Bug: Live Data HUD
flerp
C?ID=112831
Hi, first of all thanks for the recent updates. One of them seems to have improved the responsiveness of the interface. Also, controller 31 finally has the label file for my RS4.
The Live Data HUD is a good idea, but it currently has a bug where it does not display the selected fields correctly. If you go and configure multiple panes for one hud, it mixes data from the first pane into the second pane.
In the following example, I've selected 3 unique fields for each pane.
I configured Adaptation idle, adaptation partial, and lambda control for bank 1 on the left pane
Then configured the same fields for bank 2 on the right pane
I just used controller 31 as an example, the same thing happens with other controllers.
Like I said this is a very good feature once it's working correctly. It would be even better if we could create shortcuts to these huds on the main menu. Having the option to start logging the fields within the HUD would be really nice too.
jocamero
Denver, CO, USA
C?ID=133121
I've also had issues with the HUD displaying the correct fields or simply no labels.
+1 for shortcuts
Shaun
Alright guys thanks for the report. I will look into it and let you know. Can you confirm that it works as expected if using only one pane?
flerp
C?ID=112831
Yes, it works correctly when configuring only 1 pane with up to 4 measuring blocks.
jocamero
Denver, CO, USA
C?ID=133121
I'm still having this issue. Was it ever addressed? Is there an update I can apply to fix it?
henbo
C?ID=318655
I can confirm that this issue still exists with version 0.4435 of VCDS Mobile.
I try to configure two blocks of Measuring Values, side-by-side with an individually different set of values to display. In any case, after saving and displaying, all values configured in the first block, except the first one, bleed over to the next block where only the last one is shown as originally configured.
jocamero
Denver, CO, USA
C?ID=133121
There must still be a bug related to this. After the latest update I applied last week, none of my previously saved measuring values would work and I was required to recreate them all. Working once again, but this should probably be looked at.
Shaun
I made some fixes for live data hud, and a new build is on alpha, V0.4443. jocamero and henbo, I flipped both of you guys to the alpha channel. If you want to test the new build, go ahead and download the updates and try out the live data hud and feel free to report back here.
henbo
C?ID=318655
Sorry for the late reply, I didn't check back for a while and only today found a little time for digging thru.
So, there are no more duplicates between 2 HUD Measuring Values blocks (2x4), but each block shows some (1-2) "random" values. It's not really random (the same for every attempt), but its not one of the expected (configured) values. Apparently its not even a value for the same controller.
Config
01 - Engine, MVB, selection
01 - Engine, HUD, after selection
01 - Engine, HUD, result
17 - Instruments, MVB, selection
17 - Instruments, MVB, result
Also, some time ago we discussed using the URL of the HUD as a bookmark for quick access. The HUD is empty if I do that. I would guess the session to the controller needs to be created before the HUD is shown, so it cannot possible work with a single URL.
tmoe
C?ID=109772
I tried to use HUD and the values displayed do not match the values from advanced measuring blocks. I know I can measuring blocks but it would be nice to have a set of value pre-selected for the HUD instead of searching every time. Is there something I need to refresh or delete to get the dataset's in sync?
I'm on
CB: 0.4502
FW: 0.256
CFB:0.10
BL: 0.28
DS: 60000057
Trying to log engine 01it's an old log but the vin is correct.
#hndoc:?docid=00002882&xt=hnh:1E5EEEDE671F7AB9F5BBE10F63A3F1403E0F2BA760417CF3F1A4031C81D8BAA9
Sun,Feb,05,2017,10:55:51
VCDS Mobile 0.4334.0.4
VIN: WA1DGAFP9DA055175
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
	 6C 6D 72
Address 01: Engine  (CTUC4 J623)	Labels: 8R-01.lbl
	Part No SW: 8R0 907 551 A	HW: 4G0 907 551 A
	Component: 3.0l V6 TFSI
	Revision: --H07---
	Coding: 2A2A0034052601060000
	Shop #: WSC 06208 000 00000
	ASAM Dataset: EV_ECM30TFS0218R0907551A 001002
	ROD: EV_ECM30TFS0218K5907551E.rod
	VCID: 362FB5DB315FF5884C1F549B2F-8063
No fault codes found.
