Results 11 to 20 of 26
Thread: How to reset SRI (Service Reminder Indicator) Crafter/LT3
    We have something in the works that MAY solve this problem. PM me if you're interested in testing it.
  2. #12
    May 2014
    Stockholm Sweden
    I´m all in for testing what may solve this problem I have sent a PM
    /Arne
  3. #13
    New User
    Jul 2015
    Lithuania
    Hi, had the same problem today (Request out of range), any updates?
  4. #14
    Are you using the latest beta, 15.6.1 as of this moment?
  5. #15
    New User
    Jul 2015
    Lithuania
    Yes, I'm using 15.6.1
  6. Likes Uwe liked this post
  7. #16
    Sep 2015
    Norway
    This is maybe not the hightech style, but it works as well...
    https://www.youtube.com/watch?v=zjVN3xr47HU
  8. Likes Uwe liked this post
  9. #17
    Jun 2016
    Hi
    Any update to this??
    I'm trying to reset the service indicator on a 2016 Crafter with a 2E chassis no and the channel list is completely different!
    Which channel is it I need to reset??
    Thanks
    Dave
    ;SW:9069014901 HW:9069014901 --- LT3 Instruments
    ;Component: Coding:
    ;32 1056 CRFT_KOMBI_32_1056.rod
    ;Wednesday 17 May 2017 12:52:09:04619
    ;VCDS Version: Release 17.1.3 Data version: 20170320 DS267.7
    ;VCID: 071D8196BE3F3F79A8-8052
    LR029456-Write SVD2 Offset Write Write only channel
    LR029467-SVD 2 Offset write Write only channel
    LR029500-LR029501-Write date-Date - Year 17
    LR029500-LR029503-Write date-Date - Month 5
    LR029500-LR029510-Write date-Date - Day 17
    LR029522-LR029524-Write time-Time -Minute 53
    LR029522-LR029527-Write time-Time -Second 55
    LR029522-LR029532-Write time-Time -Hour 12
    LR303066-WIV Reset (VW) Write 0
    LR303076-AnpKanal_WIV_Kanal_Write_AKD69 Write 0
    LR303086-AnpKanal_WIV_Kanal_Write_AKD68 Write -1905 ml
    LR303096-AnpKanal_WIV_Kanal_Write_AKD66 Write -1905 ml
    LR303106-AnpKanal_WIV_Kanal_Write_AKD65 Write -1905 ml
    LR303116-AnpKanal_WIV_Kanal_Write_AKD64 Write 2.51656e+008 ml
    LR303126-AnpKanal_WIV_Kanal_Write_AKD49 Write 372 Days
    LR303136-AnpKanal_WIV_Kanal_Write_AKD48 Write 0
    LR303146-AnpKanal_WIV_Kanal_Write_AKD47 Write 0
    LR303156-AnpKanal_WIV_Kanal_Write_AKD45 Write 2
    LR303168-AnpKanal_WIV_Kanal_Write_AKD44 Write 744 Days
    LR303178-AnpKanal_WIV_Kanal_Write_AKD43 Write 40000 km
    LR303188-AnpKanal_WIV_Kanal_Write_AKD42 Write 20000 km
    LR303198-AnpKanal_WIV_Kanal_Write_AKD41 Write 1 Days
    LR303208-AnpKanal_WIV_Kanal_Write_AKD40 Write 0 km
    LR303218-AnpKanal_WIV_Kanal_Write_AKD38 Write On
    Elapsed Time: 00:06
  10. #18
    Unverified
    Apr 2018
    Australia
    Same Problem and a Solution.
    My vehicle is a VW Crafter 50 van, 2011 2E build. Service Reminder was on.
    I have searched the net for weeks trying to come across a solution to this as my local dealer also will not reset the service without great a good deal of money exchanging hands. The issue some people don't understand is that the dashboard method for resetting will simply not work on many vehicles, I won't go into the reason for this.
    I am still using VCDS Release 17.8.0 and initially found a major issue with Windows 10 Pro wiping out my drivers (fixed now)
    I won't post my Map as it is identical to the previous Map posted.
    Here is how it has worked for me;
    1) Clear any DTC's
    2) Click on LR135057-WIV Reset (VW) Write (This is your SERVICE RESET)
    3) Enter "0" as "new value" (stored value is also "0")
    4) Workshop code entered in this screen only is 12345 / 123 / 12345
    5) Hit "Do It!"
