Results 1 to 9 of 9
Thread: Audi A8 34 level control calibration fail
    Jul 2018
    Hi
    So have an a8, recently the suspensions been playing up, near side front sensor seized up, replaced it and so the saga begins.....
    Used vcds quite abit and have calibrated the suspension successfully before, but this time it keeps aborting for safety reasons!!
    No faults in any other modules (except headlight levelling) and the only fault in 34 is control position not learned.
    I login
    Deactivate jack mode (greyed in mmi use vcds)
    Delete calibration data
    Set to reference level
    Starts to lower, then she aborts!
    Anyone know where reference level should be and can I trick it by disconnecting the sensors and manually position them? Just so I can enter the stock values?
    Ps by know there's 4 new genuine level sensors on the car
    Please post an Auto-Scan for context.
    Jul 2018
    My apologies ....
    Friday,22,June,2018,13:03:32:57278
    VCDS Version: 17.8.0.1 (x64)
    VIN: WAUZZZ4H3BN010557   License Plate:
    Mileage: 303175km-188384mi   Repair Order: murrya8pre
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 30 34 36 3B 3C 42 46
              47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 88 89 8F 90
    VIN: WAUZZZ4H3BN010557   Mileage: 303175km-188384miles
    Address 01: Engine (J623-CDTA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4H0 907 401     HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0006
       Revision: 53H37---
       Coding: 0A2A4012052601020800
       Shop #: WSC 67000 210 91453
       ASAM Dataset: EV_ECM30TDI0114H0907401 001012
       ROD: EV_ECM30TDI0114H0907401.rod
       VCID: 61CDF5BE7096144EE5-8034
    5619 - Engine Off Timer Performance
              P150A 00 [032] - -
       Part No SW: 4H1 927 158 A    HW: 0BK 927 156 L
       Component: 0BK 30 TDIRdW H08 0003
       Revision: --H08---
       Coding: 001111
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMALX51011 001013
       ROD: EV_TCMALX51011_001.rod
       VCID: 2E575E8271C8FB3628-807A
    12446 - Valve for Transmission Fluid Cooler
              P2753 00 [032] - Open Circuit
                        Mileage: 300072 km
                        Date: 2018.02.22
                        Time: 12:03:17
                        Voltage terminal 30: 11.827 V
                        Voltage supply of regulator valves: 11.782 V
                        Current N215 Pressure control valve 1: 850.0 mA
                        Current N218 pressure reg.valve 4: 50.0 mA
                        Current N216 pressure reg.valve 2: 363.5 mA
                        Current N233 pressure reg.valve 5: 50.0 mA
                        Current N217 pressure reg.valve 3: 850.0 mA
                        Current N371 pressure reg. valve 6 lock-up clutch: 50.0 mA
                        Current N443 pressure reg.valve 7 main pressure: 693.3 mA
                        Current solenoid: 0.0 mA
                        Engine speed: 903 /min
                        Transmission fluid temperature: 8 °C
                        Control Module temperature: 7 °C
                        selected gear: without traction
                        M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                        M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                        M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                        M015_Time Normal Mode: 5 s
                        M019_Time Since Reset: 7650 ms
    12449 - Valve for Transmission Fluid Cooler
              P2755 00 [175] - Short to Plus
                        Fault Frequency: 37
                        Mileage: 299161 km
                        Date: 2018.02.12
                        Time: 07:32:40
                        Voltage terminal 30: 13.982 V
                        Voltage supply of regulator valves: 13.901 V
                        Current N215 Pressure control valve 1: 50.0 mA
                        Current N218 pressure reg.valve 4: 850.0 mA
                        Current N216 pressure reg.valve 2: 850.0 mA
                        Current N233 pressure reg.valve 5: 850.0 mA
                        Current N371 pressure reg. valve 6 lock-up clutch: 435.3 mA
                        Current N443 pressure reg.valve 7 main pressure: 850.0 mA
                        Current solenoid: 1000.0 mA
                        Engine speed: 1712 /min
                        Transmission fluid temperature: 60 °C
                        Control Module temperature: 57 °C
                        selected gear: 4
                        M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: closed
                        M015_Time Normal Mode: 340 s
    Address 03: ABS Brakes (J104)       Labels:. 4H0-907-379.clb
       Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
       Component: ESP PREMIUM   H10 0272
       Coding: 60E5E30006A7C700E300
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 316D45FE60F6E4CE35-8064
    0396 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 239
