2011 vw golf 1.6tdi... 7332- mass air flow sensor (g70)
kevvnolan
Ireland
C?ID=268109
hi i am having trouble with a 2011 1.6 diesel golf saying the air flow signal is reading too high
P0103 00 [165]-signal too high can anybody help me identify what the cause is weather it is the mass meter itsself or the loom and so on, help find a solution
Keithuk
Stoke on Trent, England
C?ID=122432
kevvnolan
Ireland
C?ID=268109
VCDS Version: Release 15.7.4 Running on Windows 7 x86
Data version: 20160216
Wednesday,13,April,2016,14:08:07:34637
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 61 62 72 77
VIN: WVWZZZ1KZBW331399   Mileage: 147630km-91733miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 MM    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9050
   Revision: --H43---    Serial number: 00000000000000
   Coding: 08114014032501080000
   ASAM Dataset: EV_ECM16TDI02103L906023MM 003006
   ROD: EV_ECM16TDI02103L906023MM_SE36.rod
   VCID: 7DF1925AEC7623D615-8028
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [167] - Signal too High
                    Mileage: 224938 km
                    Date: 2016.04.13
                    Time: 13:55:07
Readiness: 1110 1000
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 133B200D092500FBC80E04ED90220091310000
   VCID: 76E38D76C140708E54-8022
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 40
                    Mileage: 147638 km
                    Date: 2016.04.13
                    Time: 13:48:44
                    Count: 2
                    Count: 29440
                    Count: 8196
                    Count: 41216
                    Count: 1
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00001012
   Coding: 0000000003
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3C775F5EB7ECEADE62-8068
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AE
   Coding: 48180A3A8825F1C040080080340000E443510088436D8160648087200041
   VCID: 2F6D78127E9A0146D7-807A
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 29041  26  0512
   Coding: 009795
   Component: RLS 060511 05  54  0403
   Coding: 0330AD
   Component: LIN BACKUP HO  H11 9005
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 40
                    Mileage: 147638 km
                    Date: 2016.04.13
                    Time: 13:55:09
                    Voltage: 14.40 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12501111602089
   Coding: 108001
   VCID: 387F434E8BD4C6FE86-806C
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Serial number: 003G5RA4T8L.
   Coding: 00003954
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 31697E6A60AE17B6C1-8064
   Serial number: 3572MSME076B235FZZZ%
   Serial number: 3582MSME2F67025DZZZ1
   Serial number: 3512QSME6C1F292FZZZA
   Serial number: 3522QSME5C492E61ZZZ2
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90440KDT000ZJ
   Coding: 1082140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 72EBB166A5286CAE78-8026
   Serial number: 40000000000000917861
   Coding: E20000
   Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
   Component: KOMBI         H20 0420
   Coding: 470B00
   VCID: 2D51621A7C967356E5-8078
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 050511F1001101
   Coding: 350003
   VCID: 31697E6A68AE17B6C1-8064
   Component: IMMO          H20 0420
   VCID: 6ADBA9068DF8A46EC0-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669909275
   VCID: 285F930E5B74567E16-807C
   Component: Tuer-SG         009 2120
   Coding: 0131764
   VCID: 31697E6AA8AE17B6C1-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 3467777E57BC229EAA-8060
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0132020
   VCID: 3365746252B225A6B3-8066
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  041 0166
   Revision: 00000001    Serial number: VWZ1Z3L0748227
   Coding: 0100040004
   VCID: 26439D365160400E24-8072
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Component: Batt.regelung H35 0614
   Coding: 030B085A
   VCID: 71E9BE6AA82E57B681-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Coding: 0131216
   Shop #: WSC 01357 011 1012552
   VCID: 35614A7A5CC63B969D-8060
   Coding: 0131216
   VCID: 36634D7641C0308E94-8062
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669904165
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 2447873E2F5CB21E3A-8070
End-------------------------(Elapsed Time: 02:37)--------------------------
sorry lads wasnt sure weather post it or not haha thanks.
ECU remapped or engine otherwise modified?
kevvnolan
Ireland
C?ID=268109
no never modified! everything is standard!
dubTECH
Northern ireland
C?ID=104757
Your airflow reading is too high because your EGR cooler is faulty. Excessive carbon deposits cause the switchover flap to stick (and eventually the valve head breaks off) causing unmetered air into the cylinder which is then picked up by the o2 sensors, causing the ECU to think the air mass meter is faulty.
ivagp
C?ID=95551
is their a way to clean without removal
dubTECH
Northern ireland
C?ID=104757
No, the only cure is replacement of the cooler. But when you do so, removed and check the pipes from the cooler to the inlet manifold as these get gunked up too.
kevvnolan
Ireland
C?ID=268109
thanks dubTECH ill look into that straight away
bob7
Romania
C?ID=234539
hi , this is really strange...
and, look at the freeze frame
Mileage: 224938 km !!!
Date: 2016.04.13
Time: 13:55:07
u use after market air filter?
kevvnolan
Ireland
C?ID=268109
how do i get the values to perform a forced dpf regeneration while driving??
