1659 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
1660 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
1661 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
          B11CF 53 [009] - Deactivated
                    Reset counter: 162
                    Mileage: 2932 km
                    Date: 2016.05.11
                    Time: 20:32:00
   Coding: 02730202C2821A017F1E06000000
13636864 - Mobile Online Services
          B149A F0 [008] - Vehicle Condition Report
                    Reset counter: 201
                    Mileage: 2877 km
                    Date: 2016.05.10
                    Time: 16:10:58
End-------------------------(Elapsed Time: 02:37)--------------------------
doing adaptation scan now as it is not in VCDS as of yet:
;SW:5Q0-937-087-AB   HW:5Q0-937-087-AB ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0162	 Coding:00001842C041205317A44004F10407000000000000000000000000000000
;EV_BodyContrModul1UDSBosc	15002	EV_BCMBOSCH_AU37.rod
;Saturday	21	May	2016	18:17:12:58344
;VCDS Version: Release 15.7.4  Data version: 20160216
;VCID: 7BDB0F22F20688E62B-802E
(1)-Access control-Funk bei Klemme 15 ein	not active
(2)-Access control-Notschließfunktion	active
(3)-Access control-automatisches Verriegeln bei Geschwindigkeit	not active
(4)-Access control-automatisches Entriegeln	active
(5)-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
(6)-Access control-ZV Tuerentriegelung	Globale Entriegelung
(7)-Access control-CAN Wecken bei Softtouchbetaetigung	not active
(8)-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
(9)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
(10)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
(11)-Access control-Valet Parking	not active
(12)-Access control-Direkter Auswurf des Heckdeckels	active
(13)-Access control-ZV entriegelt auch Heckdeckel	active
(14)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
(15)-Access control-Autolock Autounlock wirkt auf Heck	active
(16)-Access control-ZV Heck nur direkt auswerfen	not active
(17)-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
(18)-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	active
(19)-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
(20)-Access control-ZV-Entriegelung nach Seitencrash	not active
(21)-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active
(22)-Access control-Elektrische Laderaumabdeckung	not active
(23)-Access control-Menuesteuerung Tuerentriegelung	active
(24)-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
(25)-Access control-Autounlock NAR	not active
(26)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
(27)-Access control-Softtouch-Betaetigung senden	Always
(28)-Access control-Servoheck Schlossansteuerung	Always
(29)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	not active
(30)-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active
(31)-Access control-Vorrastenhaenger_Freigabe	not active
(32)-Access control-Heckfreigabe_Ohne_Verzoegerung	not active
(33)-Access control-Deaktivierung_Laderaumschliessung_extern	active
(34)-Access control-LS_Taster_Togglefunktion	active
(35)-Access control-Nutzfahrzeug_Schliessung	active
(36)-Access control-Wiederverriegelung_Laderaum	Freigabe_Softtouch
(37)-Access control-Mindestbetaetigung_HDF_Innentaster	0.00 s
(1)-Access control 2-Komfortbedienung global	active
(2)-Access control 2-Comfort opening	not active
(3)-Access control 2-Comfort closing	active
(4)-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
(5)-Access control 2-Nachsaven_nach_Verdecklauf	not active
(6)-Access control 2-Funk Komfort schliessen	active
(7)-Access control 2-Funk Komfort oeffnen	active
(8)-Access control 2-Schliesszylinder Komfort oeffnen	active
(9)-Access control 2-Schliesszylinder Komfort schliessen	active
(10)-Access control 2-SAD Richtung Komfortoeffnen	Open
(11)-Access control 2-SAD Komfort schliessen	active
(12)-Access control 2-SAD Komfort oeffnen	active
(13)-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
(14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
(15)-Access control 2-Regenschliessen_ein_aus	not active
(16)-Access control 2-Regenschliessen_art	once
(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active
(18)-Access control 2-Spiegelverstellung Synchron	active
(19)-Access control 2-Kessy Komfort oeffnen	not active
(20)-Access control 2-Kessy Komfort schliessen	active
(21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	active
(22)-Access control 2-Menuesteuerung Spiegelabsenkung	active
(23)-Access control 2-Funk Spiegelanklappen	active
(24)-Access control 2-Funk Spiegelanklappung Modus	by convenience operation via remote control key
(25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung	active
(26)-Access control 2-Menuesteuerung Funk Spiegel anklappen	active
(27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
(28)-Access control 2-Menuesteuerung Regenschliessen	not active
(29)-Access control 2-SAD PreCrash Konturschliessen	active
(30)-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
(31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
(32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
(33)-Access control 2-Remote_Unlock_Lock	not_active
(34)-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	not active
(35)-Access control 2-Signalisierung_Spiegelanklappung	not active
(36)-Access control 2-Virtuelles_Pedal	active
(37)-Access control 2-virtuelles_pedal_HMI_einstellbar	active
(38)-Access control 2-easycloselight_aktiv	not active
(39)-Access control 2-Spiegelanklappen_bei_Wiederverriegelung	not active
(1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
(2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active
(3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal
(4)-Acknowledgement signals-Optical feedback during locking	Decelerate
(5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
(6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
(7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active
(8)-Acknowledgement signals-Akustische Rueckmeldung global	not active
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
(10)-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active
(11)-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active
Activating and deactivating all development messages	not active
(1)-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit
(2)-After-run for park light-Bedingungen zur Standlichtbegrenzung	not active
(3)-After-run for park light-Bedingungen zur Parklichtbegrenzung	not active
(4)-After-run for park light-Faktor fuer Verfügbarkeitstimer	Faktor fuer x1 Minute
(5)-After-run for park light-Standlicht-Nachlaufzeit	30 min
(6)-After-run for park light-Standlicht-Verfügbarkeit	96 s
Alternating park position 1	7.49 °
Alternating park position 2	29.49 °
(1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80%
(2)-Ambient lighting-Defaultwert Ambienteprofil Tuer	80%
(3)-Ambient lighting-Defaultwert Ambienteprofil Vorn	80%
(4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
(5)-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
(6)-Ambient lighting-Innenlichtinszenierung	not enabled
(1)-Ambientelicht Farbliste-Rotwert Farbe 4	E1
(2)-Ambientelicht Farbliste-Gruenwert Farbe 4	E1
(3)-Ambientelicht Farbliste-Blauwert Farbe 4	E1
(4)-Ambientelicht Farbliste-Rotwert Farbe 5	E1
(5)-Ambientelicht Farbliste-Gruenwert Farbe 5	E1
(6)-Ambientelicht Farbliste-Blauwert Farbe 5	E1
(7)-Ambientelicht Farbliste-Rotwert Farbe 6	E1
(8)-Ambientelicht Farbliste-Gruenwert Farbe 6	E1
(9)-Ambientelicht Farbliste-Blauwert Farbe 6	E1
(10)-Ambientelicht Farbliste-Rotwert Farbe 7	E1
(11)-Ambientelicht Farbliste-Gruenwert Farbe 7	E1
(12)-Ambientelicht Farbliste-Blauwert Farbe 7	E1
(13)-Ambientelicht Farbliste-Rotwert Farbe 8	E1
(14)-Ambientelicht Farbliste-Gruenwert Farbe 8	E1
(15)-Ambientelicht Farbliste-Blauwert Farbe 8	E1
(16)-Ambientelicht Farbliste-Rotwert Farbe 9	E1
(17)-Ambientelicht Farbliste-Gruenwert Farbe 9	E1
(18)-Ambientelicht Farbliste-Blauwert Farbe 9	E1
(19)-Ambientelicht Farbliste-Rotwert Farbe 10	E1
(20)-Ambientelicht Farbliste-Gruenwert Farbe 10	E1
(21)-Ambientelicht Farbliste-Blauwert Farbe 10	E1
(1)-Anti-theft device-Alarmsignal	frequency modulated
(2)-Anti-theft device-Verzoegerung Panikalarm	2 sekunden verzoegerung
(3)-Anti-theft device-DWA Alarmverzoegerung	driver door contact thatcham
(4)-Anti-theft device-DWA Camper Modus	not active
(5)-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active
(6)-Anti-theft device-Sirenen Alarmzahl	1 Alarm
(7)-Anti-theft device-Akustischer Alarm Signalhorn	not active
(1)-Assistance light functions-Notbremsanzeige NBA	active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	800 ms
(4)-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	not active
(5)-Assistance light functions-Fernlichtassistent Reset	not active
(6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
(7)-Assistance light functions-Assistenzfahrlicht bei Regen	active
(8)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis
(9)-Assistance light functions-LS_Error_Ausgabe	not active
(10)-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active
(11)-Assistance light functions-AFL Zeitverzoegerung	500 ms
(12)-Assistance light functions-Lichtsensorempfindlichkeit	normal
(1)-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	active
(2)-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	active
(3)-Auxiliary functions-Signalhorn ohne KL15	not active
(4)-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
(1)-Button in center console-Funktion Taster 1	Start-stop
(2)-Button in center console-Funktion Taster 2	Laderaumschließung
(3)-Button in center console-Funktion Taster 3	Driving program
(4)-Button in center console-Funktion Taster 4	Steering wheel heater
Characteristics in production mode	2000 ms
(1)-Comfort illumination-Coming Home Verbaustatus	Not Present
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
(3)-Comfort illumination-Menueeinstellung Cominghome	10 s
(4)-Comfort illumination-Coming Home Leuchten	Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis	Driver door
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	12 lx
(7)-Comfort illumination-Leaving-Home Verbausstatus	not enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung	46400 lx
(1)-Convert. top oper.-Komfortbedienung Verdeck global	active
(2)-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
(3)-Convert. top oper.-Komfortbedienung Verdeck schließen	active
(4)-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
(5)-Convert. top oper.-Verdeck schließen via Schließzylinder	active
(6)-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
(7)-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active
(8)-Convert. top oper.-Verdeck oeffnen via Kessy	active
(9)-Convert. top oper.-Verdeck schließen via Kessy	active
(10)-Convert. top oper.-Doppelpuls nur Verdeck	active
(11)-Convert. top oper.-Verdeck mit Schiebedach	not active
(12)-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
(13)-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
(14)-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active
(15)-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active
(16)-Convert. top oper.-Remote Lock Unlock Timer s1	80 s
(17)-Convert. top oper.-Remote Lock Unlock Timer s3	20.000 ms
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
(8)-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
Deactivate production mode	0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
(3)-Driving light and parking light-Standlicht aus	active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided
(5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	active
(6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
(10)-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	60 km/h
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
(3)-Dyn. turn signal modes-ZV_Blinken_zu	not active
(4)-Dyn. turn signal modes-ZV_Blinken_auf	not active
(5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
(8)-Dyn. turn signal modes-Taxialarmblinken	not active
(9)-Dyn. turn signal modes-Panikblinken	not active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
(13)-Dyn. turn signal modes-Richtungs_blinken_links	not active
(14)-Dyn. turn signal modes-ABBA_Blinken	not active
(15)-Dyn. turn signal modes-Crashblinken	not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
(18)-Dyn. turn signal modes-Emergency_alert_blinken	not active
(1)-Energy management-Energy_Management_Adaptation	Energy management active
(2)-Energy management-Praediktives_Energiemanagement	not active
(1)-Head area heater-blower_speed	1
(2)-Head area heater-Temperature	-2
(1)-Int. light; 2nd generation-Aufloesung Dimmzeit	0.25 s
(2)-Int. light; 2nd generation-weicher Farbwechsel	not active
(3)-Int. light; 2nd generation-Tuertafelbeleuchtung mehrfarbig	active
(4)-Int. light; 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
(5)-Int. light; 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
(6)-Int. light; 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
(7)-Int. light; 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
(8)-Int. light; 2nd generation-Dachbeleuchtung mehrfarbig	not active
(9)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
(10)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
(11)-Int. light; 2nd generation-BAP Farbwert Farbe 1	2
(12)-Int. light; 2nd generation-BAP Farbwert Farbe 2	3
(13)-Int. light; 2nd generation-BAP Farbwert Farbe 3	1
(14)-Int. light; 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%
(15)-Int. light; 2nd generation-Defaultwert Ambienteprofil Dach	80%
(16)-Int. light; 2nd generation-Defaultwert Ambienteprofil Farbe	2
(17)-Int. light; 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active
(18)-Int. light; 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	not active
(19)-Int. light; 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active
(20)-Int. light; 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active
(21)-Int. light; 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
(22)-Int. light; 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
(23)-Int. light; 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
(24)-Int. light; 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	not active
(25)-Int. light; 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
(26)-Int. light; 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
(27)-Int. light; 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
(28)-Int. light; 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
(29)-Int. light; 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
(30)-Int. light; 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
(31)-Int. light; 2nd generation-Rotwert Farbe 1	225
(32)-Int. light; 2nd generation-Gruenwert Farbe 1	225
(33)-Int. light; 2nd generation-Blauwert Farbe 1	225
(34)-Int. light; 2nd generation-Rotwert Farbe 2	225
(35)-Int. light; 2nd generation-Gruenwert Farbe 2	225
(36)-Int. light; 2nd generation-Blauwert Farbe 2	225
(37)-Int. light; 2nd generation-Rotwert Farbe 3	225
(38)-Int. light; 2nd generation-Gruenwert Farbe 3	225
(39)-Int. light; 2nd generation-Blauwert Farbe 3	225
(1)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed
(2)-Interior light; light configuration-Ambiente_Lautsprecher	not installed
(3)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
(4)-Interior light; light configuration-Cockpitbeleuchtung	not installed
(5)-Interior light; light configuration-Mittelkonsolenbeleuchtung	not installed
(6)-Interior light; light configuration-Dachbeleuchtung	not installed
(7)-Interior light; light configuration-Panoramaschiebedachbeleuchtung	not installed
(8)-Interior light; light configuration-Foot well lighting	not installed
(9)-Interior light; light configuration-Farbwahl ueber HMI	not installed
(10)-Interior light; light configuration-Farbwahl ueber Fahrprofil	not installed
(11)-Interior light; light configuration-LIN-Dachkonsole lokal aktivierbar	not active
(12)-Interior light; light configuration-Ambientemenue mit globalem aus	not active
(13)-Interior light; light configuration-Ambientemenue mit alle Zonen	not active
(14)-Interior light; light configuration-Ambient_Farbliste_HMI	not active
(15)-Interior light; light configuration-Frei_Farbwahl_ueber_HMI	not active
(1)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	not active
(2)-Interior lighting-KL30G ohne PWM	not active
(3)-Interior lighting-KL58 Einschalten mit Rampe	not active
(4)-Interior lighting-KL58 Verriegelungsausschalten	not active
(5)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
(6)-Interior lighting-Suchbeleuchtung Festwert	100%
(1)-Interior lighting; parameter-p_t_verzoegerung_einstieg_innenlicht	0 s
(2)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_innenlicht	0 s
