Results 1 to 8 of 8
Thread: 2006 3C vw passat electric hand brake faulty
    Mar 2016
    Ireland
    hi im having trouble with my electric handbrake on my passat it started off intermittent usually in the morning the rear left caliper not releasing and a few hours later would release and continue as normal for a few days, when i done an auto scan it told me there was no voltage going the caliper
    i tried recoding and running basic settings but did not succeed a constanting beeping was on the dash along with warning lights i bought a second hand parking brake module fitted it and the beeping has stopped but still reading the same fault codes i checked the cables from the module to the motor for continuity and resistance and all is fine any ideas were i am going wrong or what i need to do? please any help
    thanks in advance
    VCDS Version: Release 15.7.4 Running on Windows 7 x86
    Data version: 20160216
    Thursday,14,April,2016,17:07:01:34637
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
    VIN: WVWZZZ3CZ6E129375   Mileage: 220160km-136801miles
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 CD    HW: 03G 906 018 CD
       Component: R4 2.0l PPD1.5 G    9970
       Revision: --H05---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00170 941 85967
       VCID: 69D9D60A40FEAF76C9-803C
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0658378034
       Coding: 0013602
       Shop #: WSC 05311 000 08193
       VCID: 2F6D7812BE9A0146D7-807A
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
       Component: ClimatronicPQ46 050 0404
       Revision: 00050005    Serial number: 00000000000000
       VCID: 62CBC126BDC8FC2E08-8036
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000005199930
       Coding: E5808F0700041A00000A00000F00000000085D435C0000
       Shop #: WSC 05311 000 00000
       VCID: 306F7B6EA3A41EBECE-8064
       Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 05311
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 05311
       Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
       Component: 05 AIRBAG VW8   029 2521
       Revision: 09029000    Serial number: 003A2PNXWJ3L
       Coding: 0012341
       VCID: 2D51621AB4967356E5-8078
       Subsystem 1 - Serial number: 6332MSME0C650679
       Subsystem 2 - Serial number: 6342MSME0C40096A
       Subsystem 3 - Serial number: 6351HTS604FE4J23
       Subsystem 4 - Serial number: 6361HTS6I2IM4OI2
       Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
       Component: Lenksäulenmodul 005 0010
       Revision: 00005000    Serial number: 3C5953507C
       Coding: 0000013
       VCID: 2A5B69068578646E00-807E
    00888 - Wiper Switch for Intermittent Operation (E22)
       Part No SW: 3C0 920 860 H    HW: 3C0 920 860 H
       Revision: X0014000    Serial number: 00000000000000
       Coding: 0007105
       Shop #: WSC 80093 222 69422
       VCID: 275D9032966A59061F-8072
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C05B0905C3
       Coding: 3DFD2C04C21003
       VCID: 21498E2AF84EA73651-8074
       Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
       Component:    IMMO         038 0367
       Revision: 00038000    Serial number: VWZCZ000000000
       VCID: 326B7166ADA82CAEB8-8066
       Subsystem 1 - Part No: 3C0 905 861 D
       Component:    ELV          024 0370
       3C0905861D     ELV          024 0370
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2366
       Coding: 0000757
       VCID: 36634D7641C0308E94-8062
       Part No: 1K2 909 144 K
       VCID: 3467777E57BC229EAA-8060
       Component:    KSG PQ46 ELV 038 0455
       Coding: 01910A0801860E763804941570085F0E103D80
    01134 - Alarm Horn (H12)
                        Reset counter: 130
                        Mileage: 220168 km
                        Time: 16:37:09
       Part No: 1K0 959 702 K
       Coding: 0000756
       VCID: 377D407246CAC9868F-8062
       Revision:   013
       Coding: 0000012
       Shop #: WSC 00028 028 00001
    02442 - Function Lamp in Control Head
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 130
                        Mileage: 220168 km
                        Time: 16:17:49
                        Voltage: 12.42 V
                        Count: 65
    02844 - Lamp for Automatic Parking Function
                009 - Open or Short to Ground - MIL ON
                        Fault Status: 11101001
                        Reset counter: 121
                        Mileage: 217032 km
                        Time: 12:50:15
                        Voltage: 12.42 V
                        Count: 64
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Reset counter: 30
                        Voltage: 12.21 V
                        Count: 116
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Reset counter: 242
                        Mileage: 217032 km
                        Time: 10:30:20
                        Voltage: 12.73 V
                        Count: 170
       Part No: 1K0 035 186 R
       Component: Radio BVX       020 0032
       Coding: 0040400
       VCID: 35614A7A5CC63B969D-8060
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2432
       Coding: 0000144
       VCID: 3365746252B225A6B3-8066
       Part No: 1K0 959 704 F
       Coding: 0000144
       Revision: 00800000    Serial number:
                014 - Defective
    End-------------------------(Elapsed Time: 01:42)--------------------------
    Tartu, Estonia
    Was the old in same SW level as the new one? SW update is in need on these old ones.
    The world is my oyster...
  3. Likes Uwe, Jack@European_Parts liked this post
    Mar 2016
    Ireland
    sw update? is that a sensitivity update ?
    Tartu, Estonia
    Read this for example:
    http://wiki.ross-tech.com/wiki/index.php/02432
    Check TPI 2013530 (Rest of World) or TSB 2015075/01-07-47 (North American Region) for possible Control Module Software Update which corrects Low Voltage Sensitivity. This Update can be considered mandatory if you have these Fault Codes stored!
    Same description is in TPI.
    Mar 2016
    Ireland
    how do i go about updating it to correct the sensitivity?
    Northern ireland
    You replaced the parking brake module?? Why didn't you change the faulty motor on the caliper??
    Tartu, Estonia
    Quote Originally Posted by kevvnolan View Post
    If you ask like this the only answer i can give on this forum is dealer.
    Yes there are other ways, but I won't discuss them on this forum. VCDS can't do this.
  9. #8
    Mar 2016
    Ireland
    thanks golfi_vend
    i never changed the motor because it is not faulty, i put the motor on the other caliper and it cycled perfect leaving it to be a problem with the supply to the motor or the module and as i said i checked the cable for resistance and continuity and it was fine leasving it to be the module? and as the lads are saying the modules have a low voltage sensitivity problem which requires an update
