Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Bug: Live Data HUD
    Can you post an example of what you mean, preferably with some screenshots? Problems with the Live Data HUD depend a lot on what gadgets you have selected and in which positions, it's really impossible to track down without this.
  2. Likes Uwe liked this post
  3. #12
    Aug 2015
    I'm running
    Error message - I'm trying to log data for a 2013 Audi Q5 with 3.0 engine. When I log with measuring blocks it works but trying to use Live Data via HUD does not. I select the correct data parameter. Intake temp, Cylinder 3 Knock, Rail pressure requested and Rail Pressure actual and this is what I get. I did not select to log door data, stop start function or play function.
    This has been broken for some time. I'd also like to request that this interface look and feel be updated.
  4. #13
    Feb 2016
    Denver, CO, USA
    The issues I have are measuring E85 and boost. I think it's something along the lines of 'percent ethanol in fuel', 'alcohol in fuel', etc. Boost is 'charge pressure' or something similar. There are a few of them, and all have this issue. Typically the first time you view the live data it simply reads 0% or 0 pressure. If you go back, and reselect the preconfigured HUD, it then sometimes will display real values. Maybe once every few months this doesn't work and the only way I've been able to fix it is by deleting and recreating the HUD from scratch. It will then immediately display real values. Then it works the majority of the time or using the reload workaround when it doesn't immediately load values. These issues occur if I have a single or multiple values on a page and don't seem to matter the position on the screen.
  5. Likes Uwe liked this post
  6. #14
    tmoe can you try [Options] -> [Clear Dataset Cache] and then set up a new hud from scratch and see if the values match? If it's still broken, then I need an autoscan to debug this further.
  7. Likes Uwe liked this post
  8. #15
    Aug 2015
    Shaun, I did what you suggested, I cleared the dataset cache and set up a new HUD gadget with new parameters and I still didn't get the correct data. Here's a current autoscan from vcds mobile.
    Wed,Apr,24,2019,12:10:42
    VCDS Mobile 0.4502.0.4
    VIN: WA1DGAFP9DA055175
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
    	 6C 6D 72
    03-ABS Brakes -- Status: OK 16000
    05-Acc/Start Auth. -- Status: OK 16000
    08-Auto HVAC -- Status: OK 16000
    09-Cent. Elect. -- Status: OK 16000
    16-Steering wheel -- Status: OK 16000
    17-Instruments -- Status: OK 16000
    19-CAN Gateway -- Status: OK 16000
    36-Seat Mem. Drvr -- Status: OK 16000
    42-Door Elect, Driver -- Status: OK 16000
    44-Steering Assist -- Status: OK 16000
    46-Central Conv. -- Status: OK 16000
    52-Door Elect, Pass. -- Status: OK 16000
    53-Parking Brake -- Status: OK 16000
    62-Door, Rear Left -- Status: OK 16000
    6C-Back-up Cam. -- Status: OK 16000
    6D-Trunk Elect. -- Status: OK 16000
    72-Door, Rear Right -- Status: OK 16000
    Address 01: Engine  (CTUC4 J623)	Labels: 8R-01.lbl
    	Part No SW: 8R0 907 551 A	HW: 4G0 907 551 A
    	Component: 3.0l V6 TFSI
    	Revision: --H07---
    	Coding: 2A2A0034052601060000
    	Shop #: WSC 13459 002 1048576
    	ASAM Dataset: EV_ECM30TFS0218R0907551A 001004
    	ROD: EV_ECM30TFS0218R0907551A.rod
    	VCID: 362FB5DB315FF5884C0EC3-8063
    9662 - EVAP System
    Address 02: Auto Trans  (J217)	Labels: 8R-02.lbl
    	Part No SW: 8R0 927 158 AM	HW: 0BK 927 156 AM
    	Component: 0BK 30TFSIUSA H16 1003
    	Revision: --H16---
    	Coding: 000002
    	ASAM Dataset: EV_TCMAL551211 002020
    	ROD: N/A
    	VCID: 88538B238B2B33786E424D-80DD
    	No ASAM data for: "EV_TCMAL551211"
    No fault codes found.