(3)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_innenlicht	0 s
(4)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_innenlicht	0 s
(5)-Interior lighting; parameter-p_t_verzoegerung_schliessen_innenlicht	0 s
(6)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0 s
(7)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_innenlicht	0 s
(8)-Interior lighting; parameter-p_t_verzoegerung_einstieg_tueren	0 s
(9)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_tueren	0 s
(10)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_tueren	0 s
(11)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_tueren	0 s
(12)-Interior lighting; parameter-p_t_verzoegerung_schliessen_tueren	0 s
(13)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_tueren	0 s
(14)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_tueren	0 s
(15)-Interior lighting; parameter-p_t_verzoegerung_einstieg_fussraum	0 s
(16)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_fussraum	0 s
(17)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_fussraum	0 s
(18)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_fussraum	0 s
(19)-Interior lighting; parameter-p_t_verzoegerung_schliessen_fussraum	0 s
(20)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_fussraum	0 s
(21)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_fussraum	0 s
(22)-Interior lighting; parameter-p_t_verzoegerung_einstieg_cockpit	0 s
(23)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_cockpit	0 s
(24)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_cockpit	0 s
(25)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_cockpit	0 s
(26)-Interior lighting; parameter-p_t_verzoegerung_schliessen_cockpit	0 s
(27)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_cockpit	0 s
(28)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_cockpit	0 s
(29)-Interior lighting; parameter-p_t_verzoegerung_einstieg_miko	0 s
(30)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_miko	0 s
(31)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_miko	0 s
(32)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_miko	0 s
(33)-Interior lighting; parameter-p_t_verzoegerung_schliessen_miko	0 s
(34)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_miko	0 s
(35)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_miko	0 s
(36)-Interior lighting; parameter-p_t_verzoegerung_einstieg_dach	0 s
(37)-Interior lighting; parameter-p_t_verzoegerung_ausstieg_dach	0 s
(38)-Interior lighting; parameter-p_t_verzoegerung_oeffnen_dach	0 s
(39)-Interior lighting; parameter-p_t_verzoegerung_entriegelt_dach	0 s
(40)-Interior lighting; parameter-p_t_verzoegerung_schliessen_dach	0 s
(41)-Interior lighting; parameter-p_t_verzoegerung_schluessel_ab_dach	0 s
(42)-Interior lighting; parameter-p_t_verzoegerung_verriegelt_dach	0 s
(43)-Interior lighting; parameter-p_helligkeit_entriegelt_innenlicht	100%
(44)-Interior lighting; parameter-p_helligkeit_max_innenlicht	100%
(45)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%
(46)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%
(47)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%
(48)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%
(49)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%
(50)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%
(51)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%
(52)-Interior lighting; parameter-p_helligkeit_einausstieg_innenlicht	100%
(53)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%
(54)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%
(55)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%
(56)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%
(57)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%
(58)-Interior lighting; parameter-p_adaption_kundenwunsch_tuer	64
(59)-Interior lighting; parameter-p_helligkeit_entriegelt_tueren	100%
(60)-Interior lighting; parameter-p_helligkeit_max_tueren	100%
(61)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	100%
(62)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	100%
(63)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	100%
(64)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	100%
(65)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%
(66)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	100%
(67)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	100%
(68)-Interior lighting; parameter-p_helligkeit_einausstieg_tueren	100%
(69)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	100%
(70)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	100%
(71)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	100%
(72)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	100%
(73)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	100%
(74)-Interior lighting; parameter-p_adaption_kundenwunsch_fussraum	64
(75)-Interior lighting; parameter-p_helligkeit_entriegelt_fussraum	100%
(76)-Interior lighting; parameter-p_helligkeit_max_fussraum	100%
(77)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	100%
(78)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	100%
(79)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	100%
(80)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	100%
(81)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%
(82)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	100%
(83)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	100%
(84)-Interior lighting; parameter-p_helligkeit_einausstieg_fussraum	100%
(85)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	100%
(86)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	100%
(87)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	100%
(88)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	100%
(89)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	100%
(90)-Interior lighting; parameter-p_adaption_kundenwunsch_lautsprecher	64
(91)-Interior lighting; parameter-p_helligkeit_entriegelt_lautsprecher	100%
(92)-Interior lighting; parameter-p_helligkeit_max_lautsprecher	100%
(93)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%
(94)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%
(95)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%
(96)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%
(97)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%
(98)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%
(99)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%
(100)-Interior lighting; parameter-p_helligkeit_einausstieg_lautsprecher	100%
(101)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%
(102)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%
(103)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%
(104)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%
(105)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%
(106)-Interior lighting; parameter-p_adaption_kundenwunsch_itafel	64
(107)-Interior lighting; parameter-p_helligkeit_entriegelt_itafel	100%
(108)-Interior lighting; parameter-p_helligkeit_max_itafel	100%
(109)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%
(110)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%
(111)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%
(112)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%
(113)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%
(114)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%
(115)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%
(116)-Interior lighting; parameter-p_helligkeit_einausstieg_itafel	100%
(117)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%
(118)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%
(119)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%
(120)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%
(121)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	0%
(122)-Interior lighting; parameter-p_adaption_kundenwunsch_cockpit	1
(123)-Interior lighting; parameter-p_helligkeit_entriegelt_cockpit	72%
(124)-Interior lighting; parameter-p_helligkeit_max_cockpit	64%
(125)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	170%
(126)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	172%
(127)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	0%
(128)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	216%
(129)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	216%
(130)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	216%
(131)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	216%
(132)-Interior lighting; parameter-p_helligkeit_einausstieg_cockpit	216%
(133)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	216%
(134)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	216%
(135)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	216%
(136)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	233%
(137)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	32%
(138)-Interior lighting; parameter-p_adaption_kundenwunsch_miko	0
(139)-Interior lighting; parameter-p_helligkeit_entriegelt_miko	16%
(140)-Interior lighting; parameter-p_helligkeit_max_miko	0%
(141)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_miko	216%
(142)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_miko	111%
(143)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	16%
(144)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	0%
(145)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	0%
(146)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	157%
(147)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	7%
(148)-Interior lighting; parameter-p_helligkeit_einausstieg_miko	8%
(149)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	255%
(150)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	0%
(151)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	216%
(152)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	216%
(153)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	186%
(154)-Interior lighting; parameter-p_adaption_kundenwunsch_dach	DC
(155)-Interior lighting; parameter-p_helligkeit_entriegelt_dach	191%
(156)-Interior lighting; parameter-p_helligkeit_max_dach	5%
(157)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_dach	236%
(158)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_dach	248%
(159)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	148%
(160)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	1%
(161)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	6%
(162)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	16%
(163)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	136%
(164)-Interior lighting; parameter-p_helligkeit_einausstieg_dach	254%
(165)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	216%
(166)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	21%
(167)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	146%
(168)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	216%
(169)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	0%
(170)-Interior lighting; parameter-p_adaption_kundenwunsch_psd	0
(171)-Interior lighting; parameter-p_helligkeit_entriegelt_psd	28%
(172)-Interior lighting; parameter-p_helligkeit_max_psd	1%
(173)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_ein_psd	184%
(174)-Interior lighting; parameter-p_helligkeit_HD_auf_zuendung_aus_psd	59%
(175)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	64%
(176)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	0%
(177)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	144%
(178)-Interior lighting; parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	96%
(179)-Interior lighting; parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	146%
(180)-Interior lighting; parameter-p_helligkeit_einausstieg_psd	0%
(181)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	1%
(182)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	176%
(183)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	190%
(184)-Interior lighting; parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	44%
(185)-Interior lighting; parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	96%
(186)-Interior lighting; parameter-p_dimmfaktor_farbwechsel_auf	4C
(187)-Interior lighting; parameter-p_dimmfaktor_farbwechsel_ab	FE
(188)-Interior lighting; parameter-p_farbwechsel_delay	1C
(189)-Interior lighting; parameter-p_farbauswahl_HMI	8F
(190)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI	8
(191)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_2	0F
(192)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_3	0
(193)-Interior lighting; parameter-p_ambienteumfang_mehrfarbig_HMI_4	A1
(194)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI	0
(195)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_2	0
(196)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_3	1
(197)-Interior lighting; parameter-p_ambientelicht_verbauinformation_HMI_4	0
(198)-Interior lighting; parameter-p_verzoegerung_berechnen	0
(199)-Interior lighting; parameter-p_t_HMI_verzoegerung_helligkeitswerte	72 ms
(1)-Light configuration-Lasttyp 0	12 - Blinkleuchten
(2)-Light configuration-BAP Bitposition 0	34
(3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
(4)-Light configuration-Lichtfunktion A 0	2
(5)-Light configuration-Lichtfunktion B 0	0
(6)-Light configuration-Dimmwert AB 0	100
(7)-Light configuration-Lichtansteuerung HD AB 0	Always
(8)-Light configuration-Lichtfunktion C 0	0
(9)-Light configuration-Lichtfunktion D 0	0
(10)-Light configuration-Dimmwert CD 0	0
(11)-Light configuration-Dimming Direction CD 0	maximize
(12)-Light configuration-Lichtfunktion E 0	0
(13)-Light configuration-Lichtfunktion F 0	0
(14)-Light configuration-Dimmwert EF 0	0
(15)-Light configuration-Dimming Direction EF 0	maximize
(16)-Light configuration-Lichtfunktion G 0	0
(17)-Light configuration-Lichtfunktion H 0	0
(18)-Light configuration-Dimmwert GH 0	0
(19)-Light configuration-Dimming Direction GH 0	maximize
(20)-Light configuration-Lasttyp 1	12 - Blinkleuchten
(21)-Light configuration-BAP Bitposition 1	3E
(22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
(23)-Light configuration-Lichtfunktion A 1	4
(24)-Light configuration-Lichtfunktion B 1	0
(25)-Light configuration-Dimmwert AB 1	100
(26)-Light configuration-Lichtansteuerung HD AB 1	Always
(27)-Light configuration-Lichtfunktion C 1	0
(28)-Light configuration-Lichtfunktion D 1	0
(29)-Light configuration-Dimmwert CD 1	0
(30)-Light configuration-Dimming Direction CD 1	maximize
(31)-Light configuration-Lichtfunktion E 1	0
(32)-Light configuration-Lichtfunktion F 1	0
(33)-Light configuration-Dimmwert EF 1	0
(34)-Light configuration-Dimming Direction EF 1	maximize
(35)-Light configuration-Lichtfunktion G 1	0
(36)-Light configuration-Lichtfunktion H 1	0
(37)-Light configuration-Dimmwert GH 1	0
(38)-Light configuration-Dimming Direction GH 1	maximize
(39)-Light configuration-Lasttyp 2	8 - allgemeine Glühlampe 12W
(40)-Light configuration-BAP Bitposition 2	35
(41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	26
(42)-Light configuration-Lichtfunktion A 2	8
(43)-Light configuration-Lichtfunktion B 2	9
(44)-Light configuration-Dimmwert AB 2	100
(45)-Light configuration-Lichtansteuerung HD AB 2	Always
(46)-Light configuration-Lichtfunktion C 2	0
(47)-Light configuration-Lichtfunktion D 2	0
(48)-Light configuration-Dimmwert CD 2	0
(49)-Light configuration-Dimming Direction CD 2	maximize
(50)-Light configuration-Lichtfunktion E 2	0
(51)-Light configuration-Lichtfunktion F 2	0
(52)-Light configuration-Dimmwert EF 2	0
(53)-Light configuration-Dimming Direction EF 2	maximize
(54)-Light configuration-Lichtfunktion G 2	0
(55)-Light configuration-Lichtfunktion H 2	0
(56)-Light configuration-Dimmwert GH 2	0
(57)-Light configuration-Dimming Direction GH 2	maximize
(58)-Light configuration-Lasttyp 3	8 - allgemeine Glühlampe 12W
(59)-Light configuration-BAP Bitposition 3	3F
(60)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	46
(61)-Light configuration-Lichtfunktion A 3	8
(62)-Light configuration-Lichtfunktion B 3	10
(63)-Light configuration-Dimmwert AB 3	100
(64)-Light configuration-Lichtansteuerung HD AB 3	Always
(65)-Light configuration-Lichtfunktion C 3	0
(66)-Light configuration-Lichtfunktion D 3	0
(67)-Light configuration-Dimmwert CD 3	0
(68)-Light configuration-Dimming Direction CD 3	maximize
(69)-Light configuration-Lichtfunktion E 3	0
(70)-Light configuration-Lichtfunktion F3	0
(71)-Light configuration-Dimmwert EF 3	0
(72)-Light configuration-Dimming Direction EF 3	maximize
(73)-Light configuration-Lichtfunktion G 3	0
(74)-Light configuration-Lichtfunktion H 3	0
(75)-Light configuration-Dimmwert GH 3	0
(76)-Light configuration-Dimming Direction GH 3	maximize
(77)-Light configuration-Lasttyp 4	not active
(78)-Light configuration-BAP Bitposition 4	3A
(79)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	20
(80)-Light configuration-Lichtfunktion A 4	20
