Page 10 of 10 FirstFirst ... 8910
Results 91 to 100 of 100
Thread: 2016 A3 - Disable Parking Lights - US Spec?
  1. #91
    Jun 2017
    Right. It is not possible to do this via coding!
    BCM Pin A59 ----> plate lights
    ....................X----> side markers
    What a beatiful ASCII wiring diagram.
    What you could do is pinning the side markers at an empty BCM Pin. Then you can control it via coding. For this you have to find the connection...
  2. #92
    Feb 2016
    CT, USA
    Yay! Haha... Thanks for confirming. I will most likely open up the headlights this weekend and see if I can't unplug them manually as I think that would be an easier route to take. Will report back!
    What do you think you have to do in your situation to get them on? Maybe the plugs are just dangling and have to be connected
  3. #93
    May 2014
    Your statement would be true if there was a "NOT" at the end. (I put it in...)
    The priority of the "Light function" go from H to A where H > A.
    If Standlicht function in function A is removed, the lights would be still on if light function "beidseitiges Dauerparklicht" is switched on.
    Wow...what a mess.
    So somehwere is a hard-wiring from plate lights to side markers. I gues somewhere near the BCM.
    Haldez: hmm........... not sure that retaining the "beidseitiges Dauerparklicht" command in any way helps AidiSport solve the problem of the lamps being constantly illuminated. With the removal of this command from the Leuchte-set, at least Aidisport's problem is now reduced to the lamps only illuminating when low beams are switched-on. Beyond this, and as I have already suggested COMPLETE disablement of the lamps needs physical disconnections.
  4. Likes Dana liked this post
  5. #94
    Jun 2017
    Nothing more and nothing else I tried to say
  6. Likes DV52, Dana liked this post
  7. #95
    Feb 2016
    CT, USA
    Minor update - went to go open up the headlights last weekend and unplug them (if possible) and of course the bumper has to come off... I already have my B5 S4 apart so I can't have both of my Audi's in shambles... Hopefully I build up the anger one day to get the headlights out and see if I can unplug somehow. If I got as far as taking the bumper off, headlight out, and I couldn't turn those bulbs off I'd probably burn it to the ground!
    Oh - question .. So when I realized the bumper had to come off and I got down on my knees and cried to Audi - I was thinking - will that wiring diagram help me figure out which pin it is in the headlight plug? If so, can't I just unplug it from there rather than cutting my hands inside the housing?
  8. #96
    United States
    It should. I think we decided the bulbs in question are M33/34 (.. near this time frame http://forums.ross-tech.com/showthre...l=1#post111603 ) in which case T14b/8 could be pulled from the main headlight connector if you have tools to unlock the terminal.
  9. Likes Uwe liked this post
  10. #97
    Verified VCDS User Mattias Ekström's Avatar
    Jul 2018
    So is this all that is needed to disable the ambers?
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 to not active,
    and to clean-up the hanging auxiliary command - also change:
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 to 0
  11. #98
    Dec 2016
    DE
    According to what we know now: yes, this should do the job.
  12. Likes Dana liked this post
  13. #99
    Jul 2018
    And how do I dim the LED DRL's when my headlights are on? I want them to omit a light glow as to not take away from the Xenons.
  14. #100
    Sep 2015
    Quote Originally Posted by Mattias Ekström View Post
    https://forums.ross-tech.com/showthr...h-Xenons/page3
    Have you tried the latest suggestion there? If so, why not post results there and continue from that?
  15. Likes Dana liked this post
