Results 1 to 10 of 12
Thread: Block 81
    May 2016
    Block 81
    I have a mkv r32 turbo, just purchased the wifi version. I not able to view block 81, any help is appreciated.
    Lansdale, PA
    How are you accessing it?
    Did you click [Select] [01-Engine] [Functions] [Advanced Measuring values] ?
    May 2016
    Quote Originally Posted by Santos View Post
    I accesses as stated, then it goes to page with loc 1-1 etc. Nothing happens from here.
    Scroll down to locations that start with 81 and tick the check-boxes next them, then click [Submit].
  5. Likes Jetta ,97 liked this post
    May 2016
    I did scroll to loc 81 and selected it. No information.
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by zdive65 View Post
    Custom Tune ECU maybe problem?
    Immobilizer/ECU
    email : marinmm2001@gmail.com
    Lansdale, PA
    what device are you using to view VCDS-Mobile? Can you post an autoscan from the vehicle?
    Block 081 on my chipped MKV GTI. The tuner had some fun with the fields :
  9. Likes Uwe liked this post
  10. #8
    May 2016
    I hex net connected my wifes stock tiguan last night. Same isdue, no data for block 81
  11. #9
    May 2016
    WVWKC71KX8W046730
    Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 47 52 55 56 65
    VIN: WVWKC71KX8W046730
    01-Engine -- Status: Communication Error 1010
    02-Auto Trans -- Status: Communication Error 1000
    03-ABS Brakes -- Status: Communication Error 1010
    15-Airbags -- Status: Communication Error 1000
    22-AWD -- Status: Communication Error 1010
    44-Steering Assist -- Status: Communication Error 1000
    55-Xenon Range -- Status: Malfunction 0010
    Address 01: Engine	Labels: None
    	Part No SW: 022 906 032 KE	HW: 022906032GP
    	Component: C2-S4-R32T      G  1 2.28
    	Revision: 1QH02---	Serial Number: VWX7Z0G53NK88N
    	Coding: 0000178
    	Shop #: WSC 00001 000 00000
    	VCID: 58F31B63BF047B6F2673CA33A2-800D
    009267 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
    	P2433 - 001 - Short to Plus - MIL ON
    005253 - Secondary Air Injection Valve 2 (N320)
    	P1485 - 004 - Open Circuit - MIL ON
    005170 - Secondary Air Injection Solenoid Valve (N112)
    	P1432 - 004 - Open Circuit - MIL ON
    001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
    	P0660 - 004 - Elect. Malfunction
    Address 02: Auto Trans	Labels: None
    	Part No SW: 02E 300 011 CC	HW: 02E927770AD
    	Component: GSG DSG         082  1405
    	Revision: 05108020	Serial Number: 00001008310253
    	Shop #: WSC 04940 001 00001
    	VCID: 52E7E94B99F8513FD83788CBF4-8007
    No fault codes found.
    Address 03: ABS Brakes	Labels: None
    	Part No SW: 1K0 907 379 AB	HW: 1K0907379AB
    	Component: ESP 4MOTION MK60     0102
    	Revision: 00H13001
    	Coding: 0021128
    	Shop #: WSC 01279 785 00200
    	VCID: 72A749CB39B8313F3877E84B14-8027
    Address 08: Auto HVAC	Labels: None
    	Part No SW: 1K0 907 044 BS	HW: 1K0907044BS
    	Component: ClimatronicPQ35 120  1111
    	Revision: 00120021	Serial Number: 00000000000000
    	VCID: 79B57EE764CE426779BD37BFF1-802C
    Address 09: Cent. Elect.	Labels: None
    	Part No SW: 3C0 937 049 AJ	HW: 3C0937049AJ
    	Component: Bordnetz-SG     H54  2202
    	Revision: 00H54000	Serial Number: 00000007287340
    	Coding: E68F8F214004150047140000001400000008730B5C000100000000000000
    	Shop #: WSC 22228 444 53823
    	VCID: 71A546C73CBE0A27C16DDF5F19-8024
    	Subsystem 1 - 	Part No SW: 1K1-955-119-E
    	Component: Wischer 250607 021   0501
    	Coding: 0038805
    	Subsystem 2 - 	Part No SW: 1K0-955-559-AF
    	Component: RLS     030707 046   0204
    	Coding: 0207646
    10 Faults Found:
    02398 - Control Circuit for Rear Windshield Washer Pump
    00906 - Horn (H1)
    Address 0F: Digital Radio	Labels: None
    	Part No SW: 8E0 035 593 H	HW: 8E0035593H
    	Component: SDAR SIRIUS     H06  0080
    	Revision: 00000000	Serial Number: AUZ4Z7G0096188
    	VCID: 2E1F9DBBED0055DF9CCFFC3B80-807B
    Address 15: Airbags	Labels: None
    	Part No SW: 1K0 909 605 AB	HW: 1K0959339G
    	Component: 6T AIRBAG VW8R  034  8000
    	Revision: 05034000	Serial Number: 003B6D0912GI
    	Coding: 0013908
    	Shop #: WSC 01269 785 00200
    	VCID: 6C9B57B31B9CE7CFF23BA603A6-8039
    	Subsystem 1 - 	Part No SW: 1K0-959-339-G
    	Component: BF-Gewichtsens. 007  0007
    Address 16: Steering wheel	Labels: None
    	Part No SW: 1K0 953 549 AQ	HW: 1K0953549AQ
    	Component: J0527           036  0070
    	Coding: 0012122
    	VCID: 814596078C1E9AA7B10D8F1F49-80D4
    	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
    	Component: E0221           002  0010
    Address 17: Instruments	Labels: None
    	Part No SW: 1K6 920 974 D	HW: 1K6920974D
    	Component: KOMBIINSTRUMENT VDD  1216
    	Revision: V0002000	Serial Number: VWX7Z0G53NK88N
    	Coding: 0007203
    	Shop #: WSC 00000 785 00200
    	VCID: 352DB2D708566607DD154B6F6D-8060
    8 Faults Found:
    01771 - Control Module for Headlight Range (J431)
    Address 19: CAN Gateway	Labels: None
    	Part No SW: 1K0 907 530 K	HW: 1K0907951
    	Component: J533__Gateway   H04  0021
    	Revision:   H04 02	Serial Number: 190607F1002365
    	Coding: FF8F036207000000
    	VCID: 2F2180BFEA0A5CD797D90927BF-807A
    8 Faults Found:
    01312 - Powertrain Data Bus
  12. #10
    Tuna has been there. Possible they just blanked out that data?
    Tiguan: What year. We have access to several. Santos: Try one please.
    PS: What are you looking for in Group 081?
