Results 1 to 10 of 12
Thread: 2.0 TDI CBE/CJA N276 adaptation
    May 2015
    I am working on a 2009 Jetta TDI. It originally came in with a 000135/P0087 Fuel pressure too low fault (among other faults). I surmised that the fuel metering valve (N290) was at fault and installed a new one. It is now setting a P0088 Fuel pressure too HIGH fault and intermittently gives an implausible fault though sadly I do not have any instances of this fault saved anywhere.
    I believe that I must re-adapt the fuel pressure sensor so that it will accept the new fuel pressure values that result from the healthy N290 but I am having trouble going about this task.
    Here is an auto scan:
    VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
    Data version: 20160216
    Friday,22,April,2016,13:06:31:32736
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
    VIN: 3VWRL71K09M085890   Mileage: 330140km-205139miles
    Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 016 P    HW: 03L 906 022 J
       Component: R4 2,0L EDC G000AG  8681
       Revision: 12H01---    Serial number: VWX7Z0HN24A1DF
       Coding: 0050078
       VCID: 3F87B7ED6E025CC647-806A
    008201 - Intake Manifold Flap; Bank 1
                   P2009 - 000 - Short to Ground
                        Mileage: 330139 km
                        Time: 12:05:21
                        RPM: 828 /min
                        Load: 5.1 %
                        Lambda: 99.4 %
                        Mass Air / Rev.: 285.0 mg/str
                        Temperature: 98.1C
    000136 - Fuel Rail/System Pressure
                   P0088 - 000 - Too High
                        Mileage: 330139 km
                        Time: 12:05:47
                        RPM: 1610 /min
                        Inj. Quantity: 32.7 mg/str
                        (no units): 5.0
                        Pressure: 1088.0 bar
                        Pressure: 1416.0 bar
                        Temperature: 45.0C
                        Tank Cont.: 21.3 l
    001025 - EGR System
                   P0401 - 000 - Insufficient Flow - Intermittent
                        Mileage: 330140 km
                        Time: 12:06:23
                        RPM: 1679 /min
                        Speed: 85.0 km/h
                        Voltage: 13.76 V
                        Load: 98.0 %
                        Load: 100.0 %
                        Mass Air / Rev.: 570.0 mg/str
                        Mass Air / Rev.: 555.0 mg/str
       Part No SW: 02E 300 052     HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1913
       Revision: 05144002    Serial number: 00001008270639
       Shop #: WSC 04940 001 00001
       VCID: 51A38155C896DAB6A1-8004
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 113B400D492A00FF881302ED92190042B100
       VCID: 75EB15C5DCBED6965D-8020
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78F51CF10BACABFE46-802C
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
       Revision: 00H54000    Serial number: 00000001128531
       Coding: 04018E234004150007140000001400000008730B5C000120000000000000
       VCID: 3261EED9AD5081AEB8-8066
       Component: Wischer 211008 021  0501
       Coding: 00038805
       Shop #: WSC 00066
       Revision: 00000000    Serial number: AUZ4Z7H0473349
       Coding: 0000100
       VCID: 336FEBDD524A88A6B3-8066
                        Reset counter: 126
                        Mileage: 328486 km
                        Time: 13:13:18
       Revision: 05034000    Serial number: 003B6M07MY5O
       Coding: 0013889
       VCID: 6CDD30A14FF4175EB2-8038
       Subsystem 2 - Serial number: 6332MSME41414C096
       Subsystem 3 - Serial number: 6342MSME3F637132C
       Subsystem 4 - Serial number: 6351HSME18712222Z
       Subsystem 5 - Serial number: 6361HSME185A59039
       Subsystem 6 - Serial number: 63727SME190861780
       Subsystem 7 - Serial number: 63827SME1908693FC
       Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
       Coding: 0012021
       VCID: 040D78014764FF1E5A-8050
       Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
       Component: KOMBIINSTRUMENT 3HL 2418
       Revision: V0003000    Serial number: VWX7Z0HN24A1DF
       Coding: 0023203
       VCID: 3973D9F5702672F679-806C
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 200908F2000997
       Coding: ED807F070013021002
       VCID: 356BD5C55C3E96969D-8060
       Component: Kompass         005 0004
       Revision: 00005000    Serial number: 1293324T3JB504
       Coding: 0000003
       Component: IMMO            3HL 2418
       Revision: 72009005    Serial number: 00000771789028
       Coding: 0001205
       VCID: 6FE727AD7EE2EC4697-803A
                        Fault Status: 00101100
                        Reset counter: 235
                        Mileage: 324563 km
                        Fault Status: 00111000
                        Reset counter: 235
                        Mileage: 324563 km
       Part No: 1K0 909 144 C
       Revision: 00H15000
       VCID: 2A51F6B98580C96E00-807E
       Coding: 12900F880186281B0904058FB0880F0488DC00
       Revision: 72009005    Serial number: 08081222154801
       Coding: 0001204
       VCID: 70E524D163DCF3BE8E-8024
       Component: Radio DE2       016 0020
       Revision: 00016000    Serial number: VWZ4Z7H2251041
       Coding: 0010400
       VCID: 295309B58086C27609-807C
    00003 - Control Module
                014 - Defective
       Revision: 12006001    Serial number: 00000003626623
       Coding: 0001168
       VCID: 76E912C901B8DD8E54-8022
                        Reset counter: 235
                        Mileage: 324563 km
                        Fault Status: 01111100
                        Reset counter: 195
                        Mileage: 324563 km
       Coding: 0100101
       Revision: 12006001    Serial number: 00000003566334
       Coding: 0001168
       VCID: 77F71FCD06B2A4864F-8022
                        Reset counter: 235
                        Mileage: 324563 km
                        Reset counter: 195
                        Mileage: 324563 km
    End-------------------------(Elapsed Time: 02:11)--------------------------
    Following the instructions in the Long adaptation balloon:
    Nothing seems to happen when I enter the new test value, and the "save" button is grey:
    The pop up balloon instructions seem to me somewhat circular so I'd just like a little bit of clarification on the exact chronological steps required.
