Tuesday, 12 April 2016, 08:25:57:21421
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine Labels: 06C-909-559-ASN.LBL
Controller: 8E0 909 559 D
Component: 3.0L V6/5V G 0003
Coding: 0016711
Shop #: WSC 63351
VCID: 361FF676015F
8 Faults Found:
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 002 - Lower Limit Exceeded - Intermittent
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 004 - No Signal/Communication - Intermittent
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 002 - Lower Limit Exceeded - Intermittent
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 002 - Lower Limit Exceeded - Intermittent
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 001 - Upper Limit Exceeded - Intermittent
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 008 - Implausible Signal - Intermittent
P1570 - 008 - Implausible Signal
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04495
Shop #: WSC 06435
VCID: 263F2636D1FF
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Controller: 8E0 820 043 G
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
VCID: 253D213AACF9
30-00 - Open or Short to Plus
27-00 - Implausible Signal
49-00 - No Communications
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Controller: 8E0 959 655 A
Component: Airbag 8.4E 3000
Coding: 0010607
Shop #: WSC 63351
VCID: 351DF17A1C59
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Controller: 8E0 920 950 HX
Component: KOMBI+WEGFAHRS. RB8 D29
Coding: 03200
Shop #: WSC 00222
VCID: 867FC6B6B13F
WAULT68E52A121737 AUZ6Z0A0196118
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.LBL
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0202
Coding: 00002
Shop #: WSC 63351
VCID: F195856AA8B1
79-00 - Please Check Fault Codes
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Controller: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
VCID: EBA997028A9D
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 T
Component: Komfortgerát T5B 0617
Coding: 11788
Shop #: WSC 63351
VCID: 42F79AA65D97
17 Faults Found:
01134 - Alarm Horn (H12)
01616 - Signal Wire to Interior Monitor
01370 - Alarm triggered by Interior Monitoring
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
01030 - Central Locking Key Switch; Driver Side; Lock
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01734 - Potentiometer for Mirror Adj. Horizontal; Drivers Side
37-10 - Faulty - Intermittent
62-10 - No or Incorrect Adjustment - Intermittent
53-10 - Supply Voltage Too Low - Intermittent
01562 - Right Rear Door
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Controller: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00060
Shop #: WSC 63351
VCID: 047B5CBE0703
Address 56: Radio Labels: 8E0-035-1xx-56.LBL
Controller: 8E0 035 195 A
Component: symphony II NP2 0008
Coding: 00201
Shop #: WSC 00003
VCID: 253D213AACF9
End --------------------------------------------------------------------------------------------------