(81)-Light configuration-Lichtfunktion B 4	0
(82)-Light configuration-Dimmwert AB 4	100
(83)-Light configuration-Lichtansteuerung HD AB 4	Always
(84)-Light configuration-Lichtfunktion C 4	0
(85)-Light configuration-Lichtfunktion D 4	0
(86)-Light configuration-Dimmwert CD 4	0
(87)-Light configuration-Dimming Direction CD 4	maximize
(88)-Light configuration-Lichtfunktion E 4	0
(89)-Light configuration-Lichtfunktion F 4	0
(90)-Light configuration-Dimmwert EF 4	0
(91)-Light configuration-Dimming Direction EF 4	maximize
(92)-Light configuration-Lichtfunktion G 4	0
(93)-Light configuration-Lichtfunktion H 4	0
(94)-Light configuration-Dimmwert GH 4	0
(95)-Light configuration-Dimming Direction GH 4	maximize
(96)-Light configuration-Lasttyp 5	not active
(97)-Light configuration-BAP Bitposition 5	44
(98)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	21
(99)-Light configuration-Lichtfunktion A 5	20
(100)-Light configuration-Lichtfunktion B 5	0
(101)-Light configuration-Dimmwert AB 5	100
(102)-Light configuration-Lichtansteuerung HD AB 5	Always
(103)-Light configuration-Lichtfunktion C 5	0
(104)-Light configuration-Lichtfunktion D 5	0
(105)-Light configuration-Dimmwert CD 5	0
(106)-Light configuration-Dimming Direction CD 5	maximize
(107)-Light configuration-Lichtfunktion E 5	0
(108)-Light configuration-Lichtfunktion F5	0
(109)-Light configuration-Dimmwert EF 5	0
(110)-Light configuration-Dimming Direction EF 5	maximize
(111)-Light configuration-Lichtfunktion G 5	0
(112)-Light configuration-Lichtfunktion H 5	0
(113)-Light configuration-Dimmwert GH 5	0
(114)-Light configuration-Dimming Direction GH 5	maximize
(115)-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
(116)-Light configuration-BAP Bitposition 6	36
(117)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
(118)-Light configuration-Lichtfunktion A 6	11
(119)-Light configuration-Lichtfunktion B 6	15
(120)-Light configuration-Dimmwert AB 6	127
(121)-Light configuration-Lichtansteuerung HD AB 6	Always
(122)-Light configuration-Lichtfunktion C 6	0
(123)-Light configuration-Lichtfunktion D 6	0
(124)-Light configuration-Dimmwert CD 6	0
(125)-Light configuration-Dimming Direction CD 6	maximize
(126)-Light configuration-Lichtfunktion E 6	0
(127)-Light configuration-Lichtfunktion F 6	0
(128)-Light configuration-Dimmwert EF 6	0
(129)-Light configuration-Dimming Direction EF 6	maximize
(130)-Light configuration-Lichtfunktion G 6	0
(131)-Light configuration-Lichtfunktion H 6	0
(132)-Light configuration-Dimmwert GH 6	0
(133)-Light configuration-Dimming Direction GH 6	maximize
(134)-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
(135)-Light configuration-BAP Bitposition 7	40
(136)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
(137)-Light configuration-Lichtfunktion A 7	12
(138)-Light configuration-Lichtfunktion B 7	15
(139)-Light configuration-Dimmwert AB 7	127
(140)-Light configuration-Lichtansteuerung HD AB 7	Always
(141)-Light configuration-Lichtfunktion C 7	0
(142)-Light configuration-Lichtfunktion D 7	0
(143)-Light configuration-Dimmwert CD 7	0
(144)-Light configuration-Dimming Direction CD 7	maximize
(145)-Light configuration-Lichtfunktion E 7	0
(146)-Light configuration-Lichtfunktion F 7	0
(147)-Light configuration-Dimmwert EF 7	0
(148)-Light configuration-Dimming Direction EF 7	maximize
(149)-Light configuration-Lichtfunktion G 7	0
(150)-Light configuration-Lichtfunktion H 7	0
(151)-Light configuration-Dimmwert GH 7	0
(152)-Light configuration-Dimming Direction GH 7	maximize
(153)-Light configuration-Lasttyp 8	1 - LED Tagfahrlichtmodul Versorgung
(154)-Light configuration-BAP Bitposition 8	48
(155)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	AA
(156)-Light configuration-Lichtfunktion A 8	172
(157)-Light configuration-Lichtfunktion B 8	0
(158)-Light configuration-Dimmwert AB 8	88
(159)-Light configuration-Lichtansteuerung HD AB 8	only_if_closed
(160)-Light configuration-Lichtfunktion C 8	216
(161)-Light configuration-Lichtfunktion D 8	216
(162)-Light configuration-Dimmwert CD 8	88
(163)-Light configuration-Dimming Direction CD 8	minimize
(164)-Light configuration-Lichtfunktion E 8	216
(165)-Light configuration-Lichtfunktion F 8	216
(166)-Light configuration-Dimmwert EF 8	88
(167)-Light configuration-Dimming Direction EF 8	minimize
(168)-Light configuration-Lichtfunktion G 8	216
(169)-Light configuration-Lichtfunktion H 8	233
(170)-Light configuration-Dimmwert GH 8	32
(171)-Light configuration-Dimming Direction GH 8	maximize
(172)-Light configuration-Lasttyp 9	not active
(173)-Light configuration-BAP Bitposition 9	10
(174)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	D8
(175)-Light configuration-Lichtfunktion A 9	111
(176)-Light configuration-Lichtfunktion B 9	16
(177)-Light configuration-Dimmwert AB 9	100
(178)-Light configuration-Lichtansteuerung HD AB 9	Always
(179)-Light configuration-Lichtfunktion C 9	0
(180)-Light configuration-Lichtfunktion D 9	157
(181)-Light configuration-Dimmwert CD 9	7
(182)-Light configuration-Dimming Direction CD 9	maximize
(183)-Light configuration-Lichtfunktion E 9	8
(184)-Light configuration-Lichtfunktion F 9	255
(185)-Light configuration-Dimmwert EF 9	0
(186)-Light configuration-Dimming Direction EF 9	maximize
(187)-Light configuration-Lichtfunktion G 9	216
(188)-Light configuration-Lichtfunktion H 9	216
(189)-Light configuration-Dimmwert GH 9	58
(190)-Light configuration-Dimming Direction GH 9	minimize
(192)-Light configuration-BAP Bitposition 10	BF
(193)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	EC
(194)-Light configuration-Lichtfunktion A 10	248
(195)-Light configuration-Lichtfunktion B 10	148
(196)-Light configuration-Dimmwert AB 10	1
(197)-Light configuration-Lichtansteuerung HD AB 10	Always
(198)-Light configuration-Lichtfunktion C 10	6
(199)-Light configuration-Lichtfunktion D 10	16
(200)-Light configuration-Dimmwert CD 10	8
(201)-Light configuration-Dimming Direction CD 10	minimize
(202)-Light configuration-Lichtfunktion E 10	254
(203)-Light configuration-Lichtfunktion F 10	216
(204)-Light configuration-Dimmwert EF 10	21
(205)-Light configuration-Dimming Direction EF 10	maximize
(206)-Light configuration-Lichtfunktion G 10	146
(207)-Light configuration-Lichtfunktion H 10	216
(208)-Light configuration-Dimmwert GH 10	0
(209)-Light configuration-Dimming Direction GH 10	maximize
(210)-Light configuration-Lasttyp 11	not active
(211)-Light configuration-BAP Bitposition 11	1C
(212)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	B8
(213)-Light configuration-Lichtfunktion A 11	59
(214)-Light configuration-Lichtfunktion B 11	64
(215)-Light configuration-Dimmwert AB 11	0
(216)-Light configuration-Lichtansteuerung HD AB 11	Always
(217)-Light configuration-Lichtfunktion C 11	144
(218)-Light configuration-Lichtfunktion D 11	96
(219)-Light configuration-Dimmwert CD 11	18
(220)-Light configuration-Dimming Direction CD 11	minimize
(221)-Light configuration-Lichtfunktion E 11	0
(222)-Light configuration-Lichtfunktion F 11	1
(223)-Light configuration-Dimmwert EF 11	48
(224)-Light configuration-Dimming Direction EF 11	minimize
(225)-Light configuration-Lichtfunktion G 11	190
(226)-Light configuration-Lichtfunktion H 11	44
(227)-Light configuration-Dimmwert GH 11	96
(228)-Light configuration-Dimming Direction GH 11	maximize
(230)-Light configuration-BAP Bitposition 12	FE
(231)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	8F
(232)-Light configuration-Lichtfunktion A 12	8
(233)-Light configuration-Lichtfunktion B 12	15
(234)-Light configuration-Dimmwert AB 12	0
(235)-Light configuration-Lichtansteuerung HD AB 12	Always
(236)-Light configuration-Lichtfunktion C 12	161
(237)-Light configuration-Lichtfunktion D 12	0
(238)-Light configuration-Dimmwert CD 12	0
(239)-Light configuration-Dimming Direction CD 12	maximize
(240)-Light configuration-Lichtfunktion E 12	1
(241)-Light configuration-Lichtfunktion F 12	0
(242)-Light configuration-Dimmwert EF 12	0
(243)-Light configuration-Dimming Direction EF 12	maximize
(244)-Light configuration-Lichtfunktion G 12	72
(245)-Light configuration-Lichtfunktion H 12	220
(246)-Light configuration-Dimmwert GH 12	38
(247)-Light configuration-Dimming Direction GH 12	maximize
(249)-Light configuration-BAP Bitposition 13	18
(250)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	D0
(251)-Light configuration-Lichtfunktion A 13	80
(252)-Light configuration-Lichtfunktion B 13	8
(253)-Light configuration-Dimmwert AB 13	15
(254)-Light configuration-Lichtansteuerung HD AB 13	Always
(255)-Light configuration-Lichtfunktion  C 13	0
(256)-Light configuration-Lichtfunktion D 13	0
(257)-Light configuration-Dimmwert CD 13	52
(258)-Light configuration-Dimming Direction CD 13	maximize
(259)-Light configuration-Lichtfunktion E 13	64
(260)-Light configuration-Lichtfunktion F 13	170
(261)-Light configuration-Dimmwert EF 13	65
(262)-Light configuration-Dimming Direction EF 13	maximize
(263)-Light configuration-Lichtfunktion G 13	146
(264)-Light configuration-Lichtfunktion H 13	84
(265)-Light configuration-Dimmwert GH 13	0
(266)-Light configuration-Dimming Direction GH 13	maximize
(267)-Light configuration-Lasttyp 14	5 - LED Abblendlicht
(268)-Light configuration-BAP Bitposition 14	D0
(269)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	C2
(270)-Light configuration-Lichtfunktion A 14	0
(271)-Light configuration-Lichtfunktion B 14	106
(272)-Light configuration-Dimmwert AB 14	1
(273)-Light configuration-Lichtansteuerung HD AB 14	Always
(274)-Light configuration-Lichtfunktion C 14	146
(275)-Light configuration-Lichtfunktion D 14	1
(276)-Light configuration-Dimmwert CD 14	1
(277)-Light configuration-Dimming Direction CD 14	maximize
(278)-Light configuration-Lichtfunktion E 14	1
(279)-Light configuration-Lichtfunktion F 14	1
(280)-Light configuration-Dimmwert EF 14	32
(281)-Light configuration-Dimming Direction EF 14	maximize
(282)-Light configuration-Lichtfunktion G 14	190
(283)-Light configuration-Lichtfunktion H 14	236
(284)-Light configuration-Dimmwert GH 14	3
(285)-Light configuration-Dimming Direction GH 14	maximize
(286)-Light configuration-Lasttyp 15	9 - allgemeine Glühlampe 27W; auch H15
(287)-Light configuration-BAP Bitposition 15	FF
(288)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	98
(289)-Light configuration-Lichtfunktion A 15	70
(290)-Light configuration-Lichtfunktion B 15	152
(291)-Light configuration-Dimmwert AB 15	0
(292)-Light configuration-Lichtansteuerung HD AB 15	Always
(293)-Light configuration-Lichtfunktion C 15	248
(294)-Light configuration-Lichtfunktion D 15	0
(295)-Light configuration-Dimmwert CD 15	120
(296)-Light configuration-Dimming Direction CD 15	minimize
(297)-Light configuration-Lichtfunktion E 15	102
(298)-Light configuration-Lichtfunktion F 15	80
(299)-Light configuration-Dimmwert EF 15	10
(300)-Light configuration-Dimming Direction EF 15	maximize
(301)-Light configuration-Lichtfunktion G 15	216
(302)-Light configuration-Lichtfunktion H 15	8
(303)-Light configuration-Dimmwert GH 15	19
(304)-Light configuration-Dimming Direction GH 15	minimize
(306)-Light configuration-BAP Bitposition 16	4E
(307)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0
(308)-Light configuration-Lichtfunktion A 16	78
(309)-Light configuration-Lichtfunktion B 16	205
(310)-Light configuration-Dimmwert AB 16	0
(311)-Light configuration-Lichtansteuerung HD AB 16	Always
(312)-Light configuration-Lichtfunktion C 16	208
(313)-Light configuration-Lichtfunktion D 16	78
(314)-Light configuration-Dimmwert CD 16	32
(315)-Light configuration-Dimming Direction CD 16	minimize
(316)-Light configuration-Lichtfunktion E 16	58
(317)-Light configuration-Lichtfunktion F 16	208
(318)-Light configuration-Dimmwert EF 16	15
(319)-Light configuration-Dimming Direction EF 16	maximize
(320)-Light configuration-Lichtfunktion G 16	160
(321)-Light configuration-Lichtfunktion H 16	24
(322)-Light configuration-Dimmwert GH 16	93
(323)-Light configuration-Dimming Direction GH 16	maximize
(325)-Light configuration-BAP Bitposition 17	D0
(326)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	8A
(327)-Light configuration-Lichtfunktion A 17	36
(328)-Light configuration-Lichtfunktion  B 17	1
(329)-Light configuration-Dimmwert AB 17	0
(330)-Light configuration-Lichtansteuerung HD AB 17	Always
(331)-Light configuration-Lichtfunktion C 17	0
(332)-Light configuration-Lichtfunktion D 17	112
(333)-Light configuration-Dimmwert CD 17	127
(334)-Light configuration-Dimming Direction CD 17	minimize
(335)-Light configuration-Lichtfunktion E 17	255
(336)-Light configuration-Lichtfunktion F 17	71
(337)-Light configuration-Dimmwert EF 17	24
(338)-Light configuration-Dimming Direction EF 17	maximize
(339)-Light configuration-Lichtfunktion G 17	208
(340)-Light configuration-Lichtfunktion H 17	0
(341)-Light configuration-Dimmwert GH 17	0
(342)-Light configuration-Dimming Direction GH 17	maximize
(343)-Light configuration-Lasttyp 18	not active
(344)-Light configuration-BAP Bitposition 18	0
(345)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	0
(346)-Light configuration-Lichtfunktion A 18	0
(347)-Light configuration-Lichtfunktion B 18	0
(348)-Light configuration-Dimmwert AB 18	1
(349)-Light configuration-Lichtansteuerung HD AB 18	Always
(350)-Light configuration-Lichtfunktion C 18	185
(351)-Light configuration-Lichtfunktion D 18	244
(352)-Light configuration-Dimmwert CD 18	7
(353)-Light configuration-Dimming Direction CD 18	maximize
(354)-Light configuration-Lichtfunktion E 18	252
(355)-Light configuration-Lichtfunktion F 18	104
(356)-Light configuration-Dimmwert EF 18	96
(357)-Light configuration-Dimming Direction EF 18	maximize
(358)-Light configuration-Lichtfunktion G 18	108
(359)-Light configuration-Lichtfunktion H 18	254
(360)-Light configuration-Dimmwert GH 18	80
(361)-Light configuration-Dimming Direction GH 18	minimize
(362)-Light configuration-Lasttyp 19	14 - kombinierte Blink- Bremsleuchten
(363)-Light configuration-BAP Bitposition 19	92
(364)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	C7
(365)-Light configuration-Lichtfunktion A 19	0
(366)-Light configuration-Lichtfunktion B 19	0
(367)-Light configuration-Dimmwert AB 19	0
(368)-Light configuration-Lichtansteuerung HD AB 19	Always
(369)-Light configuration-Lichtfunktion C 19	136
(370)-Light configuration-Lichtfunktion D 19	112
(371)-Light configuration-Dimmwert CD 19	27
(372)-Light configuration-Dimming Direction CD 19	maximize
(373)-Light configuration-Lichtfunktion E 19	132
(374)-Light configuration-Lichtfunktion F 19	240
(375)-Light configuration-Dimmwert EF 19	18
(376)-Light configuration-Dimming Direction EF 19	minimize
(377)-Light configuration-Lichtfunktion G 19	229
(378)-Light configuration-Lichtfunktion H 19	146
(379)-Light configuration-Dimmwert GH 19	78
(380)-Light configuration-Dimming Direction GH 19	maximize
(382)-Light configuration-BAP Bitposition 20	0
(383)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	0C
(384)-Light configuration-Lichtfunktion A 20	172
(385)-Light configuration-Lichtfunktion B 20	78
(386)-Light configuration-Dimmwert AB 20	93
(387)-Light configuration-Lichtansteuerung HD AB 20	only_if_closed
(388)-Light configuration-Lichtfunktion C 20	0
(389)-Light configuration-Lichtfunktion D 20	136
(390)-Light configuration-Dimmwert CD 20	97
(391)-Light configuration-Dimming Direction CD 20	minimize
(392)-Light configuration-Lichtfunktion E 20	116
(393)-Light configuration-Lichtfunktion F 20	219
(394)-Light configuration-Dimmwert EF 20	78
(395)-Light configuration-Dimming Direction EF 20	maximize
(396)-Light configuration-Lichtfunktion G 20	231
(397)-Light configuration-Lichtfunktion H 20	49
(398)-Light configuration-Dimmwert GH 20	111
(399)-Light configuration-Dimming Direction GH 20	maximize
(401)-Light configuration-BAP Bitposition 21	92
(402)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	72
(403)-Light configuration-Lichtfunktion A 21	19
(404)-Light configuration-Lichtfunktion B 21	5
(405)-Light configuration-Dimmwert AB 21	0
(406)-Light configuration-Lichtansteuerung HD AB 21	Always
(407)-Light configuration-Lichtfunktion C 21	0
(408)-Light configuration-Lichtfunktion D 21	0
(409)-Light configuration-Dimmwert CD 21	0
(410)-Light configuration-Dimming Direction CD 21	maximize
(411)-Light configuration-Lichtfunktion E 21	188
(412)-Light configuration-Lichtfunktion F 21	225
(413)-Light configuration-Dimmwert EF 21	4
(414)-Light configuration-Dimming Direction EF 21	maximize
(415)-Light configuration-Lichtfunktion G 21	189
(416)-Light configuration-Lichtfunktion H 21	112
(417)-Light configuration-Dimmwert GH 21	127
(418)-Light configuration-Dimming Direction GH 21	minimize
(420)-Light configuration-BAP Bitposition 22	98
(421)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	0
(422)-Light configuration-Lichtfunktion A 22	49
(423)-Light configuration-Lichtfunktion B 22	106