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 11:36:29
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 35
                        F-Type: 92
                        Uz: B8
    0677 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 19
                        Mileage: 303039 km
                        Date: 2018.06.10
                        Time: 19:55:14
                        VzRef: 3F
                        Bit Info 1: 40
                        Bit Info 2: 40
                        Bit Info 3: 06
                        Bit Info 4: 12
                        F-Path: 39
                        F-Type: 1A
                        Uz: B4
    0678 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 18
                        Mileage: 303039 km
                        Date: 2018.06.10
                        Time: 19:55:10
                        VzRef: 45
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 06
                        Bit Info 4: 12
                        F-Path: 39
                        F-Type: 0F
                        Uz: B5
    0776 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:23:20
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 39
                        F-Type: 23
                        Uz: B6
    0778 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
                        Reset counter: 234
                        Mileage: 303077 km
                        Date: 2018.06.10
                        Time: 21:40:06
                        VzRef: 00
                        Bit Info 1: C0
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 39
                        F-Type: 19
                        Uz: 98
       Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 AB
       Component: BCM2 2.0      H23 0510
       Coding: 05B72F00000000000000
       Shop #: WSC 29810 000 1048576
       VCID: 6CD3948A8F54492646-8038
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Component: J764 ELV MLB  H38 0044
       Serial number: 2310000036855003
       Component: MEM-BFS       H08 0153
       Revision: AA000000    Serial number: 00001002187892
       Coding: 0038320000047201000001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 34634CEA97E4D1E65E-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 D    HW: 4H0 820 043 D
       Component: Klima 4 Zonen H14 0061
       Coding: 362102B808
       ROD: EV_AirCondiFront_001_AU64.rod
       VCID: 214DB5BE3016544EA5-8074
    0378 - Coolant Circulation Pump
              B10D0 04 [008] - Internal System Fault
                        Fault Frequency: 229
                        Reset counter: 22
                        Mileage: 297449 km
                        Date: 2018.01.15
                        Time: 09:07:36
                        Voltage terminal 30-Data: 13.0 V
                        Outside air temperature-Data: 10.50 °C
                        Interior temperature-Data: 9.80 °C
       Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0092
       Revision: 15012002    Serial number: 00000000702613
       Coding: 26002010C034AFE18B810007A0001D0C009DC30A07010101800008402000
       VCID: 316D45FE68F6E4CE35-8064
       Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 100824  H32 0040
       Serial number:         100828193702
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 10037486
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531     HW: 4H0 941 531
       Component: E1 - LDS  H07 0044
       Serial number: 27 10 2010  00000208
       Subsystem 4 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0275
       Serial number: WA101803000000111972
       Coding: 020300
       Serial number: 8A084655000000000001
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55931030807385
       Coding: 300302
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 37797BE68E923AFE7B-8062
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG0012MV8
       Coding: 30314246323430303038554A305234483053
       VCID: 366776E28998C3F660-8062
       Serial number: 3575HRB405J06JDC90C2
       Serial number: 3585HRB405J06JDC48A4
       Serial number: 3515JRB404R036N2PGR-
       Serial number: 3525JRB404P036N2A8G1
       Serial number: 3554VRB404V04QM080V1
       Serial number: 3564VRB404R04QM078P%
       Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815JK80000G
       Coding: 000034
       Subsystem 1 - Part No SW: 4H0 951 528 G    HW: 4H0 951 528 G
       Component: E221 - MFL  H04 0009
       Serial number: 03 08 2010  33015635
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4H0 920 910 D    HW: 4H0 920 910 A
       Component: TDieGB------- H30 0297
       Revision: 26110011    Serial number: 658141110593002
       Coding: 33A608001B002600010000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K.rod
       VCID: 2545A1AE243EB86ED9-8070
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
       Component: Analoguhr D4  H04 0210
       Serial number: 1101101000530
       Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000061566
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 34634CEA9FE4D1E65E-8060
