MK7 Golf R DCC Delete- Ross Tech?
elemons
C?ID=271863
I have a MK7 R that has DCC. I hate DCC and want to turn it completely off. Unfortunately when I bought my R it was the only one available and it came with DCC. I ordered VWR Coilovers from the UK and by installing them it will set off some fault codes because the VW will sense the DCC is unplugged. KW makes EDC Delete Kits (which sends false signal to dcc to tell the ecu they are working) But I would rather figure out a way to turn them off using the Ross Tech system. Considering that lots of MK7 R Owners had to buy a Golf R equipped with DCC but want to use coilovers for track or sportier look. I figured figuring out an option for this would help me as well as others in the same situation. I wanted to see if anybody could help me code this out or if you had any solutions. If there is anybody who could help it would be wonderful. :banghead:
Basically need to turn off DCC through VCDS for short. Lol
Dana
Western PA, USA
Hi Evan,
Please post the complete Auto-Scan from this vehicle. If you made any modifications with VCDS in the DCC area please include the oldest/factory condition scan as well.
elemons
C?ID=271863
Hi Evan,
I havent made any tweaks or scans yet. I spoke ti Uwe via email and he suggested to make my post here. He said he may have a few ideas on what to do based off his email. I was also hoping we could work this out together . Im at a loss to where to even begin. I know there are lots of people who want to be able to use VCDS to turn off DCC to run aftermarket suspension.
My guess:
  • Unplug DCC module.
  • Uncheck 14-Susp. Electronics from Gateway Installation List
  • Recode Xenon, ABS, and any other modules that are unhappy due to the above two.
I suggest posting an Auto-Scan in stock form before doing anything else, then doing the first two steps above, and re-scanning to see what modules have what fault codes.
elemons
C?ID=271863
My guess:
I dont know how to scan, and honestly dont feel comfortable going that deep in it. Lol I wish I had a live phone support during this trial and error session.
elemons
C?ID=271863
I would have to look into how to post and file an auto scan
tracert
C?ID=9072
I have an MK7 Golf R with DCC and I am looking to ditch the factory suspension to run coilovers. Has anyone figured out how to disable the DCC? If not, I am willing to try and document the results to help the community. I am aware of the cancellation kit available but I am much more interested in using the Vag-Com do disable the feature:thumbs:
It strikes me as something that should be doable, but the OP in this thread doesn't seem to have perused it.
MichiganMK7R
C?ID=160838
I'll be giving this a shot within the next few days. Supposedly people are having a hard time getting the ABS module to not throw a fit.
HMFIC
C?ID=155258
Saturday,01,September,2018,19:05:31:29449
VCDS Version: 18.2.1.5 (x64)
VIN: WVWWF7AU8HW170117   License Plate: KYLERSEP12018
Mileage: 32612km-20264mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F 75 A5 A9
VIN: WVWWF7AU8HW170117   Mileage: 32612km-20264miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091900122446000E3000
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 489FE33AF3C0F204AC-801C
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
                    Coolant temperature: 27 °C
                    Intake air temperature: 29 °C
                    Ambient air pressure: 870 mbar
                    Voltage terminal 30: 11.972 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
21320 - Implausible Data Received from ABS Control Module
          U0415 00 [047] - -
                    Fault Frequency: 48
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:28
                    Voltage terminal 30: 12.089 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 25.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 20 min
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Control component verified: No
                    T_AST_SAE: 0 s
15343 - Boost Pressure Regulation
          P0299 00 [104] - Control Range Not Reached
                    Fault Frequency: 19
                    Mileage: 29832 km
                    Date: 2018.07.29
                    Time: 15:04:00
                    Engine speed: 5588.25 /min
                    Normed load value: 56.9 %
                    Vehicle speed: 112 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 13.828 V
                    Unlearning counter according OBD: 18
                    Engine: operating status: PL
                    STATE_BPA[0]: OPM
                    Charge air pressure control valve position: target value: 30.09 %
                    Charge air pressure control valve position: actual value: 30.67 %
                    MAP_MES_SAE: 253 kPa
                    Charge air pressure control valve activation pulse duty factor: -21.86 %
                    Charge air pressure control valve voltage: position closed: 3.6816 V
23128 - Implausible Data Received from ABS Control Module
          U0415 00 [047] - -
                    Fault Frequency: 50
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:28
                    ECU_STATE: ENG_STOP
                    T_ES: 20 min
                    T_AST_SAE: 0 s
Readiness: 0010 0001
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63466000000850
