My Mk6 GTI is running rough (but no check engine light) so I just ran my first scan with VCDS today: 2 Faults Found.
Recent maintenance summary - current mileage 65,275 miles:
I am thinking that #2 Injector may be at fault (again) here, and I will likely take it back to the Dealer next week for an assessment -- hopefully for a warranty replacement
Please reply if you think that something else may be happening here. Thanks!
- [02FEB2016 - 63,520 miles] Dealer replaced #2 Injector under warranty
- [30JAN2016 - 63,434 miles] Dealer replaced Intake Manifold under warranty
- [14SEP2015 - 60,019 miles] Self performed 60K service (Oil change & filter, Cabin Filter, Air Filter, Rotate Tires, Castrol Edge 5W-40 Synth)
- [10JUN2015 - 57,362 miles] Dealer replaced Vacuum Purge Valve
- [10DEC2014 - 50,825 miles] Dealer replaced Intake Manifold & Cleaned Intake Valves (under warranty) plus Oil Change & Filter
- [15NOV2014 - 49,891 miles] Dealer performed 50K service (Oil Change & Filter) plus replaced Fuel Filter
- [04JAN2014 - 39,225 miles] Dealer performed 40K service (Oil Change & Filter, Air Filter, Pollen Filter) plus Spark Plugs
Friday,08,April,2016,08:25:53:08422
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWEV7AJXBW170423 License Plate:
Mileage: 105050km-65275mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 77
VIN: WVWEV7AJXBW170423 Mileage: 105050km-65275miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AP HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0403010A18070160
VCID: 74C92438179BC99E6A-8020
P0300 - 000 - - Intermittent
Mileage: 104848 km
Date: 2016.04.03
Time: 10:40:21
RPM: 750 /min
Load: 17.6 %
Temperature: 96.0∞C
Temperature: 26.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Mileage: 104848 km
Date: 2016.04.03
Time: 10:40:36
RPM: 762 /min
Load: 18.0 %
Temperature: 96.0∞C
Temperature: 26.0∞C
Voltage: 14.097 V
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492900FA880F06E6921C0041B70800
VCID: 78D11008CBF3ADFE46-802C
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 3D5FC11CAC5148D655-8068
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AE
Coding: 6D180A1A80272A040088008570000D0440050086534D8D60648020200040
VCID: 3A55CA00B57F7FEE70-806E
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 25111 26 0512
Coding: 009795
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R01FS6A
Coding: 00003031
VCID: 3957D50CB87974F679-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005CBUH00
Serial number: 3572MSME67166459ZZZ.
Serial number: 3582MSME3D6C5059ZZZ4
Serial number: 3512QSME3A03775DZZZ$
Serial number: 3522QSME1A247661ZZZT
Serial number: 35527SME79545624ZZZI
Serial number: 35627SME01675624ZZZ8
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JKT00052
Coding: 108A140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72C52220A58FC7AE78-8026
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0068588
Coding: 820000
Part No SW: 5K6 920 971 C HW: 5K6 920 971 C
Component: KOMBI H20 0420
Coding: 270F01
VCID: 354FD93C946190969D-8060
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 301110F2002508
Coding: 350000
VCID: 3041E8286303B5BECE-8064
Component: IMMO H20 0420
VCID: 6AF53A408D5F0F6EC0-803E
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669029227
Coding: 020000
VCID: 287100485BD3FD7E16-807C
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 HW: 1K0 035 274
Component: RNS315-NAR H05 0011
Serial number: VWZAZ2K8422620
Coding: 040004210400000000001000
ASAM Dataset: EV_RNS315VWNARV1UDS A01005
ROD: EV_RNS315VWNARV1UDS.rod
VCID: 61E75D6C70694C3611-8034
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2149
Coding: 0001076
VCID: 334BE72452158EA6B3-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3147ED2CA809BCB6C1-8064
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Coding: 0001076
VCID: 3449E438571B899EAA-8060
Component: AFS-Steuergeraet 0148
Coding: 1446940
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668916257
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 3245E220650F87AEB8-8066
End-------------------------(Elapsed Time: 01:47)--------------------------
