- Joined
- May 16, 2014
- Messages
- 5,469
- Reaction score
- 5,935
- Location
- Melbourne, Australia
- VCDS Serial number
- C?ID=194404
I loaded the new Beta version yesterday and I instantly noticed the enhanced DTC reporting facility - Kudos to whoever designed them.
Anyway, eager to learn what was actually in these new reporting functions, I decided to generate a few test DTCs by resetting 03-ABS and the 44-Steering Assist control modules to factory values. The reason that I chose these two control modules was that they had a reasonable admap listing without being too onerous to reconstitute back to their original values. I've now finished rebuilding the coding/adaption channels and everything is back to normal, but I have this wonderful treasure-trove of information which I want to decode, But there's so much new stuff that I need help!
The autoscan that I took after the control modules were reset is below:
Amongst the many items that I need to find-out about are the following - for which I seek assistance:
Any assistance with answering these questions wqould be greatly appreciated
Saturday,16,April,2016,10:26:15:03521
VCDS Version: 16.3.1.1 (x64)
Data version: 20160325
VIN: ************** License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: ************ Mileage: 22291km-13850miles
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1,4l R4 TSI H08 7862
Revision: WAH08---
Coding: 01250032242405082000
Shop #: WSC 04363 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906016G 002011
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 26431A2059EACC0CEE-8072
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 22291 km
Date: 2016.04.16
Time: 09:45:42
Coolant temperature: 21 °C
Intake air temperature: 22 °C
Voltage terminal 30: 11.968 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS); status-Bit 0: 0
Drivetrain coordinator; ACC fault status-Bit 0: 0
Drivetrain coordinator; ACC fault status-Bit 8: 0
Drivetrain coord; cause of shutdown in cruise cntr and ACC mode-Bit 0: 0
Drivetrain coord; cause of shutdown in cruise cntr and ACC mode-Bit 16: 128
Drivetrain coord; cause of shutdown in cruise cntr and ACC mode-Bit 24: 128
Drivetrain coord; cause of shutdown in cruise cntr and ACC mode-Bit 8: 0
Drivetrain coordinator; brake fault status-Bit 0: 4
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [040] - -
Mileage: 22291 km
Date: 2016.04.16
Time: 09:59:52
Engine speed: 712.00 /min
Normed load value: 16.1 %
Coolant temperature: 72 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.630 V
Outside air temperature: 18 °C
Absolute intake pressure: 30 kPa abs
Engine torque: 17.5 Nm
Fuel level: 45.00 l
Oxygen sensor bank 1 sensor 1; specified value: 1.0000
U0428 00 [047] - -
Mileage: 22291 km
Date: 2016.04.16
Time: 09:52:00
Engine speed: 755.00 /min
Normed load value: 18.0 %
Coolant temperature: 47 °C
Intake air temperature: 21 °C
Voltage terminal 30: 14.606 V
Absolute intake pressure: 32 kPa abs
Engine torque: 22.5 Nm
Fuel level: 45.00 l
4716 - No Communications with Parking Brake Control Module
U0128 00 [040] - -
Mileage: 22291 km
Date: 2016.04.16
Time: 09:59:52
Fuel level: 45.00 l
Part No SW: 0CW 300 045 HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5240
Revision: 00043014 Serial number: CU501212296246
Shop #: WSC 00028 028 00025
ROD: EV_TCMDQ200021.rod
VCID: 76E30A60C9CAFC8C9E-8022
25472 - No Communication with Gear Selector Module
U0103 00 [072] - -
Mileage: 22142 km
Date: 2016.04.08
Time: 11:39:00
Engine speed: 18.75 /min
Engine torque: -100 Nm
Vehicle speed: 78 km/h
Control Module temperature: -13 °C
CURRENT pressure: -10.0 bar
Clutch; primary stat: Fahren
selected gear: GANG_5
Driving position: N
Accelerator position: 0.4 %
DTC memory status: 7168
21221 - No Communications with Parking Brake Control Module
U0128 00 [008] - -
Mileage: 22291 km
Date: 2016.04.16
Time: 09:59:52
Engine speed: 3590.25 /min
Vehicle speed: 66 km/h
Control Module temperature: 72 °C
CURRENT pressure: -9.5 bar
Driving position: N
DTC memory status: 8448
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
VCID: 7DF1154CECFCAFD4DF-8028
0295 - Steering angle sensor
Reset counter: 5
Mileage: 22291 km
Date: 2016.04.16
Time: 10:12:58
8299 - Databus
Reset counter: 5
Mileage: 22291 km
Date: 2016.04.16
Time: 10:12:58
Reset counter: 5
Mileage: 22291 km
Date: 2016.04.16
Time: 10:13:07
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 Q HW: 5G0 907 044 Q
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00120004200100011005004012101800