   Coding: 01FA6BA15427096C4578030140CA6980D62A90A2C0029637144050D4C0A8430000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 78FF53FAC3A042841C-802C
0040 - Front Left Wheel Speed Sensor
          C101A 01 [137] - Electrical Failure
                    Reset counter: 180
                    Mileage: 32051 km
                    Time: 00:00:00
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 229
                    Mileage: 32318 km
                    Date: 2018.08.26
                    Time: 17:02:25
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 237
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
16417 - Display for Tire Pressure Monitoring
          C1146 02 [009] - Signal Failure
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:01:42
32993 - Control Module for Electric Parking Brake
          C10E2 F0 [009] - RPM Sensor Implausble Signal
                    Reset counter: 180
                    Mileage: 32051 km
                    Time: 00:00:00
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0425472986
   Coding: 032C0C
   VCID: 3B758CF6B216A99C31-806E
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000010500001211140A
   VCID: 6DD172AEBCE2F72CFF-8038
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061634100447
   Coding: 00010B46C041A2E169E44000091807201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0407370A8F68166400-8050
   Component: WWS    161113  043 0551
   Serial number:         161201003633
   Component: RLHS  042 0105
   Serial number: S6Y16M12D14H01M24S03
   Coding: 00A8DD
   Revision: --------    Serial number: 39331633804664
   Coding: 0071155001
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 4385F416CAE6D15C79-8016
13637411 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
13637426 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
13688835 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Component: ACC BOSCH MQB H10 0620
   Coding: 2D0000C151FFC428949C810510301600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002005
   VCID: 3C778FEAB718AEA438-8068
10 Faults Found:
2055 - Databus
                    Reset counter: 237
                    Mileage: 32544 km
                    Date: 2018.08.29
                    Time: 00:30:40
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 11.7 V
                    Status_ACC_System: ACC_irreversible error
2093 - Functional Restriction due to Brake Over-Temp
          B106F F0 [008] - Unknown Error Elaboration
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:01:33
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 11.6 V
0803 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
                    Voltage terminal 15: 11.8 V
2102 - Databus
                    Fault Frequency: 34
                    Reset counter: 239
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
                    Control Module temperature: 28 °C
0837 - Databus
          U1122 00 [009] - Implausible Message
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
                    Status_ACC_System: ACC_Init
0863 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
2101 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
0810 - Databus
                    Fault Frequency: 42
                    Reset counter: 239
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:24:23
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 13.6 V
                    Velocity_vehicle_reference: 2.80 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.33 m/s²
0815 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
2068 - Databus
                    Reset counter: 187
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:30
   Serial number: 24101641350298
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 387F93FA83208284DC-806C
7 Faults Found:
835584 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [137] - -
                    Fault Frequency: 50
                    Reset counter: 199
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:33
198666 - Front Left Ride-Height Sensor
          C1034 15 [008] - Open or Short to Plus
                    Reset counter: 236
452874 - Front Right Ride-Height Sensor
          C1035 15 [008] - Open or Short to Plus
                    Reset counter: 236
36363 - Valve for Damping Adjustment Front Left
          C1040 13 [137] - Open Circuit
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
36619 - Valve for Damping Adjustment Front Right
          C1041 13 [137] - Open Circuit
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
36875 - Valve for Damping Adjustment Rear Left
          C1042 13 [137] - Open Circuit
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
37131 - Valve for Damping Adjustment Rear Right
          C1043 13 [137] - Open Circuit
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
   Serial number: 003GCR06P2GL
   VCID: 479DE006FEDEFD7CA5-8012
   Occupant Detection:
   Serial number: IBH0000000000066JZI1
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 001 012 16
   Serial number: 35700000000FC745402L
   Subsystem 3 - Part No SW: -----------    HW: 480 001 012 16
   Serial number: 35800000000A0631202/
   Subsystem 4 - Part No SW: -----------    HW: 480 400 912 16
   Serial number: 3510001A723692E28670
   Subsystem 5 - Part No SW: -----------    HW: 480 400 912 16
   Serial number: 3520001A7230E746664.