Address 02: Auto Trans  (J217)	Labels: 8R-02.lbl
	Part No SW: 8R0 927 158 AM	HW: 0BK 927 156 AM
	Component: 0BK 30TFSIUSA H16 1003
	Revision: --H16---
	Coding: 000002
	ASAM Dataset: EV_TCMAL551211 002020
	ROD: EV_TCMAL551211_AU48.rod
	VCID: 88538B238B2B33786E53DA7305-80DD
Address 03: ABS Brakes  (J104)	Labels: None
	Part No SW: 8R0 907 379 AL	HW: 8R0 907 379 AL
	Component: ESP8 quattro  H09 0040
	Revision: --------
	Coding: 191D1C03
	Shop #: WSC 06335 123 12345
	VCID: 8A57B12B952759687867F06BEB-80DF
Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
	Part No SW: 8K0 907 064 GP	HW: 8K0 907 064 FP
	Coding: 0DA54040000000000000
	Shop #: WSC 06335 000 00000
	VCID: 844B9F13B7030F18022BAE2359-80D1
	Subsystem 1 - 	Part No SW: 8K0-905-852-E
Address 08: Auto HVAC  (J255)	Labels: 8K-08.clb
	Part No SW: 8K1 820 043 T	HW: 8K1 820 043 T
	Revision: C1000000
	Coding: 6621228000
	VCID: 3935BEE7004102F0A13D77BF06-806C
Address 09: Cent. Elect.  (J519)	Labels: 8K0-907-063.clb
	Part No SW: 8K0 907 063 DH	HW: 8K0 907 063 DH
	Revision: 08016001
	Coding: 26000095813CAFE00201480300003D0D4F9C4708A6090321000008004000030100000034000000
	VCID: 78B37BE37BCBDBF89EB32AB3F5-802D
	Subsystem 1 - 	Part No SW: 8R1-955-119-A	Labels: 1Kx-955-119.clb
	Component: WWS416 121210H11 0050
	Coding: 01DD13
	Subsystem 2 - 	Part No SW: 8U0-955-559-B	Labels: 8U0-955-559.clb
	Component: G397_RLFS    H06 0002
	Coding: 02005C
	Subsystem 3 - 	Part No SW: 8K0-941-531-AS
	Component: E1 - LDS     H03 0031
	Subsystem 4 - 	Part No SW: 4G0-907-410-A
	Component: USHL4.2      H30 0030
	Subsystem 5 - 	Part No SW: 4H0-907-658
	Component: AQ_Hum_SensorH03 0003
Address 15: Airbags  (J234)	Labels: 8R0-959-655.clb
	Part No SW: 8R0 959 655 F	HW: 8R0 959 655 F
	Coding: 303634313432303030304A55304C38523053
	ROD: EV_AirbaAU10SMEAU416.rod
	VCID: 47D1C81F46B57C0027C9114770-8012
	Subsystem 1 - 	Part No SW: 8R0-959-339-A
	Component: BF-Gewichtss.H02 0040
	Serial Number: 5810000R120000BKTBªª
	Subsystem 2 - 	Serial Number: 6334MSME7435280ACBªª
	Subsystem 3 - 	Serial Number: 6344MSME754412726Bªª
	Subsystem 4 - 	Serial Number: 6352QSME52281F4AOBªª
	Subsystem 5 - 	Serial Number: 6362QSME76281566JBªª
	Subsystem 6 - 	Serial Number: 63732SME5F2557566Bªª
	Subsystem 7 - 	Serial Number: 63832SME5F25426C8Bªª
Address 16: Steering wheel  (J527)	Labels: 8K0-953-568.clb
	Part No SW: 8K0 953 568 L	HW: 8K0 953 568 L
	Revision: --------
	Coding: 000037
	VCID: 43C9DC0F728D4820FBA1E53784-8016
	Subsystem 1 - 	Component: E221 - MFL   H03 0004
Address 17: Instruments  (J285)	Labels: 8R0-920-xxx-17.clb
	Part No SW: 8R0 920 980 T	HW: 8R0 920 980 T
	Revision: 00000000
	Coding: 83FF22000300D705020201
	VCID: 4AD7F12B55A7996838E7306B2B-801F
Address 19: CAN Gateway  (J533)	Labels: 8T0-907-468.clb
	Part No SW: 8R0 907 468 N	HW: 8R0 907 468 C
	Component: GW-BEM 4CAN-M H11 0055
	Revision: 1Y060027
	Coding: 80CF03FF00
	Subsystem 1 - 	Part No SW: 8R0-915-181
	Component: J367-BDM     H07 0141
Address 36: Seat Mem. Drvr  (J136)	Labels: None
	Part No SW: 8R0 959 760 D	HW: 8R0 959 760 B
	Component: MEM-FS        H07 0076
	Revision: AA000000
	Coding: 01581B00000000000000
	VCID: 42C7D90B6D974128F097D80BB3-8017
Address 42: Door Elect, Driver  (J386)	Labels: 8K0-959-793.clb
	Part No SW: 8K0 959 793 R	HW: 8K0 959 793 P
	Component: TSG FA        H02 0506
	Revision:
	Coding: 011D13205E00440004
	VCID: 4FE1E03FAEC5BC406F1969A7E8-801A
