Results 1 to 4 of 4
Thread: 2011 Mk6 GTI Cylinder Misfire Detected
    Apr 2016
    My Mk6 GTI is running rough (but no check engine light) so I just ran my first scan with VCDS today: 2 Faults Found.
    Recent maintenance summary - current mileage 65,275 miles:
    • [02FEB2016 - 63,520 miles] Dealer replaced #2 Injector under warranty
    • [30JAN2016 - 63,434 miles] Dealer replaced Intake Manifold under warranty
    • [14SEP2015 - 60,019 miles] Self performed 60K service (Oil change & filter, Cabin Filter, Air Filter, Rotate Tires, Castrol Edge 5W-40 Synth)
    • [10JUN2015 - 57,362 miles] Dealer replaced Vacuum Purge Valve
    • [10DEC2014 - 50,825 miles] Dealer replaced Intake Manifold & Cleaned Intake Valves (under warranty) plus Oil Change & Filter
    • [15NOV2014 - 49,891 miles] Dealer performed 50K service (Oil Change & Filter) plus replaced Fuel Filter
    • [04JAN2014 - 39,225 miles] Dealer performed 40K service (Oil Change & Filter, Air Filter, Pollen Filter) plus Spark Plugs
    I am thinking that #2 Injector may be at fault (again) here, and I will likely take it back to the Dealer next week for an assessment -- hopefully for a warranty replacement
    Please reply if you think that something else may be happening here. Thanks!
    Friday,08,April,2016,08:25:53:08422
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WVWEV7AJXBW170423   License Plate:
    Mileage: 105050km-65275mi   Repair Order:
    Chassis Type: AJ (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 77
    VIN: WVWEV7AJXBW170423   Mileage: 105050km-65275miles
    Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
       Part No SW: 1K0 907 115 AP    HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0030
       Revision: AAH18---    Serial number:
       Coding: 0403010A18070160
       VCID: 74C92438179BC99E6A-8020
                   P0300 - 000 -  - Intermittent
                        Mileage: 104848 km
                        Date: 2016.04.03
                        Time: 10:40:21
                        RPM: 750 /min
                        Load: 17.6 %
                        Temperature: 96.0∞C
                        Temperature: 26.0∞C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.097 V
    000770 - Cylinder 2
                   P0302 - 000 - Misfire Detected - Intermittent
                        Mileage: 104848 km
                        Date: 2016.04.03
                        Time: 10:40:36
                        RPM: 762 /min
                        Load: 18.0 %
                        Temperature: 96.0∞C
                        Temperature: 26.0∞C
                        Voltage: 14.097 V
       Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
       Component: ESP MK60EC1   H31 0106
       Revision: 00H31001
       Coding: 114B600C492900FA880F06E6921C0041B70800
       VCID: 78D11008CBF3ADFE46-802C
       Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000001002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 3D5FC11CAC5148D655-8068
       Part No SW: 1K0 937 087 L    HW: 1K0 937 087 L
       Component: BCM PQ35  H   104 0615
       Revision: 00104 AE
       Coding: 6D180A1A80272A040088008570000D0440050086534D8D60648020200040
       VCID: 3A55CA00B57F7FEE70-806E
       Component: Wischer 25111  26  0512
       Coding: 009795
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R01FS6A
       Coding: 00003031
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360_SE36.rod
       VCID: 3957D50CB87974F679-806C
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--0005CBUH00
       Serial number: 3572MSME67166459ZZZ.
       Serial number: 3582MSME3D6C5059ZZZ4
       Serial number: 3512QSME3A03775DZZZ$
       Serial number: 3522QSME1A247661ZZZT
       Serial number: 35527SME79545624ZZZI
       Serial number: 35627SME01675624ZZZ8
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JKT00052
       Coding: 108A140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 72C52220A58FC7AE78-8026
       Component: E221__MFL-TAS  H07 0013
       Serial number: 0068588
       Coding: 820000
       Part No SW: 5K6 920 971 C    HW: 5K6 920 971 C
       Component: KOMBI         H20 0420
       Coding: 270F01
       VCID: 354FD93C946190969D-8060
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 301110F2002508
       Coding: 350000
       VCID: 3041E8286303B5BECE-8064
       Component: IMMO          H20 0420
       VCID: 6AF53A408D5F0F6EC0-803E
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669029227
       Coding: 020000
       VCID: 287100485BD3FD7E16-807C
       Part No SW: 1K0 035 274     HW: 1K0 035 274
       Component: RNS315-NAR    H05 0011
       Serial number: VWZAZ2K8422620
       Coding: 040004210400000000001000
       ASAM Dataset: EV_RNS315VWNARV1UDS A01005
       ROD: EV_RNS315VWNARV1UDS.rod
       VCID: 61E75D6C70694C3611-8034
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2149
       Coding: 0001076
       VCID: 334BE72452158EA6B3-8066
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 74     3001
       Revision: 00H17000
       VCID: 3147ED2CA809BCB6C1-8064
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Coding: 0001076
       VCID: 3449E438571B899EAA-8060
       Coding: 1446940
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Coding: 00000022
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668916257
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 3245E220650F87AEB8-8066
    End-------------------------(Elapsed Time: 01:47)--------------------------
    What is the condition for wear/burn rate on spark plugs + compression of the respective cylinder being washed......... from prior dump fuel damage?
    Coils?
    Grounds?
    MAF condition?
    Oil quality?
    Apr 2016
    Coils?
    Grounds?
    MAF condition?
    Oil quality?
    Thanks for the quick reply, but I am not sure I am following you (regret that I am not an automotive technician)...
    I will probably be taking my GTI back to the local dealer for an assessment next week. Vehicle has been well-maintained so I would be surprised if there were any compression issues. My VCDS data at least gives me some confidence that there IS an engine issue -- whereas in the past I would simply have to trust the dealer service technicians if they told me they saw (or did not see) any codes. I am hoping that this is simply a bad injector (again). I probably cannot go any deeper with the troubleshooting right now, so I will post findings after my dealer visit next week.
    Thanks again!
    It would be foolish to assume and not do a compression test.
    This is the absolute first basic step.......... and if avoiding the basics you might as well throw the towel in.
    I would request the test be done.......... and in comparison to the other cylinders, further I would want to know the data they observe.
  5. Likes Uwe, dubTECH liked this post