   Subsystem 6 - Part No SW: -----------    HW: 480 400 912 16
   Serial number: 3550001AD22CA56414DA
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 912 16
   Component: FrontSensor_P  000 6149
   Serial number: 3560001A7230E745075-
9483008 - Seat Occupied Recognition
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 47
                    Reset counter: 199
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:01:49
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 08121604221056
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0919263EA84A4B0C73-805C
   Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
   Component: KOMBI         304 8311
   Coding: 0BAD08127F88CF0502886B0B5400000000000000
   VCID: 2F6DA8A6766E453C8D-807A
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Fault Frequency: 10
                    Reset counter: 235
                    Mileage: 29961 km
                    Date: 2018.07.30
                    Time: 20:32:32
   Revision: --------    Serial number: 05121610801029
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CF74FEAF7986EA478-8028
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 27160003196050056487
   Coding: 34FFFF
   Serial number: HA1-00021.11.16
   Coding: 0001
   VCID: 4A9BD932EDCC0014BA-801E
16656 - Databus
                    Reset counter: 189
                    Mileage: 32051 km
                    Date: 2018.08.24
                    Time: 10:00:47
   Revision: 00000000    Serial number: 16000212922004
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467A7CA9F4866E4F0-8060
13637378 - Databus
                    Fault Frequency: 24
                    Reset counter: 199
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:03
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: E0 01
                    WFS State: 00 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 6D
                    AD-Value H-bridge: 35
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 04
   Component: HRE_Master    H12 0071
   Serial number: 0422639030
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0071
   Serial number: 0413036450
   Coding: 020111
337760 - Databus
                    Reset counter: 180
338048 - Databus
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:01:47
   Serial number: 241116EKO2716A
   Coding: 003E13208000040000000000
   Serial number: 00000000000012727661
   Coding: 111000
589827 - Window Regulator; Rear Driver Side
          B131F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Mileage: 32211 km
                    Date: 2018.08.25
                    Time: 07:32:06
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A7B89F2BD2C90942A-806E
8 Faults Found:
20740 - Databus
                    Reset counter: 199
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
                    Motor status: 00
                    System status: Driving mode
                    Supply voltage: 12.00 V
                    Temperature: 29.0 °C
                    KFC: 51
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 11.98 V
                    uAdSensI_SwitchedKl30_xdu16: 11.99 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: activated
22528 - Databus
                    Reset counter: 158
                    Mileage: 29819 km
                    Date: 2018.07.29
                    Time: 13:26:49
                    Motor status: 03
                    Supply voltage: 12.75 V
                    Temperature: 47.0 °C
                    KFC: 58
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.86 V
                    uAdSensI_SwitchedKl30_xdu16: 12.86 V
                    RP_VALCNTSAV: not activated
                    RP_CNTERR: not activated
23040 - Databus
                    Reset counter: 158
                    Mileage: 29819 km
                    Date: 2018.07.29
                    Time: 13:26:49
                    Motor status: 03
                    KFC: 5A
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.69 V
                    uAdSensI_SwitchedKl30_xdu16: 12.74 V
22784 - Databus
                    Reset counter: 158
                    Mileage: 29819 km
                    Date: 2018.07.29
                    Time: 13:26:49
                    Motor status: 03
                    KFC: 59
                    KFA: 00 00
23296 - Databus
                    Reset counter: 158
                    Mileage: 29819 km
                    Date: 2018.07.29
                    Time: 13:26:54
                    Motor status: 03
                    KFC: 5B
                    KFA: 00 00
19716 - Databus
                    Reset counter: 199
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
                    Motor status: 00
                    KFC: 4D
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 12.14 V
                    uAdSensI_SwitchedKl30_xdu16: 12.14 V
20228 - Databus
                    Reset counter: 199
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:29
                    Motor status: 00
                    KFC: 4F
                    KFA: 00 04
16275 - Steering Angle Sensor
                    Reset counter: 202
                    Mileage: 1048574 km
                    Time: 00:00:00
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.50 V
                    Temperature: 34.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.66 V
                    uAdSensI_SwitchedKl30_xdu16: 12.66 V
                    NoInitCause_RackPos_Rohwert: 01 C0
                    RP_UNDERVOLT: activated
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H30 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA02TA38