(424)-Light configuration-Dimmwert AB 22	0
(425)-Light configuration-Lichtansteuerung HD AB 22	Always
(426)-Light configuration-Lichtfunktion C 22	146
(427)-Light configuration-Lichtfunktion D 22	78
(428)-Light configuration-Dimmwert CD 22	7
(429)-Light configuration-Dimming Direction CD 22	maximize
(430)-Light configuration-Lichtfunktion E 22	9
(431)-Light configuration-Lichtfunktion F 22	78
(432)-Light configuration-Dimmwert EF 22	64
(433)-Light configuration-Dimming Direction EF 22	minimize
(434)-Light configuration-Lichtfunktion G 22	147
(435)-Light configuration-Lichtfunktion H 22	146
(436)-Light configuration-Dimmwert GH 22	78
(437)-Light configuration-Dimming Direction GH 22	maximize
(438)-Light configuration-Lasttyp 23	17 - 4* 3W
(439)-Light configuration-BAP Bitposition 23	0
(440)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	CD
(441)-Light configuration-Lichtfunktion A 23	0
(442)-Light configuration-Lichtfunktion B 23	52
(443)-Light configuration-Dimmwert AB 23	78
(444)-Light configuration-Lichtansteuerung HD AB 23	Always
(445)-Light configuration-Lichtfunktion C 23	88
(446)-Light configuration-Lichtfunktion D 23	58
(447)-Light configuration-Dimmwert CD 23	52
(448)-Light configuration-Dimming Direction CD 23	maximize
(449)-Light configuration-Lichtfunktion E 23	215
(450)-Light configuration-Lichtfunktion F 23	88
(451)-Light configuration-Dimmwert EF 23	24
(452)-Light configuration-Dimming Direction EF 23	maximize
(453)-Light configuration-Lichtfunktion G 23	93
(454)-Light configuration-Lichtfunktion H 23	12
(455)-Light configuration-Dimmwert GH 23	0
(456)-Light configuration-Dimming Direction GH 23	maximize
(457)-Light configuration-Lasttyp 24	8 - allgemeine Glühlampe 12W
(458)-Light configuration-BAP Bitposition 24	8A
(459)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	1
(460)-Light configuration-Lichtfunktion A 24	0
(461)-Light configuration-Lichtfunktion B 24	0
(462)-Light configuration-Dimmwert AB 24	112
(463)-Light configuration-Lichtansteuerung HD AB 24	Always
(464)-Light configuration-Lichtfunktion C 24	255
(465)-Light configuration-Lichtfunktion D 24	255
(466)-Light configuration-Dimmwert CD 24	71
(467)-Light configuration-Dimming Direction CD 24	maximize
(468)-Light configuration-Lichtfunktion E 24	24
(469)-Light configuration-Lichtfunktion F 24	52
(470)-Light configuration-Dimmwert EF 24	0
(471)-Light configuration-Dimming Direction EF 24	maximize
(472)-Light configuration-Lichtfunktion G 24	0
(473)-Light configuration-Lichtfunktion H 24	0
(474)-Light configuration-Dimmwert GH 24	0
(475)-Light configuration-Dimming Direction GH 24	maximize
(476)-Light configuration-Lasttyp 25	not active
(477)-Light configuration-BAP Bitposition 25	0
(478)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	0
(479)-Light configuration-Lichtfunktion A 25	1
(480)-Light configuration-Lichtfunktion B 25	59
(481)-Light configuration-Dimmwert AB 25	12
(482)-Light configuration-Lichtansteuerung HD AB 25	Always
(483)-Light configuration-Lichtfunktion C 25	7
(484)-Light configuration-Lichtfunktion D 25	52
(485)-Light configuration-Dimmwert CD 25	8
(486)-Light configuration-Dimming Direction CD 25	maximize
(487)-Light configuration-Lichtfunktion E 25	96
(488)-Light configuration-Lichtfunktion F 25	108
(489)-Light configuration-Dimmwert EF 25	126
(490)-Light configuration-Dimming Direction EF 25	minimize
(491)-Light configuration-Lichtfunktion G 25	176
(492)-Light configuration-Lichtfunktion H 25	90
(493)-Light configuration-Dimmwert GH 25	18
(494)-Light configuration-Dimming Direction GH 25	minimize
(496)-Light configuration-BAP Bitposition 26	4B
(497)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	1C
(498)-Light configuration-Lichtfunktion A 26	1
(499)-Light configuration-Lichtfunktion B 26	146
(500)-Light configuration-Dimmwert AB 26	8
(501)-Light configuration-Lichtansteuerung HD AB 26	Always
(502)-Light configuration-Lichtfunktion C 26	208
(503)-Light configuration-Lichtfunktion D 26	8
(504)-Light configuration-Dimmwert CD 26	72
(505)-Light configuration-Dimming Direction CD 26	minimize
(506)-Light configuration-Lichtfunktion E 26	1
(507)-Light configuration-Lichtfunktion F 26	200
(508)-Light configuration-Dimmwert EF 26	0
(509)-Light configuration-Dimming Direction EF 26	maximize
(510)-Light configuration-Lichtfunktion G 26	146
(511)-Light configuration-Lichtfunktion H 26	90
(512)-Light configuration-Dimmwert GH 26	0
(513)-Light configuration-Dimming Direction GH 26	maximize
(515)-Light configuration-BAP Bitposition 27	0
(516)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	D4
(517)-Light configuration-Lichtfunktion A 27	157
(518)-Light configuration-Lichtfunktion B 27	97
(519)-Light configuration-Dimmwert AB 27	0
(520)-Light configuration-Lichtansteuerung HD AB 27	Always
(521)-Light configuration-Lichtfunktion C 27	1
(522)-Light configuration-Lichtfunktion D 27	6
(523)-Light configuration-Dimmwert CD 27	16
(524)-Light configuration-Dimming Direction CD 27	maximize
(525)-Light configuration-Lichtfunktion E 27	170
(526)-Light configuration-Lichtfunktion F 27	128
(527)-Light configuration-Dimmwert EF 27	20
(528)-Light configuration-Dimming Direction EF 27	maximize
(529)-Light configuration-Lichtfunktion G 27	52
(530)-Light configuration-Lichtfunktion H 27	8
(531)-Light configuration-Dimmwert GH 27	125
(532)-Light configuration-Dimming Direction GH 27	maximize
(533)-Light configuration-Lasttyp 28	1 - LED Tagfahrlichtmodul Versorgung
(534)-Light configuration-BAP Bitposition 28	0
(535)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	10
(536)-Light configuration-Lichtfunktion A 28	16
(537)-Light configuration-Lichtfunktion B 28	0
(538)-Light configuration-Dimmwert AB 28	6
(539)-Light configuration-Lichtansteuerung HD AB 28	only_if_closed
(540)-Light configuration-Lichtfunktion C 28	216
(541)-Light configuration-Lichtfunktion D 28	216
(542)-Light configuration-Dimmwert CD 28	32
(543)-Light configuration-Dimming Direction CD 28	minimize
(544)-Light configuration-Lichtfunktion E 28	96
(545)-Light configuration-Lichtfunktion F 28	1
(546)-Light configuration-Dimmwert EF 28	44
(547)-Light configuration-Dimming Direction EF 28	minimize
(548)-Light configuration-Lichtfunktion G 28	98
(549)-Light configuration-Lichtfunktion H 28	5
(550)-Light configuration-Dimmwert GH 28	55
(551)-Light configuration-Dimming Direction GH 28	minimize
(552)-Light configuration-Lasttyp 29	19 - 3* 5W
(553)-Light configuration-BAP Bitposition 29	10
(554)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	10
(555)-Light configuration-Lichtfunktion A 29	80
(556)-Light configuration-Lichtfunktion B 29	80
(557)-Light configuration-Dimmwert AB 29	120
(558)-Light configuration-Lichtansteuerung HD AB 29	Always
(559)-Light configuration-Lichtfunktion C 29	43
(560)-Light configuration-Lichtfunktion D 29	0
(561)-Light configuration-Dimmwert CD 29	44
(562)-Light configuration-Dimming Direction CD 29	maximize
(563)-Light configuration-Lichtfunktion E 29	16
(564)-Light configuration-Lichtfunktion F 29	5
(565)-Light configuration-Dimmwert EF 29	15
(566)-Light configuration-Dimming Direction EF 29	maximize
(567)-Light configuration-Lichtfunktion G 29	32
(568)-Light configuration-Lichtfunktion H 29	0
(569)-Light configuration-Dimmwert GH 29	19
(570)-Light configuration-Dimming Direction GH 29	maximize
(571)-Light configuration-Lasttyp 30	44 - LED Fußraum- oder -Innenleuchte
(572)-Light configuration-BAP Bitposition 30	5C
(573)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	1
(574)-Light configuration-Lichtfunktion A 30	15
(575)-Light configuration-Lichtfunktion B 30	92
(576)-Light configuration-Dimmwert AB 30	80
(577)-Light configuration-Lichtansteuerung HD AB 30	only_if_closed
(578)-Light configuration-Lichtfunktion C 30	224
(579)-Light configuration-Lichtfunktion D 30	112
(580)-Light configuration-Dimmwert CD 30	48
(581)-Light configuration-Dimming Direction CD 30	minimize
(582)-Light configuration-Lichtfunktion E 30	204
(583)-Light configuration-Lichtfunktion F 30	168
(584)-Light configuration-Dimmwert EF 30	76
(585)-Light configuration-Dimming Direction EF 30	maximize
(586)-Light configuration-Lichtfunktion G 30	255
(587)-Light configuration-Lichtfunktion H 30	0
(588)-Light configuration-Dimmwert GH 30	40
(589)-Light configuration-Dimming Direction GH 30	maximize
(591)-Light configuration-BAP Bitposition 31	0
(592)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	95
(593)-Light configuration-Lichtfunktion A 31	19
(594)-Light configuration-Lichtfunktion B 31	5
(595)-Light configuration-Dimmwert AB 31	104
(596)-Light configuration-Lichtansteuerung HD AB 31	Always
(597)-Light configuration-Lichtfunktion C 31	200
(598)-Light configuration-Lichtfunktion D 31	16
(599)-Light configuration-Dimmwert CD 31	0
(600)-Light configuration-Dimming Direction CD 31	maximize
(601)-Light configuration-Lichtfunktion E 31	52
(602)-Light configuration-Lichtfunktion F 31	219
(603)-Light configuration-Dimmwert EF 31	19
(604)-Light configuration-Dimming Direction EF 31	maximize
(605)-Light configuration-Lichtfunktion G 31	5
(606)-Light configuration-Lichtfunktion H 31	0
(607)-Light configuration-Dimmwert GH 31	47
(608)-Light configuration-Dimming Direction GH 31	maximize
(610)-Light configuration-BAP Bitposition 32	72
(611)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	BE
(612)-Light configuration-Lichtfunktion A 32	19
(613)-Light configuration-Lichtfunktion B 32	3
(614)-Light configuration-Dimmwert AB 32	0
(615)-Light configuration-Lichtansteuerung HD AB 32	Always
(616)-Light configuration-Lichtfunktion C 32	0
(617)-Light configuration-Lichtfunktion D 32	0
(618)-Light configuration-Dimmwert CD 32	0
(619)-Light configuration-Dimming Direction CD 32	maximize
(620)-Light configuration-Lichtfunktion E 32	188
(621)-Light configuration-Lichtfunktion F 32	225
(622)-Light configuration-Dimmwert EF 32	4
(623)-Light configuration-Dimming Direction EF 32	maximize
(624)-Light configuration-Lichtfunktion G 32	189
(625)-Light configuration-Lichtfunktion H 32	112
(626)-Light configuration-Dimmwert GH 32	52
(627)-Light configuration-Dimming Direction GH 32	maximize
(629)-Light configuration-BAP Bitposition 33	8
(630)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0
(631)-Light configuration-Lichtfunktion A 33	84
(632)-Light configuration-Lichtfunktion B 33	106
(633)-Light configuration-Dimmwert AB 33	0
(634)-Light configuration-Lichtansteuerung HD AB 33	Always
(635)-Light configuration-Lichtfunktion C 33	114
(636)-Light configuration-Lichtfunktion D 33	19
(637)-Light configuration-Dimmwert CD 33	5
(638)-Light configuration-Dimming Direction CD 33	maximize
(639)-Light configuration-Lichtfunktion E 33	0
(640)-Light configuration-Lichtfunktion F 33	19
(641)-Light configuration-Dimmwert EF 33	0
(642)-Light configuration-Dimming Direction EF 33	minimize
(643)-Light configuration-Lichtfunktion G 33	147
(644)-Light configuration-Lichtfunktion H 33	114
(645)-Light configuration-Dimmwert GH 33	19
(646)-Light configuration-Dimming Direction GH 33	maximize
(647)-Light configuration-Lasttyp 34	5 - LED Abblendlicht
(648)-Light configuration-BAP Bitposition 34	0
(649)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	CD
(650)-Light configuration-Lichtfunktion A 34	0
(651)-Light configuration-Lichtfunktion B 34	52
(652)-Light configuration-Dimmwert AB 34	19
(653)-Light configuration-Lichtansteuerung HD AB 34	Always
(654)-Light configuration-Lichtfunktion C 34	24
(655)-Light configuration-Lichtfunktion D 34	58
(656)-Light configuration-Dimmwert CD 34	52
(657)-Light configuration-Dimming Direction CD 34	maximize
(658)-Light configuration-Lichtfunktion E 34	114
(659)-Light configuration-Lichtfunktion F 34	19
(660)-Light configuration-Dimmwert EF 34	5
(661)-Light configuration-Dimming Direction EF 34	maximize
(662)-Light configuration-Lichtfunktion G 34	0
(663)-Light configuration-Lichtfunktion H 34	76
(664)-Light configuration-Dimmwert GH 34	32
(665)-Light configuration-Dimming Direction GH 34	minimize
(1)-Light sensor-Einschaltgrenze_CHO_LHO	30 lx
(2)-Light sensor-Daemmerungsgrenze; Hysterese_obergrenze	60 lx
(3)-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	110 lx
(4)-Light sensor-Helligkeitsgrenze_sehr_hell	100 lx
(5)-Light sensor-Helligkeitsgrenze_Licht__einschalten	60 lx
(6)-Light sensor-Helligkeitsgrenze_Licht_ausschalten	110 lx
(7)-Light sensor-Minimale_Beleuchtungsstaerke	0 lx
(8)-Light sensor-Maximale_Beleuchtungsstaerke	300 lx
(9)-Light sensor-Minimale_Ausgangsspannung	2000 mV
(10)-Light sensor-Maximale_Ausgangsspannung	4500 mV
(11)-Light sensor-Tunnel_einschalt_verzoegerung	2
(12)-Light sensor-ECE_Lichteinschaltschwelle	1000 lx
(13)-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	80
lower turn position	31.49 °
Position during interval mode	31.49 °
(1)-Production mode-Scheinwerferreinigung	not active
(2)-Production mode-Frontwischer deaktivieren	not active
(3)-Production mode-Heckwischer	not active
(4)-Production mode-Interior lighting	not active
(5)-Production mode-Aussenbeleuchtung	not active
(6)-Production mode-Access control	active
(7)-Production mode-Virtuel_pedal	not active
Read parameter address	FE 00 00
(1)-Rear Window Wiper-Komfortwischen Heck	active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
(3)-Rear Window Wiper-Automatisches Heckwischen	not active
(4)-Rear Window Wiper-Traenenwischen Heck	not active
(5)-Rear Window Wiper-Heckwischer Weiterlauf	not active
(6)-Rear Window Wiper-Kein automatisches Abparken	not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	5 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	5 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	3 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	1 s
(11)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s
(12)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16.0 s
(13)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active
Roller test bench mode; functional	not active
(1)-Seat fan charac. curve-Level_1_Sitz	25%
(2)-Seat fan charac. curve-Level_1_Lehne	30%
(3)-Seat fan charac. curve-Level_2_Sitz	25%
(4)-Seat fan charac. curve-Level_2_Lehne	30%
(5)-Seat fan charac. curve-Level_3_Sitz	53%
(6)-Seat fan charac. curve-Level_3_Lehne	58%
(7)-Seat fan charac. curve-Level_4_Sitz	53%
(8)-Seat fan charac. curve-Level_4_Lehne	58%
(9)-Seat fan charac. curve-Level_5_Sitz	80%
(10)-Seat fan charac. curve-Level_5_Lehne	85%
(11)-Seat fan charac. curve-Level_6_Sitz	80%
(12)-Seat fan charac. curve-Level_6_Lehne	85%
(1)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	18.50 °C
(2)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	20.00 °C
(3)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	22.00 °C
(4)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	24.00 °C
(5)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	26.00 °C
(6)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	28.00 °C
(7)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	30.00 °C
(8)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	32.00 °C
(9)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	34.00 °C
(10)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	36.00 °C
(11)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	38.00 °C
(12)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	40.00 °C
(13)-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s
(14)-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C
Service position	170.49 °
(1)-static AFS light-bei Rueckwaertsfahrt	OFF
(2)-static AFS light-Vorschrift	OFF
(3)-static AFS light-Lower speed threshold	0.00 km/h
(4)-static AFS light-Upper speed threshold	32.00 km/h
(5)-static AFS light-Steering wheel angle; offset	-0.25 °
(6)-static AFS light-Unterer Lenkradwinkel	30 °
(7)-static AFS light-Oberer Lenkradwinkel	90 °
(8)-static AFS light-Abdimmgeschwindigkeit	50.00 %/s
(9)-static AFS light-Maximaltemperatur	100.00 °C
(10)-static AFS light-obere Grenztemperatur	95.00 °C
(11)-static AFS light-untere Grenztemperatur	80.00 °C
Transport mode	active
(1)-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
(2)-Turn signal control-Komfortblinken Blinkzyklen	3
(3)-Turn signal control-Sonderfunktionen	not enabled
(4)-Turn signal control-Signalprioritaet fuer Blinker	SMLS
(5)-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte
(6)-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
(7)-Turn signal control-Komfortblinken	active
(8)-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	6.00%
(9)-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1
(10)-Turn signal control-Abbruch Komfortblinken	not active
upper turn position	170.49 °
(1)-Window heater-Temperaturabhaengige Einschaltzeit HSH	active
(2)-Window heater-Temperaturabhaengige Einschaltzeit FSH	active
(3)-Window heater-FSH Automatik	not active
(4)-Window heater-Heckscheibenheizung Zeitwert	600 s