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650208209
       Voltage stabilizer:
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H14 0062
       Coding: 0800000000
       ROD: EV_AirCondiHeck.rod
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000008016
       Coding: 01010101000000000000000202
       VCID: 64C3FCAA678401660E-8030
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008006
       Shop #: WSC 12345 123 12345
       ROD: EV_AirSuspe_VW51.rod
    7 Faults Found:
    0025 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:21:32
    0002 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
    403200 - Function Shut-Off Active
              C10C8 00 [009] -  -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
    367877 - Ride Height Not Learned
              C1044 00 [009] -  -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
    266752 - Control module not coded
              U1013 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
    267265 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:21:32
    38144 - No End-of-Line Programming
              B2013 00 [009] -  -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
       Revision: AA000000    Serial number: 00001002173167
       Coding: 00383B0000057201000001010101112131313333203333
    Address 3B: Sensor Elect. (J849)       Labels: None
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA310070SX0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6CD3948A8754492646-8038
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4H0 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH02 0100
       Revision: 00H02000    Serial number: 6PZ 010 287-00
       Coding: 0001102
       Shop #: WSC 00444 210 101616
       VCID: 6DD5998E744E402E51-8038
       Subsystem 1 - Part No: 4H0 907 568
       Component: J770  SWA Slave H01 0100
       Subsystem 2 - Serial number: 6PZ 010 287-20
       Subsystem 3 - Serial number: 5F08.11.1000H010003CH13396˙
       Subsystem 4 - Serial number: H13396˙
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000110067013
       Coding: 011F12205E2162C202080006
       VCID: 3B7167D6BABA1E9E9F-806E
                        Fault Status: 01101100
                        Reset counter: 239
                        Mileage: 282890 km
                        Date: 2017.05.31
                        Time: 10:51:12
       Revision: 00002001    Serial number: 0136978543
       Coding: 011B0E2200B93D85B320C7C40A0100000000000000000000000000000000
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.028  H06 0006
       Serial number:     WOO10828340
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
       Component: Dachelektroni  H11 0080
       Serial number: A2010000000000248833
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS009  H05 0004
       Serial number:     WOO100084I5
    03128 - Switch 1 for Sunroof
                        Fault Status: 00101100
                        Reset counter: 19
                        Mileage: 303079 km
                        Date: 2018.06.11
                        Time: 17:04:13
    00204 - Sunroof Button (E325)
                        Reset counter: 19
                        Mileage: 303079 km
                        Date: 2018.06.11
                        Time: 17:04:13
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000008165
       VCID: 1B3187561A7A7E9E7F-804E
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000110064984
       VCID: 3A7F62D2B580279684-806E
       Part No SW: 4H0 907 801 C    HW: 4H0 907 801 A
       Component: EPB-4         H03 0009
       Revision: --------    Serial number: 00000000020294
       ASAM Dataset: EV_ParkiBrake 001015
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 285BA89A532CA506E2-807C
    721152 - Brake pad replacement mode active
              C1011 00 [000] -  -
       Part No SW: 4H0 907 357     HW: 4H0 907 357
       Component: ....LWR12.... H02 0090
       Serial number: 101104-0004-035
       Coding: 11116F101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 6BD19796825A4E1E4F-803E
    120580 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 24
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 11:36:29
    120589 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
                        Fault Frequency: 6
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 11:36:09
       Part No SW: 4E0 035 061 H    HW: 4E0 035 061
       Component: Radio U DAB   H46 0048
       Revision: AB001007    Serial number: 014KP0A7510901
       Coding: 010103010000000001
       VCID: 204BB0BA331C5D46AA-8074
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4F0 919 129 D    HW: 4F0 919 129
       Component: HybridTV-DVB  H07 HybridTV-DVB  H07 05100510
       Coding: 03010000
       VCID: 2D55598E74CE802E11-8078
    No Faults Found
       Part No SW: 4H0 035 670 C    HW: 4H0 035 670 C
       Component: H-BNT-EU      H41 0171
       Revision: --------    Serial number: 030KQ0A7505432
       Coding: 020101000001F1EF55108B1E000000030000010000000000
       VCID: 2443BCAA27044166CE-8070
       Subsystem 1 - Part No: 8R0 060 884 R
