Page 6 of 6 FirstFirst ... 456
Results 51 to 58 of 58
Thread: Jacks Professional Problem Solver Guide. "JPPSG"
  1. #51
    If these tools are not in your box yet & in today's day in age, than you are lost!
    ALL CAN BE HAD CHEAP TOO, NO EXCUSES!
    TONE GEN SET:
    LOAD & LED LIGHT
    DECADE BOX + DVOM
  2. Likes Uwe liked this post
  3. #52
    TIME TO STOP FOD & ISOLATE ABILITY TO COM
    Okay now no one can whine I don't have a WD when I say JPPSG and go find pins and manually connect with ECU.
    Also see this thread & Go play with Don and Dr. Z : https://forums.ross-tech.com/showthr...estbench-setup
    MED 17
    5 : +12V ( term.15 )
    1 : GND ( term. 31 )
    87 : +12V ( term. 30 )
    92 : +12V ( term. 30 )
    68 : CAN High
    67 : CAN Low
    MED 9
    3, 5, 6 : +12V ( term.15 )
    1, 2, 4 : GND ( term. 31 )
    87, 92 : +12V ( term. 30 )
    86 : K Line
    68 : CAN High
    67 : CAN Low
    EDC16
    EDC16U1, EDC16CP34, EDC16U31
    18 : +12V ( term. 30 )
    72 : K Line
    89 : CAN High
    66 : CAN Low
    ME7.1.1 add T81/PIN 62 B+ for Terminal 30 for ME7.5
    3 : +12V ( term.15 )
    2 : GND ( term. 31 )
    21 : +12V ( term. 30 )
    43 : K Line
    60 : CAN High
    58 : CAN Low
    BOSCH EDC15, EDC15V, EDC15xx & P
    2 : +12V ( term.15 )
    5 : GND ( term. 31 )
    16 : K Line
    37 : +12V ( term. 30 )
    82 or 7 : CAN High
    83 or 6 : CAN Low
  4. Likes Uwe, MartinsX, Fredrick Awuor liked this post
  5. #53
    WARNING!
    Do not just change parts or controllers due to a DTC or being burned up!
    Verify circuit tracks and why a burn down happened!
    Widespread misdiagnosed problems with controllers not being needed & for negated wire testing or repairs on LIN or PWM & due to wiring being insufficient in size or inadequate shield.
    Time to sharpen your pencil & because places are going to steal your money and compound your problems for inability to do proper repairs or transfers with inoperable vehicles!
    Shielding and ground plus ability to attenuate signals over a wire are very important!
    Verify critical wires are sufficient in diameter and can carry current or signals through connection T points.
    NostraJackASS Has Spoken!
    MERRY XMAS!
    Good reading!
    https://www.machinedesign.com/mechan...motion-systems
  6. #54
    Come get your Factory FOD lunch tray!
    https://www.vwmpgsettlement.com/
    Fuel Economy Settlement for Gasoline-Powered Audi, Bentley, Porsche, and Volkswagen Vehicles
    Make Model Engine Capacity Model Year(s)
    Audi A8L 4.0L 2015
    Audi A8L 6.3L 2013 2016
    Audi RS7 4.0L 2014 2016
    Audi S8 4.0L 2013 2016
    Bentley Continental GT 4.0L 2013 2017
    Bentley Continental GTC 4.0L 2013 2014
    Bentley Continental GT Convertible 4.0L 2015 - 2017
    Bentley Flying Spur 4.0L 2015 2016
    Bentley Flying Spur 6.0L 2014 2016
    Porsche Cayenne 3.6L 2013 2014, 2016
    Porsche Cayenne GTS 3.6L 2016
    Porsche Cayenne GTS 4.8L 2013 - 2014
    Porsche Cayenne S 3.6L 2015 2016
    Porsche Cayenne S 4.8L 2013 2014
    Porsche Cayenne Turbo 4.8L 2013 2014
    Porsche Cayenne Turbo S 4.8L 2014, 2016
    Volkswagen Tiguan 4MOTION 2.0L 2017
    Volkswagen Touareg 3.6L 2013 - 2014
  7. #55
    MM Approximate Size In Inches Exact Size In Inches
    1mm 1/25 Inch 0.03937 Inches
    2mm 1/16 Inch 0.07874 Inches
    3mm 3/32 Inch 0.11811 Inches
    4mm 1/8 Inch 0.15748 Inches
    5mm 3/16 Inch 0.19685 Inches
    6mm Just short of 1/4 Inch 0.23622 Inches
    7mm Little over 1/4 Inch 0.27559 Inches
    8mm 5/16 Inch 0.31496 Inches
    9mm Just short of 3/8 Inch 0.35433 Inches
    10mm Little over 3/8 Inch 0.39370 Inches
    11mm 7/16 Inch 0.43307 Inches
    12mm Just short of 1/2 Inch 0.47244 Inches
    13mm Little over 1/2 Inch 0.51181 Inches
    14mm 9/16 Inch 0.55118 Inches
    15mm Just short of 5/8 Inch 0.59055 Inches
    16mm 5/8 Inch 0.62992 Inches
    17mm Just short of 11/16 Inch 0.66929 Inches
    18mm Just short of 3/4 Inch 0.70866 Inches
    19mm Little under 3/4 Inch 0.74803 Inches
    20mm Just short of 13/16 Inch 0.78740 Inches
    21mm Little over 13/16 Inch 0.82677 Inches
    22mm Just short of 7/8 Inch 0.86614 Inches
    23mm Little over 7/8 Inch 0.90551 Inches
    24mm 15/16 Inch 0.94488 Inches
    25mm 1 Inch 0.98425 Inches
  8. #56
    Aug 2016
    Eindhoven, NB, NL
    This is why metric sometimes is better.