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   Serial number: 051216EL406499
   Coding: 003E13208000040000800000
   VCID: 428BF112D5FCD85472-8016
   Serial number: 00000000000012676865
   Coding: 091000
589843 - Window Regulator; Front Passenger Side
          B1320 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Mileage: 32211 km
                    Date: 2018.08.25
                    Time: 07:32:06
   Coding: 022202010B000400
   VCID: 408FFB1ADBF0CA4464-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
13705984 - Databus
          U1123 00 [137] - Received Error Message
                    Reset counter: 180
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:31
13705990 - Databus
                    Fault Frequency: 42
                    Reset counter: 236
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:31
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0751
   Coding: 027300020000000051220002001808009F0207F401200105C6
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 326BA1D2655C68D4E2-8066
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX00GN4
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
          B11CF 53 [009] - Deactivated
                    Reset counter: 118
                    Mileage: 29819 km
                    Date: 2018.07.29
                    Time: 13:27:10
                    Voltage terminal 30: 12.7 V
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 139 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Component: OCULowMQBUS   007 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 15121611P10600
   Coding: 0003070000000201002213548040490084000E100020
   ROD: EV_MFKBoschMQBB_VW27.rod
1123173 - Databus
                    Reset counter: 199
                    Mileage: 32050 km
                    Date: 2018.08.24
                    Time: 00:00:31
                    Control Module temperature: 26 °C
                    Outside air temperature: 26.0 °C
                    System run time: 3.3 s
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
4195331 - Databus
                    Reset counter: 233
                    Mileage: 32450 km
                    Date: 2018.08.27
                    Time: 20:56:56
                    Control Module temperature: 23 °C
                    Outside air temperature: 28.5 °C
                    Vehicle speed: 6.50 km/h
                    System run time: 3.8 s
                    Voltage terminal 15: 12.3 V
                    mid: 02 A7
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 161126201261
End-------------------------(Elapsed Time: 05:35)--------------------------
HMFIC
C?ID=155258
so I have the same Issues need to fix the abs sensor that got de-pinned.. we would like to retain the adaptive headlight AFS system.. i briefly looked over a few modules and seems fairly straight forward however my Deutsch ist nicht so gut.. the new MK7 platforms are a definite new monster..
Thanks in advance
Akkipen
Norway
C?ID=327213
Maybe a bit late to revive this thread, but we tried this on a MY15 Mk7 Golf R yesterday to no avail.
Unchecked the Susp.Electronics from CAN-Gateway still leaves us with a "Suspension error".
Unchecking DCC in the 17-Instruments leaves us with the fault code "Module incorrectly coded".
Asking the lights to recieve hight information from the level-sensor in the suspension instead of the CAN from gateway throws a lighting error
Wondering if we might have to unplug the fuses for DCC and then remove it from the CAN-Gateway to prevent it from powering up at startup.
Adaptive lights are easily fixed after lowering with basic settings.
I would suggest that as the very first step, then checking what other modules are unhappy about it.
You might also try to find scan(s) from similar car(s) that came from the factory without DCC to compare.
Somnus
SLC, USA
C?ID=215931
I don't know if it helps, but in the ABS module Byte 27 Bit 7 is the "DCC Installed" bit. deselecting that bit should keep the ABS module happy when you disconnect the DCC module
EDIT: Random thought that popped into my head, i'm surprised DCC isn't in the forum's acronym decoder.
Fixed. :D
Akkipen
Norway
C?ID=327213
Ahh, interesting piece of information, i'll try that!
Unplugging Fuse 13 in fuse holder C (just behind the flip down compartment) on LHD cars reveals the fuse-panel.
This did indeed shut off the warning for suspension fault -but as the ABS is unhappy with this it still throws an error for ESP and disables the dropdown-menu with the message "This is currently not available"
I'll keep you posted.
darkchina811
ITALY
C?ID=333184
rear level sensor is directly connected to module 14. if you remove the module, the sensor wires need to be extended to the front of the car and connected to module 55/4B (whatever is handling headlights level).
headlight module needs new coding because the sensor is now direct and not over CAN-BUS.
Akkipen
Norway
C?ID=327213
Rejoyce everyone, for the collective thinking has once again broken the mould.
Recipe for coding out DCC on a MK7 Golf R (ROW) is as follows
Step Uno: Unplug Fuse 13 in fuse holder C located behind the flip-down compartment to the left of the steering wheel (LHD).
Step Dos: Uncheck Susp.Electronics from the CAN-Gateway.
Step Tres: Uncheck Bit 7 in Byte 27 of the ABS-module to allow the ESP to function.
Step wish you had quattro: Go scrape on the nearest speed-bump after lowering your golf too much.
Sidenote: Adaptive light is still throwing an error, but this is not really an issue, so i'll look into it at a later date.
Thanks to Somnus, Uwe and darkchina811.
Thread solved bois :cool:
