Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: 2017 Q7 (US), 3.0l V6 TFSI
  1. #41
    Jan 2016
    Australia
    Quote Originally Posted by andyhud View Post
    Hey Ant,
    Appreciate you continuing to look into this. If there is anything else you need to assist, please let me know. I tried to look in Adaption Channels but couldnt see anything "obvious" to enable it. I'll take another look though
    RE: Soft Power Close doors, sadly not... quite rare for a car to have them here in the UK as a pricey option. I'd love to retro-fit if someone could work out how.
    No worries. It must be in the adaption channels so I'll look with ODIS over the next few days and post a screen capture.
    Re soft close doors, I'm thinking of doing the retrofit as I believe our door controllers support this feature (as there are no PR variants in ETKA). Having said that, it is a little expensive as you need:
    1. 4 x New door locks that have a connector that links down to the soft close motor. Front doors are LHD and RHD specific so you can't get ones from mainland Europe. I think however that the A8 ones from 2012 onwards are compatible as the non-soft close door locks are actually A8 ones. The soft close ones have a "4M0" part number but obviously as you are replacing the old ones which are A8 variants, the newer A8 ones should fit.
    2. 4 x soft close motors. These are the A8 ones.
    3. 4 x new black plastic trim that houses the soft close motor
    4. 2 pin wire loom from the soft close motor to the door controller per door.
    I'll check the exiting door controller with VCDS and see whether it accepts the coding for soft close doors. I wont do the mod if I have to replace them as well.
    If door controllers are OK I will most probably do the mod and will write it up on one of the Audi forums.
    cheers
    ant
  2. #42
    Mar 2016
    Ant, very interesting... I was looking into the motor units also on ETKA ( I have a copy too) and trying to piece all the bits together but sometimes its not that clear.
    Your comment about not getting parts from mainland Europe, surely I could just order the right ones for the UK version of the car as its a selectable option on the car? or do you mean something else?
    Otherwise it seems pretty simple.
    I was looking at retrofitting side assist, but apparently the door control units need replacing if you dont have side assist also for it so there is a probability the power door function could be the same. I'm trying to find someone localish to me with them so I can AutoScan the hell out their car
  3. #43
    Mar 2016
    Another scan on 16.6.0 with Hex-Net and latest firmware
    Sunday,19,June,2016,11:24:34:50897
    VCDS Version: 16.6.0.2 (x64)  HEX-NET CB: 0.4321.4
    Data version: 20160602 DS251
    VIN: WAUZZZ4MXGD0xxxxx   License Plate:
    Chassis Type: 4M (4M2)
    Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 42 44 46 47
              50 52 5F 69 6C 6D 74 81 82 8B A5 AC BB BC CA D6 D7
    50-Seat Adj. 3rd row -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CRTC)       Labels: None
       Part No SW: 4M0 907 401     HW: 059 907 309 B
       Component: 3.0TDI EDC17  H45 0004
       Revision: 91H45---
       Coding: 2A2A4032057E050335180000000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114M0907401 001008
       ROD: EV_ECM30TDI0114M0907401.rod
       VCID: 66807A9599A11C7343-8032
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H03 1008
       Revision: --H03---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 3B36FBE1B2A3719BCC-806E
       Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
       Component: ESP9 Premium  H08 0514
       Coding: 249830B230A30A9DD6A5589A187E52AAE6A6D2240C0C506B1A184A5567654B
       ASAM Dataset: EV_ESP9BOSCHAU736 011006
       ROD: EV_ESP9BOSCHAU736_AU73.rod
       VCID: 3FCE8FF1A6BB6DBBE0-806A
       Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
       Component: MEM-BFS       008 0014
       Serial number: 00000163424401
       Coding: 002010000000B0410000210101010000110000313100000000000000000000
       ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
       ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
       VCID: 3A38FEE5BD994893D7-806E
    Address 08: Auto HVAC (E87)       Labels: None
       Part No SW: 4M0 820 043 K    HW: 4M0 820 043 K
       Component: Klima Zone 4  H52 0071
       Coding: 6618083C5545451102220180800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 2D12C5B97CD7EF2B42-8078
       Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000553567
       Part No SW: 8W0 907 063 G    HW: 8W0 907 063 G
       Component: BCM1 MLBevo   H12 0215
       Coding: 07501943C12900CD010D57195B3F08F9130331009000000000000000E00016810A4502AB32B60A
       ASAM Dataset: EV_BCM1BOSCHAU736 014003
       ROD: EV_BCM1BOSCHAU736_AU49.rod
       Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C
       Component: WWS536 150424  042 0792
       Serial number:         150617201146
       Coding: 1BC7F7
       Serial number: 20522486
       Coding: 0200FF
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 P    HW: 4M0 941 531 P
       Component: E1 - LDS  H05 0007
       Serial number: 14 07 2015  00047313
       Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
       Component: Y7_Innenspieg  H08 0002
       Serial number: GX1CE105081511520096
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
       Component: J528-Dachele  H13 0080
       Serial number: Q00029636
       Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
       Component: SL-Q7NF/AU736  H09 0006
       Serial number: 00000000000000011137
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 4M0 907 561 C    HW: 4M0 907 561
       Component: LRR4          H08 0160
       Coding: 3473FFEB58FFEC08949880A4
       ASAM Dataset: EV_ACCBOSCHAU736 001016
       ROD: EV_ACCBOSCHAU736.rod
       VCID: 302CDCCD6BE582C369-8064
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 4M0 959 655     HW: 4M0 959 655
       Component: Airbag10.44   H50 0084
       Serial number: 003L1000KE5L
       Coding: AACCF0D80C80000098F650F3C08C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_AU73.rod
       VCID: 78BC24EDC3159A83E1-802C
       Subsystem 1 - Part No SW: -----------    HW: 442 060 908 15
       Serial number: 3577Y00B11A19FC164B9
       Subsystem 2 - Part No SW: -----------    HW: 442 060 908 15
       Serial number: 3587Y00B11A19FC0D337
       Subsystem 3 - Part No SW: -----------    HW: 442 0B2 707 15
       Serial number: 35177009F1B9D76282EY
       Subsystem 4 - Part No SW: -----------    HW: 442 0B2 707 15
       Serial number: 3527700991B9D761E07P
       Subsystem 5 - Part No SW: -----------    HW: 442 0C2 807 15
       Serial number: 3557500991C3DEC2639W
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 15
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500A91C3DEA5E12Y
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 15
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A91C3DEA3A14L
       Subsystem 8 - Part No SW: -----------    HW: 442 420 508 15
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00B71989851C31O
       Subsystem 9 - Part No SW: -----------    HW: 442 420 508 15
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00B71989851D55W
       Central Sensor XY:
       Subsystem 10 - Part No SW: -----------    HW: 410 202 707 15
       Component: CentrSensorXY  1C8 0108
       Serial number: I0O7800C31BCC0E17056
       Part No SW: 4M0 907 129 JE    HW: 4M0 907 129 JE
       Component: Lenks.Modul   H11 0008
       ROD: EV_SMLSKLOAU736_AU49.rod
       VCID: 7CB438FDF72DB6A385-8028
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 4M0 920 790 A    HW: 4M0 920 790 A
       Component: FBenRDW       H12 0262
       Coding: 248D01D07C90060001A369603000600000000000
       ASAM Dataset: EV_DashBoardAU736 001020
       ROD: EV_DashBoardAU736.rod
    Trying Address 19
       Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
       Component: Gateway       H13 0078
       Revision: 3C030052    Serial number: 5243C001115729
       Coding: 0301000100008F407F00000000590032D8920007180000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736.rod
