Results 1 to 6 of 6
Thread: HN network profile count lower after delete profile
    Oct 2016
    Minnesota USA
    I found something that may or may not be normal, and figured I would ask since I couldn't find the answer using the forum search.
    I recently removed a network profile from my HN. after removing, I had 7 total profiles available rather than 8. Is this normal?
    does the count only reset to 8 if you perform the 45-50 second button hold to reset all network profiles?
    If this is normal I'll just forget about it. I don't anticipate needing 7 unique network profiles...
    I think 1 is always the AP mode setting for a direct connection to the hexnet. so 1 is AP and 7 are infrastructure
  3. Likes Uwe liked this post
    Oct 2016
    Minnesota USA
    Correct, profile 1 is AP mode, after removing one profile I now have 6 profiles for infrastructure mode and 1 profile for AP mode
    It sounds like a bug... how did you delete the profile, through VCI-Config or VCDS-Mobile? Does it come back if you do a 45-second button reset?
  6. Likes Uwe liked this post
    Jun 2014
    Swansea, UK
    Just tried this on our test interface.
    Connected to Wi-Fi via VCI-Config then checked profiles in VCDS-Mobile.
    Removed and re-added via VCI-Config, and sure enough, one less profile:
    Oct 2016
    Minnesota USA
    I've been making changes to the network profiles via VCDS-Mobile UI. The SSID for main network doesn't show up in VCIConfig.
    The 45-50 second reset puts the profile count back to 8.