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 3561CD6C944CB79457-8060
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011234701612
Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
ROD: EV_BCMBOSCH_VW37.rod
VCID: 4385A3B4CA981924E9-8016
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 121120 042 0551
Serial number: 121206042218
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M01D03H20M05S37S1
Coding: 00A8DD
554773 - Databus
Reset counter: 45
Mileage: 22291 km
Date: 2016.04.16
Time: 09:59:52
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231233000504
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002016
VCID: 3A7BDE50BD5258ECBA-806E
12658704 - Databus
Reset counter: 45
Mileage: 22291 km
Date: 2016.04.16
Time: 09:59:51
13637426 - Databus
Reset counter: 4
Mileage: 22291 km
Date: 2016.04.16
Time: 09:45:42
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R01UHNZ
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00061
VCID: 408FACB8DB8E023CF4-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 357670000007612C7C0W
Subsystem 2 - Part No SW: ----------- HW: 480 000 201 13
Serial number: 358670000006332C7C0V
Subsystem 3 - Part No SW: ----------- HW: 480 400 301 13
Serial number: 3516502AF0CD5EC471C+
Subsystem 4 - Part No SW: ----------- HW: 480 400 201 13
Serial number: 3526502B30CD5EC2136J
Subsystem 5 - Part No SW: ----------- HW: 480 401 112 12
Serial number: 3556502B30CD5EC4008M
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 08011304220489
Coding: 0500
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 79F9015CF8D493F4F3-802C
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 235 0555
Coding: 27A501082380800801087E00040000
VCID: 65C15D2C646C071427-8030
16776967 - Databus
Reset counter: 45
Mileage: 22291 km
Date: 2016.04.16
Time: 09:59:52
16776973 - Databus
Reset counter: 45
Mileage: 22291 km
Date: 2016.04.16
Time: 09:59:56
Part No SW: 5Q0 907 530 E HW: 5Q0 907 530 E
Component: GW MQB Mid 121 1109
Revision: -------- Serial number: 0000188941
Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear.rod
VCID: 3365F3749A38A9A479-8066
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H13 0035
Serial number: 02120005290300060291
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3451678601
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000046453458
Coding: 003A02208001020000001000
VCID: 020B66B09502D02CA2-8056
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Serial number: 00000000000000502227
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
VCID: 3D71D54CAC7C6FD49F-8068
15873 - Steering angle sensor
Reset counter: 5
Mileage: 22291 km
Date: 2016.04.16
Time: 10:20:49
Motor status: 01
System status: Driving mode
Supply voltage: 14.25 V
Temperature: 33.0 °C
KFC: 3E
KFA: 00 01
Environmental conditions: 5F
uAdSensI_U5VFiltered_xdu16: 5.07820 V
uioUdNotFilt_xdu16: 14.36 V
uAdSensI_SwitchedKl30_xdu16: 14.36 V
NoInitCause_AsicSens: [0x01] ASC_CTRL_SAS_HL_ERR - Error discovered by the High level application
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000048027940
Coding: 003A00208E01020000801000
VCID: 010969BC9004CB34BB-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Serial number: 00000000000000502825
Coding: 050000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846
Component: MU-S-N-ER 039 0450
Serial number: V1F00501130081
Coding: 02730008FF00000011510001000900001F0104960100010047
Shop #: WSC 12345 123 61029
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 275D17245EE0D504D5-8072
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H44 0022
Serial number: VWZ8Z9M3400KZM
Subsystem 2 - Part No SW: 5G0 919 866 A HW: -----------
Component: ROW 2013 --- 0022
7175 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 45
Mileage: 22291 km
Date: 2016.04.16
Time: 10:00:09
7206 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 45
Mileage: 22291 km
Date: 2016.04.16
Time: 10:00:09
End-------------------------(Elapsed Time: 03:13)--------------------------
- For the Engine Control module - what do the "mode-Bit" values signify?
- For the Engine control module what is "Unlearning counter according OBD: 40"?
- For the Engine Control module what is "Engine operating condition-Test_Program_Channel 87: 5"?
- For the Auto Trans control module what is "DTC memory status: 7168"? and "DTC memory status: 8448"? (note this was a pre-existing DTC unrelated to my test program
- For the Steering Assist control module can anyone explain the string of new reports under DTC "15873"