    I have tried this using both sets of security access login numbers and I have tried to go into Group 117 in basic settings but I get an error message (again, neither set of security logins make any difference in this error message)
    I'm probably going to put in a call to tech support but I thought I might go ahead and put this info up while they're at lunch so he/she can refer to it if necessary.
    Thanks!
    May 2015
    I did note this information in the wiki:
    VW
    When found in Common Rail TDI engines, please see TSB 01-10-11 (TPI 2023624) for Contaminated fuel found in fuel system concerns.
    RoW (Rest of World) market
    Audi
    When found in Common Rail TDI 4 Cylinder Bosch engines, please see TPI 2026879 for Contaminated fuel found in fuel system concerns.
    When found in Audi Common Rail V6, V8 and V12 TDI engines, please see TPI 2020693 for Contaminated fuel found in fuel system concerns. After mechanical all repairs are made N276 may need to be adapted and the EDC may need to be flash updated on the Audi Dealer level.
    Nothing was found in the bore of the N290 except nice clean diesel fuel (no metal)
    May 2015
    I have looked over the WD and it does not appear as though there are any common current carriers between any of the fuel system monitoring/control components the V157 which is clearly faulted out. So I ruled out the possiblilty that there is a wiring problem here on this end of things.
    United States
    Hi Robbie, per our phone conversation I would try unplugging that IMRC to see if it runs any differently.
    The RoW market V6 and larger engines support a reset after the latest dealer level flash updates are applied but a large majority of NAR engines do not support (or require) a diagnostic Adaptation reset. We are concerned about that used N290 though... I pinged Peter to make sure I wasn't having a brain fart and he confirmed those are only sold with the pump because they are calibrated to the pump.
    Side note, this EDC is out of date at SWL 8681. Even though it isn't likely to resolve all of the issues SWL 9970 or newer should be flashed at some point.
    ST?ID=66855
    May 2015
    No resolution here.
    Had a pleasant helpful call with Dana from Ross-tech but we were unable to reach any solid resolution. Evidently fuel pressure adaptation is not supported by this ECU or this particular software variety (she said a lot of stuff that shot right over my head).
    In the end we went with a longshot super double secret "FMA" reset which involved entering 10008 into function 11 CodingII. This had the effect of shutting down and resetting some "fuel trim.." and other learned values in the ECU but it persistently faulted out P0088 fuel pressure to high while the second N290 was installed.
    I went ahead put his original N290 back in and took it for a drive without incident.
    The customer indicated that the instances of reduced power and flashing glow plug light were "very infrequent" I had to explain to him several times that the problem had nothing at all to do with the glow plugs even though he coincidentally had a faulted out plug/pressure sensor when he showed up this morning.
    So it was fun but ultimately disappointing to not be able to offer a fix. I am still not sure why this problem (the low fuel pressure fault) is even happening. Like I said, underneath the N290 is nice and clean.
    Here is some amazing information: I initially inspected the fuel filter (found no metal) and I asked him how long it had been in. He said it was brand new and in fact that the guy who installed it called him up while he was working on it to tell him that there was no filter installed previously. Customer told me he had put 100K miles on the car prior to this WITH NO FUEL FILTER INSTALLED. Amazing. I will not name the shop in San Antonio that last performed a fuel filter service on the car but I did see the service record which included a fuel filter change was perfomed 2 years ago.