  9. #57
    Nope........ it's always better!
  10. Likes PetrolDave, NZDubNurd, iichel liked this post
  11. #58
    VOLUME AND PRESSURE ARE NOT THE SAME!
    I have been pointing to these two videos for many years.
    I strongly suggest you watch them and relate them to any fluid mechanics in anything!
    Funny story this last weekend.
    Recent posts are amusing me & disturbing me at same time how much basics are lacking.
    That good old "Pressure versus Volume" & I'm always running my mouth about in aforementioned videos.
    How does it affect fuel systems though?
    https://forums.ross-tech.com/showthr...h-idle-misfire
    Can a car appear to run rich while being lean as a result?
    Can a car run lean while appearing too operate rich as a result?
    Can air leaks or sensors cause it or controllers?
    Indeed it can....... the answer is yes to ALL!
    Have a life long friend that called about a month ago, there are not too many that exist in this category!
    He did all his basic tests, however, was missing something and he said he changed about everything under hood, now done listening to idiots.
    Car starts runs smooth than seconds later goes to misfire and dumping fuel, no codes!
    Now mind you this friend is not a dummy and knows what is what for most part.
    He was extremely frustrated, even when I'm asking him questions, than replying with saying I'm thinking of changing the entire engine, I've already done everything or having programmed with code to ignore it.
    I replied don't do that!, let me know when you want me to come by.
    He was so frustrated by even me asking questions, "did you check this or that" & because he really did already change or checked it, .....he went dark.
    I left him with some ideas, however, he indeed dismissed the volume test.
    He dismissed this test because he was sure he had PSI from fuel pump on gauge and he even changed it, in addition to regulator + tests.
    Well a few weeks later he changed the entire engine + other parts including, injectors, ECU & now it was driving him to a beyond defeated stance.
    I called and said so what was the solution? He was like man I changed the whole motor and it still does it!
    So I said let me come over and bring a bag and go over step by step and we will find it together.
    Car ran rich pig rich & filled the sump rich.....misfire like crazy, than reported literally no data on either OXS or no DTC's. ( The no DTC's was killing him on this car )
    Car would barely make it out of driveway no power down road bla bla.....
    He is like can't be a fuel PSI problem we have tons of gas or so it would seem I changed everything! "Nope Changed it" Dismissed!
    So we hook up with his scanner, OMG so FFFFFing slow compared to VCDS. We start with the decade box checking the reactions of the sensors in ECU blocks & to verify harness.
    We use a tone generator to track stuff quick & since we are in the field not in a shop, however, at least under a shade tree. Yeah I was sneezing from allergies & no AC, OMG not my fun work environment other than company,..... was well worth it, so I stuck it out, anyone that is truly my friend knows I'd die for them.
    We back trace OXS and verify that harness isn't grounded making some anomaly for full rich fuel dump, nope all good and he drops the cat to down pipe at same time to check for plugged cat, nope good!
    So I said hey I have an idea lets unplug the MAP sensor and plug it into one not in intake & so it doesn't see vacuum to force a condition in ECU.
    Note: this is a field test I developed many years ago and works very well outside the scope of RTFB!
    ( Unplugging a map sensor from vacuum port and covering hole or plugging in a spare map sensor.
    This is sometimes a great method of matching the BARO in ECU blocks and it permits a car that has inadequate delivery to usually run at idle to surmise a volume condition!)
    ( CRIMPING A FUEL LINE HOT & ENGINE RUNNING SHOULD NEVER BE DONE WITHOUT EXTREME SAFETY MEASURES IN PLACE IF NOT EVER! )
    It starts and idles perfect even after a minute just wont take a throttle and rightfully so, however, trims pop up and so does OXS!
    We cross check the map sensors they are all fine.
    We wait for adaption and trims they eventually go red lean......still no DTC's.....?
    I'm like here we go we have a volume issue, so did you know I convinced him to crimp the return fuel line & while running to see if we get a change and plug the map sensor on intake? Did you know it revs right up no miss no issues other than trims still red so now have to get other fuel pump?
    Further investigation resulted in possible additional FOD TBD!
    Triple FOD match ...... The vehicle can have 3 different fuel pumps, all look the same and each with a different volume output 190 LPH, another at 250 LPH and yet another at 350 LPH!
    OBD DATA SHOULD NEVER BE TRUSTED EVER AND UNTIL UNLESS MECHANICAL/ELECTRICAL TESTS HAVE QUALIFIED IT!
    SECOND NOTE:
    JUST IMAGINE THE SITUATION IF HE WOULD OF PROGRAMMED WITH NEFARIOUS CODE TO IGNORE A PARAMETER!
  12. Likes PetrolDave, Bruce, Uwe, NZDubNurd liked this post