(5)-Window heater-Running time of heated front window	600 s
(6)-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C
(7)-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C
(1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	5
(2)-Windshield wiper-SRA Verzoegerungszeit	0 ms
(3)-Windshield wiper-SRA Waschzeit	2000 ms
(4)-Windshield wiper-SRA Einweichpausenzeit	0 ms
(5)-Windshield wiper-SRA Nachwaschzeit	0 ms
(6)-Windshield wiper-SRA Pausenzeit	10000 ms
(7)-Windshield wiper-SRA bei Waschwassermangel	active
(8)-Windshield wiper-Frontwischer Referenzlauf	active
(9)-Windshield wiper-Variable Regensensoraktivierung	active
(10)-Windshield wiper-Wischer stop bei KL15 aus	active
(11)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
(12)-Windshield wiper-Regensensor aktivieren	Deactivating
(13)-Windshield wiper-Menuesteuerung Frontwischer	not active
(14)-Windshield wiper-Frontwischer Notlaufprogramm	active
(15)-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
(16)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
(17)-Windshield wiper-Traenenwischen Front Status	not active
(18)-Windshield wiper-Washer_Tipwiping_Variant	0
(19)-Windshield wiper-Adaptives Nachwischen bei SRA	not active
(20)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
(21)-Windshield wiper-Tippendes_Frontwaschen	not active
(22)-Windshield wiper-Frontwischer_Abtauposition	not active
(1)-Writing parameter-Parameter address	FE 00 00
(2)-Writing parameter-Value	130
(1)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed
(2)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door
(3)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1
(4)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed
(5)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door
(6)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1
(7)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed
(8)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door
(9)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1
(10)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed
(11)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door
(12)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1
(13)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed
(14)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door
(15)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1
(16)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed
(17)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door
(18)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1
(19)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed
(20)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door
(21)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1
(22)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed
(23)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door
(24)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1
(25)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed
(26)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door
(27)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1
(28)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed
(29)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door
(30)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1
(31)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed
(32)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door
(33)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1
(34)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed
(35)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door
(36)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1
(37)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed
(38)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door
(39)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1
(40)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed
(41)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door
(42)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1
(43)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed
(44)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door
(45)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1
(1)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0
(2)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed
(3)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0
(4)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0
(5)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed
(6)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0
(7)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0
(8)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed
(9)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0
(10)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0
(11)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed
(12)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0
(13)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0
(14)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed
(15)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0
(16)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0
(17)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed
(18)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0
(19)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0
(20)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed
(21)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0
(22)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0
(23)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed
(24)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0
(25)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0
(26)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed
(27)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0
(28)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0
(29)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed
(30)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0
(31)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0
(32)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed
(33)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0
(34)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0
(35)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed
(36)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0
(37)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0
(38)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed
(39)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0
(40)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0
(41)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed
(42)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0
(43)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0
(44)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed
(45)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0
(46)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0
(47)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed
(48)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0
(49)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0
(50)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed
(51)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0
(52)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0
(53)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed
(54)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0
(55)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0
(56)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed
(57)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0
(58)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0
(59)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed
(60)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0
(1)-debug_light_function-Adresse	0
(2)-debug_light_function-Bitmask	0
(3)-debug_light_function-Offset	0
(4)-debug_light_function-Divisor	0
(5)-debug_light_function-Polaritaet	0
(6)-debug_light_function-Activation	0
(7)-debug_light_function-WBT-Ausgabe	0
(1)-Innenbeleuchtung Abdimmen-x0	0 ms
(2)-Innenbeleuchtung Abdimmen-X1	200 ms
(3)-Innenbeleuchtung Abdimmen-X2	400 ms
(4)-Innenbeleuchtung Abdimmen-X3	600 ms
(5)-Innenbeleuchtung Abdimmen-X4	800 ms
(6)-Innenbeleuchtung Abdimmen-X5	1000 ms
(7)-Innenbeleuchtung Abdimmen-X6	1200 ms
(8)-Innenbeleuchtung Abdimmen-x7	1400 ms
(9)-Innenbeleuchtung Abdimmen-x8	1600 ms
(10)-Innenbeleuchtung Abdimmen-x9	1800 ms
(11)-Innenbeleuchtung Abdimmen-x10	2000 ms
(12)-Innenbeleuchtung Abdimmen-y0	100.00%
(13)-Innenbeleuchtung Abdimmen-Y1	100.00%
(14)-Innenbeleuchtung Abdimmen-Y2	95.00%
(15)-Innenbeleuchtung Abdimmen-Y3	80.00%
(16)-Innenbeleuchtung Abdimmen-Y4	40.00%
(17)-Innenbeleuchtung Abdimmen-Y5	20.00%
(18)-Innenbeleuchtung Abdimmen-Y6	10.00%
(19)-Innenbeleuchtung Abdimmen-y7	5.00%
(20)-Innenbeleuchtung Abdimmen-y8	3.00%
(21)-Innenbeleuchtung Abdimmen-y9	1.00%
(22)-Innenbeleuchtung Abdimmen-y10	0.00%
(1)-Innenbeleuchtung Fotosensor-x0	0
(2)-Innenbeleuchtung Fotosensor-X1	50
(3)-Innenbeleuchtung Fotosensor-X2	100
(4)-Innenbeleuchtung Fotosensor-X3	200
(5)-Innenbeleuchtung Fotosensor-X4	253
(6)-Innenbeleuchtung Fotosensor-X5	0
(7)-Innenbeleuchtung Fotosensor-X6	0
(8)-Innenbeleuchtung Fotosensor-x7	0
(9)-Innenbeleuchtung Fotosensor-x8	0
(10)-Innenbeleuchtung Fotosensor-x9	0
(11)-Innenbeleuchtung Fotosensor-x10	0
(12)-Innenbeleuchtung Fotosensor-y0	0 lx
(13)-Innenbeleuchtung Fotosensor-Y1	50 lx
(14)-Innenbeleuchtung Fotosensor-Y2	100 lx
(15)-Innenbeleuchtung Fotosensor-Y3	200
(16)-Innenbeleuchtung Fotosensor-Y4	500
(17)-Innenbeleuchtung Fotosensor-Y5	0
(18)-Innenbeleuchtung Fotosensor-Y6	0 lx
(19)-Innenbeleuchtung Fotosensor-y7	0 lx
(20)-Innenbeleuchtung Fotosensor-y8	0 lx
(21)-Innenbeleuchtung Fotosensor-y9	0 lx
(22)-Innenbeleuchtung Fotosensor-y10	0 lx
(1)-Innenbeleuchtung Hochdimmen-x0	0 ms
(2)-Innenbeleuchtung Hochdimmen-X1	200 ms
(3)-Innenbeleuchtung Hochdimmen-X2	400 ms
(4)-Innenbeleuchtung Hochdimmen-X3	600 ms
(5)-Innenbeleuchtung Hochdimmen-X4	800 ms
(6)-Innenbeleuchtung Hochdimmen-X5	1000 ms
(7)-Innenbeleuchtung Hochdimmen-X6	1200 ms
(8)-Innenbeleuchtung Hochdimmen-x7	1400 ms
(9)-Innenbeleuchtung Hochdimmen-x8	1600 ms
(10)-Innenbeleuchtung Hochdimmen-x9	1800 ms
(11)-Innenbeleuchtung Hochdimmen-x10	2000 ms
(12)-Innenbeleuchtung Hochdimmen-y0	0.00%
(13)-Innenbeleuchtung Hochdimmen-Y1	1.00%
(14)-Innenbeleuchtung Hochdimmen-Y2	3.00%
(15)-Innenbeleuchtung Hochdimmen-Y3	5.00%
(16)-Innenbeleuchtung Hochdimmen-Y4	11.00%
(17)-Innenbeleuchtung Hochdimmen-Y5	22.00%
(18)-Innenbeleuchtung Hochdimmen-Y6	40.00%
(19)-Innenbeleuchtung Hochdimmen-y7	80.00%
(20)-Innenbeleuchtung Hochdimmen-y8	95.00%
(21)-Innenbeleuchtung Hochdimmen-y9	100.00%
(22)-Innenbeleuchtung Hochdimmen-y10	100.00%
(1)-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
(2)-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
(3)-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
(4)-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
(5)-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
(6)-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
(7)-Innenbeleuchtung KL 58xd log Bus-y0	10
(8)-Innenbeleuchtung KL 58xd log Bus-Y1	10
(9)-Innenbeleuchtung KL 58xd log Bus-Y2	100
(10)-Innenbeleuchtung KL 58xd log Bus-Y3	150
(11)-Innenbeleuchtung KL 58xd log Bus-Y4	220
(12)-Innenbeleuchtung KL 58xd log Bus-Y5	253
(1)-Innenbeleuchtung KL 58xd max-x0	0 lx
(2)-Innenbeleuchtung KL 58xd max-X1	8 lx
(3)-Innenbeleuchtung KL 58xd max-X2	200 lx
(4)-Innenbeleuchtung KL 58xd max-X3	300 lx
(5)-Innenbeleuchtung KL 58xd max-X4	500 lx
(6)-Innenbeleuchtung KL 58xd max-y0	16
(7)-Innenbeleuchtung KL 58xd max-Y1	16
(8)-Innenbeleuchtung KL 58xd max-Y2	100
(9)-Innenbeleuchtung KL 58xd max-Y3	100
(10)-Innenbeleuchtung KL 58xd max-Y4	100
(1)-Innenbeleuchtung KL 58xd min-x0	0 lx
(2)-Innenbeleuchtung KL 58xd min-X1	8 lx
(3)-Innenbeleuchtung KL 58xd min-X2	220 lx
(4)-Innenbeleuchtung KL 58xd min-X3	300 lx
(5)-Innenbeleuchtung KL 58xd min-X4	500 lx
(6)-Innenbeleuchtung KL 58xd min-y0	6
(7)-Innenbeleuchtung KL 58xd min-Y1	6
(8)-Innenbeleuchtung KL 58xd min-Y2	100
(9)-Innenbeleuchtung KL 58xd min-Y3	100
(10)-Innenbeleuchtung KL 58xd min-Y4	100
(1)-Innenbeleuchtung KL 58xd PWM-x0	0
(2)-Innenbeleuchtung KL 58xd PWM-X1	10
(3)-Innenbeleuchtung KL 58xd PWM-X2	50
(4)-Innenbeleuchtung KL 58xd PWM-X3	100
(5)-Innenbeleuchtung KL 58xd PWM-X4	220
(6)-Innenbeleuchtung KL 58xd PWM-X5	253
(7)-Innenbeleuchtung KL 58xd PWM-y0	2.00%
(8)-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
(9)-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
(10)-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
(11)-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
(12)-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
(1)-Innenbeleuchtung KL 58xs max-x0	0 lx
(2)-Innenbeleuchtung KL 58xs max-X1	8 lx
(3)-Innenbeleuchtung KL 58xs max-X2	50 lx
(4)-Innenbeleuchtung KL 58xs max-X3	500 lx
(5)-Innenbeleuchtung KL 58xs max-y0	100
(6)-Innenbeleuchtung KL 58xs max-Y1	100
(7)-Innenbeleuchtung KL 58xs max-Y2	100
(8)-Innenbeleuchtung KL 58xs max-Y3	100
(1)-Innenbeleuchtung KL 58xs min-x0	0 lx
(2)-Innenbeleuchtung KL 58xs min-X1	8 lx
(3)-Innenbeleuchtung KL 58xs min-X2	50 lx
(4)-Innenbeleuchtung KL 58xs min-X3	510 lx
(5)-Innenbeleuchtung KL 58xs min-y0	6
(6)-Innenbeleuchtung KL 58xs min-Y1	6
(7)-Innenbeleuchtung KL 58xs min-Y2	100
(8)-Innenbeleuchtung KL 58xs min-Y3	100
(1)-Innenbeleuchtung KL 58xs PWM-x0	0.00%
(2)-Innenbeleuchtung KL 58xs PWM-X1	50.00%
(3)-Innenbeleuchtung KL 58xs PWM-X2	100.00%
(4)-Innenbeleuchtung KL 58xs PWM-y0	0.00%
(5)-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
(6)-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
(1)-Innenbeleuchtung KL 58xt max-x0	0 lx
(2)-Innenbeleuchtung KL 58xt max-X1	8 lx
(3)-Innenbeleuchtung KL 58xt max-X2	50 lx
(4)-Innenbeleuchtung KL 58xt max-X3	500 lx
(5)-Innenbeleuchtung KL 58xt max-y0	100
(6)-Innenbeleuchtung KL 58xt max-Y1	100
(7)-Innenbeleuchtung KL 58xt max-Y2	100
(8)-Innenbeleuchtung KL 58xt max-Y3	100
(1)-Innenbeleuchtung KL 58xt min-x0	0 lx
(2)-Innenbeleuchtung KL 58xt min-X1	8 lx
(3)-Innenbeleuchtung KL 58xt min-X2	50 lx
(4)-Innenbeleuchtung KL 58xt min-X3	500 lx
(5)-Innenbeleuchtung KL 58xt min-y0	6
(6)-Innenbeleuchtung KL 58xt min-Y1	6
(7)-Innenbeleuchtung KL 58xt min-Y2	100
(8)-Innenbeleuchtung KL 58xt min-Y3	100
(1)-Innenbeleuchtung KL 58xt PWM-x0	0.00%
(2)-Innenbeleuchtung KL 58xt PWM-X1	50.00%
(3)-Innenbeleuchtung KL 58xt PWM-X2	100.00%
(4)-Innenbeleuchtung KL 58xt PWM-y0	0.00%
(5)-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
(6)-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
(1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
(2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	2000 ms
(3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	3000 ms
(4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	4000 ms
(5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	5100 ms
(6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
(7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
(8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
(9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	40
(10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
(1)-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
(2)-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
(3)-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0	100
(7)-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
(1)-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
(3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
(4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
(5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
(6)-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
(7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
(8)-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
(9)-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
(10)-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
(11)-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
(12)-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
(13)-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
(14)-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
(15)-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
(16)-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
(17)-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
(18)-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
(19)-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
(1)-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
(3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
(4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
(5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
(6)-Leuchte11SHUTTER RB22-Dimmwert AB 11	127
(7)-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
(8)-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
