- Joined
- Apr 20, 2014
- Messages
- 52
- Reaction score
- 66
- Location
- Near Nashville, Tennessee, USA
- VCDS Serial number
- C?ID=151918
Hi I've been working on a problem over at AW and thought I'd ask for some expert help here... so if the thread is a bit disjointed, forgive me.
(Below I was lamenting the lack of advice much beyond "Run a can of techron through her") -and no offense to those who said that - she's been through five cans since this started
Either some EE who can speed through a wiring diagram like we read the comics; or my Laird Uwe who might know the correlation of these codes - they all occur together and the car stalls. She was kind enough to provide a full set just now, for my immediate use. Didn't quite stall as my 11-year old is getting good at save/clear codes! It is happening with increasing frequency, every 40 miles or so.
Please to enjoy le codes:
(sorry my email hacks up the formatting, I tried to fix it)
Then there are usually these codes as well, not sure if caused by the stall or if they "mean something":
The first two codes are almost always there.
Anytime the 16487 MAF P0103 occurs the car stalls. It only occurs at or near idle, usually after driving at 45-55 MPH for 5-10 minutes.
Once, the car stalled without the last two, but usually they are set.
I know there is a common connector where these converge that's broken! Or at least they are related somehow.
Also that big pucklike throttle control valve makes me nervous. Can't find much info on it.
Another thought I'm entertaining is to swap the old MAF back in. Bosch doesn't send out defective ECUs right? I fixed the EGR lines and airbox since then....
Naturally, and as usual; thanks in advance for any help.
Going out to look for vacuum leaks. You can still do that with propane, right? I've got a big full tank that won't connect to my grill. Hmmmm.
Is there no fuel pressure sensor? Found the blocks where fuel pumps status is, will try to post a log ASAP
Thought I'd found it by searching Bentley but only on the V10 and another production code (=newer) engine. Mine's the BFM as are all US 2004s.
Trying to run down codes including a trail to fuel pumps and would love to log pressure, pump status, etc. for each, but I searched last night and no luck.
Also, do all these cars (4.2s) need the EGR Adaptation MP talked of in the past?
I had replaced the vac lines to the EGR valves, one was broken off open, but I suspect I broke it when I was leak-hunting.
FWIW, I liberally sprayed the manifold/block juncture with CRC MAF cleaner without result. Then I thought I better verify its effect , so I disconnected the vac tube from the B/W check valve and sprayed into the tube going straight into the manifold (I guess)... it took a surprisingly large amount to affect the idle. I then took off the fuel pressure regulator tube and it had virtually no effect.. I sprayed first a little then a lot into the tube and finally got a slight reaction. No DTCs triggered by all this...
One old school test I performed was manifold vacuum; it was not exactly steady at idle, but varied +/- maybe five pounds. Measured at FPR tube. Revved to ~4000 RPM but vac performed as expected, smooth and up & down.
Here's another thread. I just cannot believe all these continue to happen at the same time by chance - do there must be a connection (or a connector?, ha)
Sorry, I know this could have been more concise but I am in a big rush. Wife just reminded me she needs to be dropped off before I pick up kids; meaning I have to leave nearly an hour earlier than planned - and if she/you could see the car (it's quite disassembled - cowl's off, looking for ECU to check harness, it seems to be buried in leaves. They're dry at least.) she'd defecate a a building product!
Thanks! Love your product!
-Tom
Thursday,22,May,2014,15:19:49:64698 VCDS Version: Release 12.12.2
Address 01: Engine Labels: 077-910-560-BFM.LBL
Control Module Part Number: 4E0 910 560 A HW: 4E0 907 560
Component and/or Version: 4.2L V8/5V G 0050
Software Coding: 0007773
Work Shop Code: WSC 98765 666 30770
VCID: 1F4D5514CD4166E682D-5124
6 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - Intermittent
16487 - Mass Air Flow Sensor (G70)
P0103 - 008 - Signal too High
18663 - Oxygen (Lambda) Sensor B1 S1
P2231 - 004 - Signal Shorted to Heater Circuit
18666 - Oxygen (Lambda) Sensor B2 S1
P2234 - 004 - Signal Shorted to Heater Circuit
Readiness: 0000 1101
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0060
Shop #: WSC 02353 785 00200
VCID: 24475AF8E727453EDFF-8071
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
RPM: 1312 /min
RPM: 1216 /min
RPM: 1792 /min
(no units): 38.0
(no units): 54.0
Temperature: 77.0°C
T.B. Angle: 14.1°
Voltage: 13.12 V
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 03419 000 00000
VCID: 214953ECF8355016B49-8074
18265 - Load Signal
-Tom
