Results 1 to 10 of 10
Thread: Where do I get a Wiring Diagram?
    North American Models:
    Rest-of-World Models:
    Yes, these are "subscription" sites, but they have the real-deal, the official up-to-date stuff. Make sure your computer is set up to print stuff to PDF files, get a one-day subscription, and print everything relevant to your car.
    Feb 2016
    Denver, CO, USA
    Should the Audi link point to:
    https://erwin.audi.com/
    and not:
    https://erwin.vw.com/
    Oops. Fixed, thanks!
    Jan 2016
    Chicago, IL, USA
    I got a day pass for both erwin.audiusa.com and erwin.audi.com and neither had wiring plans for the A4 B9 yet. Is there any other source for those plans or di just have to wait and try again in six month?
    Dirk
    Magdeburg, Germany
    Are you certain that you looked in the right places? I would suggest contacting them directly, if the stuff truly wasn't there yet I'm sure they will offer a refund.
  6. Likes Uwe liked this post
    Jan 2016
    Chicago, IL, USA
    Well, I found the Q7 4M wiring plan and some other stuff for the A4 8W but not the wiring, the US side had even more than the ROW site.
    Oct 2019
    Hi
    Links from the first post are no longer valid. You can update them.
    The correct addresses are below
    VW
    Audi
    Seat
  9. Likes Uwe, PetrolDave, Dana liked this post
  10. #8
    Jan 2020
    Good day:
    Why is the reason you are suggesting to print the PDF's? Can't they be saved into the computer to be read later?
    1999 GOLF ALH no mods
    2000 Jetta EGR Deleted, .205 injectors, Stage I
    2002 Jetta ALH, no mods
    2002 Jetta .205 Injectors, Stage 2 Clutch, Stage 2 tuning
    2006 Jetta BRM no mods
  11. #9
    Sep 2016
    Riga, Latvia
    The "print to pdf" application installs a virtual printer on Your computer. Then You are able to save anything from Ervin as *.pdf files on Your HDD. Ervin does not allow to download files directly.
  12. Likes PetrolDave, Uwe liked this post
  13. #10
    Quote Originally Posted by MartinsX View Post
    Depending on which erWin site is being used, some things can be downloaded directly. Those things obviously don't need to be printed to PDF. But for things that cannot be downloaded direct, print to PDF is (IMO) a far better option that printing to physical paper.
  14. Likes PetrolDave, MartinsX, downtime liked this post