(9)-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
(10)-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
(11)-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
(12)-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
(13)-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
(14)-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
(15)-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
(16)-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
(17)-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
(18)-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
(19)-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
(1)-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer
(2)-Leuchte12NL LB45-Lampendefektbitposition 12	38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
(4)-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12	not active
(6)-Leuchte12NL LB45-Dimmwert AB 12	100
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
(8)-Leuchte12NL LB45-Lichtfunktion C 12	not active
(9)-Leuchte12NL LB45-Lichtfunktion D 12	not active
(10)-Leuchte12NL LB45-Dimmwert CD 12	0
(11)-Leuchte12NL LB45-Dimming Direction CD 12	maximize
(12)-Leuchte12NL LB45-Lichtfunktion E 12	not active
(13)-Leuchte12NL LB45-Lichtfunktion F 12	not active
(14)-Leuchte12NL LB45-Dimmwert EF 12	0
(15)-Leuchte12NL LB45-Dimming Direction EF 12	maximize
(16)-Leuchte12NL LB45-Lichtfunktion G 12	not active
(17)-Leuchte12NL LB45-Lichtfunktion H 12	not active
(18)-Leuchte12NL LB45-Dimmwert GH 12	0
(19)-Leuchte12NL LB45-Dimming Direction GH 12	maximize
(1)-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer
(2)-Leuchte13NL RB5-Lampendefektbitposition 13	42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
(4)-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13	not active
(6)-Leuchte13NL RB5-Dimmwert AB 13	100
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
(8)-Leuchte13NL RB5-Lichtfunktion C 13	not active
(9)-Leuchte13NL RB5-Lichtfunktion D 13	not active
(10)-Leuchte13NL RB5-Dimmwert CD 13	0
(11)-Leuchte13NL RB5-Dimming Direction CD 13	maximize
(12)-Leuchte13NL RB5-Lichtfunktion E 13	not active
(13)-Leuchte13NL RB5-Lichtfunktion F 13	not active
(14)-Leuchte13NL RB5-Dimmwert EF 13	0
(15)-Leuchte13NL RB5-Dimming Direction EF 13	maximize
(16)-Leuchte13NL RB5-Lichtfunktion G 13	not active
(17)-Leuchte13NL RB5-Lichtfunktion H 13	not active
(18)-Leuchte13NL RB5-Dimmwert GH 13	0
(19)-Leuchte13NL RB5-Dimming Direction GH 13	maximize
(1)-Leuchte15AL RB44-Lasttyp 15	not active
(2)-Leuchte15AL RB44-Lampendefektbitposition 15	4F
(3)-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	25
(4)-Leuchte15AL RB44-Lichtfunktion A 15	Abbiegelicht rechts
(5)-Leuchte15AL RB44-Lichtfunktion B 15	not active
(6)-Leuchte15AL RB44-Dimmwert AB 15	100
(7)-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
(8)-Leuchte15AL RB44-Lichtfunktion C 15	not active
(9)-Leuchte15AL RB44-Lichtfunktion D 15	not active
(10)-Leuchte15AL RB44-Dimmwert CD 15	0
(11)-Leuchte15AL RB44-Dimming Direction CD 15	maximize
(12)-Leuchte15AL RB44-Lichtfunktion E 15	not active
(13)-Leuchte15AL RB44-Lichtfunktion F 15	not active
(14)-Leuchte15AL RB44-Dimmwert EF 15	0
(15)-Leuchte15AL RB44-Dimming Direction EF 15	maximize
(16)-Leuchte15AL RB44-Lichtfunktion G 15	not active
(17)-Leuchte15AL RB44-Lichtfunktion H 15	not active
(18)-Leuchte15AL RB44-Dimmwert GH 15	0
(19)-Leuchte15AL RB44-Dimming Direction GH 15	maximize
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active
(2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	39
(3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	17
(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Blinken links Hellphase
(5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	100
(7)-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
(8)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active
(9)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
(10)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
(11)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
(12)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active
(13)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
(14)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
(15)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
(16)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
(17)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
(18)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
(19)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active
(2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	43
(3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	19
(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Blinken rechts Hellphase
(5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active
(6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	100
(7)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
(8)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active
(9)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
(10)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
(11)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
(12)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active
(13)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
(14)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
(15)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
(16)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
(17)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
(18)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
(19)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
(1)-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten
(2)-Leuchte18BLK HLA60-Lampendefektbitposition 18	8
(3)-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16
(4)-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase
(5)-Leuchte18BLK HLA60-Lichtfunktion B 18	not active
(6)-Leuchte18BLK HLA60-Dimmwert AB 18	100
(7)-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
(8)-Leuchte18BLK HLA60-Lichtfunktion C 18	not active
(9)-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
(10)-Leuchte18BLK HLA60-Dimmwert CD 18	0
(11)-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
(12)-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
(13)-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
(14)-Leuchte18BLK HLA60-Dimmwert EF 18	0
(15)-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
(16)-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
(17)-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
(18)-Leuchte18BLK HLA60-Dimmwert GH 18	0
(19)-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
(1)-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten
(2)-Leuchte19BLK HRC31-Lampendefektbitposition 19	18
(3)-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18
(4)-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase
(5)-Leuchte19BLK HRC31-Lichtfunktion B 19	not active
(6)-Leuchte19BLK HRC31-Dimmwert AB 19	100
(7)-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
(8)-Leuchte19BLK HRC31-Lichtfunktion C 19	not active
(9)-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
(10)-Leuchte19BLK HRC31-Dimmwert CD 19	0
(11)-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
(12)-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
(13)-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
(14)-Leuchte19BLK HRC31-Dimmwert EF 19	0
(15)-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
(16)-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
(17)-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
(18)-Leuchte19BLK HRC31-Dimmwert GH 19	0
(19)-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
(1)-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
(2)-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
(3)-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1	not active
(6)-Leuchte1BLK VRB20-Dimmwert AB 1	100
(7)-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1	not active
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1	0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 1	not active
(13)-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
(14)-Leuchte1BLK VRB20-Dimmwert EF 1	0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
(17)-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
(18)-Leuchte1BLK VRB20-Dimmwert GH 1	0
(19)-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
(1)-Leuchte20BR LA71-Lasttyp 20	13 - Bremsleuchten
(2)-Leuchte20BR LA71-Lampendefektbitposition 20	10
(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	39
(4)-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
(5)-Leuchte20BR LA71-Lichtfunktion B 20	not active
(6)-Leuchte20BR LA71-Dimmwert AB 20	100
(7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte20BR LA71-Lichtfunktion D 20	Parklicht links (beidseitiges Parklicht aktiviert li & re)
(10)-Leuchte20BR LA71-Dimmwert CD 20	25
(11)-Leuchte20BR LA71-Dimming Direction CD 20	maximize
(12)-Leuchte20BR LA71-Lichtfunktion E 20	not active
(13)-Leuchte20BR LA71-Lichtfunktion F 20	not active
(14)-Leuchte20BR LA71-Dimmwert EF 20	0
(15)-Leuchte20BR LA71-Dimming Direction EF 20	maximize
(16)-Leuchte20BR LA71-Lichtfunktion G 20	not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20	not active
(18)-Leuchte20BR LA71-Dimmwert GH 20	0
(19)-Leuchte20BR LA71-Dimming Direction GH 20	maximize
(1)-Leuchte21BR RC8-Lasttyp 21	13 - Bremsleuchten
(2)-Leuchte21BR RC8-Lampendefektbitposition 21	20
(3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3A
(4)-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
(5)-Leuchte21BR RC8-Lichtfunktion B 21	not active
(6)-Leuchte21BR RC8-Dimmwert AB 21	100
(7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(9)-Leuchte21BR RC8-Lichtfunktion D 21	Parking light right
(10)-Leuchte21BR RC8-Dimmwert CD 21	25
(11)-Leuchte21BR RC8-Dimming Direction CD 21	maximize
(12)-Leuchte21BR RC8-Lichtfunktion E 21	not active
(13)-Leuchte21BR RC8-Lichtfunktion F 21	not active
(14)-Leuchte21BR RC8-Dimmwert EF 21	0
(15)-Leuchte21BR RC8-Dimming Direction EF 21	maximize
(16)-Leuchte21BR RC8-Lichtfunktion G 21	not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21	not active
(18)-Leuchte21BR RC8-Dimmwert GH 21	0
(19)-Leuchte21BR RC8-Dimming Direction GH 21	maximize
(1)-Leuchte22BR MA57-Lasttyp 22	34 - LED Bremsleuchten
(2)-Leuchte22BR MA57-Lampendefektbitposition 22	29
(3)-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
(4)-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
(5)-Leuchte22BR MA57-Lichtfunktion B 22	not active
(6)-Leuchte22BR MA57-Dimmwert AB 22	100
(7)-Leuchte22BR MA57-Lichtansteuerung HD AB 22	only_if_closed
(8)-Leuchte22BR MA57-Lichtfunktion C 22	not active
(9)-Leuchte22BR MA57-Lichtfunktion D 22	not active
(10)-Leuchte22BR MA57-Dimmwert CD 22	0
(11)-Leuchte22BR MA57-Dimming Direction CD 22	maximize
(12)-Leuchte22BR MA57-Lichtfunktion E 22	not active
(13)-Leuchte22BR MA57-Lichtfunktion F 22	not active
(14)-Leuchte22BR MA57-Dimmwert EF 22	0
(15)-Leuchte22BR MA57-Dimming Direction EF 22	maximize
(16)-Leuchte22BR MA57-Lichtfunktion G 22	not active
(17)-Leuchte22BR MA57-Lichtfunktion H 22	not active
(18)-Leuchte22BR MA57-Dimmwert GH 22	0
(19)-Leuchte22BR MA57-Dimming Direction GH 22	maximize
(1)-Leuchte23SL HLC10-Lasttyp 23	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte23SL HLC10-Lichtfunktion B 23	not active
(6)-Leuchte23SL HLC10-Dimmwert AB 23	100
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	only_if_closed
(8)-Leuchte23SL HLC10-Lichtfunktion C 23	not active
(9)-Leuchte23SL HLC10-Lichtfunktion D 23	not active
(10)-Leuchte23SL HLC10-Dimmwert CD 23	0
(11)-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23	not active
(13)-Leuchte23SL HLC10-Lichtfunktion F 23	not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23	0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23	not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23	not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23	0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
(1)-Leuchte24SL HRA65-Lasttyp 24	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte24SL HRA65-Lichtfunktion B 24	not active
(6)-Leuchte24SL HRA65-Dimmwert AB 24	100
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	only_if_closed
(8)-Leuchte24SL HRA65-Lichtfunktion C 24	not active
(9)-Leuchte24SL HRA65-Lichtfunktion D 24	not active
(10)-Leuchte24SL HRA65-Dimmwert CD 24	0
(11)-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24	not active
(13)-Leuchte24SL HRA65-Lichtfunktion F 24	not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24	0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24	not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24	not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24	0
(19)-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
(1)-Leuchte25KZL HA59-Lasttyp 25	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte25KZL HA59-Lampendefektbitposition 25	28
(3)-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
(4)-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte25KZL HA59-Lichtfunktion B 25	not active
(6)-Leuchte25KZL HA59-Dimmwert AB 25	100
(7)-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
(8)-Leuchte25KZL HA59-Lichtfunktion C 25	not active
(9)-Leuchte25KZL HA59-Lichtfunktion D 25	not active
(10)-Leuchte25KZL HA59-Dimmwert CD 25	0
(11)-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
(12)-Leuchte25KZL HA59-Lichtfunktion E 25	not active
(13)-Leuchte25KZL HA59-Lichtfunktion F 25	not active
(14)-Leuchte25KZL HA59-Dimmwert EF 25	0
(15)-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
(16)-Leuchte25KZL HA59-Lichtfunktion G 25	not active
(17)-Leuchte25KZL HA59-Lichtfunktion H 25	not active
(18)-Leuchte25KZL HA59-Dimmwert GH 25	0
(19)-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
(1)-Leuchte26NSL LA72-Lasttyp 26	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte26NSL LA72-Lampendefektbitposition 26	0C
(3)-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2E
(4)-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht auch wenn ein Anhaenger gesteckt
(5)-Leuchte26NSL LA72-Lichtfunktion B 26	not active
(6)-Leuchte26NSL LA72-Dimmwert AB 26	100
(7)-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	only_if_closed
(8)-Leuchte26NSL LA72-Lichtfunktion C 26	not active
(9)-Leuchte26NSL LA72-Lichtfunktion D 26	not active
(10)-Leuchte26NSL LA72-Dimmwert CD 26	0
(11)-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
(12)-Leuchte26NSL LA72-Lichtfunktion E 26	not active
(13)-Leuchte26NSL LA72-Lichtfunktion F 26	not active
(14)-Leuchte26NSL LA72-Dimmwert EF 26	0
(15)-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
(16)-Leuchte26NSL LA72-Lichtfunktion G 26	not active
(17)-Leuchte26NSL LA72-Lichtfunktion H 26	not active
(18)-Leuchte26NSL LA72-Dimmwert GH 26	0
(19)-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
(1)-Leuchte27NSL RC6-Lasttyp 27	not active
(2)-Leuchte27NSL RC6-Lampendefektbitposition 27	1C
(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	2F
(4)-Leuchte27NSL RC6-Lichtfunktion A 27	Nebelschlusslicht auch wenn ein Anhaenger gesteckt
(5)-Leuchte27NSL RC6-Lichtfunktion B 27	not active
(6)-Leuchte27NSL RC6-Dimmwert AB 27	100
(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	only_if_closed
(8)-Leuchte27NSL RC6-Lichtfunktion C 27	not active
(9)-Leuchte27NSL RC6-Lichtfunktion D 27	not active
(10)-Leuchte27NSL RC6-Dimmwert CD 27	0
(11)-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
(12)-Leuchte27NSL RC6-Lichtfunktion E 27	not active
(13)-Leuchte27NSL RC6-Lichtfunktion F 27	not active
(14)-Leuchte27NSL RC6-Dimmwert EF 27	0
(15)-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
(16)-Leuchte27NSL RC6-Lichtfunktion G 27	not active
(17)-Leuchte27NSL RC6-Lichtfunktion H 27	not active
(18)-Leuchte27NSL RC6-Dimmwert GH 27	0
(19)-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
(1)-Leuchte28RFL LC11-Lasttyp 28	not active
(2)-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
(3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
(4)-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
(5)-Leuchte28RFL LC11-Lichtfunktion B 28	not active
(6)-Leuchte28RFL LC11-Dimmwert AB 28	100
(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	only_if_closed
(8)-Leuchte28RFL LC11-Lichtfunktion C 28	not active
(9)-Leuchte28RFL LC11-Lichtfunktion D 28	not active
(10)-Leuchte28RFL LC11-Dimmwert CD 28	0
(11)-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
(12)-Leuchte28RFL LC11-Lichtfunktion E 28	not active
(13)-Leuchte28RFL LC11-Lichtfunktion F 28	not active
(14)-Leuchte28RFL LC11-Dimmwert EF 28	0
(15)-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
(16)-Leuchte28RFL LC11-Lichtfunktion G 28	not active
(17)-Leuchte28RFL LC11-Lichtfunktion H 28	not active
(18)-Leuchte28RFL LC11-Dimmwert GH 28	0
