Just installed 16.3.1 Beta and here is an Autoscan as requested in the Beta thread.
Still missing labels
Fuel Flap error is an odd one, but it has been making a bit of a whirring sound when unlocking the car recently...
Reverse camera calibration error is known, I've not calibrated it with the floor mounted visual panel.
Monday,11,April,2016,17:30:18:09724
VCDS Version: 16.3.1.1 (x64)
Data version: 20160325
VIN: WAUZZZ8U2ER111920 License Plate: V22LAC
Mileage: 24500km-15223mi Repair Order:
Chassis Type: 8U (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 56 5F
62 6C 72
VIN: WAUZZZ8U2ER111920 Mileage: 24500km-15223miles
Address 01: Engine (J623-CFGC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PH HW: 03L 906 018 ES
Component: R4 2,0L EDC H28 6636
Revision: 41H28--- Serial number:
Coding: 00250012043701080000
Shop #: WSC 00049 770 00118
ASAM Dataset: EV_ECM20TDI01103L906018PH 003006
ROD: EV_ECM20TDI01103L906018EQ.rod
VCID: 7F06CC35E6D880C4CD-802A
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BH 300 012 A HW: 0BH 927 711 C
Component: DSG DQ500-7A H08 2233
Revision: 00H08V01
ROD: EV_TCMDQ500021_VW37.rod
VCID: 21422A4D30EC16349B-8074
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BA HW: 5N0 614 109 BA
Component: J104 C6 450M VDF9 0160
Revision: --H07--- Serial number: 00000008231167
Coding: 0056717
Shop #: WSC 00049 770 00153
VCID: 6BDE08654AA00C6471-803E
Part No SW: 8U0 820 043 E HW: 8U0 820 043 E
Component: E87 Klimavoll 0100
Revision: 00H04000 Serial number: 8U0820043E
VCID: 336ED005521094A479-8066
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 R HW: 8X0 907 063 R
Component: BCM PQ35 M 113 0811
Revision: AD113811
Coding: 0E000A2BE805F1C0201841C02104094C53FF84AA216F912BE408878400C5
Shop #: WSC 00049 770 00008
VCID: 4B9EA8E5EAE0EC6411-801E
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119
Component: WWS316 140515 H37 0085
Coding: 0047F7
Component: G397_RLFS H06 0002
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
00332 - Control Circuit for Tank Flap
Fault Status: 00100111
Fault Frequency: 65
Reset counter: 19
Mileage: 21487 km
Date: 2015.12.19
Time: 17:04:39
Term 15 Off
Voltage: 12.15 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels: 8X0-919-475.clb
Part No SW: 8X0 919 475 N HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0050
Revision: 11001001 Serial number: 61061416201043
Coding: A8C305
Shop #: WSC 01211 210 01254
ASAM Dataset: EV_EPHVA18AU21X0000 003006
ROD: EV_EPHVA18AU21X0000.rod
VCID: 51A2BA8D00CCC6B46B-8004
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
Component: AirbagVW-AU10 H09 0520
Serial number: 003LRR08GZ5D
Coding: 30393132313030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316.rod
VCID: 468899D1F982110CCE-8012
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME0648232FZZZ-
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME7F67232FZZZ2
Serial number: 3516KSME6361232FZZZR
Serial number: 3526KSME2977232FZZZ.
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME520D5C2DZZZB
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 521 D HW: 5K0 953 569 AE
Revision: FF010018 Serial number: 20140616101321
Coding: 1894204000
ROD: EV_SMLSNGVOLWS.rod
VCID: 3D7AF63DAC5452D49F-8068
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8U0 920 990 E HW: 8U0 920 990 E
Component: KOMBI_COLOUR H01 0240
Coding: 42CF01
VCID: 3F868C35A65840C48D-806A
Part No SW: 8U0 907 468 AE HW: 8U0 907 468 J
Component: GAT 4CAN 2L M H13 0072
Revision: 1R150039 Serial number: 3941R1452503D8
Coding: FBCF1A5A050B05610353
VCID: 050A5EDD8C04DA1487-8050
Subsystem 1 - Part No SW: 8U0 959 591 HW: 8V3 959 591
Component: J245 PS11.018 H02 0007
Coding: 901E00
Subsystem 2 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Subsystem 3 - Part No SW: 8U0 959 591 HW: 8V3 959 591
Component: J394 PS11.018 H02 0007
Coding: 801E00
Subsystem 4 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Part No SW: 0AY 907 554 F HW: 0AY 907 554 F
Component: Haldex4Motion H52 7521
Serial number: HA1-00023.05.14
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_VW36.rod
VCID: 4E98A1F111F2D94C76-801A
Component: IMMO H01 0240
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011E06200401000000
VCID: 52A0B5810DCABDAC52-8006
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501
Revision: 00H22000
VCID: 40848FC913A63F3CF4-8014
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
VCID: 51A2BA8D08CCC6B46B-8004
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000079643
Coding: 0025167
VCID: 3874E7294B7677FC4C-806C
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 140606-0002-070
Coding: 1157A41010002700
ROD: EV_HeadlRegulBasic.rod
VCID: 428085C1D5AA2D2CE2-8016
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109F50E7934298
Coding: 010105020100000002
VCID: 285437695BD6E77CDC-807C
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8U0 035 666 J HW: 8U0 035 666 D
Component: H-BN-EU H46 0814
Revision: -------- Serial number: 199F/0EB002147
Coding: 0E010106010AE1EB0180073E00000001E00100020000000000
VCID: 41828ACDD8AC3634FB-8014
Subsystem 1 - Part No: 8R0 060 884 BT
Component: EUR 2014 1903
Subsystem 2 - Part No SW: 8U0 919 604 A HW: 8U0 919 604 A
Component: DU High AU316 H42 0018
Subsystem 3 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H07 0415
Coding: 010E06200001000000
VCID: 4FA6BCF51EF8D0447D-801A
Part No SW: 8U0 907 441 HW: 8U0 907 441
Component: SG Rueckfahrkamera 0031
Revision: --H09--- Serial number: 525 PA8J49H1RC
Coding: 1020015
VCID: 76E8291101E2C18C9E-8022
Reset counter: 142
Component: TSG HR H07 0415
End-------------------------(Elapsed Time: 03:28)--------------------------