    Address 03: ABS Brakes  (J104)	Labels: 8R0-907-379-V2.clb
    	Part No SW: 8R0 907 379 AL	HW: 8R0 907 379 AL
    	Component: ESP8 quattro  H09 0040
    	Revision: --------
    	Coding: 191D1C03
    	Shop #: WSC 06335 123 12345
    	VCID: 8A57B12B95275968787667-80DF
    Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
    	Part No SW: 8K0 907 064 GP	HW: 8K0 907 064 FP
    	Coding: 0DA54040000000000000
    	Shop #: WSC 06335 000 00000
    	VCID: 844B9F13B7030F18023A39-80D1
    	Subsystem 1 - 	Part No SW: 8K0-905-852-E
    Address 08: Auto HVAC  (J255)	Labels: None
    	Part No SW: 8K1 820 043 T	HW: 8K1 820 043 T
    	Revision: C1000000
    	Coding: 6621228000
    	VCID: 3935BEE7004102F0A12CE0-806C
    Address 09: Cent. Elect.  (J519)	Labels: 8K0-907-063.clb
    	Part No SW: 8K0 907 063 DH	HW: 8K0 907 063 DH
    	Revision: 08016001
    	Coding: 26004091853CAFE00700480300003D0D4F9C4708A6090321000008004000030100000034000000
    	VCID: 78B37BE37BCBDBF89EA2BD-802D
    	Subsystem 1 - 	Part No SW: 8R1-955-119-A	Labels: 1Kx-955-119.clb
    	Component: WWS416 121210H11 0050
    	Coding: 01DD13
    	Subsystem 2 - 	Part No SW: 8U0-955-559-B	Labels: 8U0-955-559.clb
    	Component: G397_RLFS    H06 0002
    	Coding: 1B005C
    	Subsystem 3 - 	Part No SW: 8K0-941-531-AS
    	Component: E1 - LDS     H03 0031
    	Subsystem 4 - 	Part No SW: 4G0-907-410-A
    	Component: USHL4.2      H30 0030
    	Subsystem 5 - 	Part No SW: 4H0-907-658
    	Component: AQ_Hum_SensorH03 0003
    Address 15: Airbags  (J234)	Labels: 8R0-959-655.clb
    	Part No SW: 8R0 959 655 F	HW: 8R0 959 655 F
    	Coding: 303634313432303030304A55304C38523053
    	ROD: EV_AirbaAU10SMEAU416.rod
    	VCID: 47D1C81F46B57C0027D886-8012
    	Subsystem 1 - 	Part No SW: 8R0-959-339-A
    	Component: BF-Gewichtss.H02 0040
    	Serial Number: 5810000R120000BKTBªª
    	Subsystem 2 - 	Serial Number: 6334MSME7435280ACBªª
    	Subsystem 3 - 	Serial Number: 6344MSME754412726Bªª
    	Subsystem 4 - 	Serial Number: 6352QSME52281F4AOBªª
    	Subsystem 5 - 	Serial Number: 6362QSME76281566JBªª
    	Subsystem 6 - 	Serial Number: 63732SME5F2557566Bªª
    	Subsystem 7 - 	Serial Number: 63832SME5F25426C8Bªª
    Address 16: Steering wheel  (J527)	Labels: 8K0-953-568.clb
    	Part No SW: 8K0 953 568 L	HW: 8K0 953 568 L
    	Revision: --------
    	Coding: 000037
    	VCID: 43C9DC0F728D4820FBB072-8016
    	Subsystem 1 - 	Component: E221 - MFL   H03 0004
    Address 17: Instruments  (J285)	Labels: 8R0-920-xxx-17.clb
    	Part No SW: 8R0 920 980 T	HW: 8R0 920 980 T
    	Revision: 00000000
    	Coding: 837F22000301D705020200
    	VCID: 4AD7F12B55A7996838F6A7-801F
    Address 19: CAN Gateway  (J533)	Labels: 8T0-907-468.clb
    	Part No SW: 8R0 907 468 N	HW: 8R0 907 468 C
    	Component: GW-BEM 4CAN-M H11 0055
    	Revision: 1Y060027
    	Coding: 80CF07FF00
    	Subsystem 1 - 	Part No SW: 8R0-915-181
    	Component: J367-BDM     H07 0141
    	Subsystem 2 - 	Part No SW: 8K0-959-663-B
    	Component: J532_DCDCStabH05 0006
    Address 36: Seat Mem. Drvr  (J136)	Labels: None
    	Part No SW: 8R0 959 760 D	HW: 8R0 959 760 B
    	Component: MEM-FS        H07 0076
    	Revision: AA000000
    	Coding: 01581B00000000000000
    	VCID: 42C7D90B6D974128F0864F-8017