       VCID: 3620EAD58981ACF333-8062
       Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
       Component: J453 MFL  H06 0002
       Serial number: 20150723052256 RD031
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9052
       Serial number: 1194427103
    Address 28: HVAC, Rear (E265)       Labels: None
       Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
       Component: Klima Zone 2  H52 0070
       Coding: 000000000000040100820080000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
       ROD: EV_AirCondiFondBHTCAU736.rod
       VCID: 3522EDD99487A7EB3A-8060
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 4M0 907 397 B    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0011
       ASAM Dataset: EV_LCMLeftHELLAAU736 001006
       ROD: EV_LCMLeftHELLAAU736.rod
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 15000000413006
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 3228D6C565E9B0D31F-8066
       Component: MEM-FS        008 0014
       Serial number: 00000163486575
       Coding: 00381B000000B0410000210101010000110000313100000000000000000000
       ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
    Address 39: Right Light (J1023)       Labels: None
       ASAM Dataset: EV_LCMRightHELLAAU736 001006
       Part No SW: 4M0 959 593 D    HW: 4M0 959 593 C
       Component: TSG FS        005 0036
       Serial number: 0000159961174
       Coding: 005D9A015E01000000003082
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 3D32F5F9ACB77FABF2-8068
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 4M0 909 144 E    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H17 0003
       Revision: --------    Serial number: 0000118290
       Coding: B0150101000101
       ASAM Dataset: EV_EPSVWBSAU736 006014
       ROD: EV_EPSVWBSAU736_AU49.rod
       VCID: 312AD9C960EF8BCB66-8064
    Address 46: Central Conv. (J393)       Labels: None
       Part No SW: 8W0 907 064 AD    HW: 4M0 907 064 D
       Component: BCM2 MLBevo   015 0307
       Coding: 01351E006F110040630980006E00580203004004004702502F0400000504803F001F0001000000
       Shop #: WSC 37082 001 104857
       ASAM Dataset: EV_BCM2HellaAU736 010010
       ROD: EV_BCM2HellaAU736_AU49.rod
       VCID: 7EB032F5E131A4B3AB-802A
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY151821J5E
       Subsystem 2 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Serial number: 00000000000033093340
       Heated Windshield Control Module:
       Subsystem 3 - Part No SW: 4M0 907 133     HW: 4M0 907 133
       Component: J505-FSH  H03 0050
       Serial number: 00000000000000003568
       Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
       Component: GEB.F.Heckoef  H16 0815
       Serial number: 94015250
       Part No SW: 4M0 035 223 A    HW: 4M0 035 223
       Component: MIB2_amp_PD   H02 0420
       Serial number: 00000000001999
       Coding: 0135060A008AF53AAF0000010000
       ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
       ROD: EV_AMPMst16C4Gen2BOSE.rod
       VCID: 210A2989300F3B4BF6-8074
    Address 50: Seat Adj. 3rd row (J857)       Labels: None
       Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
       Component: MEM-SR3       008 0014
       Serial number: 00000163698793
       Coding: FF201020F1000000000F000000000900000021210900000000000000440000
       ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
       ROD: EV_SCM3rdRowCONTIAU736.rod
       VCID: 3C34F8FDB7AD76A3C5-8068
       Part No SW: 4M0 959 592 D    HW: 4M0 959 592 C
       Component: TSG BFS       005 0036
       Serial number: 0000161932025
       Coding: 005D9A015E01000000003080
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       Part No SW: 4M0 035 035 B    HW: 4M0 035 035 A
       Component: MU-P-LND-EU   050 0358
       Serial number: A649H0F7500568
       Coding: 013706010000000013111102000A00332F001BE7017001009E
       VCID: 230623812A13295BE4-8076
       Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
       Component: ECE 2016  --- 0134