  7. Likes Uwe, dieselland liked this post
    May 2015
    ST?ID=66855
    Thank Dana, I missed your reply before making my last post. Thank you for filling in the gaps there. I will advise the customer that he may want to pursue a dealer reflash. However I also advised him to await the potential buyback off and get out from underneath the car.
    He pretty much jumped out of his skin when I told him how much it would cost to replace the torched DPF.
    I am thankful that I have only seen this fault on this one car (once before a long time ago under the previous owner). As I said I had seen this car years ago with the same fault but the guy disappeared and this was long before there was an issue with the intake manifold.
  9. Likes Dana liked this post
  10. #7
    Apr 2016
    Dana -
    Could you elaborate on what the FMA reset does?
    I have a car in the shop which may benefit from this reset.
    Autoscan:
    Tuesday,26,April,2016,19:24:36:37258
    VCDS Version: 15.7.4.1 (x64)
    VIN: 3VWRL71K79M028859   License Plate:
    Mileage: 209790km-130357mi   Repair Order: jeskewitz codes
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
    VIN: 3VWRL71K79M028859   Mileage: 209790km-130357miles
       Part No SW: 03L 997 016 N    HW: 03L 906 022 J
       Component: R4 2,0L EDC G000SG  8680
       Revision: 12H01---    Serial number: VWX7Z0H724214L
       Coding: 0050072
       VCID: 3D71F9B764E024D655-8068
    008817 - Oxygen (Lambda) Sensor Signal B1 S2
                   P2271 - 000 - too Rich
                        Mileage: 209688 km
                        Time: 12:42:09
                        RPM: 1840 /min
                        Speed: 65.0 km/h
                        Lambda: 37.1 %
                        Mass Air / Rev.: 405.0 mg/str
                        Voltage: 0.300 V
                        (no units): 0.01
                        Voltage: 0.975 V
                   P0087 - 000 - Too Low - Intermittent
                        Mileage: 209770 km
                        Time: 17:58:35
                        RPM: 1564 /min
                        Inj. Quantity: 0.3 mg/str
                        (no units): 17.0
                        Pressure: 264.0 bar
                        Pressure: 112.0 bar
                        Temperature: 27.9C
                        Tank Cont.: 17.1 l
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0104
       Revision: 00H35001
       Coding: 113B400D49240002881302E9922200423000
       Shop #: WSC 25018 444 85691
       VCID: 74E71C93D72AA59E6A-8020
                        Fault Status: 00100011
                        Reset counter: 19
                        Mileage: 209712 km
                        Count: 8
                        Count: 32768
                        Count: 4608
                        Count: 91
                        Count: 49934
                        Count: 257
                        Reset counter: 19
                        Mileage: 209712 km
                        Count: 8
                        Count: 32768
                        Count: 4608
                        Count: 75
                        Count: 49934
                        Count: 257
                        Reset counter: 238
                        Mileage: 209790 km
                        Count: 7
                        Count: 3
                        Count: 4096
                        Count: 128
                        Count: 28928
                        Count: 513
       Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7CF734B33F7AEDDE22-8028
    00532 - Supply Voltage B+
       Revision: 00H54000    Serial number: 00000001027735
       Coding: 14018E234004150007140000001400000008730B5C000120000000000000
       VCID: 326BDA8BADBEEBAEB8-8066
       Component: Wischer 070808 021  0501
       Coding: 00038805
       Shop #: WSC 00066
    9 Faults Found:
                        Reset counter: 21
                        Mileage: 209768 km
                        Voltage: 10.85 V
                        Reset counter: 21
                        Mileage: 209586 km
                        Voltage: 14.15 V
                        Reset counter: 21
                        Mileage: 209768 km
                        Voltage: 11.30 V
                        Reset counter: 21
                        Mileage: 209665 km
                        Voltage: 12.15 V
                        Fault Status: 00111010
                        Reset counter: 21
                        Mileage: 209768 km
                        Voltage: 11.45 V
                        Reset counter: 21
                        Mileage: 209768 km
                        Voltage: 11.45 V
                        Reset counter: 21
                        Mileage: 209768 km
                        Voltage: 11.40 V
                        Reset counter: 21
                        Mileage: 209768 km
                        Voltage: 11.35 V
                        Fault Status: 01100010
                        Reset counter: 238
                        Mileage: 209768 km
                        Voltage: 9.40 V
       Revision: 00000000    Serial number: AUZ4Z7H0384796
       Coding: 0000100
