Results 1 to 10 of 12
Thread: VCDS reports "Unable to find a ROD file". Whazzat mean?
    Toronto, Canada
    Hello All:
    I encountered the message shown below when using VCDS (current stable release, version 12.something) today. I have never seen such a message before. Can someone tell me what it means?
    Also, what the heck is a '.ROD' file? Is ROD an acronym for something?
    Michael
    Uncommon Application Message
  2. Likes jyoung8607 liked this post
  3. #2
    Toronto, Canada
    I have attached the Autoscan file below. The car is a model year 2014 Italian version of a Volkswagen. Subsequent to this scan, I cleared all the faults and no faults persisted. I am still trying to find the muffler controller so I can turn the noise level down.
    Thursday,22,May,2014,16:54:56:25683
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: ZHWCC1ZD1ELA02890   License Plate: LAMBORGHINI
    Mileage: 500km-310mi   Repair Order: AVENTADOR
    Chassis Type: ZD (8R0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 42 46 52 53 56 5F 65
              6B 6C
    VIN: ZHWCC1ZD1ELA02890   Mileage: 500km/310miles
    17-Instruments -- Status: Sporadic communication error 1000
    6B-Aerodynamics -- Status: OK 0000
    Address 01: Engine (----)       Labels: None
       Part No SW: 470 909 049 AL    HW: 470 907 552 A
       Component: LIE 2010      H01 1482
       Revision: --------    Serial number: 3371
       Coding: 00000000
       VCID: 67D7DE64960987263AD-8032
    000352 - Oxygen (Lambda) Sensor B2 S2
                   P0160 - 000 - No Activity - Intermittent - MIL ON
                        Fault Status: 10110000
                        Reset counter: 201
                        Mileage: 288 km
                        Date: 2014.05.13
                        Time: 17:21:56
    012835 - Oxygen (Lambda) Sensor B3 S2
                   P3223 - 000 - No Activity - Intermittent - MIL ON
                        Reset counter: 201
                        Mileage: 288 km
                        Date: 2014.05.13
                        Time: 17:21:56
    000320 - Oxygen (Lambda) Sensor B1 S2
                   P0140 - 000 - No Activity - Intermittent - MIL ON
                        Reset counter: 201
                        Mileage: 288 km
                        Date: 2014.05.13
                        Time: 17:21:56
    Address 02: Auto Trans        Labels: None
       Part No SW: 470 927 256 B    HW: 470 927 156 A
       Component: SL750 Lambo E-Gear  0935
       Revision: 00H01000    Serial number: 100048
       VCID: 1C3DB188DFCF94FE67F-8049
       Part No SW: 470 614 517 A    HW: 470 614 517 A
       Component: ESP8 quattro  H04 0160
       Coding: 020504
       Shop #: WSC 02311 785 00200
       VCID: 142DD9A8F71FDCBE2FF-8041
       Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
       Component: BCM2 2.0      H14 0650
       Coding: 0B201000000000000000
       VCID: 840D69E8077FCC3E3FF-80D1
       Subsystem 1 - Part No SW: 470 959 754 A    HW: 470 959 754 A
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Part No SW: 470 820 043 G    HW: 470 820 043 G
       Component: KLIMA 1 ZONE  H09 0110
       Revision: A1010000    Serial number: 01290120140032
       Coding: 4C322000
       VCID: 132FDAB4F211DB86365-8046
       Part No SW: 8K0 907 063 BE    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0400
       Revision: 10030001    Serial number: 00000001688607
       Coding: 0428105800208F210700080300797900855C47C806030121000000
       VCID: 73EFBA34D2D17B86965-8026
       Subsystem 1 - Part No SW: 471 955 119     HW: 955 119
       Component: WWS83x ??????  H35 0010
       Coding: 000071
       Component: RLS  H04 0003
       Coding: 024237
       Subsystem 3 - Part No SW: 470 941 531 B    HW: 470 941 531 B
       Component: LCU  H02 0011
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    03674 - Indicator Lamp for Start-Stop Operation
                        Reset counter: 0
                        Mileage: 103 km
                        Date: 2014.05.01
                        Time: 14:50:00
    Address 10: Park/Steer Assist (J446)       Labels: None
       Part No SW: 470 919 475     HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0012
       Revision: 11001001    Serial number: 12561405600278
       Coding: 300101
       VCID: DEB97B80C95346EE49B-808B
    Address 14: Susp. Elect. (J197)       Labels: None
       Part No SW: 470 907 376 B    HW: 470 907 376
       Component: Niveau-LB     H01 0009
       Serial number: WP5CFUBCN