    6) Without leaving the previous screen, switch IGNITION to off then back to on position. (At this stage the service reminder is gone!)
    7) Close down and exit VCDS
    8) Pull up a chair with a cold drink in hand and celebrate!
    It is now 4 days since I have completed the reset procedure, some people have reported a return of the service reminder after resetting but I have had no problem with this.
    Good luck, I hope this works for everyone else with this problem.
  11. Likes Boki Ar, Daca liked this post
  12. #19
    Sep 2014
    Hi all,
    I have a question on a 2017 LT3. The controller map, part numbers etc are identical to those posted above by Yupster.
    We have tried writing '0' to 'LR303066-WIV Reset (VW) Write' - which already had a stored value of '0' but this has not reset the values on the dashboard.
    The dashboard is saying it is an Inspection due. Please can anyone help?
    Thanks,
  13. #20
    United States
    Hi Grant,
    I took a look at that map and it looks like the service was reset properly. I realize that doesn't explain why the Inspection light is still on but I added additional SRI related text to the last column of the map:
    ;Component: Coding:
    ;Thursday 5 July 2018 15:37:02:14247
    ;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
    LR029500-LR029501-Write date-Date - Year 18
    LR029500-LR029503-Write date-Date - Month 7
    LR029500-LR029510-Write date-Date - Day 5
    LR029522-LR029524-Write time-Time -Minute 38
    LR029522-LR029527-Write time-Time -Second 28
    LR029522-LR029532-Write time-Time -Hour 15
    LR303066-WIV Reset (VW) Write 0 WIV Reset (VW) Write - Konstante
    LR303076-AnpKanal_WIV_Kanal_Write_AKD69 Write 0 Z Diff SUM
    LR303086-AnpKanal_WIV_Kanal_Write_AKD68 Write -1905 ml S Diff SUM in 15Ml Minus1905
    LR303096-AnpKanal_WIV_Kanal_Write_AKD66 Write -1905 ml dw Out M2 in 15Ml Minus1905
    LR303106-AnpKanal_WIV_Kanal_Write_AKD65 Write -1905 ml dwM2 Max in 15Ml Minus 1905
    LR303116-AnpKanal_WIV_Kanal_Write_AKD64 Write 2.51656e+008 ml dwM2 Min in 15Ml Minus 1905
    LR303126-AnpKanal_WIV_Kanal_Write_AKD49 Write 372 Days Time min in Days
    LR303136-AnpKanal_WIV_Kanal_Write_AKD48 Write 0 FV Sum Cons Wear Equiv
    LR303146-AnpKanal_WIV_Kanal_Write_AKD47 Write 0 FR Sum Soot Equiv
    LR303156-AnpKanal_WIV_Kanal_Write_AKD45 Write 2 Flexible Maintainace Interval
    LR303168-AnpKanal_WIV_Kanal_Write_AKD44 Write 744 Days Time max in Days
    LR303178-AnpKanal_WIV_Kanal_Write_AKD43 Write 40000 km W max in km
    LR303188-AnpKanal_WIV_Kanal_Write_AKD42 Write 20000 km W min in km
    LR303198-AnpKanal_WIV_Kanal_Write_AKD41 Write 0 Days Days Since Last Service
    LR303208-AnpKanal_WIV_Kanal_Write_AKD40 Write 0 km Km Since Last Service
    LR303218-AnpKanal_WIV_Kanal_Write_AKD38 Write On f Oil Min Recognition Is Off
    Elapsed Time: 00:04
    I cannot add clarity to the channels with names like Diff SUM but someone else may. I believe:
    • WIV Reset (VW) Write - Konstante = ESI: Resetting ESI / normal oil change status. 0 should be reset
    • Days Since Last Service and zero is good (reset).
    • Km Since Last Service and zero is good (reset).
    I'll check the German file to see if it adds any clarity to some of those channels but I honestly don't see why the service still shows INSP needed.
    You may want to see if the channels report the same with our Beta (make sure the customer know how to switch his HN to the Beta channel) in addition to using the Soft Reset tickbox per the pic half way down on this page.
  14. Likes grant@gendan liked this post