Address 44: Steering Assist  (J500)	Labels: 8K0-909-144.clb
	Part No SW: 8R0 909 144 F	HW: 8R0 909 144 B
	Revision: 00001000
	Coding: 100000010001
	Shop #: WSC 42520 123 104857
	ROD: N/A
	VCID: 3B39A4EF0A7D28E0B3518DD7EC-806E
	No ASAM data for: "EV_RCEPSAU48X"
Address 46: Central Conv.  (J393)	Labels: 8K0-907-064-46.clb
	Coding: 01260E3A30FA709787B0053602040007
	Shop #: WSC 06334 123 12345
	Subsystem 1 - 	Part No SW: 8K0-959-719-B
	Component: GTO BF       H01 0080
	Subsystem 2 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part No SW: 8R0-959-591-A
	Component: J245EE20SKB13H05 0220
	Subsystem 4 - 	Part No SW: 8R0-959-591-A
	Component: J394EE20SKB13H05 0220
Address 47: Sound System  (J525)	Labels: 8T0-035-223-BOM.clb
	Part No SW: 8T1 035 223 A	HW: 8T1 035 223 A
	Revision: 00005001
	Shop #: WSC 00000 000
	VCID: 2D1D9AB7C409AE503DC5F30FA2-8078
Address 52: Door Elect, Pass.  (J387)	Labels: 8K0-959-792.clb
	Part No SW: 8K0 959 792 R	HW: 8K0 959 792 P
	Component: TSG BF        H02 0506
	Revision:
	VCID: 4EDFFD3BA9CFB548640F5CBB17-801B
Address 53: Parking Brake  (----)	Labels: 8K0-907-801-V2.clb
	Part No SW: 8K0 907 801 L	HW: 8K0 907 801 J
	Revision: --------
	ROD: N/A
	VCID: 3833BBE33B4B03F85E336AB335-806D
	No ASAM data for: "EV_ParkiBrake"
Address 56: Radio  (R)	Labels: None
	Part No SW: 4G0 035 082 E	HW: 4G0 035 082
	Component: Radio U SIRIU H60 0121
	Revision: AB001007
	Coding: 020007010000000001
	VCID: 2207798B8DD761289057788B53-8077
Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
	Part No SW: 8R1 035 746 C	HW: 8R1 035 746 B
	Component: H-BNT-NA      H44 0624
	Revision: --------
	Coding: 1C0200060105E1EF47029B5C00000403140000000000000002
	VCID: 3731B8DF365514805729618720-8062
	Subsystem 1 - 	Part No SW: 8R0-060-884-BAø
	Component: NAR 2013     0703
	Subsystem 2 - 	Part No SW: 8R0-919-604-A
	Component: DU7 High     H42 0104
	Subsystem 3 - 	Part No SW: 8T0-919-611-L
	Component: E0380 BedientH02 0030
	Subsystem 4 - 	Part No SW: 8R0-060-961-E
	Component: CD-Database  4949
Address 62: Door, Rear Left  (J388)	Labels: 8K0-959-795.clb
	Part No SW: 8K0 959 795 G	HW: 8K0 959 795 D
	Revision:
	Coding: 010C13204000240004
	VCID: 46CFC51B41BF7D08DCBF045B7F-8013
Address 6C: Back-up Cam.	Labels: 8T0-907-441.clb
	Part No SW: 8R0 907 441 A	HW: 4L0907441B
	Component: J772__Rearview       0040
	Revision: --H07---	Serial Number: 525PA8-J2YA23J
	Coding: 1020010
	VCID: 342B8FD327237F98720B3E6349-8061
Address 6D: Trunk Elect.  (J605)	Labels: None
	Part No SW: 8R0 827 851 B	HW: 8R0 827 851 B
	Component: J605  Master  H52 0330
	Revision: --------
	VCID: 3B39A4EF0A7D30E0B3518DD7EC-806E
	Subsystem 1 - 	Part No SW: 8R0-827-852-B
	Component: J756  Slave  H52 0330
Address 72: Door, Rear Right  (J389)	Labels: 8K0-959-795.clb
	Revision:
Shaun
Can you post an example of what you mean, preferably with some screenshots? Problems with the Live Data HUD depend a lot on what gadgets you have selected and in which positions, it's really impossible to track down without this.
tmoe
C?ID=109772
I'm running
Error message - I'm trying to log data for a 2013 Audi Q5 with 3.0 engine. When I log with measuring blocks it works but trying to use Live Data via HUD does not. I select the correct data parameter. Intake temp, Cylinder 3 Knock, Rail pressure requested and Rail Pressure actual and this is what I get. I did not select to log door data, stop start function or play function.