       VCID: 3365DF8F52A4E2A6B3-8066
                        Fault Frequency: 12
                        Reset counter: 207
                        Mileage: 207223 km
                        Time: 16:35:11
       Revision: 05034000    Serial number: 003B6M06DKD8
       Coding: 0013889
       VCID: 6CD704F34F1A7D5EB2-8038
       Subsystem 2 - Serial number: 6332MSME3B3404466
       Subsystem 3 - Serial number: 6342MSME37454B0DJ
       Subsystem 4 - Serial number: 6351HSME17004501S
       Subsystem 5 - Serial number: 6361HSME17004C2D7
       Subsystem 6 - Serial number: 63727SME173B0234Y
       Subsystem 7 - Serial number: 63827SME173B0A2B6
       Coding: 0002021
       VCID: 04074C53478A951E5A-8050
    6 Faults Found:
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
       Revision: V0003000    Serial number: VWX7Z0H724214L
       Coding: 0023203
       VCID: 3979EDA770C818F679-806C
                        Reset counter: 23
                        Mileage: 209790 km
                        Time: 19:09:36
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 160608F1000802
       Coding: E9807F070013021002
       VCID: 3561E1975CD0FC969D-8060
       Revision: 00005000    Serial number: 1293324T33QT04
       Coding: 0000003
                        Reset counter: 125
                        Reset counter: 174
                        Mileage: 6591 km
                        Time: 13:32:52
       Shop #: WSC 20156 444 999999
       Revision: 72009005    Serial number: 00000024288708
       Coding: 0001205
       VCID: 6FED13FF7E0C864697-803A
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 69     2901
       Revision: 00H17000
       VCID: 2F6DD3FFBE8CC646D7-807A
                        Fault Status: 00101101
                        Reset counter: 19
                        Mileage: 209712 km
                        Time: 13:11:46
                        Voltage: 13.88 V
                            DU
                        Temperature: 36.0C
                        RPM: 1792 /min
                        Speed: 16.0 km/h
                        Speed: 16.0 km/h
       Coding: 13900F880186281B0904058FB0880F0488DC00
       Revision: 72009005    Serial number: 00000553888804
       Coding: 0001204
       VCID: 70EF1083633299BE8E-8024
    00110 - Right Mirror Turn Signal Lamp (L132)
                        Reset counter: 21
       Component: Radio ZSW       019 0035
       Revision: 00019000    Serial number: VWZ5Z7H6079543
       Coding: 0040402
       VCID: 29593DE78068A87609-807C
                        Reset counter: 22
                        Mileage: 209790 km
                        Time: 19:09:39
       Revision: 12006001    Serial number: 00000003345543
       Coding: 0001168
       VCID: 76E3269B0156B78E54-8022
       Coding: 0100101
    00625 - Vehicle Speed Signal
                        Reset counter: 23
                        Mileage: 209790 km
                        Time: 19:22:23
       Revision: 12006001    Serial number: 00000003342620
       Coding: 0001168
       VCID: 77FD2B9F065CCE864F-8022
                        Reset counter: 21
                        Mileage: 202912 km
                        Fault Status: 00111100
                        Fault Frequency: 10
                        Reset counter: 21
                        Mileage: 202912 km
    End-------------------------(Elapsed Time: 02:02)--------------------------
  11. #8
    All issues must be corrected before a full reset or adaptation can take place.
    Recoding and full reboot are needed and not with the engine running.
    Me and Eric did verify that sometimes this ecu will not allow an adaptation for specific tests such as this issue unless reflashed.
  12. #9
    United States
    Hello Anuthee,
    Thanks for joining the forum. Per your email concerns:
    1. This EDC is out of date (despite the dealer claiming there wasn't one)
      03L 997 016 N @ 8680 would update to 9970 or higher. I would have that completed and you may need to spoon feed them TSB # 01-14-14 -or- SVM code 3339 so they can find it this time
      Side note, I don't have any reason to believe the flash will help with that P0087/000135 - Fuel Rail/System Pressure - Too Low - Intermittent DTC but you mentioned the dealer may be covering something under Goodwill
    2. The FMA (Fuel Mean Value Adaptation / Kraftstoffmengen-Mittelwertadaptation) probably won't help - but we had a dual EDC TDI Touareg (caller) not long ago with a persistent fuel trim issue after failed oxygen sensor replacement. The FMA reset worked in that vehicle FWIW.
      Key on, Engine Off > Login / Coding-II > 10008 > Do it! The controller will reboot kicking you out of the diagnostic session. After it does so I would patiently wait, cycle the ignition and try reconnecting after 30 seconds.
  13. #10
    16.4905 S, 151.7375 W
    Hi... Be sure to drive the vehicle after the FMA / Fuel Mean Value Adaptation is completed at least 50 to 60 miles, this is absolutely necessary to allow the ECM to learn the cleared adaptations.
    Then recheck the fault codes and Readiness status.
    drpeter
  14. Likes Dana, dieselland, Uwe, Jack@European_Parts liked this post