       VCID: 1D3BBC8C04D59DF6901-8048
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Fault Frequency: 17
                        Reset counter: 40
                        Mileage: 84 km
                        Date: 2014.05.01
                        Time: 14:33:15
                        Battery Volts: 15.5 V
                        RPM: 2040 /min
                        Speed: 30.6 km/h
                        Temperature: 13.5°C
                        (no units): 227.0
                        Reset counter: 40
                        Mileage: 358 km
                        Date: 2014.05.21
                        Time: 12:06:50
                        Battery Volts: 14.5 V
                        RPM: 2346 /min
                        Speed: 35.7 km/h
                        Temperature: 18.5°C
                        (no units): 298.0
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 470 959 655 A    HW: 470 959 655 A
       Component: AirbagVW-AU10 H13 0100
       Serial number: 003M0D091ME+
       Coding: 303133313130303030304A55304C56303353
       ASAM Dataset: EV_AirbaAU10SMELB83X 001001
       ROD: N/A
       VCID: 234F8A742AB1AB06A65-8076
       Subsystem 1 - Part No SW: 470 959 339 B    HW: 470 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R140000JF41
       Subsystem 2 - Serial number: 6334MSME416E022BD
       Subsystem 3 - Serial number: 6344MSME416E0336B
       Subsystem 4 - Serial number: 6352QSME1C422D64L
       Subsystem 5 - Serial number: 6362QSME0A41346EK
       Subsystem 6 - Serial number: 63732SME673E567CG
       Subsystem 7 - Serial number: 63832SME583D226EA
    No ASAM data for: "EV_AirbaAU10SMELB83X" (AU48)
    9446407 - ROD - Unknown Error Code
              - 00 [137]
                        Fault Frequency: 15
                        Reset counter: 0
                        Mileage: 83 km
                        Date: 2014.05.01
                        Time: 14:25:12
       Part No SW: 470 953 513 A    HW: 8K0 953 568 L
       Revision: --------    Serial number: 90815NC3000FD
       Coding: 000012
       VCID: 1629A3A0E1E3CEAE51B-8043
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 470 920 900 E    HW: 470 920 900 E
       Component: KOMBIINSTR.   H07 0060
       Revision: AA001001    Serial number:       10400023
       Coding: 0108329381B60080020000
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y1421407A2
       Coding: 00E503FF00
       VCID: 4A9107D0E5DB5A4E053-801F
       Component: J367-BDM  H07 0141
                        Reset counter: 40
                        Mileage: 83 km
                        Date: 2014.05.01
                        Time: 11:32:24
                        Bin. Bits:    00000
                        Voltage: 12.10 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.40 s
       Part No SW: 01S 907 554 A    HW: 01S 907 554 A
       Component: HLSC 737 Lambo 4WD  0104
       Revision:   H45       Serial number:
       VCID: 336F7A3452513B86565-8066
       Part No SW: 470 959 793 A    HW: 4F0 959 793 AB
       Component: TSG FA        H11 0702
       Revision:             Serial number: 0000093995502
       Coding: 01064B025000420102
       VCID: 2649936051835E2EC1B-8073
                        Reset counter: 40
                        Mileage: 117 km
                        Date: 2014.05.01
                        Time: 20:52:16
       Revision: 00002001    Serial number: 0328075571
       Coding: 011E029A18324081209000B600000000
       Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8K0 959 719
       Component: GTO BF  H01 0080
       Subsystem 2 - Part No: 8J0 951 177
       Component: DWA-Sensor  H03 0030
    00526 - Brake Light Switch-F
                        Reset counter: 40
                        Mileage: 83 km
                        Date: 2014.05.01
                        Time: 11:21:25
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 0
                        Mileage: 448 km
                        Date: 2014.05.21
                        Time: 19:32:25
       Part No SW: 470 959 792 A    HW: 4F0 959 792 AB
       Component: TSG BF        H11 0702
       Revision:             Serial number: 0000050448129
       Coding: 01064B825000420102
       VCID: 254B946C2C855536C81-8070
                        Reset counter: 40
                        Mileage: 117 km
                        Date: 2014.05.01
                        Time: 20:52:16
    Address 53: Parking Brake (J540)       Labels: None
       Part No SW: 470 907 801     HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0003