       Component: EUR 2010  1107
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDA11006ELC
       Subsystem 3 - Part No SW: 4H2 919 600 C    HW: 4H2 919 600
       Component: E380 BDT D4  H09 0062
       Serial number: 00000000020297
       Component: CD-Database  1886
    03787 - Rotation Mechanism for Display Module Front
                        Fault Status: 00100011
                        Reset counter: 11
                        Mileage: 302428 km
                        Date: 2018.04.06
                        Time: 07:33:32
                        Voltage: 13.00 V
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000110069133
       Coding: 010F1220402162C202080006
       VCID: 397D7DDEB0862C8E8D-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H03---    Serial number: 525 PA8J09D1R5
       Coding: 1022003
       VCID: 65C5E1AEACBE786E19-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 305000319
       Coding: 0210044000
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B7167D6B2BA1E9E9F-806E
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Part No SW: 4H0 907 412     HW: 4H0 907 412
       Component: ALM           H05 0004
       Revision: --------    Serial number: 000000015681
       Coding: 220000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63C1FFB66A8A065EF7-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000110069273
       Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
       Component: GSM-RL        H07 0083
       Revision: 0R0D5012    Serial number: SN101027  0114
       ROD: EV_GSM2x3Mono.rod
       VCID: 2C53548A47D4892606-8078
    Address 88: Multicont. Seat Driver (J873)       Labels:* None
       Part No SW: 4H0 907 182     HW: 4H0 907 182
       Component: IVB           H03 0042
       Serial number: 00455826041701
       Coding: 672FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 67D9EBA69EB26A7E2B-8032
    Address 89: Multicont. Seat Pass. (J872)       Labels:* None
       Serial number: 00455826039001
       Coding: 272FF2
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 0006F009031F0000070308004244CA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FE98386B642B23E63-803A
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70EB80FAAB7CADC67A-8024
    End-------------------------(Elapsed Time: 06:45)--------------------------
    Dec 2016
    Amsterdam
    You might want to use the latest VCDS version.
    Current:
    Jul 2018
    Hi, tried current vcds, dealers Odis, and Autologic....almost want to try older say vcds 12.12 402 mod style and just put ride heights in 4 channels and 5 to save yeah!
    Currently tweaking sensors to try and get her sitting level
  6. #6
    Jul 2018
    Update....
    When I Vent front and rear axles, I can jack the front springs all the way up but on the rear, only the offside moves up, the near side rear bag appears to be holding all the air still.
    There are no fault codes relating to valves or Solinoids, has anyone experienced a spring not delfalting?
  7. #7
    Quote Originally Posted by Schoonerzero View Post
    7 Faults Found:
              U1111 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:21:32
              U1111 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
              C10C8 00 [009] -  -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
              C1044 00 [009] -  -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
              U1013 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
              U1014 00 [009] - -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:21:32
              B2013 00 [009] -  -
                        Reset counter: 240
                        Mileage: 303175 km
                        Date: 2018.06.22
                        Time: 12:00:12
    I'm going to suggest the last one is the first one that needs to get dealt with. If I had to guess, at some point, someone ran:
    IDE01475 -- Resetting of all adaptations, which is really bad news.
  8. Likes Dana liked this post
  9. #8
    Jul 2018
    Yep that's what they did and that's why I had to go to the dealers to have the level control module programmed on Odis, they tried to learn the control position but it fails when it try's to reach the reference level...
    It goes down at the front initially then aborts - for safety reasons
    Further today... I think the near side rear spring is stuck or holding pressure and not lowering but I get no codes for this.
    If I vent the front and rear axles and I ndo the valve block unions next the pump, I can jack the other three wheels up into the archs, with that one the struts solid and jacks the body up.
    Gonna strip out the strut tomorrow to see if there's any restriction in the valve one the top of it.
    Currently the only fault in level control is control position not learned.
  10. Likes Dana liked this post
  11. #9
    Jul 2018
    Final update....
    Replaced near side rear residual pressure valve.......
    Not aborting on its way to reference level......
    Successful calibration!
    Thanks to alll
  12. Likes Uwe liked this post