(19)-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
(1)-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
(3)-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
(4)-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
(5)-Leuchte29RFL RA64-Lichtfunktion B 29	not active
(6)-Leuchte29RFL RA64-Dimmwert AB 29	100
(7)-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	only_if_closed
(8)-Leuchte29RFL RA64-Lichtfunktion C 29	not active
(9)-Leuchte29RFL RA64-Lichtfunktion D 29	not active
(10)-Leuchte29RFL RA64-Dimmwert CD 29	0
(11)-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
(12)-Leuchte29RFL RA64-Lichtfunktion E 29	not active
(13)-Leuchte29RFL RA64-Lichtfunktion F 29	not active
(14)-Leuchte29RFL RA64-Dimmwert EF 29	0
(15)-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
(16)-Leuchte29RFL RA64-Lichtfunktion G 29	not active
(17)-Leuchte29RFL RA64-Lichtfunktion H 29	not active
(18)-Leuchte29RFL RA64-Dimmwert GH 29	0
(19)-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
(1)-Leuchte2SL VLB10-Lasttyp 2	8 - allgemeine Glühlampe 12W
(2)-Leuchte2SL VLB10-Lampendefektbitposition 2	35
(3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	26
(4)-Leuchte2SL VLB10-Lichtfunktion A 2	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte2SL VLB10-Lichtfunktion B 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte2SL VLB10-Dimmwert AB 2	100
(7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
(8)-Leuchte2SL VLB10-Lichtfunktion C 2	not active
(9)-Leuchte2SL VLB10-Lichtfunktion D 2	not active
(10)-Leuchte2SL VLB10-Dimmwert CD 2	0
(11)-Leuchte2SL VLB10-Dimming Direction CD 2	maximize
(12)-Leuchte2SL VLB10-Lichtfunktion E 2	not active
(13)-Leuchte2SL VLB10-Lichtfunktion F 2	not active
(14)-Leuchte2SL VLB10-Dimmwert EF 2	0
(15)-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
(16)-Leuchte2SL VLB10-Lichtfunktion G 2	not active
(17)-Leuchte2SL VLB10-Lichtfunktion H 2	not active
(18)-Leuchte2SL VLB10-Dimmwert GH 2	0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
(1)-Leuchte30FR LC72-Lasttyp 30	not active
(2)-Leuchte30FR LC72-Lampendefektbitposition 30	FF
(3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
(4)-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
(5)-Leuchte30FR LC72-Lichtfunktion B 30	not active
(6)-Leuchte30FR LC72-Dimmwert AB 30	0
(7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
(8)-Leuchte30FR LC72-Lichtfunktion C 30	not active
(9)-Leuchte30FR LC72-Lichtfunktion D 30	not active
(10)-Leuchte30FR LC72-Dimmwert CD 30	0
(11)-Leuchte30FR LC72-Dimming Direction CD 30	maximize
(12)-Leuchte30FR LC72-Lichtfunktion E 30	not active
(13)-Leuchte30FR LC72-Lichtfunktion F 30	not active
(14)-Leuchte30FR LC72-Dimmwert EF 30	0
(15)-Leuchte30FR LC72-Dimming Direction EF 30	maximize
(16)-Leuchte30FR LC72-Lichtfunktion G 30	not active
(17)-Leuchte30FR LC72-Lichtfunktion H 30	not active
(18)-Leuchte30FR LC72-Dimmwert GH 30	0
(19)-Leuchte30FR LC72-Dimming Direction GH 30	maximize
(1)-Leuchte31AMBL 1C61-Lasttyp 31	not active
(2)-Leuchte31AMBL 1C61-Lampendefektbitposition 31	FF
(3)-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	3
(4)-Leuchte31AMBL 1C61-Lichtfunktion A 31	Ambientelicht 1
(5)-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
(6)-Leuchte31AMBL 1C61-Dimmwert AB 31	0
(7)-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
(8)-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
(9)-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
(10)-Leuchte31AMBL 1C61-Dimmwert CD 31	0
(11)-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
(12)-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
(13)-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
(14)-Leuchte31AMBL 1C61-Dimmwert EF 31	0
(15)-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
(16)-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
(17)-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
(18)-Leuchte31AMBL 1C61-Dimmwert GH 31	0
(19)-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
(1)-Leuchte32AMBL 2C35-Lasttyp 32	not active
(2)-Leuchte32AMBL 2C35-Lampendefektbitposition 32	FF
(3)-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	4
(4)-Leuchte32AMBL 2C35-Lichtfunktion A 32	Ambientelicht 2
(5)-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
(6)-Leuchte32AMBL 2C35-Dimmwert AB 32	0
(7)-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
(8)-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
(9)-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
(10)-Leuchte32AMBL 2C35-Dimmwert CD 32	0
(11)-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
(12)-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
(13)-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
(14)-Leuchte32AMBL 2C35-Dimmwert EF 32	0
(15)-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
(16)-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
(17)-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
(18)-Leuchte32AMBL 2C35-Dimmwert GH 32	0
(19)-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
(1)-Leuchte33AMBL 3C36-Lasttyp 33	not active
(2)-Leuchte33AMBL 3C36-Lampendefektbitposition 33	FF
(3)-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	5
(4)-Leuchte33AMBL 3C36-Lichtfunktion A 33	Ambientelicht 3
(5)-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
(6)-Leuchte33AMBL 3C36-Dimmwert AB 33	0
(7)-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
(8)-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
(9)-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
(10)-Leuchte33AMBL 3C36-Dimmwert CD 33	0
(11)-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
(12)-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
(13)-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
(14)-Leuchte33AMBL 3C36-Dimmwert EF 33	0
(15)-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
(16)-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
(17)-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
(18)-Leuchte33AMBL 3C36-Dimmwert GH 33	0
(19)-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
(1)-Leuchte34AMBL 4C37-Lasttyp 34	not active
(2)-Leuchte34AMBL 4C37-Lampendefektbitposition 34	FF
(3)-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	6
(4)-Leuchte34AMBL 4C37-Lichtfunktion A 34	Ambientelicht 4
(5)-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
(6)-Leuchte34AMBL 4C37-Dimmwert AB 34	0
(7)-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
(8)-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
(9)-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
(10)-Leuchte34AMBL 4C37-Dimmwert CD 34	0
(11)-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
(12)-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
(13)-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
(14)-Leuchte34AMBL 4C37-Dimmwert EF 34	0
(15)-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
(16)-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
(17)-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
(18)-Leuchte34AMBL 4C37-Dimmwert GH 34	0
(19)-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
(1)-Leuchte3SL VRB21-Lasttyp 3	8 - allgemeine Glühlampe 12W
(2)-Leuchte3SL VRB21-Lampendefektbitposition 3	3F
(3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	46
(4)-Leuchte3SL VRB21-Lichtfunktion A 3	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte3SL VRB21-Lichtfunktion B 3	Parking light right
(6)-Leuchte3SL VRB21-Dimmwert AB 3	100
(7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
(8)-Leuchte3SL VRB21-Lichtfunktion C 3	not active
(9)-Leuchte3SL VRB21-Lichtfunktion D 3	not active
(10)-Leuchte3SL VRB21-Dimmwert CD 3	0
(11)-Leuchte3SL VRB21-Dimming Direction CD 3	maximize
(12)-Leuchte3SL VRB21-Lichtfunktion E 3	not active
(13)-Leuchte3SL VRB21-Lichtfunktion F 3	not active
(14)-Leuchte3SL VRB21-Dimmwert EF 3	0
(15)-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3	not active
(17)-Leuchte3SL VRB21-Lichtfunktion H 3	not active
(18)-Leuchte3SL VRB21-Dimmwert GH 3	0
(19)-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
(1)-Leuchte4TFL LB4-Lasttyp 4	not active
(2)-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
(3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	20
(4)-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights
(5)-Leuchte4TFL LB4-Lichtfunktion B 4	not active
(6)-Leuchte4TFL LB4-Dimmwert AB 4	100
(7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
(8)-Leuchte4TFL LB4-Lichtfunktion C 4	not active
(9)-Leuchte4TFL LB4-Lichtfunktion D 4	not active
(10)-Leuchte4TFL LB4-Dimmwert CD 4	0
(11)-Leuchte4TFL LB4-Dimming Direction CD 4	maximize
(12)-Leuchte4TFL LB4-Lichtfunktion E 4	not active
(13)-Leuchte4TFL LB4-Lichtfunktion F 4	not active
(14)-Leuchte4TFL LB4-Dimmwert EF 4	0
(15)-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
(16)-Leuchte4TFL LB4-Lichtfunktion G 4	not active
(17)-Leuchte4TFL LB4-Lichtfunktion H 4	not active
(18)-Leuchte4TFL LB4-Dimmwert GH 4	0
(19)-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
(1)-Leuchte5 TFL RB32-Lasttyp 5	not active
(2)-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
(3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	21
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights
(5)-Leuchte5 TFL RB32-Lichtfunktion B 5	not active
(6)-Leuchte5 TFL RB32-Dimmwert AB 5	100
(7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5	not active
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5	not active
(10)-Leuchte5 TFL RB32-Dimmwert CD 5	0
(11)-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5	not active
(13)-Leuchte5 TFL RB32-Lichtfunktion F 5	not active
(14)-Leuchte5 TFL RB32-Dimmwert EF 5	0
(15)-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
(16)-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
(17)-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
(18)-Leuchte5 TFL RB32-Dimmwert GH 5	0
(19)-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
(1)-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
(2)-Leuchte6ABL LC5-Lampendefektbitposition 6	36
(3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
(4)-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
(5)-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6	127
(7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
(8)-Leuchte6ABL LC5-Lichtfunktion C 6	not active
(9)-Leuchte6ABL LC5-Lichtfunktion D 6	not active
(10)-Leuchte6ABL LC5-Dimmwert CD 6	0
(11)-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
(12)-Leuchte6ABL LC5-Lichtfunktion E 6	not active
(13)-Leuchte6ABL LC5-Lichtfunktion F 6	not active
(14)-Leuchte6ABL LC5-Dimmwert EF 6	0
(15)-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
(16)-Leuchte6ABL LC5-Lichtfunktion G 6	not active
(17)-Leuchte6ABL LC5-Lichtfunktion H 6	not active
(18)-Leuchte6ABL LC5-Dimmwert GH 6	0
(19)-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
(1)-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
(2)-Leuchte7ABL RB1-Lampendefektbitposition 7	40
(3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
(4)-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
(5)-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7	127
(7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
(8)-Leuchte7ABL RB1-Lichtfunktion C 7	not active
(9)-Leuchte7ABL RB1-Lichtfunktion D 7	not active
(10)-Leuchte7ABL RB1-Dimmwert CD 7	0
(11)-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
(12)-Leuchte7ABL RB1-Lichtfunktion E 7	not active
(13)-Leuchte7ABL RB1-Lichtfunktion F 7	not active
(14)-Leuchte7ABL RB1-Dimmwert EF 7	0
(15)-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
(16)-Leuchte7ABL RB1-Lichtfunktion G 7	not active
(17)-Leuchte7ABL RB1-Lichtfunktion H 7	not active
(18)-Leuchte7ABL RB1-Dimmwert GH 7	0
(19)-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
(1)-Leuchte8FL LB39-Lasttyp 8	not active
(2)-Leuchte8FL LB39-Lampendefektbitposition 8	37
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C
(4)-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam
(5)-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell
(6)-Leuchte8FL LB39-Dimmwert AB 8	100
(7)-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
(8)-Leuchte8FL LB39-Lichtfunktion C 8	not active
(9)-Leuchte8FL LB39-Lichtfunktion D 8	not active
(10)-Leuchte8FL LB39-Dimmwert CD 8	0
(11)-Leuchte8FL LB39-Dimming Direction CD 8	maximize
(12)-Leuchte8FL LB39-Lichtfunktion E 8	not active
(13)-Leuchte8FL LB39-Lichtfunktion F 8	not active
(14)-Leuchte8FL LB39-Dimmwert EF 8	0
(15)-Leuchte8FL LB39-Dimming Direction EF 8	maximize
(16)-Leuchte8FL LB39-Lichtfunktion G 8	not active
(17)-Leuchte8FL LB39-Lichtfunktion H 8	not active
(18)-Leuchte8FL LB39-Dimmwert GH 8	0
(19)-Leuchte8FL LB39-Dimming Direction GH 8	maximize
(1)-Leuchte9FL RB2-Lasttyp 9	not active
(2)-Leuchte9FL RB2-Lampendefektbitposition 9	41
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D
(4)-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam
(5)-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell
(6)-Leuchte9FL RB2-Dimmwert AB 9	100
(7)-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
(8)-Leuchte9FL RB2-Lichtfunktion C 9	not active
(9)-Leuchte9FL RB2-Lichtfunktion D 9	not active
(10)-Leuchte9FL RB2-Dimmwert CD 9	0
(11)-Leuchte9FL RB2-Dimming Direction CD 9	maximize
(12)-Leuchte9FL RB2-Lichtfunktion E 9	not active
(13)-Leuchte9FL RB2-Lichtfunktion F 9	not active
(14)-Leuchte9FL RB2-Dimmwert EF 9	0
(15)-Leuchte9FL RB2-Dimming Direction EF 9	maximize
(16)-Leuchte9FL RB2-Lichtfunktion G 9	not active
(17)-Leuchte9FL RB2-Lichtfunktion H 9	not active
(18)-Leuchte9FL RB2-Dimmwert GH 9	0
(19)-Leuchte9FL RB2-Dimming Direction GH 9	maximize
(1)-Leuchten14AL LB6-Lasttyp 14	not active
(2)-Leuchten14AL LB6-Lampendefektbitposition 14	4E
(3)-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	24
(4)-Leuchten14AL LB6-Lichtfunktion A 14	Abbiegelicht links
(5)-Leuchten14AL LB6-Lichtfunktion B 14	not active
(6)-Leuchten14AL LB6-Dimmwert AB 14	100
(7)-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
(8)-Leuchten14AL LB6-Lichtfunktion C 14	not active
(9)-Leuchten14AL LB6-Lichtfunktion D 14	not active
(10)-Leuchten14AL LB6-Dimmwert CD 14	0
(11)-Leuchten14AL LB6-Dimming Direction CD 14	maximize
(12)-Leuchten14AL LB6-Lichtfunktion E 14	not active
(13)-Leuchten14AL LB6-Lichtfunktion F 14	not active
(14)-Leuchten14AL LB6-Dimmwert EF 14	0
(15)-Leuchten14AL LB6-Dimming Direction EF 14	maximize
(16)-Leuchten14AL LB6-Lichtfunktion G 14	not active
(17)-Leuchten14AL LB6-Lichtfunktion H 14	not active
(18)-Leuchten14AL LB6-Dimmwert GH 14	0
(19)-Leuchten14AL LB6-Dimming Direction GH 14	maximize
(1)-LIN-Mirrormode-mirror_mode_typ	not active
(2)-LIN-Mirrormode-Data bus LIN 1	active
(3)-LIN-Mirrormode-Data bus LIN 2	active
(4)-LIN-Mirrormode-Data bus LIN 3	active
(5)-LIN-Mirrormode-Data bus LIN 4	active
(6)-LIN-Mirrormode-Data bus LIN 5	active
(7)-LIN-Mirrormode-Data bus LIN 6	active
(1)-LuB Lichtrouter Kennlinie 1-x0	0.00%
(2)-LuB Lichtrouter Kennlinie 1-X1	5.00%
(3)-LuB Lichtrouter Kennlinie 1-X2	50.00%
(4)-LuB Lichtrouter Kennlinie 1-X3	75.00%
(5)-LuB Lichtrouter Kennlinie 1-X4	110
(6)-LuB Lichtrouter Kennlinie 1-X5	126.5
(7)-LuB Lichtrouter Kennlinie 1-y0	0.00%
(8)-LuB Lichtrouter Kennlinie 1-Y1	6.00%
(9)-LuB Lichtrouter Kennlinie 1-Y2	16.00%
(10)-LuB Lichtrouter Kennlinie 1-Y3	30.00%
(11)-LuB Lichtrouter Kennlinie 1-Y4	60.00%
(12)-LuB Lichtrouter Kennlinie 1-Y5	100.00%
(1)-Personalisierung-Personalisierung_aktiv	active
(2)-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar	active
(3)-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active
(4)-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active
(5)-Personalisierung-Anzahl_Benutzerkonten	4
(6)-Personalisierung-Automatische_ Schluesselzuordnung	active
(7)-Personalisierung-PSO_FSG_Setup2_Bit_0	active
(8)-Personalisierung-PSO_FSG_Setup2_Bit_1	active
(9)-Personalisierung-PSO_FSG_Setup2_Bit_2	active
(10)-Personalisierung-PSO_FSG_Setup2_Bit_3	active
(11)-Personalisierung-PSO_FSG_Setup2_Bit_4	active
(12)-Personalisierung-PSO_FSG_Setup2_Bit_5	active
(13)-Personalisierung-PSO_FSG_Setup2_Bit_6	active
(14)-Personalisierung-PSO_FSG_Setup2_Bit_7	active
(1)-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	active
(2)-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active
(1)-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
(2)-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
(3)-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
(4)-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
(5)-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
(6)-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
(7)-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
(8)-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
(9)-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
(10)-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
I did send this in for uploading.