This has been broken for some time. I'd also like to request that this interface look and feel be updated.
jocamero
Denver, CO, USA
C?ID=133121
The issues I have are measuring E85 and boost. I think it's something along the lines of 'percent ethanol in fuel', 'alcohol in fuel', etc. Boost is 'charge pressure' or something similar. There are a few of them, and all have this issue. Typically the first time you view the live data it simply reads 0% or 0 pressure. If you go back, and reselect the preconfigured HUD, it then sometimes will display real values. Maybe once every few months this doesn't work and the only way I've been able to fix it is by deleting and recreating the HUD from scratch. It will then immediately display real values. Then it works the majority of the time or using the reload workaround when it doesn't immediately load values. These issues occur if I have a single or multiple values on a page and don't seem to matter the position on the screen.
Shaun
tmoe can you try [Options] -> [Clear Dataset Cache] and then set up a new hud from scratch and see if the values match? If it's still broken, then I need an autoscan to debug this further.
tmoe
C?ID=109772
Shaun, I did what you suggested, I cleared the dataset cache and set up a new HUD gadget with new parameters and I still didn't get the correct data. Here's a current autoscan from vcds mobile.
Wed,Apr,24,2019,12:10:42
VCDS Mobile 0.4502.0.4
	 6C 6D 72
03-ABS Brakes -- Status: OK 16000
05-Acc/Start Auth. -- Status: OK 16000
08-Auto HVAC -- Status: OK 16000
09-Cent. Elect. -- Status: OK 16000
16-Steering wheel -- Status: OK 16000
17-Instruments -- Status: OK 16000
19-CAN Gateway -- Status: OK 16000
36-Seat Mem. Drvr -- Status: OK 16000
42-Door Elect, Driver -- Status: OK 16000
44-Steering Assist -- Status: OK 16000
46-Central Conv. -- Status: OK 16000
52-Door Elect, Pass. -- Status: OK 16000
53-Parking Brake -- Status: OK 16000
62-Door, Rear Left -- Status: OK 16000
6C-Back-up Cam. -- Status: OK 16000
6D-Trunk Elect. -- Status: OK 16000
72-Door, Rear Right -- Status: OK 16000
	Revision: --H07---
	Shop #: WSC 13459 002 1048576
	ASAM Dataset: EV_ECM30TFS0218R0907551A 001004
	ROD: EV_ECM30TFS0218R0907551A.rod
	VCID: 362FB5DB315FF5884C0EC3-8063
9662 - EVAP System
	Revision: --H16---
	Coding: 000002
	ROD: N/A
	VCID: 88538B238B2B33786E424D-80DD
	No ASAM data for: "EV_TCMAL551211"
Address 03: ABS Brakes  (J104)	Labels: 8R0-907-379-V2.clb
	Revision: --------
	Coding: 191D1C03
	VCID: 8A57B12B95275968787667-80DF
	VCID: 844B9F13B7030F18023A39-80D1
Address 08: Auto HVAC  (J255)	Labels: None
	Revision: C1000000
	Coding: 6621228000
	VCID: 3935BEE7004102F0A12CE0-806C
	Revision: 08016001
	Coding: 26004091853CAFE00700480300003D0D4F9C4708A6090321000008004000030100000034000000
	VCID: 78B37BE37BCBDBF89EA2BD-802D
	Coding: 01DD13
	Coding: 1B005C
	VCID: 47D1C81F46B57C0027D886-8012
	Revision: --------
	Coding: 000037
	VCID: 43C9DC0F728D4820FBB072-8016
	Revision: 00000000
	Coding: 837F22000301D705020200
	VCID: 4AD7F12B55A7996838F6A7-801F
	Revision: 1Y060027
	Coding: 80CF07FF00
	Subsystem 2 - 	Part No SW: 8K0-959-663-B
	Component: J532_DCDCStabH05 0006
	Revision: AA000000
	VCID: 42C7D90B6D974128F0864F-8017
	Revision:
	VCID: 4FE1E03FAEC5BC406F08FE-801A
	Revision: 00001000
	ROD: N/A
	VCID: 3B39A4EF0A7D28E0B3401A-806E
	Coding: 01260E3A20FA70978730053202040007
	Revision: 00005001
	VCID: 2D1D9AB7C409AE503DD464-8078
	Revision:
	VCID: 4EDFFD3BA9CFB548641ECB-801B
	Revision: --------
	ROD: EV_ParkiBrake_AU48.rod
	VCID: 3833BBE33B4B03F85E22FD-806D
	Revision: AB001007
	VCID: 2207798B8DD761289046EF-8077
	Revision: --------
	Coding: 160200060005A1EF45028B4E00000403140000000000000000
	VCID: 3731B8DF365514805738F6-8062
	Revision:
	VCID: 46CFC51B41BF7D08DCAE93-8013
	Coding: 1020010
	VCID: 342B8FD327237F98721AA9-8061
	Revision: --------
	VCID: 3B39A4EF0A7D30E0B3401A-806E
	Revision:
End--(Elapsed Time: 03:01, VBatt start/end: 14.1/14.6 Vign: 0.0)-