       Revision: 00000003    Serial number: 30000000010862
       VCID: D4AD99A8B79F9CBEEFF-8081
       Part No SW: 4G0 035 080 E    HW: 4G0 035 080
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 158C40E7506688
       Coding: 020007020100000001
       VCID: 2045857833A7B01EBB7-8075
       Part No SW: 470 035 664 A    HW: 470 035 664
       Component: H-BN-NA       H51 0179
       Revision: --------    Serial number: 023CT0E7505275
       Coding: 010200020206816F01000306000000010000
       Subsystem 1 - Part No: 470 919 859 B
       Component: NAR 2010  0407
       Component: DU7 High  H42 0104
       Subsystem 3 - Part No SW: 470 919 609 B    HW: 470 919 609 B
       Component: E0380 Bedient  H01 0100
       Component:   CD-Database  2712
    Address 65: Tire Pressure        Labels: None
       Part No SW: 470 907 273     HW: 470 907 273
       Component: TPMS                0329
       Revision: 00H03000    Serial number: 00000000021270
       Coding: 0002891
       VCID: D7B76EA46669B7A60AD-8082
    Address 6B: Aerodynamics (J920)       Labels: None
       Part No SW: 470 959 433 D    HW: 470 959 433 D
       Component: GFA 2012      H01 0004
       Serial number: 16100306400110
       Coding: 01006111
    Address 6C: Back-up Cam.        Labels: None
       Part No SW: 470 907 441     HW: 8F0 907 441
       Component: J772__Rearview      0020
       Revision: --H09---    Serial number: 525PA8-J42B08S
       Coding: 4020012
       VCID: D4AD99A8779F9CBEEFF-8081
  4. Likes jyoung8607 liked this post
  5. #3
    Tartu, Estonia
    I guess, the problem is that this car is so new, vcds doesn't have a file made for it.
    Just wait and see, if geniuses of Ross-Tech can make a file for you.
    But seriously 14 Aventador? How cool is that!
    The world is my oyster...
  6. #4
    Toronto, Canada
    I dunno - I don't think it's all that impressive - the thing has more angles than a geometry teacher, and it makes an awful racket when it is running. It converts fuel to noise with efficiency that rivals Harley-Davidson.
    I need to find the muffler controller and turn the sound down.
    Michael
  7. Likes jyoung8607 liked this post
  8. #5
    Quote Originally Posted by PanEuropean View Post
    Well, the new-fangled UDS/ODX/ASAM protocol that VWAG started using in the B8 chassis Audis in 2007 or so, and that has now become pervasive is heavily data-driven. It's not possible to do very much with such a module without a data file that describes it. ROD files are our (proprietary, much more efficient) containers for such data. The error message you posted means that the version of VCDS you're using has no data for that module.
    Although HDs do that very well, they do it without making absurd amounts of horsepower as a byproduct.
  10. Likes vreihen liked this post
  11. #7
    Toronto, Canada
    Thanks for explaining that Uwe.
    Is a ROD file sort of like a replacement for a label file?
    FYI I managed to get about 75% of the controllers on this car scanned at the 'debug level 2' setting this afternoon before I ran out of time to finish. I've already sent the PLB and PLA files in to the 'support' email. Are PLA and PLB files what you need to create ROD files, or do you need additional data? If you need additional data, is that something that I can suck out of the car with my VCDS application? If so, let me know and I will do that for you.
    Also, I think it would be helpful to add this vehicle family to the "List of Supported Vehicle Families" within the PDF at this URL: VCDS Compatibility Charts.
    Michael
  12. #8
    No, it's not exactly a replacement. There are some similarities, but there's lower level stuff in there too. And the fact that a ROD file is needed for a particular module doesn't preclude there also being a label file for the same module.
    Thank you!
    No. However, PLA and PLB files continue to be useful for making Label files.
    I can't think of anything else right now, but if Sebastian or anyone else can, they should chime in here.
    Thanks again!
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Well, I think Michael officially won the first world problems meme. Turn out the lights on that one, we can all go home.
    I need to be one of Michael's neighbors. What do the immigration laws look like for Americans moving to Canada?
    Jason
  14. Likes Uwe liked this post
  15. #10
    Toronto, Canada
    It actually did have a CEL...
    Michael
  16. Likes jyoung8607 liked this post
