Results 1 to 7 of 7
Thread: 2016 VW Up! ecofuel CPGA
    Friday,29,April,2016,14:41:41:31678
    VCDS Version: 16.3.1.1 (x64)
    Data version: 20160325
    VIN: WVWZZZAAZGD09xxxx   License Plate:
    Chassis Type: AA (1S0)
    Scan: 01 03 09 15 17 19 25 44 56 61 AD
    VIN: WVWZZZAAZGD09xxxx   Mileage: 0km-0miles
    AD-Brake Sensors -- Status: Malfunction 0010
    Address 01: Engine (------CPGA)       Labels: None
       Part No SW: 04C 906 020 CP    HW: 04C 907 309 AF
       Component: R3 1.0l CPI   H12 2110
       Revision: U5H12---
       Coding: 00110010000401000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM10CPI01104C906020CP 001005
       ROD: EV_ECM10CPI01104C906020CP_VW12.rod
       VCID: 6B96066B82FE4E6471-803E
    14690 - Loading Mode active
              P169A 00 [175] - -
                        Mileage: 4 km
                        Date: 2016.04.04
                        Time: 16:40:00
                        Coolant temperature: 72 C
                        Intake air temperature: 40 C
                        Voltage terminal 30: 12.415 V
                        Unlearning counter according OBD: 0
                        Mass flow through throttle valve: 0.0 kg/h
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 L    HW: 1S0 614 517 L
       Component: EBC 460 ESP   H16 0023
       Serial number: A014YU4
       Coding: 12BF247129B602F148FD24F694AA40505FB100
       ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
       ROD: EV_Brake1ESPEBC460TRW_VW12.rod
       VCID: 383CE927832835FC4C-806C
    Address 09: Cent. Elect. (J519)       Labels: 1S0-937-08x-09.clb
       Part No SW: 1S0 937 090 D    HW: 1S0 937 090 D
       Component: PQ25 BCM      H59 0584
       Revision: -8------    Serial number: --------------
       Coding: 62B82B0000010000000001F42C2BAC807340424E7E031460200000460100
       VCID: 3424DD179740D19C60-8060
       Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
       Component: VW10Airbag01Q H03 0006
       Revision: --------    Serial number: 003MY00JB1VZ
       Coding: 000000000000000000000000000000003151
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 3D32F833AC0A10D49F-8068
       Serial number: 3497ARB405J3U9U65H2T
       Serial number: 3507ARB405R3UHHSRGVA
       Serial number: 3557BRB404P3OMV2I16.
    Address 17: Instruments (J285)       Labels: 1Sx-920-xxx-17.clb
       Part No SW: 1S0 920 861 K    HW: 1S0 920 861 K
       Component: KOMBI         H52 0405
       Revision: X0052001    Serial number: 00000000000000
       Coding: 1142010000
       ASAM Dataset: EV_KombiUDSMM9RM10 A05803
       ROD: EV_KombiUDSMM9RM10_VW12.rod
       VCID: 393AEC23B8222CF4B3-806C
       Part No SW: 1S0 909 901     HW: 1S0 937 090 D
       Component: GW-K-CAN TP20 H59 0584
       Revision: -8------
       Coding: 001600
       VCID: 70AC1107A3D8ADBC44-8024
       Part No SW: 5K0 953 234     HW: 1S0 920 861 K
       Component: IMMO          H52 0405
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW01.rod
       VCID: 6A98036F8D04576C0A-803E
    Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
       Part No SW: 6R1 909 144 AJ    HW: 6R1 909 144 E
       Component: EPS_TRW_ALow  312 3132
       Serial number: CG3P1319
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016029
       ROD: EV_SteerAssisUDSTRW_VW12.rod
       VCID: 7F4EC23BE686C2C4CD-802A
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1S0 035 156 B    HW: 1S0 035 156 B
       Component: Radio         567 5543
       Revision: AA001001    Serial number: VWZ8Z1S2286133
       Coding: 0000020801
       VCID: 2A18C36F4584976CCA-807E
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 1S0 907 534     HW: 1S0 937 090 D
       Component: Batt-regelung H59 0584
       Coding: 032B7864
       Subsystem 1 - Part No SW: 1S0 915 181 B    HW: 1S0 915 181 B
       Component: J367-BDM  H08 0210
    Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
       Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
       Component: CV-SENSOR     H07 0460
       ASAM Dataset: EV_CVSen 001001
       ROD: EV_CVSen.rod
       VCID: 281C39675388A57CDC-807C
    12290 - Transport Mode Active
              U1105 00 [009] - -
                        Reset counter: 0
                        Mileage: 4 km
                        Date: 2016.04.04
                        Time: 16:53:45
    End----------(Elapsed Time: 00:46, VBatt start/end: 15.0V/15.0V)-----------
  2. Likes Sebastian, Eric, Uwe, Jef liked this post
  3. #2
    46 seconds, holy shit
    Yes and with 1 controller scanned twice and error codes present
    You know, what VCDS always does.
    Ah, with the hexnet, it should scan 17, then 19 and retrieve GVL at the same time, then scan the rest of them without scanning either 17 or 19 again. Did it not behave like that?
    Yeah you are right, I thought I had seen VCDS did 17 or 01 twice.
    Just tried on my Up, 43 sec. for a complete Autoscan.
  9. Likes Eric, Uwe, Sebastian liked this post