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9FJ400KPG
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
       Component: ControlUnit_P  H14 0161
       Serial number: 31071500000000000006
       Component: Gracenote2  --- 1011
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H20 0208
       Revision: 9A001003    Serial number: 0375642968
       Coding: 0110000202010000
       VCID: 3326D3C19AF3B9DB14-8066
    428804 - Pitch Angle Sensor
              U115A 00 [009] - No Communications
                        Reset counter: 138
                        Mileage: 9110 km
                        Date: 2016.06.19
                        Time: 11:20:18
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 4M0 907 428 B    HW: 4M0 907 428
       Component: Areaview 2    H11 0301
       Serial number: C854606JG000947
       Coding: 02370601BF0FA10008404480
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004013
       ROD: EV_CamSysRVAV2CE2MLBEv_AU49.rod
    Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
       Part No SW: 4M0 959 107     HW: 4M0 959 107
       Component: HDSG-Modul    H12 0143
       Revision: --------    Serial number: 30165574600000
       Coding: 00F0
       ASAM Dataset: EV_DeckLidCONTIAU736 001010
       VCID: 70AC1CCDAB65C2C329-8024
    Address 74: Chassis Control (J775)       Labels: None
       Part No SW: 4M0 907 777     HW: 4M0 907 777
       Component: Fahrwerk-SG   H10 0102
       Serial number: 2508150523
       Coding: 98505048F8
       ASAM Dataset: EV_ChassContrContiAU736 002013
       ROD: EV_ChassContrContiAU736_AU73.rod
       VCID: 76A02AD5C901ECF3F3-8022
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
       Component: V66LFKompOLV  H06 0012
       Serial number: 00000000004130021620
       Coding: 303030
       Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
       Component: GSM-LL        H07 0066
       Revision: 0L0D5012    Serial number: 20150701001139
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 271E37915E2BC57BB8-8072
    Address 82: Heads Up Display (J898)       Labels: None
       Part No SW: 4M0 919 617 A    HW: 4M0 919 617 A
       Component: HeadUpDisplay H26 1524
       Coding: 4F00C0
       ASAM Dataset: EV_HudNSEIKAU736 001012
       ROD: EV_HudNSEIKAU736.rod
    Address 8B: Adaptive Cruise 2 (J850)       Labels: None
       Part No SW: 4M0 907 541 C    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 001016
       ROD: EV_ACC2BOSCHAU736_AU73.rod
       VCID: 2E10C2B571D194337B-807A
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
       Part No SW: 4M0 907 217 C    HW: 4M0 907 217 A
       Component: BVS           H12 0030
       Coding: 0407030600000402024023A5CD0000B4B0F0C020E280
       ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    Address AC: Reductant Control (J880)       Labels: None
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736.rod
       VCID: 6E9002B5B151D4333B-803A
    Address BB: Door Rear Drv (J388)       Labels: None
       Part No SW: 4M0 959 595 D    HW: 4M0 959 595 C
       Component: TSG HFS       005 0036
       Serial number: 0000161937048
       Coding: 004D98000001000000003080
       ROD: EV_DCU2RearDriveMAXHCONT.rod
    Address BC: Door Rear Pass (J389)       Labels: None
       Component: TSG HBFS      005 0036
       Serial number: 0000161994529
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    Address CA: Sunroof (J245)       Labels: None
       Part No SW: 4M0 907 594     HW: 4M0 907 594
       Component: SAD_STG_1     011 0003
       Coding: 588000053602
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_VW37.rod
       VCID: 73A613C1DA73F9DBD4-8026
    Address D6: Light Ctrl Left 2 (A31)       Labels: None
       Part No SW: 7PP 941 592 CA    HW: 7PP 941 592 C
       Component: LED1L         H09 2002
       ROD: EV_LEDModLeftMELCOAU736_AU49.rod
       VCID: 197A0169185F638B3E-804C
    Address D7: Light Ctrl Right 2 (A27)       Labels: None
       Component: LED1R         H09 2002
    End----------(Elapsed Time: 02:22, VBatt start/end: 12.2V/12.2V)-----------
  4. Likes Uwe liked this post