    Address 42: Door Elect, Driver  (J386)	Labels: 8K0-959-793.clb
    	Part No SW: 8K0 959 793 R	HW: 8K0 959 793 P
    	Component: TSG FA        H02 0506
    	Revision:
    	Coding: 011D13205E00440004
    	VCID: 4FE1E03FAEC5BC406F08FE-801A
    Address 44: Steering Assist  (J500)	Labels: 8K0-909-144.clb
    	Part No SW: 8R0 909 144 F	HW: 8R0 909 144 B
    	Revision: 00001000
    	Coding: 100000010001
    	ROD: N/A
    	VCID: 3B39A4EF0A7D28E0B3401A-806E
    	No ASAM data for: "EV_RCEPSAU48X"
    Address 46: Central Conv.  (J393)	Labels: 8K0-907-064-46.clb
    	Coding: 01260E3A20FA70978730053202040007
    	Subsystem 1 - 	Part No SW: 8K0-959-719-B
    	Component: GTO BF       H01 0080
    	Subsystem 2 - 	Part No SW: 1K0-951-605-C
    	Component: LIN BACKUP HOH05 1501
    	Subsystem 3 - 	Part No SW: 8R0-959-591-A
    	Component: J245EE20SKB13H05 0220
    	Subsystem 4 - 	Part No SW: 8R0-959-591-A
    	Component: J394EE20SKB13H05 0220
    Address 47: Sound System  (J525)	Labels: 8T0-035-223-BOM.clb
    	Part No SW: 8T1 035 223 A	HW: 8T1 035 223 A
    	Revision: 00005001
    	Shop #: WSC 00000 000
    	VCID: 2D1D9AB7C409AE503DD464-8078
    Address 52: Door Elect, Pass.  (J387)	Labels: 8K0-959-792.clb
    	Part No SW: 8K0 959 792 R	HW: 8K0 959 792 P
    	Component: TSG BF        H02 0506
    	Revision:
    	VCID: 4EDFFD3BA9CFB548641ECB-801B
    Address 53: Parking Brake  (----)	Labels: 8K0-907-801-V2.clb
    	Part No SW: 8K0 907 801 L	HW: 8K0 907 801 J
    	Revision: --------
    	ROD: EV_ParkiBrake_AU48.rod
    	VCID: 3833BBE33B4B03F85E22FD-806D
    Address 56: Radio  (R)	Labels: None
    	Part No SW: 4G0 035 082 E	HW: 4G0 035 082
    	Component: Radio U SIRIU H60 0121
    	Revision: AB001007
    	Coding: 020007010000000001
    	VCID: 2207798B8DD761289046EF-8077
    Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
    	Part No SW: 8R1 035 746 C	HW: 8R1 035 746 B
    	Component: H-BNT-NA      H44 0624
    	Revision: --------
    	Coding: 160200060005A1EF45028B4E00000403140000000000000000
    	VCID: 3731B8DF365514805738F6-8062
    	Subsystem 1 - 	Part No SW: 8R0-060-884-BA
    	Component: NAR 2013     0703
    	Subsystem 2 - 	Part No SW: 8R0-919-604-A
    	Component: DU7 High     H42 0104
    	Subsystem 3 - 	Part No SW: 8T0-919-611-L
    	Component: E0380 BedientH02 0030
    	Subsystem 4 - 	Part No SW: 8R0-060-961-E
    	Component: CD-Database  4949
    Address 62: Door, Rear Left  (J388)	Labels: 8K0-959-795.clb
    	Part No SW: 8K0 959 795 G	HW: 8K0 959 795 D
    	Revision:
    	Coding: 010C13204000240004
    	VCID: 46CFC51B41BF7D08DCAE93-8013
    Address 6C: Back-up Cam.	Labels: 8T0-907-441.clb
    	Part No SW: 8R0 907 441 A	HW: 4L0907441B
    	Component: J772__Rearview       0040
    	Revision: --H07---	Serial Number: 525PA8-J2YA23J
    	Coding: 1020010
    	VCID: 342B8FD327237F98721AA9-8061
    Address 6D: Trunk Elect.  (J605)	Labels: None
    	Part No SW: 8R0 827 851 B	HW: 8R0 827 851 B
    	Component: J605  Master  H52 0330
    	Revision: --------
    	VCID: 3B39A4EF0A7D30E0B3401A-806E
    	Subsystem 1 - 	Part No SW: 8R0-827-852-B
    	Component: J756  Slave  H52 0330
    Address 72: Door, Rear Right  (J389)	Labels: 8K0-959-795.clb
    	Revision:
    End--(Elapsed Time: 03:01, VBatt start/end: 14.1/14.6 Vign: 0.0)-