is there an easy way to remap adapt channels? or do I really have to go line by line for 1700+ lines???
   #38
What I would do is make another map from the new one and use a file comparison utility to see what's different.
This should work well, but there are of course many others:
http://www.grigsoft.com/wincmp3.htm
DV52
C?ID=194404
new bcm has arrived, confirming it has pins that mine does not. not hard to swap part if you know how to, and now I know how.
Iceraver, As I said in one of my previous replies - installing a new BCM has its own problems!
If you make a "Standard" Adaptation channel map of the new BCM in CSV format (the same as the admap you made and posted for the old BCM) and post it here, I will attempt to do a side-by-side comparison for you.
Quick look at auto-scan - the component protection DTC will be problematic - perhaps others can suggest an alternative, but the only way that I know of deleting this error is through FAZIT (i.e. dealer tool)
IceRacerX
C?ID=275929
SOOOOO.... the fog lights work..:D. the rest of the car is a mess tho...:banghead::facepalm:
does VCDS have the 'factory" lock available like the mk6 guys? I have found a few threads that guys have done what I am attempting, just on different cars.
polo:http://www.team-bhp.com/forum/diy-d...lo-diy-upgrading-bcm-body-control-module.html
mk6: http://www.vwgolf.net.au/showthread.php?14428-DIY-OEM-Bixenon-Headlights-CECM-Upgrade-and-AFS
"fatory mode" does not come up in VCDS, I even updated to BETA
new "beta" scans here:
Sunday,22,May,2016,11:37:00:58344
VCDS Version: 16.5.0.4
Data version: 20160506 DS251
VIN: 3VWA17AU1GM516884   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWA17AU1GM516884   Mileage: 3270km-2031miles
Address 01: Engine (J623-CXBA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091100122424002F0000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3FA3BB32A69E54BB42-806A
20250 - Software Incompatibility with Body Control Module
          U0322 00 [038] - -
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:54
                    Coolant temperature: 29 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 11.718 V
                    Engine; operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 101 kPa
                    Lambda probe voltage; bank 1; probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 570.0 kPa
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:10
                    Coolant temperature: 75 °C
                    Intake air temperature: 59 °C
                    Voltage terminal 30: 12.324 V
                    Drivetrain coordinator; ACC fault status-ACC: Not active; although TSK passive
                    Drivetrain coordinator; ACC fault status-Start and stop request: Set at stopping speed
                    Drivetrain coordinator; ACC fault status-Bit 2: Not transmitted simultaneously
                    Drivetrain coordinator; ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
                    Drivetrain coordinator; ACC fault status-Bit 4: Not active when limiter active
                    Drivetrain coordinator; ACC fault status-Bit 5: Transmits no undefined signals
                    Drivetrain coordinator; ACC fault status-Bit 6: Not active when main switch off
                    Drivetrain coordinator; ACC fault status-Bit 7: Not active when driver braking
                    Drivetrain coordinator; ACC fault status-Bit 8: Not active during the EPB emer. braking
                    Drivetrain coordinator; brake fault status-ESP: no error
                    Drivetrain coordinator; brake fault status-Deceleration controller: Available
                    Drivetrain coordinator; brake fault status-TSK/ESP handshake: no error
                    Drivetrain coordinator; brake fault status-Bit 1: no error
                    Drivetrain coordinator; brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
                    Drivetrain coordinator; brake fault status-Bit 4: No indication of TSK message consistency error
                    Drivetrain coordinator; brake fault status-Bit 6: Automatic engagement OK
                    Drivetrain coordinator; brake fault status: 4
                    Drivetrain coordinator; brake function status-Parking Brake: not active
                    Drivetrain coordinator; brake function status-ACC: Not braking
                    Drivetrain coordinator; brake function status-ESP: Not invoking TSK braking
                    Drivetrain coordinator; brake function status-Driver: Not braking
                    Drivetrain coordinator; brake function status-Hill descent control: passive
                    Drivetrain coordinator; brake function status-ASR: no intervention
                    Drivetrain coordinator; brake function status-MSR: no intervention
                    Drivetrain coordinator; brake function status-ADS: no intervention
                    Drivetrain coordinator; brake function status-ABS: no intervention
                    Drivetrain coordinator; brake function status-EDL: no intervention
                    Drivetrain coordinator; brake function status-ASP: no intervention
                    Drivetrain coordinator; brake function status-AWV2: No warning pressure
                    Drivetrain coordinator; brake function status-Bit 4: no intervention
                    Drivetrain coordinator; brake function status-Bit 11: not passively cycled
                    Drivetrain coordinator; brake function status-Bit 12: not passively cycled
                    Drivetrain coordinator; brake function status-Bit 13: Standstill not detected
15236 - Please Check Fault Codes in Body Control / Central Electric Module
          U1021 00 [038] - -
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:59
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 27.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 17 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: Yes
                    STATE_ERR_ABC_PRED: 0
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 53165000000809
   Coding: 04FA6AA124210972007F020881C7292056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 4BBB9FE2E226F81BDE-801E
0297 - Steering angle sensor
          B1168 16 [137] - Voltage Too Low
                    Fault Frequency: 7
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:10
8304 - Databus
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:59
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:20
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:20
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Revision: 00001K01
   Coding: 02020004200100000000000000000002
   ROD: EV_ACManueBHBVW37X.rod
   VCID: 052F69DA84C2CE6B48-8050
329220 - Motor for Air Distribution Flap
          B109D 71 [008] - Actuator stuck
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:44
                    Voltage terminal 30: 11.0 V
                    Outside air temperature: 30.5 °C
                    Air distribution flap; actual value: 172
                    Air distribution flap; actual value: 54.0 %
                    Air distribution flap; specified value: 26
459527 - Databus
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:55
   Part No SW: 5Q0 937 087 AB    HW: 5Q0 937 087 AB
   Revision: --------    Serial number: 86580801160508
   Coding: 000008424041805969E44000000407001000050000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 7BDB0F22F206889B2E-802E
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:24:42
15361024 - Component Protection
          U1101 00 [009] - Active
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:24:42
206085 - Remote Control
          B1311 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:24:42
   Serial number: 003GCR03KV3T
   VCID: 47B3A3D2FE4E1C7BFA-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003ZUE32
   Coding: 303133
   Subsystem 2 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 35700000000C8064E61N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 35800000000E172DF61W
   Subsystem 4 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3510002C71CF1D1522C8
   Subsystem 5 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3520002AB1CF1D2212A6
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3550002C91D1B621A252
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3560002C71D1B62071B2
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151102500369
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3A55CA26BDBC719375-806E
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BB51102A180CF0502086A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 256F095A2402EE6B28-8070
   Part No SW: 5Q0 907 530 AH    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2246
   Revision: --------    Serial number: 24101510800925
   Coding: 0101000830085900FB000008080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti.rod
   VCID: 77D31312CE2EACFB4A-8022
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150001515720025325
   Coding: 30FFFF
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:29
                    Supply voltage; Terminal 30: 11.7 V
                    Terminal 15: On
   Component: TSG FS        010 0031
   Serial number: 9601152730397
   Coding: 003103205000040000000000
   Shop #: WSC 12345 123 12345
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000002389556
   Coding: 011000
65588 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 176
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:17:37
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0102
   ROD: EV_SteerAssisMQB_VW37.rod
   VCID: 44A9B4DECF7837631F-8010
16130 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 0
                    Motor status: 00
                    Supply voltage: 12.50 V
                    Temperature: 42.0 °C
                    KFC: 3F
                    KFA: 00 02
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 12.50 V
                    uAdSensI_SwitchedKl30_xdu16: 12.49 V
                    NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
                    NoInitCause_RackPos_Rohwert: 00 00
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_KMN_RACKPOS_SET: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_WHLSPDPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Component: TSG BFS       010 0031
   Serial number: 9901153100925
   Coding: 003103205C00040000000000
   Shop #: WSC 12345 813 111111
   VCID: 46ADAED6F944057301-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000002391317
   Coding: 091000
65591 - Motor for Window Regulator
          B1487 4B [008] - Over temperature
                    Reset counter: 212
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:23:09
                    Reset counter: 184
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:21:42
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730200FF00000051220001001808001F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6CF93C7E87681F23B7-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9RJW001SF
16 Faults Found:
1600 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
                    Voltage terminal 30: 12.5 V
1659 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
1660 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
1661 - Data Set Implausible
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
          B11CF 53 [009] - Deactivated
                    Reset counter: 162
                    Mileage: 2932 km
                    Date: 2016.05.11
                    Time: 20:32:00
                    Voltage terminal 30: 13.6 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Channel selection for satellite radio: 0
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 127 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Tuner für Satellitenradio; Status der Voraktivierung: 05
                    SDARS_tuner_status_2-Tuner für Satellitenradio; Wert der Voraktivierung: 05
6920 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
                    Voltage terminal 30: 11.7 V
6921 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
6924 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
6925 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
6926 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
7169 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 01:03:26
                    Voltage terminal 30: 13.5 V
                    BAP-BAP_Function_ID: 0D
7176 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
                    BAP-BAP_Function_ID: 02
7177 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
7180 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
7181 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
7182 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730202C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43ABB7C2CA76305B26-8016
13636864 - Mobile Online Services
          B149A F0 [008] - Vehicle Condition Report
                    Reset counter: 201
                    Mileage: 2877 km
                    Date: 2016.05.10
                    Time: 16:10:58
End-------------------------(Elapsed Time: 02:34)--------------------------
adaptation log:
Sunday,22,May,2016,11:37:11:58344
VIN: 3VWA17AU1GM516884   License Plate: BETA AUTOSCN
Mileage: 3270km-2031mi   Repair Order:
   Revision: --H13---
          U0322 00 [038] - -
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:54
                    T_AST_SAE: 0 s
17178 - Databus
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:10
          U1021 00 [038] - -
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:59
                    ECU_STATE: ENG_STOP
                    T_ES: 17 min
                    Fault Frequency: 7
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:10
8304 - Databus
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:59
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:20
                    Reset counter: 183
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:20
   Revision: 00001K01
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:44
459527 - Databus
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:55
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:24:42
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:24:42
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:24:42
   Occupant Detection:
   Coding: 303133
   Coding: 0400
   Coding: 30FFFF
                    Reset counter: 184
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:01:29
                    Terminal 15: On
   Coding: 011000
                    Reset counter: 176
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:17:37
   Coding: 0102
                    Reset counter: 0
                    Motor status: 00
                    KFC: 3F
                    KFA: 00 02
   Coding: 091000
                    Reset counter: 212
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:23:09
                    Reset counter: 184
                    Mileage: 3068 km
                    Date: 2016.05.16
                    Time: 05:21:42
16 Faults Found:
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
          B2012 00 [008] -  -
                    Reset counter: 207
                    Mileage: 3006 km
                    Date: 2016.05.13
                    Time: 21:12:48
                    Reset counter: 162
                    Mileage: 2932 km
                    Date: 2016.05.11
                    Time: 20:32:00
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:18:57
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 01:03:26
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
          U1111 00 [008] - -
                    Reset counter: 224
                    Mileage: 3270 km
                    Date: 2016.05.21
                    Time: 00:19:00
                    Reset counter: 201
                    Mileage: 2877 km
                    Date: 2016.05.10
                    Time: 16:10:58
I know there are a lot of faults, I disconnected the battery.
something to note, mirror dip also works, no high beams or drls, interior HUD and display is very dim.
biggest concern for me is this "factory mode" that I cannot find in the admap.
again thanks for all the help:thumbs:
